    4. Meldungen beim/nach Upgrade
      Homoran Global Moderator Administrators @Homoran last edited by
      ich bekomme die Daten als User nicht auf den Pi5
      pi@ioBrokerpi5:~ $ groups
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      pi@ioBrokerpi5:~ $ ls -la /media/usbplatte/backups
      total 77732
      drwxr-xr-x 2 iobroker iobroker    4096 Apr 11 04:22 .
      drwxr-xr-x 4 root     root        4096 Dec 25 13:08 ..
      -rw-r--r-- 1 iobroker iobroker 4680106 Mar 16 01:36 homematic_2024_03_16-01_36_12_3.71.12_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Mar 19 01:36 homematic_2024_03_19-01_36_12_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Mar 22 01:36 homematic_2024_03_22-01_36_12_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Mar 25 01:36 homematic_2024_03_25-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Mar 28 01:36 homematic_2024_03_28-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Mar 31 01:36 homematic_2024_03_31-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Apr  1 01:36 homematic_2024_04_01-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Apr  4 01:36 homematic_2024_04_04-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Apr  7 01:36 homematic_2024_04_07-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 4813226 Apr 10 01:36 homematic_2024_04_10-01_36_11_3.73.9_backupiobroker.tar.sbk
      -rw-r--r-- 1 iobroker iobroker 3148949 Apr  2 04:22 iobroker_2024_04_02-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3154652 Apr  3 04:22 iobroker_2024_04_03-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3154705 Apr  4 04:22 iobroker_2024_04_04-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3155077 Apr  5 04:22 iobroker_2024_04_05-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3153078 Apr  6 04:22 iobroker_2024_04_06-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3152355 Apr  7 04:22 iobroker_2024_04_07-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3153662 Apr  8 04:22 iobroker_2024_04_08-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3153630 Apr  9 04:22 iobroker_2024_04_09-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3157581 Apr 10 04:22 iobroker_2024_04_10-04_22_10_backupiobroker.tar.gz
      -rw-r--r-- 1 iobroker iobroker 3157378 Apr 11 04:22 iobroker_2024_04_11-04_22_10_backupiobroker.tar.gz
      pi@ioBrokerpi5:~ $
      Thomas Braun S 2 Replies Last reply Reply Quote 0
        Verwendest du nicht den Backitup-Adapter?
        Der macht da eigentlich alles richtig.
          @thomas-braun sagte in Meldungen beim/nach Upgrade:
          doch, das funktioniert ja auch.
          jetzt will ich aber das Backup vom Nuc auf den pi5 bringen.
          wenn ich das dort via backitup hochlade landet es local und nicht in der gemounteten SSD
            Thomas Braun Most Active @Homoran last edited by Thomas Braun
            @homoran sagte in Meldungen beim/nach Upgrade:
            Verstehe ich nicht.
            zeigt doch ein gemountetes, externes Medium.
              richtig!
              aber wenn ich im backitup Reiter trotz aktivierter copy/nas option ein Backup hochlade landet es nur in /opt/iobroker/backups. nicht im mount
              und wenn ich via filezilla auf /media/usbplatte/backups als user pi schieben will, bekomme ich einen permission error obwohl pi in der Gruppe iobroker ist.
              die Rechte liegen nur auf 755, was wohl nicht das Screiben durch Gruppenmitglueder zulässt.
                Der User iobroker darf lesen und schreiben, die Gruppe ioboroker und der Rest darf nur lesen. Damit darf der user pi da nix schreiben.
                Mit welchen Optionen mountest du denn?
                  ??Bahnhof??
                  das Laufwerk ist einfach mit sudo mount sda1 /media/usbplatte gemountet, ohne weitere Parameter.
                  davon hör ich gerade zum ersten mal 😳
                    Man kann/muss da noch Optionen mitgeben. Meine FritzNAS mounte ich (ist aber eine CIFS-Freigabe) z. B. so:
                    //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,cache=loose,noauto,rw,uid=iobroker,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                    Wichtig ist hier
                    uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777
                    Dateien werden also mit vollen Rechten (Lesen/Schreiben/Ausführen) für den user iobroker wie für die Gruppe iobroker gemountet. (Gut, das Ausführen-Bit könnte man auch weglassen, zumindest für Dateien)
                    Die Optionen unterscheiden sich je nach Dateisystem, das gemountet wird, die Rechte sind aber alle ähnlich zu vergeben.
                      Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                      Dann werde ich mir später mal diese Lektion anlernen.
                      im Moment schiebe ich die aktuellen Backups dann eben in lokal
                      die mountplatte kommt dann irgendwann
                      der Befehl wäre dann sudo mount /dev/sda1 /media/usbplatte,uid=iobroker gid=iobroker,file_mode=0775,dir_mode=0775?
                      in der fstab ist er eh noch nicht drin
                        Ich würde hier mal reinschauen:
                        https://wiki.ubuntuusers.de/mount/
                          @thomas-braun Danke!
                          dann wären das hier dchon ein paar Optionen
                          /dev/sda1 on /media/usbplatte type ext4 (rw,relatime) zuzüglich uid, gid und den modes
                          412
