    4. NodeRed fkt. nicht nach Node.js Update auf 18.20.2
    • Marc Berg
      Marc Berg Most Active @Thomas Braun last edited by
      @thomas-braun sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
      iob update node-red@5.2.0
      Computer sagt: Nö!
      iobroker@iobroker:~$ iob upgrade node-red@5.2.0
      Would you like to reinstall version 5.2.0 of node-red now? [(y)es, (n)o]: y
      Update node-red from @5.2.0 to @5.2.0
      host.iobroker Adapter "system.adapter.node-red.0" is stopped.
      NPM version: 10.5.2
      Installing iobroker.node-red@5.2.0... (System call)
      up to date in 3s
      109 packages are looking for funding
        run `npm fund` for details
      upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
      upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
      host.iobroker Adapter "system.adapter.node-red.0" is started
      iobroker@iobroker:~$ npm ls node-red
      iobroker.inst@3.0.0 /opt/iobroker
      └─┬ iobroker.node-red@5.2.0
        └── node-red@3.1.5
        Thomas Braun Most Active @Marc Berg last edited by Thomas Braun
        @marc-berg sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
        Du stehst aber auch nicht im Installationsverzeichnis vom ioBroker sondern in dessen home.
        cd /opt/iobroker
        npm ls node-red
        Es sei denn, du hast das bei der Installation auf ~ umgebogen.
        • Marc Berg
          Zumindest im Container ist das home Verzeichnis des Users "iobroker" = /opt/iobroker. Nichts umgebogen.
            Ist mir neu. Wird im iob diag nämlich auch nicht berücksichtigt und das funktioniert da mit cwd /opt/iobroker
            • Marc Berg
              Ist mir neu.
              Steht aber so im Dockerfile
                  # Setting up iobroker-user
                  && chsh -s /bin/bash iobroker \
                  && usermod --home /opt/iobroker iobroker \
                  && usermod -u 1000 iobroker \
                  && groupmod -g 1000 iobroker \
                  && chown root:iobroker /usr/sbin/gosu \
                @marc-berg
                Ach, docker? Die Dinger interessieren mich nicht.
                Bei LXCs hast du aber definitv /opt/iobroker als Installationsverzeichnis als Default.
                • Marc Berg
                  Welche Relevanz hat das jetzt gerade für das aktuelle Problem? Unter einer VM habe ich das gleiche Verhalten, dass ich Node-Red nicht auf die 3.19 gehoben bekomme. Es sei denn, ich deinstalliere komplett.
                  Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
                    Homoran Global Moderator Administrators @Marc Berg last edited by
                    nur dass Thomas sichergestellt haben möchte, dass der Versuch korrekt gelaufen ist, und das frustrane Ergebnis nicht aufgrund falscher Durchführung existiert
                      Nur insofern, dass ich in Unkenntnis der Docker-Situation davon ausgehen muss, dass ~ nach /home/USER führt und nicht nach /opt/iobroker.
                      • mcm1957
                        mcm1957 @Thomas Braun last edited by
                        Ich habe das Thema REINSTALLATION vor Kurzem getestet. Und nein, node / iobroker reinstalliert definitiv zumindest den Adapter nicht nochmals , wenn schon was in der selben Version installiert ist.
                        Siehe: https://github.com/ioBroker/ioBroker.js-controller/issues/2667
                        Ob dependencies aktualisiert werden hab ich da nicht getestet.
                        mcm1957 created this issue in ioBroker/ioBroker.js-controller
                        closed [enhancement]: improve reinstall of existing adapter release #2667
                        Thomas Braun 1 Reply Last reply Reply Quote 2
                          Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                          @mcm57 sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
                          Werden sie. Zumindest auf meinem System...
                          echad@chet:/opt/iobroker $ npm ls node-red
                          `-- iobroker.node-red@5.2.0
                            `-- node-red@3.1.2
                          echad@chet:/opt/iobroker $ iob upgrade node-red@5.2.0
                          host.chet Adapter "system.adapter.node-red.0" is stopped.
                          NPM version: 10.5.0
                          removed 722 packages, and changed 13 packages in 13s
                          143 packages are looking for funding
                          host.chet Adapter "system.adapter.node-red.0" is started
                            `-- node-red@3.1.9
                          • mcm1957
                            OK danke,
                            Dann optimiert node nur die Installation identer Versionen weg.
                            Hintergrund (bei mir):
                            Nach ein wenig direkter Pfusch in den Scripts wg. Debugging wollte ich alle Datein wieder auf den offiziellen Stand bringen - daher reinstallationd erselben Versione - neda, das geht so nicht 😞
                            • haus-automatisierung
                              haus-automatisierung Developer Most Active @mcm1957 last edited by
                              @mcm57 Ne, dann wird ja auch nix gemacht, weil npm denkt es ist immer alles so wie installiert. Es wird ja nicht jede Datei geprüft (ob die zur noch Version passt).
                              • mcm1957
                                mcm1957 @haus-automatisierung last edited by mcm1957
                                @haus-automatisierung said in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
                                Ja - das weiß ich jetzt auch. Nur versteh zumindest ich unter REINSTALLATION was anderes. Reinstallation bedeutet für mich, dass der Stand wie nach einer Installation hergestellt wird - zumindest was Code & Libraries betrifft - nicht den Datenbestand. Daher auch das Issue. Minimal ist der Text irreführend. Aber es spricht m.E. auch nichts dagegen npm deinstall und install zu machen und damit wirklich alles zu erneuern. Derzeit geht das nur über downgrade / upgrade oder manuell mit npm. Beides eindeutig zweite Wahl Lösungen.
                                  apollon77 last edited by
                                  Was npm (nicht iobroker!!) bei einem reinstall tut weiss man nie so genau. Das Paket was man reinstalliert - wenn gleiche version - das fasst er denke nicht an. Was npm mit Sub Deps machen ... keine Ahnung und gefühlt Sonnenfleckenabhängig. Also am besten reinstall ...
                                  • mcm1957
                                    mcm1957 @apollon77 last edited by
                                    @apollon77
                                    iobroker reinstall macht derzeit noch ein npm i reinstall ...
                                    Aber ich habe schon ein commit gesehen dass da in Zukunft ein echtes uninstall / reinstall erfolgen sollte.
                                    • mcm1957
                                      mcm1957 @mcm1957 last edited by
                                      Und noch was - keine Ahnung ob das auch ioBroker / node-red betrifft:
                                      https://github.com/node-red/node-red/pull/4652
                                      Ein Windows security Fix hat node-red auf windows getroffen. Wurde bereits gefixed.
                                      knolleary created this issue in node-red/node-red
                                      closed Fix use of spawn on windows with cmd files #4652
                                      • U
                                        undeat @mcm1957 last edited by
                                        @mcm57 Ich habe das gleiche Problem. Der Telegram Adapter und der vom Saugroboter haben mich auf node 18.20 gezwungen aber jetzt geht node red nicht mehr. Der Fix für Node Red sollte ja da sein, aber wie bekomme ich den in das Node Red vom Iobroker? Ein Update für den Adapter gibt es noch nicht, auch nicht als Beta.
                                        • mcm1957
                                          mcm1957 @undeat last edited by
                                          @undeat
                                          Das MS induzierte Problem hat eigentlich nichts mit nodeJs x zu tun.
                                          Bitte gib mal an
                                          -) welche Versionen von Adapter, js-conttrolelr und node nun bei dir aktiv sind
                                          -) welche Fehlermeldung du nun hast (Kopie vom Log)
                                          • U
                                            @mcm57
                                            Win11
                                            Node.js 18.20.2
                                            node-red Adapter 5.2.0
                                            NPM 10.5.0
                                            Node-RED: 20 Apr 18:32:29 - [error] Error: spawn EINVAL at ChildProcess.spawn (node:internal/child_process:414:11) at spawn (node:child_process:761:9) at Object.execFile (node:child_process:351:17) at G:\SmartHome\node_modules@node-red\registry\lib\installer.js:581:27 at new Promise (<anonymous>) at Object.checkPrereq (G:\SmartHome\node_modules@node-red\registry\lib\installer.js:580:16) at Object.load (G:\SmartHome\node_modules@node-red\registry\lib\index.js:59:22) at G:\SmartHome\node_modules@node-red\runtime\lib\index.js:162:29
                                            Ich habe es selbst hin bekommen.
                                            Ich habe die node-red 3.1.9.zip herunter geladen und die beiden Ordner, die da drin sind ("node-red" und "@node-red") in den Ordner "G:\SmartHome\node_modules" kopiert. Nun läuft es wieder
                                            49
                                            3544
