    4. IoBroker zerschossen, nach Update
    • HomeWolf
      HomeWolf last edited by
      ich habe heute manuell nach der Anleitung IoBroker ein update durchgeführt. IoBroker läuft unter Windows.
      Leider startet jetzt nichts mehr. Hier ist das Log
      0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
      1 info using npm@9.6.7
      2 info using node@v18.17.1
      3 timing npm:load:whichnode Completed in 3ms
      4 timing config:load:defaults Completed in 2ms
      5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 5ms
      6 timing config:load:builtin Completed in 6ms
      7 timing config:load:cli Completed in 2ms
      8 timing config:load:env Completed in 0ms
      9 timing config:load:file:C:\ioBroker\.npmrc Completed in 6ms
      10 timing config:load:project Completed in 8ms
      11 timing config:load:file:C:\Users\Administrator\.npmrc Completed in 0ms
      12 timing config:load:user Completed in 0ms
      13 timing config:load:file:C:\Users\Administrator\AppData\Roaming\npm\etc\npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 1ms
      16 timing config:load Completed in 20ms
      17 timing npm:load:configload Completed in 20ms
      18 timing npm:load:mkdirpcache Completed in 0ms
      19 timing npm:load:mkdirplogs Completed in 0ms
      20 verbose title npm exec @iobroker/fix
      21 verbose argv "exec" "--" "@iobroker/fix"
      22 timing npm:load:setTitle Completed in 1ms
      23 timing config:load:flatten Completed in 3ms
      24 timing npm:load:display Completed in 4ms
      25 verbose logfile logs-max:10 dir:C:\Users\Administrator\AppData\Local\npm-cache\_logs\2024-04-14T09_13_50_586Z-
      26 verbose logfile C:\Users\Administrator\AppData\Local\npm-cache\_logs\2024-04-14T09_13_50_586Z-debug-0.log
      27 timing npm:load:logFile Completed in 13ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 43ms
      31 silly logfile start cleaning logs, removing 4 files
      32 timing arborist:ctor Completed in 1ms
      33 silly logfile done cleaning log files
      34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      35 http fetch GET 200 https://registry.npmjs.org/@iobroker%2ffix 1713ms (cache miss)
      36 timing arborist:ctor Completed in 0ms
      37 timing arborist:ctor Completed in 1ms
      Das ist das Ergebnis, wenn ich iobroker Status abfrage.
      C:\ioBroker>iobroker status
      C:\ioBroker\node_modules\iobroker.js-controller\lib\objects.js:12
          throw 'Unknown objects type: ' + config.objects.type;
      Unknown objects type: jsonl
      (Use `node --trace-uncaught ...` to show where the exception was thrown)
      Node.js v18.17.1
      Kann mir jemand helfen?
        sigi234 Forum Testing Most Active @HomeWolf last edited by sigi234
        @homewolf sagte in IoBroker zerschossen, nach Update:
        Warum nicht mit dem Installer?
        https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
        HomeWolf 1 Reply Last reply Reply Quote 0
        • HomeWolf
          HomeWolf @sigi234 last edited by
          @sigi234 said in IoBroker zerschossen, nach Update:
          Gute Frage, da es in der Weboberfläche so angezeigt wurde.
          Meinst du es macht sin, jetzt die Installer noch mal drüber laufen zulassen oder verschlimmert das nur die Situation ?
            Nein, iob stoppen , iobroker-data Ordner kopieren und extern sichern
            iob neu installieren aber den Host anders benennen und bei der Installation mit dem Installer den gesicherten iobroker-data Ordner auswählen.
            https://github.com/ioBroker/ioBroker.build/blob/master/Windows-Installer.md
            • HomeWolf
              HomeWolf @sigi234 last edited by HomeWolf
              @sigi234 danke schon mal, habe ich nun gemacht und der neue IoBroker läuft wieder... ich schaue jetzt mal ob alles läuft und alles beim alten ist. Danke schon mal vorab
              • HomeWolf
                HomeWolf @HomeWolf last edited by
                @homewolf said in IoBroker zerschossen, nach Update:
                Also bis jetzt läuft alles. Ich weiß nicht ob ich das falsch verstanden hatte, aber ich habe die neue Installation im Ordner iobroker_neu gemacht. Wenn alles geht, kann ich dann einfach den alten Ordner löschen und den Ordner iobroker_neu umbennen in iobroker?
                  Nein
                  • HomeWolf
                    @sigi234 ok...
                    beides nein oder kann man den alten Ordner wenigstens löschen ?
                      @sigi234 ok...
                      Mit dem Installer deinstallieren
                      • HomeWolf
                        @sigi234 ich bekomme da nirgends die Möglichkeit, zu deinstallierte ?
                        Zu deinem Bild, das habe ich so ausgewählt, nur das ich vorab halt einen andern Ordner gewählt hatte.
                        359
