    4. vedirect keine Verbindung bei rasp 4
      mere13 @Thomas Braun last edited by
      @thomas-braun sorry.
      iobdiag.txt
        Homoran Global Moderator Administrators @mere13 last edited by
        @mere13 sagte in vedirect keine Verbindung bei rasp 4:
        iobdiag.txt
        bitte in code-tags gesetzt posten
          mere13 @Homoran last edited by
          @homoran verstehe ich leider nicht. wie bekomme ich die code-tags? Hab alles per copy-paste übertragen. So?
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: rasp
                 Icon name: computer
                    Kernel: Linux 6.6.20+rpt-rpi-v8
              Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           11:15:46 up 1 day,  1:06,  3 users,  load average: 0.14, 0.26, 0.34
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-04-14 11:15:47 CEST
                     Universal time: Sun 2024-04-14 09:15:47 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          marcel
          /home/marcel
          marcel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:            8.2G        1.2G        5.7G        1.4M        1.4G        6.9G
          Swap:           104M          0B        104M
          Total:          8.3G        1.2G        5.8G
                   7810 M total memory
                   1184 M used memory
                   1421 M active memory
                    775 M inactive memory
                   5445 M free memory
                    122 M buffer memory
                   1181 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
          * lightdm.service loaded failed failed Light Display Manager
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     782M  1.3M  780M   1% /run
          /dev/mmcblk0p2 ext4       58G  6.4G   48G  12% /
          tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
          /dev/mmcblk0p1 vfat      510M   82M  429M  17% /boot/firmware
          tmpfs          tmpfs     782M   28K  781M   1% /run/user/1000
          [Sat Apr 13 10:09:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B1:D2:3A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8a167c7b-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
          [Sat Apr 13 10:09:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
          [Sat Apr 13 10:09:09 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          870M	/var/
          341M	/var/cache
          334M	/var/cache/apt
          322M	/var/lib
          221M	/var/cache/apt/archives
          Archived and active journals take up 104.0M in the file system.
          /opt/iobroker/backups:
          2.9M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          62M	/opt/iobroker/iobroker-data/
          31M	/opt/iobroker/iobroker-data/backup-objects
          19M	/opt/iobroker/iobroker-data/files
          13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          8.8M	/opt/iobroker/iobroker-data/objects.jsonl
          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          4.6M	/opt/iobroker/iobroker-data/states.jsonl
          2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
          2.6M	/opt/iobroker/iobroker-data/files/ble.admin/build/index.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.20.2
          /usr/bin/node 		v18.20.2
          /usr/bin/npm 		10.5.0
          /usr/bin/npx 		10.5.0
          /usr/bin/corepack 	0.25.2
          nodejs:
            Installed: 18.20.2-1nodesource1
            Candidate: 18.20.2-1nodesource1
            Version table:
           *** 18.20.2-1nodesource1 600
                  100 /var/lib/dpkg/status
               18.20.1-1nodesource1 600
               18.20.0-1nodesource1 600
               18.19.1-1nodesource1 600
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 600
               18.18.2-1nodesource1 600
               18.18.1-1nodesource1 600
               18.18.0-1nodesource1 600
               18.17.1-1nodesource1 600
               18.17.0-1nodesource1 600
               18.16.1-1nodesource1 600
               18.16.0-1nodesource1 600
               18.15.0-1nodesource1 600
               18.14.2-1nodesource1 600
               18.14.1-1nodesource1 600
               18.14.0-1nodesource1 600
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 600
               18.12.0-1nodesource1 600
               18.11.0-1nodesource1 600
               18.10.0-1nodesource1 600
               18.9.1-1nodesource1 600
               18.9.0-1nodesource1 600
               18.8.0-1nodesource1 600
               18.7.0-1nodesource1 600
               18.6.0-1nodesource1 600
               18.5.0-1nodesource1 600
               18.4.0-1nodesource1 600
               18.3.0-1nodesource1 600
               18.2.0-1nodesource1 600
               18.1.0-1nodesource1 600
               18.0.0-1nodesource1 600
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.19
          admin: 		6.13.16
          javascript: 	"javascript" not found
          Adapters from github: 	1
          Adapter State
          + system.adapter.admin.0                  : admin                 : rasp                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : rasp                                     -  enabled
          + system.adapter.ble.0                    : ble                   : rasp                                     -  enabled
          + system.adapter.discovery.0              : discovery             : rasp                                     -  enabled
          + system.adapter.influxdb.0               : influxdb              : rasp                                     -  enabled, port: 8086
          + system.adapter.mqtt.0                   : mqtt                  : rasp                                     -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mystrom.0                : mystrom               : rasp                                     -  enabled
          + system.adapter.vedirect.0               : vedirect              : rasp                                     -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
          Objects and States
          Objects: 	385
          States: 	287
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2106529    42615/cupsd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       42475      11730/io.mqtt.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8479       1072/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8472       1072/iobroker.js-co
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9234       778/sshd: /usr/sbin
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        6022       896/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7635       1122/io.admin.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2106528    42615/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      113        6061       1071/grafana
          tcp6       0      0 :::22                   :::*                    LISTEN      0          9236       778/sshd: /usr/sbin
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1857       626/dhcpcd: [networ
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2107407    42643/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7074       570/avahi-daemon: r
          udp        0      0 0.0.0.0:38954           0.0.0.0:*                           104        7076       570/avahi-daemon: r
          udp6       0      0 :::36418                :::*                                104        7077       570/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          1859       626/dhcpcd: [networ
          udp6       0      0 :::5353                 :::*                                104        7075       570/avahi-daemon: r
          2024-04-14 10:37:15.420  - debug: vedirect.0 (70677) Objects client ready ... initialize now
          2024-04-14 10:37:15.423  - debug: vedirect.0 (70677) Objects create System PubSub Client
          2024-04-14 10:37:15.425  - debug: vedirect.0 (70677) Objects create User PubSub Client
          2024-04-14 10:37:15.461  - debug: vedirect.0 (70677) Objects client initialize lua scripts
          2024-04-14 10:37:15.470  - debug: vedirect.0 (70677) Objects connected to redis: 127.0.0.1:9001
          2024-04-14 10:37:15.488  - debug: vedirect.0 (70677) Redis States: Use Redis connection: 127.0.0.1:9000
          2024-04-14 10:37:15.496  - debug: vedirect.0 (70677) States create System PubSub Client
          2024-04-14 10:37:15.497  - debug: vedirect.0 (70677) States create User PubSub Client
          2024-04-14 10:37:15.511  - debug: vedirect.0 (70677) States connected to redis: 127.0.0.1:9000
          2024-04-14 10:37:15.541  - debug: vedirect.0 (70677) Plugin sentry Initialize Plugin (enabled=true)
          2024-04-14 10:37:15.965  - info: vedirect.0 (70677) starting. Version 0.3.3 (non-npm: DrozmotiX/ioBroker.vedirect#8435302add9dc410535180c6c0d5ebbaef2eeb1e) in /opt/iobroker/node_modules/iobroker.vedirect, node: v18.20.2, js-controller: 5.0.19
          2024-04-14 10:37:15.987  - info: vedirect.0 (70677) Starting VE.Direct with Protocol Version 3.33 and configurable expiring state capability
          2024-04-14 10:37:15.998  - error: vedirect.0 (70677) Issue handling serial port connection : {}
          2024-04-14 10:37:45.453  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
          2024-04-14 10:37:55.638  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201
          2024-04-14 10:39:42.298  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
          2024-04-14 10:40:09.177  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
          2024-04-14 10:43:51.983  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
          2024-04-14 10:44:41.987  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
          2024-04-14 10:57:05.970  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
          2024-04-14 11:01:56.002  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
          2024-04-14 11:06:49.715  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
          2024-04-14 11:08:09.723  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
          2024-04-14 11:10:09.427  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
          2024-04-14 11:14:58.222  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
          iob diag has finished.
          Press any key for a summary
            Homoran Global Moderator Administrators @mere13 last edited by Homoran
            da steht er.
            in deinem Screenshot leider nicht zu lesen.
            Aber da sind anscheinend Leerzeichen verwendet und der abschließende Slash fehlt
              Thomas Braun Most Active @mere13 last edited by
              Setz das auf
              sudo systemctl set-default multi-user.target
              Nach einem Neustart:
              ls -la /dev/serial/by-id
                @thomas-braun said in vedirect keine Verbindung bei rasp 4:
                Bekomme das:
                total 0
                drwxr-xr-x 2 root root 60 Apr 14 12:29 .
                drwxr-xr-x 4 root root 80 Apr 14 12:29 ..
                lrwxrwxrwx 1 root root 13 Apr 14 12:29 usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0 -> ../../ttyUSB0
                und im Adapter ist das eingetragen, keine Leerzeichen
                /dev/serial/by-id usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
                DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                • DJMarc75
                  DJMarc75 @mere13 last edited by
                  keine Leerzeichen
                  doch, zwischen id und usb
                    mere13 @DJMarc75 last edited by
                    @djmarc75 ok. sorry, war blind. habs jetzt korrigiert und mit / ersetzt. Was meintest Du mit abschließendem Slash? Jetzt steht das da, aber leider noch keine Verbindung:
                      @mere13
                      Es muss exakt das eingetragen werden:
                      Rechte sind vorhanden?
                      ls -la /dev/ttyUSB0
                      sudo -u iobroker groups
                        mit copy-paste übertragen. leider nix.
                        marcel@rasp:~ $ ls -la /dev/ttyUSB0
                        crw-rw----+ 1 root plugdev 188, 0 Apr 14 12:29 /dev/ttyUSB0
                        iobroker tty dialout audio video bluetooth gpio i2c
                          leider nix.
                          Wie nix? Da sind doch die Ausgaben. Würde man besser sehen, wenn du freundlicherweise für solche Ausgaben aus der Konsole die CodeTags verwenden würdest.
                          Der user 'iobroker' ist nicht in der Gruppe 'plugdev' drin. Deswegen darf der mit dem Gerät nix anfangen.
                          Setz den da rein:
                          sudo usermod -a -G plugdev iobroker
                          iob stop
                          sudo reboot
                          Sollte danach funktionieren.
                            eben!
                            keine Leerzeichen
                            Doch
                            @homoran sagte in vedirect keine Verbindung bei rasp 4:
                              iob stop
                              sudo reboot
                              Das war die Lösung. Danke! Keine Ahnung, wieso das falsch war.
                              Und tut mir leid: Bin noch nicht besonders routiniert mit den codes und code-tags.
                                War ja nix falsch.
                                Nur nicht richtig konfiguriert.
                                Der user 'iobroker' ist im Standard nie in der Gruppe 'plugdev' enthalten.
                                Wenn du magst kannst du ein Issue beim iobroker-Installer aufmmachen, dann kann man mal prüfen ob das nicht geändert werden könnte bei der Installation.
                                  Thomas Braun Most Active last edited by
                                  @mere13
                                  Ich habe gleich mal einen PR draus gebastelt.
                                  https://github.com/ioBroker/ioBroker/pull/518
                                  Grothesk242 created this issue in ioBroker/ioBroker
                                  closed Add 'iobroker' to 'plugdev' group #518
                                  625
