    4. vedirect keine Verbindung bei rasp 4
      mere13 @Homoran last edited by
      @homoran verstehe ich leider nicht. wie bekomme ich die code-tags? Hab alles per copy-paste übertragen. So?
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: rasp
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       11:15:46 up 1 day,  1:06,  3 users,  load average: 0.14, 0.26, 0.34
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-04-14 11:15:47 CEST
                 Universal time: Sun 2024-04-14 09:15:47 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      marcel
      /home/marcel
      marcel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            8.2G        1.2G        5.7G        1.4M        1.4G        6.9G
      Swap:           104M          0B        104M
      Total:          8.3G        1.2G        5.8G
               7810 M total memory
               1184 M used memory
               1421 M active memory
                775 M inactive memory
               5445 M free memory
                122 M buffer memory
               1181 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     782M  1.3M  780M   1% /run
      /dev/mmcblk0p2 ext4       58G  6.4G   48G  12% /
      tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   82M  429M  17% /boot/firmware
      tmpfs          tmpfs     782M   28K  781M   1% /run/user/1000
      [Sat Apr 13 10:09:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B1:D2:3A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=8a167c7b-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Sat Apr 13 10:09:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
      [Sat Apr 13 10:09:09 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      870M	/var/
      341M	/var/cache
      334M	/var/cache/apt
      322M	/var/lib
      221M	/var/cache/apt/archives
      Archived and active journals take up 104.0M in the file system.
      /opt/iobroker/backups:
      2.9M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      62M	/opt/iobroker/iobroker-data/
      31M	/opt/iobroker/iobroker-data/backup-objects
      19M	/opt/iobroker/iobroker-data/files
      13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      8.8M	/opt/iobroker/iobroker-data/objects.jsonl
      6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.6M	/opt/iobroker/iobroker-data/states.jsonl
      2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      2.6M	/opt/iobroker/iobroker-data/files/ble.admin/build/index.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.20.2
      /usr/bin/node 		v18.20.2
      /usr/bin/npm 		10.5.0
      /usr/bin/npx 		10.5.0
      /usr/bin/corepack 	0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 600
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.19
      admin: 		6.13.16
      javascript: 	"javascript" not found
      Adapters from github: 	1
      Adapter State
      + system.adapter.admin.0                  : admin                 : rasp                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : rasp                                     -  enabled
      + system.adapter.ble.0                    : ble                   : rasp                                     -  enabled
      + system.adapter.discovery.0              : discovery             : rasp                                     -  enabled
      + system.adapter.influxdb.0               : influxdb              : rasp                                     -  enabled, port: 8086
      + system.adapter.mqtt.0                   : mqtt                  : rasp                                     -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mystrom.0                : mystrom               : rasp                                     -  enabled
      + system.adapter.vedirect.0               : vedirect              : rasp                                     -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
      Objects and States
      Objects: 	385
      States: 	287
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2106529    42615/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       42475      11730/io.mqtt.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8479       1072/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8472       1072/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9234       778/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        6022       896/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7635       1122/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2106528    42615/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        6061       1071/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          9236       778/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1857       626/dhcpcd: [networ
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2107407    42643/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7074       570/avahi-daemon: r
      udp        0      0 0.0.0.0:38954           0.0.0.0:*                           104        7076       570/avahi-daemon: r
      udp6       0      0 :::36418                :::*                                104        7077       570/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          1859       626/dhcpcd: [networ
      udp6       0      0 :::5353                 :::*                                104        7075       570/avahi-daemon: r
      2024-04-14 10:37:15.420  - debug: vedirect.0 (70677) Objects client ready ... initialize now
      2024-04-14 10:37:15.423  - debug: vedirect.0 (70677) Objects create System PubSub Client
      2024-04-14 10:37:15.425  - debug: vedirect.0 (70677) Objects create User PubSub Client
      2024-04-14 10:37:15.461  - debug: vedirect.0 (70677) Objects client initialize lua scripts
      2024-04-14 10:37:15.470  - debug: vedirect.0 (70677) Objects connected to redis: 127.0.0.1:9001
      2024-04-14 10:37:15.488  - debug: vedirect.0 (70677) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-04-14 10:37:15.496  - debug: vedirect.0 (70677) States create System PubSub Client
      2024-04-14 10:37:15.497  - debug: vedirect.0 (70677) States create User PubSub Client
      2024-04-14 10:37:15.511  - debug: vedirect.0 (70677) States connected to redis: 127.0.0.1:9000
      2024-04-14 10:37:15.541  - debug: vedirect.0 (70677) Plugin sentry Initialize Plugin (enabled=true)
      2024-04-14 10:37:15.965  - info: vedirect.0 (70677) starting. Version 0.3.3 (non-npm: DrozmotiX/ioBroker.vedirect#8435302add9dc410535180c6c0d5ebbaef2eeb1e) in /opt/iobroker/node_modules/iobroker.vedirect, node: v18.20.2, js-controller: 5.0.19
      2024-04-14 10:37:15.987  - info: vedirect.0 (70677) Starting VE.Direct with Protocol Version 3.33 and configurable expiring state capability
      2024-04-14 10:37:15.998  - error: vedirect.0 (70677) Issue handling serial port connection : {}
      2024-04-14 10:37:45.453  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
      2024-04-14 10:37:55.638  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201
      2024-04-14 10:39:42.298  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
      2024-04-14 10:40:09.177  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
      2024-04-14 10:43:51.983  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
      2024-04-14 10:44:41.987  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
      2024-04-14 10:57:05.970  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
      2024-04-14 11:01:56.002  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
      2024-04-14 11:06:49.715  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
      2024-04-14 11:08:09.723  - info: admin.0 (1122) <== Disconnect system.user.admin from ::ffff:192.168.2.201 admin
      2024-04-14 11:10:09.427  - info: mystrom.0 (1240) Set update interval for 9C9C1FE323DC to 60
      2024-04-14 11:14:58.222  - info: admin.0 (1122) ==> Connected system.user.admin from ::ffff:192.168.2.201
      iob diag has finished.
      Press any key for a summary
        Homoran Global Moderator Administrators @mere13 last edited by Homoran
        @mere13 sagte in vedirect keine Verbindung bei rasp 4:
        da steht er.
        in deinem Screenshot leider nicht zu lesen.
        Aber da sind anscheinend Leerzeichen verwendet und der abschließende Slash fehlt
          Thomas Braun Most Active @mere13 last edited by
          Setz das auf
          sudo systemctl set-default multi-user.target
          Nach einem Neustart:
          ls -la /dev/serial/by-id
            @thomas-braun said in vedirect keine Verbindung bei rasp 4:
            Bekomme das:
            total 0
            drwxr-xr-x 2 root root 60 Apr 14 12:29 .
            drwxr-xr-x 4 root root 80 Apr 14 12:29 ..
            lrwxrwxrwx 1 root root 13 Apr 14 12:29 usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0 -> ../../ttyUSB0
            und im Adapter ist das eingetragen, keine Leerzeichen
            /dev/serial/by-id usb-VictronEnergy_BV_VE_Direct_cable_VE6WATIJ-if00-port0
            DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
            • DJMarc75
              DJMarc75 @mere13 last edited by
              keine Leerzeichen
              doch, zwischen id und usb
                mere13 @DJMarc75 last edited by
                @djmarc75 ok. sorry, war blind. habs jetzt korrigiert und mit / ersetzt. Was meintest Du mit abschließendem Slash? Jetzt steht das da, aber leider noch keine Verbindung:
                  @mere13
                  Es muss exakt das eingetragen werden:
                  Rechte sind vorhanden?
                  ls -la /dev/ttyUSB0
                  sudo -u iobroker groups
                    mit copy-paste übertragen. leider nix.
                    marcel@rasp:~ $ ls -la /dev/ttyUSB0
                    crw-rw----+ 1 root plugdev 188, 0 Apr 14 12:29 /dev/ttyUSB0
                    iobroker tty dialout audio video bluetooth gpio i2c
                      leider nix.
                      Wie nix? Da sind doch die Ausgaben. Würde man besser sehen, wenn du freundlicherweise für solche Ausgaben aus der Konsole die CodeTags verwenden würdest.
                      Der user 'iobroker' ist nicht in der Gruppe 'plugdev' drin. Deswegen darf der mit dem Gerät nix anfangen.
                      Setz den da rein:
                      sudo usermod -a -G plugdev iobroker
                      iob stop
                      sudo reboot
                      Sollte danach funktionieren.
                        eben!
                        keine Leerzeichen
                        Doch
                        @homoran sagte in vedirect keine Verbindung bei rasp 4:
                          iob stop
                          sudo reboot
                          Das war die Lösung. Danke! Keine Ahnung, wieso das falsch war.
                          Und tut mir leid: Bin noch nicht besonders routiniert mit den codes und code-tags.
                            War ja nix falsch.
                            Nur nicht richtig konfiguriert.
                            Der user 'iobroker' ist im Standard nie in der Gruppe 'plugdev' enthalten.
                            Wenn du magst kannst du ein Issue beim iobroker-Installer aufmmachen, dann kann man mal prüfen ob das nicht geändert werden könnte bei der Installation.
                              Thomas Braun Most Active last edited by
                              @mere13
                              Ich habe gleich mal einen PR draus gebastelt.
                              https://github.com/ioBroker/ioBroker/pull/518
                              Grothesk242 created this issue in ioBroker/ioBroker
                              closed Add 'iobroker' to 'plugdev' group #518
                              625
