    4. SNMP Adapter Update startet nicht
    • MartinP
      MartinP last edited by
      Angeblich sei eine zu alte Node-Version vorgefunden worden
      Jedoch:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
        Thomas Braun Most Active @MartinP last edited by Thomas Braun
        @martinp
        Mach es über die Konsole. Die ist ggf. gesprächiger.
        iob update
        iob upgrade
        Edit: Kann auch kein Fehler im Paket sein, hier läuft das nämlich durch:
        echad@chet:~ $ iob add snmp
        NPM version: 10.5.0
        Installing iobroker.snmp@3.2.0... (System call)
        added 3 packages in 12s
        171 packages are looking for funding
          run `npm fund` for details
        host.chet install adapter snmp
        upload [14] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [13] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [12] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [11] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [10] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [9] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [8] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [7] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [6] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [5] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [4] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [3] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/index_m.html index_m.html text/html
        upload [2] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/jsonConfig.json jsonConfig.json application/json
        upload [1] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/snmp.png snmp.png image/png
        upload [0] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/words.js words.js application/javascript
        host.chet object system.adapter.snmp created/updated
        host.chet create instance snmp
        host.chet object system.adapter.snmp.0.alive created
        host.chet object system.adapter.snmp.0.connected created
        host.chet object system.adapter.snmp.0.compactMode created
        host.chet object system.adapter.snmp.0.cpu created
        host.chet object system.adapter.snmp.0.cputime created
        host.chet object system.adapter.snmp.0.memHeapUsed created
        host.chet object system.adapter.snmp.0.memHeapTotal created
        host.chet object system.adapter.snmp.0.memRss created
        host.chet object system.adapter.snmp.0.uptime created
        host.chet object system.adapter.snmp.0.inputCount created
        host.chet object system.adapter.snmp.0.outputCount created
        host.chet object system.adapter.snmp.0.eventLoopLag created
        host.chet object system.adapter.snmp.0.sigKill created
        host.chet object system.adapter.snmp.0.logLevel created
        host.chet object snmp.0.info created
        host.chet object snmp.0.info.connection created
        host.chet Set default value of snmp.0.info.connection: false
        host.chet object system.adapter.snmp.0 created
        echad@chet:~ $
          Homoran Global Moderator Administrators @MartinP last edited by
          @martinp hast du multihost?
          • MartinP
            MartinP @Thomas Braun last edited by
            @thomas-braun Aus der Konsole hat es geklappt
            Die Web-GUI war da auch inkonsistent
            Eine blaue "2" über "Instances", aber nur der SNMP Adapter wurde angezeigt .. in der Konsole war es vollständig ...
            martin@iobroker-test-sicher:/opt/iobroker/backups$ iob update
            Used repository: stable
            Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
            Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
            Adapter    "deconz"       : 1.4.0    , installed 1.4.0
            Adapter    "discovery"    : 4.4.0    , installed 4.4.0
            Adapter    "email"        : 1.2.2    , installed 1.2.2
            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
            Adapter    "ical"         : 1.14.3   , installed 1.14.3
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
            Adapter    "operating-hours": 1.0.6  , installed 1.0.6
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "snmp"         : 3.2.0    , installed 3.1.0  [Updatable]
            Adapter    "socketio"     : 6.6.1    , installed 6.6.1
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
            Adapter    "ws"           : 2.5.11   , installed 2.5.11
            Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
            martin@iobroker-test-sicher:/opt/iobroker/backups$ iob upgrade
            This upgrade of "snmp" will introduce the following changes:
            -> 3.2.0:
            Adapter requires node.js 18 and js-controller >= 5 now
            Dependencies have been updated
            Would you like to upgrade snmp from @3.1.0 to @3.2.0 now? [(y)es, (n)o]: y
            Update snmp from @3.1.0 to @3.2.0
            host.iobroker-test-sicher Adapter "system.adapter.snmp.0" is stopped.
            NPM version: 10.5.0
            changed 3 packages in 21s
            132 packages are looking for funding
            Update "system.adapter.snmp.0"
            host.iobroker-test-sicher Adapter "system.adapter.snmp.0" is started
            This upgrade of "backitup" will introduce the following changes:
            -> 2.11.0:
            Fix Sqlite3 Path
            Would you like to upgrade backitup from @2.10.11 to @2.11.0 now? [(y)es, (n)o]: y
            Update backitup from @2.10.11 to @2.11.0
            host.iobroker-test-sicher Adapter "system.adapter.backitup.0" is stopped.
            NPM version: 10.5.0
            Installing iobroker.backitup@2.11.0... (System call)
            removed 2 packages, and changed 6 packages in 19s
            Update "system.adapter.backitup.0"
            upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
            upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
            upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
            upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
            host.iobroker-test-sicher Adapter "system.adapter.backitup.0" is started
              @martinp
              Und was sag ich immer: GUIs lügen.
              • MartinP
                MartinP @Thomas Braun last edited by MartinP
                @thomas-braun aktuell aber sowas von ...
                host.iobroker-test-sicher	2024-04-15 18:45:37.552	error	cannot get getHostInfo: Cannot read properties of undefined (reading 'speed')
                Und das hier dazu noch ...
                Ist das ggfs. ein Kollateralschaden der neuen SNMP Adapter Version?
                Mal schauen, ob sich das irgendwann beruhigt...
                ein "iob restart" habe ich schon gemacht - immer noch "offline", und dieses "cannot read properties of undefined ... " im Logging taucht immer mal wieder auf ...
                "iob stop - iob fix - iob start"
                Offline bleibt ...
                Mal schauen, wie sich das ansonsten auswirkt ...
                  @martinp
                  Kannst dir ja mal die Großwetterlage per
                  iob diag
                  anschauen.
                  • MartinP
                    @thomas-braun vorher iob stop wenn ich mich nicht irre?
                      @martinp
                      Nein, bei laufendem System.
                      • MartinP
                        Die "Transport Endpoint is not connected" Meldungen sind etwas merkwürdig ...
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                         Static hostname: iobroker-test-sicher
                               Icon name: computer-container
                                 Chassis: container ☐
                          Virtualization: lxc
                                  Kernel: Linux 6.5.13-5-pve
                            Architecture: x86-64
                        grep: /proc/cpuinfo: Transport endpoint is not connected
                        Docker          : false
                        Virtualization  : lxc
                        Kernel          : x86_64
                        Userland        : amd64
                        Systemuptime and Load:
                        uptime: Cannot get system uptime: Transport endpoint is not connected
                        CPU threads:
                        *** Time and Time Zones ***
                                       Local time: Mon 2024-04-15 19:14:08 CEST
                                   Universal time: Mon 2024-04-15 17:14:08 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        *** User and Groups ***
                        martin
                        /home/martin
                        martin sudo iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        free: Unable to create meminfo structure
                        vmstat: Unable to create system stat structure
                        *** FAILED SERVICES ***
                          UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                        * mnt-backup.mount                     loaded failed failed /mnt/backup
                        * mnt-data.mount                       loaded failed failed /mnt/data
                        * mnt-unterhaltung.mount               loaded failed failed /mnt/unterhaltung
                        * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
                        * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
                        * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                        LOAD   = Reflects whether the unit definition was properly loaded.
                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                        SUB    = The low-level unit activation state, values depend on unit type.
                        6 loaded units listed.
                        *** FILESYSTEM ***
                        df: /proc/cpuinfo: Transport endpoint is not connected
                        df: /proc/diskstats: Transport endpoint is not connected
                        df: /proc/loadavg: Transport endpoint is not connected
                        df: /proc/meminfo: Transport endpoint is not connected
                        df: /proc/slabinfo: Transport endpoint is not connected
                        df: /proc/stat: Transport endpoint is not connected
                        df: /proc/swaps: Transport endpoint is not connected
                        df: /proc/uptime: Transport endpoint is not connected
                        df: /sys/devices/system/cpu: Transport endpoint is not connected
                        Filesystem                       Type      Size  Used Avail Use% Mounted on
                        /dev/mapper/pve-vm--101--disk--0 ext4       63G   13G   47G  22% /
                        none                             tmpfs     492K  4.0K  488K   1% /dev
                        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
                        tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
                        tmpfs                            tmpfs     1.6G  124K  1.6G   1% /run
                        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                        dmesg: read kernel buffer failed: Operation not permitted
                        TARGET SOURCE                           FSTYPE OPTIONS
                        /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                        /var:
                        2.2G    /var/
                        1.2G    /var/lib
                        1.1G    /var/lib/influxdb/engine
                        978M    /var/lib/influxdb/engine/data/f11825691705bf53/autogen
                        Archived and active journals take up 106.9M in the file system.
                        /opt/iobroker/backups:
                        4.6G    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        952M    /opt/iobroker/iobroker-data/
                        905M    /opt/iobroker/iobroker-data/files
                        771M    /opt/iobroker/iobroker-data/files/vis-2-beta
                        738M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
                        736M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        9.7M    /opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
                        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                        8.3M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.a81e98bd.js
                        8.3M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.a256af99.js
                        USB-Devices by-id:
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        nodejs:
                          Installed: 18.20.2-1nodesource1
                          Candidate: 18.20.2-1nodesource1
                          Version table:
                         *** 18.20.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                100 /var/lib/dpkg/status
                             18.20.1-1nodesource1 1001
                             18.20.0-1nodesource1 1001
                             18.19.1-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://security.debian.org bookworm-security/main amd64 Packages
                             18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                                500 http://ftp.debian.org/debian bookworm/main amd64 Packages
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.19
                        admin:          6.13.16
                        javascript:     7.8.0
                        Adapters from github:   0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker-test-sicher                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : iobroker-test-sicher                     -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker-test-sicher                     -  enabled
                        + system.adapter.discovery.0              : discovery             : iobroker-test-sicher                     -  enabled
                        + system.adapter.email.0                  : email                 : iobroker-test-sicher                     -  enabled
                        + system.adapter.fritzdect.0              : fritzdect             : iobroker-test-sicher                     -  enabled
                          system.adapter.ical.0                   : ical                  : iobroker-test-sicher                     -  enabled
                          system.adapter.ical.1                   : ical                  : iobroker-test-sicher                     -  enabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker-test-sicher                     -  enabled, port: 8086
                        + system.adapter.javascript.0             : javascript            : iobroker-test-sicher                     -  enabled
                        + system.adapter.meross.0                 : meross                : iobroker-test-sicher                     -  enabled
                        + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-test-sicher                     -  enabled, port: 1888
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker-test-sicher                     -  enabled, port: 1888, bind: 0.0.0.0
                        + system.adapter.operating-hours.0        : operating-hours       : iobroker-test-sicher                     -  enabled
                        + system.adapter.ping.0                   : ping                  : iobroker-test-sicher                     -  enabled
                        + system.adapter.simple-api.0             : simple-api            : iobroker-test-sicher                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.snmp.0                   : snmp                  : iobroker-test-sicher                     -  enabled
                        + system.adapter.sonoff.0                 : sonoff                : iobroker-test-sicher                     -  enabled, port: 1892, bind: 0.0.0.0
                        + system.adapter.tradfri.0                : tradfri               : iobroker-test-sicher                     -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker-test-sicher                     -  enabled
                        + system.adapter.web.0                    : web                   : iobroker-test-sicher                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                        Objects and States
                        Objects:        1561
                        States:         1208
                        Hit:1 http://security.debian.org bookworm-security InRelease
                        Hit:2 http://ftp.debian.org/debian bookworm InRelease
                        Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
                        Hit:4 https://apt.grafana.com stable InRelease
                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          35821      1/init
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32173897   50483/iobroker.js-c
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32173937   50483/iobroker.js-c
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          44561      349/master
                        tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       32177860   50670/io.sonoff.0
                        tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       32177590   50645/io.mqtt.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          35823      1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          38539      1/init
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          44562      349/master
                        tcp6       0      0 :::3000                 :::*                    LISTEN      109        10568373   16590/grafana
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32182013   50978/io.simple-api
                        tcp6       0      0 :::8086                 :::*                    LISTEN      998        32082191   48633/influxd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32175354   50501/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32181799   50948/io.web.0
                        udp        0      0 0.0.0.0:52497           0.0.0.0:*                           1001       32180338   50812/io.snmp.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          35822      1/init
                        udp        0      0 0.0.0.0:37461           0.0.0.0:*                           1001       32182377   50967/io.tradfri.0
                        udp6       0      0 :::111                  :::*                                0          35824      1/init
                        2024-04-15 19:14:38.133  - info: tradfri.0 (50967) got all scenes in group 131075: []
                        2024-04-15 19:14:38.226  - info: tradfri.0 (50967) updating possible scenes for group 131073: ["196611"]
                        2024-04-15 19:14:38.379  - info: tradfri.0 (50967) updating possible scenes for group 131073: ["196611","196612"]
                        2024-04-15 19:14:38.478  - info: tradfri.0 (50967) updating possible scenes for group 131073: ["196611","196612","196614"]
                        2024-04-15 19:14:38.607  - info: tradfri.0 (50967) received all groups and scenes
                        2024-04-15 19:14:38.642  - info: tradfri.0 (50967) updating possible scenes for group 131074: ["196615","196616"]
                        2024-04-15 19:14:38.773  - info: host.iobroker-test-sicher instance system.adapter.operating-hours.0 started with pid 51001
                        2024-04-15 19:14:41.714  - info: simple-api.0 (50978) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.20.2, js-controller: 5.0.19
                        2024-04-15 19:14:41.777  - warn: simple-api.0 (50978) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                        2024-04-15 19:14:41.804  - info: simple-api.0 (50978) simpleAPI server listening on port 8087
                        2024-04-15 19:14:41.814  - info: simple-api.0 (50978) Allow states only when user is owner: false
                        2024-04-15 19:14:41.857  - info: simple-api.0 (50978) http server listening on port 8087
                        2024-04-15 19:14:43.965  - info: operating-hours.0 (51001) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.operating-hours, node: v18.20.2, js-controller: 5.0.19
                        2024-04-15 19:14:48.740  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                        2024-04-15 19:14:54.742  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                        2024-04-15 19:14:58.743  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                        2024-04-15 19:15:02.722  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connection closed: closed
                        2024-04-15 19:15:04.722  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connected with secret 1713201304721_956
                        2024-04-15 19:15:04.724  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] Received pubrec on esp8266-cf6d7a for unknown messageId 1
                        2024-04-15 19:15:32.770  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                        2024-04-15 19:15:40.772  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                        2024-04-15 19:15:44.773  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                        2024-04-15 19:15:45.815  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connection closed: closed
                        2024-04-15 19:15:47.822  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connected with secret 1713201347821_3327
                        2024-04-15 19:15:47.824  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] Received pubrec on esp8266-cf6d7a for unknown messageId 1
                        Thomas Braun MartinP 2 Replies Last reply Reply Quote 0
                          @martinp
                          Das führe ich auf den Betrieb im LXC zurück.
                          • MartinP
                            MartinP @MartinP last edited by MartinP
                            schon ein
                            "ls /proc/cpuinfo" meldet dieses "Transport endpoint is not connected"
                            Starte den Container mal neu ...
                            EDIT Nach dem Neustart funzt es wieder
                            Auch die Übersichtsseite sieht gut aus ...
                              @martinp sagte in SNMP Adapter Update startet nicht:
                              Und den Host...
                              Laufen da mehrere Container? Schaut für mich aus wie 'Kampf um die gleichen Ressourcen'.
                              • MartinP
                                @thomas-braun Sieht erstmal unauffällig aus, PVE Speicherauslastung bei ca 4/8 GByte, CPU auch nicht am Anschlag...
                                Mal eine Nacht nicht an den Knöpfen drehen, und schauen, ob es morgen immer noch funktioniert ...
                                • MartinP
                                  Bis jetzt funktioniert der LXC Container von iobroker tadellos.
                                  Ein zweiter Container, in dem ich weitere Spielereien betreibe, scheint auch das "Transport endpoint is not connected" Problem zu haben.
                                  Kriegt jetzt auch einen Neustart ... done, Probleme behoben.
                                  Scheint dies zu sein:
                                  https://discuss.linuxcontainers.org/t/top-failed-proc-stat-open-transport-endpoint-is-not-connected/13630
                                  227
