    4. [gelöst] Sporadische Neustarts des iobroker
      Thomas Braun Most Active @m.schalk last edited by
      @m-schalk sagte in Sporadische Neustarts des iobroker:
      Deine grafana.list hat Doubletten.
      Schmeiß die doppelten Einträge dort raus.
      Dein nodejs ist veraltet. Per
      iob nodejs-update
      auf Stand bringen.
      Dann wird es wohl so sein, dass du für redis/redis zu wenig RAM hast. redis läuft ja komplett im RAM und deswegen braucht es da halt reichlich von.
      Pending Updates: 98
      Updaten. Die iob-Adapter auch.
        m.schalk @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: BU02SMART02-iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 6.2.16-18-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         21:19:03 up 26 min,  3 users,  load average: 3.10, 4.57, 4.47
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Tue 2024-04-16 21:19:03 CEST
                   Universal time: Tue 2024-04-16 19:19:03 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        mario
        /home/mario
        mario sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.2G        3.6G        2.6G        0.0K        2.0G        4.6G
        Swap:           7.8G        0.0K        7.8G
        Total:           15G        3.6G         10G
                 8192 M total memory
                 3619 M used memory
                  565 M active memory
                 4778 M inactive memory
                 2612 M free memory
                    0 M buffer memory
                 1959 M swap cache
                 7759 M total swap
                    0 M used swap
                 7759 M free swap
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        /dev/loop0     ext4    26G   20G  4.6G  82% /
        none           tmpfs  492K  4.0K  488K   1% /dev
        tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs          tmpfs  3.1G  172K  3.1G   1% /run
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/0
        tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE     FSTYPE OPTIONS
        /      /dev/loop0 ext4   rw,relatime
        /var:
        4.0G    /var/
        2.8G    /var/log
        2.7G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
        781M    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        713M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        7.9G    /opt/iobroker/iobroker-data/
        6.5G    /opt/iobroker/iobroker-data/history
        627M    /opt/iobroker/iobroker-data/files
        487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        49M     /opt/iobroker/iobroker-data/objects.jsonl
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        28M     /opt/iobroker/iobroker-data/states.jsonl
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.2
        /usr/bin/node           v18.20.2
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.2-1nodesource1
          Candidate: 18.20.2-1nodesource1
          Version table:
         *** 18.20.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.5 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.3
        javascript:     8.0.3
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
        + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.backitup.0               : backitup              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
          system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
          system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     - disabled
        + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
          system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
          system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
          system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
        + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
          system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
        + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
        + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
          system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
          system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
        + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.proxmox.0                : proxmox               : BU02SMART02-iobroker                     - disabled, port: 8006
        + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
          system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
        + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
          system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
          system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
        + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
          system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
          system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
        + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
          system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Beta (latest)
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "admin"        : 6.17.3   , installed 6.17.3
        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "apcups"       : 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 2.11.0   , installed 2.9.9  [Updatable]
        Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.0  , installed 2.12.0
        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "ems-esp"      : 3.1.1    , installed 3.1.1
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "ford"         : 0.2.0    , installed 0.2.0
        Adapter    "hass-mqtt"    : 0.0.7    , installed 0.0.7
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "ical"         : 1.14.3   , installed 1.14.3
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "iot"          : 3.2.2    , installed 3.2.2
        Adapter    "javascript"   : 8.0.3    , installed 8.0.3
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
        Adapter    "mercedesme"   : 0.2.2    , installed 0.2.2
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
        Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "ring"         : 5.0.10   , installed 5.0.10
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.9.0    , installed 6.9.0
        Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
        Adapter    "slideshow"    : 0.1.4    , installed 0.1.4
        Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "telegram"     : 3.2.1    , installed 3.2.1
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis"          : 1.5.5    , installed 1.5.5
        Adapter    "vis-2"        : 2.9.49   , installed 2.9.49
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
        Adapter    "vis-2-widgets-material": 1.3.27, installed 1.3.27
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        49449
        States:         43067
        Hit:1 https://repos.influxdata.com/debian stable InRelease
        Hit:2 https://apt.grafana.com stable InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          134632524  1/init
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       134767830  3724/io.mqtt.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          134635725  283/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        134631393  100/systemd-resolve
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        134635550  116/redis-server 12
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          134652904  935/sshd: root@pts/
        tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       134826590  5717/sshd: mario@pt
        tcp        0      0 0.0.0.0:39227           0.0.0.0:*               LISTEN      1000       134773301  4042/io.yahka.0
        tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       134769007  3803/io.shelly.1
        tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       134770223  3841/io.mqtt.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          134632526  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          134632859  1/init
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        134639723  339/grafana
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          134635726  283/master
        tcp6       0      0 ::1:6379                :::*                    LISTEN      113        134635551  116/redis-server 12
        tcp6       0      0 ::1:6010                :::*                    LISTEN      0          134652903  935/sshd: root@pts/
        tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       134826589  5717/sshd: mario@pt
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       134762300  3585/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       134782529  4319/io.web.0
        udp        0      0 0.0.0.0:50492           0.0.0.0:*                           1000       134778743  3917/io.shelly.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134775091  4042/io.yahka.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       134773821  3917/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       134765342  3672/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       134765343  3672/io.tuya.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        134631392  100/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          134632525  1/init
        udp6       0      0 :::111                  :::*                                0          134632527  1/init
        2024-04-16 21:14:16.270  - info: sourceanalytix.0 (4060) Initialising (24 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt"
        2024-04-16 21:14:17.088  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay1.gesamt successfully
        2024-04-16 21:14:17.089  - info: sourceanalytix.0 (4060) Initialising (25 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt"
        2024-04-16 21:14:18.113  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E7B0#1.Relay0.gesamt successfully
        2024-04-16 21:14:18.114  - info: sourceanalytix.0 (4060) Initialising (26 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt"
        2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#1D409A#1.Relay0.gesamt successfully
        2024-04-16 21:14:18.812  - info: sourceanalytix.0 (4060) Initialising (27 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt"
        2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC4E571#1.Relay1.gesamt successfully
        2024-04-16 21:14:19.828  - info: sourceanalytix.0 (4060) Initialising (28 of 34) "linkeddevices.0.Solarleistung.Summe-Solar-kwh"
        2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.Summe-Solar-kwh successfully
        2024-04-16 21:14:20.982  - info: sourceanalytix.0 (4060) Initialising (29 of 34) "javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt"
        2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHSW-25#ECFABCC49C48#1.Relay0.gesamt successfully
        2024-04-16 21:14:21.914  - info: sourceanalytix.0 (4060) Initialising (30 of 34) "linkeddevices.0.Solarleistung.open-DTU-612W"
        2024-04-16 21:14:22.613  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Solarleistung.open-DTU-612W successfully
        2024-04-16 21:14:22.614  - info: sourceanalytix.0 (4060) Initialising (31 of 34) "javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt"
        2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.shellyplus1pm#4855199d4330#1.Relay0.gesamt successfully
        2024-04-16 21:14:23.863  - info: sourceanalytix.0 (4060) Initialising (32 of 34) "javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt"
        2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHEM-3#C45BBE783E1A#1.Total.gesamt successfully
        2024-04-16 21:14:24.861  - info: sourceanalytix.0 (4060) Initialising (33 of 34) "linkeddevices.0.Gesamt"
        2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialization of linkeddevices.0.Gesamt successfully
        2024-04-16 21:14:25.916  - info: sourceanalytix.0 (4060) Initialising (34 of 34) "javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt"
        2024-04-16 21:14:27.233  - info: sourceanalytix.0 (4060) Initialization of javascript.0.ShellyVerbrauch.SHPLG-S#E868E7C38CAD#1.Relay0.gesamt successfully
        2024-04-16 21:14:27.245  - warn: sourceanalytix.0 (4060) Cannot handle calculations for 1 of 34 enabled states, check error messages
        2024-04-16 21:14:27.245  - info: sourceanalytix.0 (4060) Successfully activated SourceAnalytix for 33 of 34 states, will do my Job until you stop me!
        2024-04-16 21:14:58.300  - error: daikin.0 (3782) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
          CPU threads: 4
          Irgendwas haut dir da aber auch die Load in ungesunde Bereiche. Bei 4 ist die Kiste dicht.
          Ausschalten:
          Boot Target: graphical.target
          sudo systemctl set-default multi-user.target
          Das Dateisystem droht dir auch in absehbarer Zeit vollzulaufen:
          Trag im zigbee-Adapter statt /dev/ttyUSB0
          besser
          ein.
          Und meld dich NICHT als root an.
          Hier läuft eine root shell:
          Mach es einfach nicht.
          Und bring die Adapter auf Stand.
            @thomas-braun said in Sporadische Neustarts des iobroker:
            also Zigbee läuft nicht mehr, habe zurückgestellt.
            Starting zigbee-herdsman problem : "Error: Permission denied, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0"
              Thomas Braun Most Active @m.schalk last edited by Thomas Braun
              Und welche Rechte wären erforderlich?
              ls -la /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
              Kann aber auch mit dem Container zusammenhängen. Die Dinger ticken ja anders.
                @thomas-braun root 🙂
                1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                  @m-schalk
                  Und den wichtigsten Part hast unterschlagen. Die Rechte stehen ganz am Anfang.
                  So soll das aussehen:
                  echad@chet:/opt/iobroker $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                  lrwxrwxrwx 1 root root 13 Apr  8 17:19 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                    ---------- 1 root root 0 Apr 16 20:52 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
                      @m-schalk
                      Ja, das hat mit dem Durchreichen in den Container zu tun. Hab ich aber keine Ahnung von.
                        @thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Chassis: container
                          Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                         22:13:26 up  1:20,  2 users,  load average: 5.88, 4.78, 4.63
                        CPU threads: 4
                                       Local time: Tue 2024-04-16 22:13:26 CEST
                                   Universal time: Tue 2024-04-16 20:13:26 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        mario
                        /home/mario
                        mario sudo iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            8.2G        4.0G        1.9G        0.0K        2.3G        4.2G
                        Total:           15G        4.0G        9.6G
                                 8192 M total memory
                                 4020 M used memory
                                  844 M active memory
                                 5138 M inactive memory
                                 1879 M free memory
                                    0 M buffer memory
                                 2292 M swap cache
                                 7759 M total swap
                                    0 M used swap
                                 7759 M free swap
                        *** FILESYSTEM ***
                        /dev/loop0     ext4    26G   21G  4.6G  82% /
                        tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
                        /var:
                        4.0G    /var/
                        2.8G    /var/log
                        781M    /var/lib
                        USB-Devices by-id:
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: redis
                        States  type: redis
                        admin:          6.17.3
                        javascript:     8.0.3
                        Adapter State
                        + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
                        + instance is alive
                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                        Objects and States
                        Objects:        49451
                        States:         42960
                        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                        Hit:3 https://apt.grafana.com stable InRelease
                        Pending Updates: 0
                        udp        0      0 0.0.0.0:55014           0.0.0.0:*                           1000       135249274  3917/io.shelly.0
                        2024-04-16 21:49:27.283  - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.285  - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.287  - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.289  - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router)
                        2024-04-16 21:49:27.291  - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router)
                        2024-04-16 21:49:27.294  - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
                        2024-04-16 21:49:27.297  - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router)
                        2024-04-16 21:49:27.298  - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router)
                        2024-04-16 21:49:27.306  - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-04-16 21:49:27.308  - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                        2024-04-16 21:49:27.309  - info: zigbee.0 (13050) Zigbee started
                        2024-04-16 21:49:27.379  - info: zigbee.0 (13050) debug devices set to []
                        2024-04-16 21:49:35.454  - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160
                        2024-04-16 21:49:35.812  - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
                        2024-04-16 21:50:03.153  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01
                        2024-04-16 21:59:03.751  - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                        2024-04-16 21:59:03.864  - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                        2024-04-16 21:59:03.874  - info: feiertage.0 (14906) all objects written
                        2024-04-16 21:59:03.883  - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason
                        2024-04-16 22:00:09.226  - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19
                        2024-04-16 22:00:09.729  - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024
                        2024-04-16 22:00:09.875  - info: feiertage.0 (15092) all objects written
                        2024-04-16 22:00:09.889  - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason
                        2024-04-16 22:00:21.817  - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ...
                        2024-04-16 22:06:45.998  - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
                          Wenn die Kiste jetzt nicht stabiler läuft:
                          Ich vermute hier ein Skript, das ungünstig angelegt wurde.
                            @thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
                            Thomas Braun ? 2 Replies Last reply Reply Quote 0
                              @m-schalk
                              Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
                                @thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
                                  @m-schalk
                                  Ich auch nicht.
                                    A Former User @m.schalk last edited by
                                    oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
                                    Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
                                    Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
                                      @thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
                                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.475  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                         at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                                         at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                      2024-04-19 21:30:47.823  - error: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.829  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.833  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.835  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.841  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.843  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.846  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.850  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.851  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.855  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.859  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.861  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.862  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.864  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.866  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.869  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.870  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.872  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.875  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.876  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.877  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.879  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.881  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.884  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.886  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.887  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.888  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.889  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.892  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.893  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.894  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.897  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.899  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.901  - error: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                      2024-04-19 21:30:47.831  - error: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
                                        m.schalk @Thomas Braun last edited by m.schalk
                                        @thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
                                        der Logfile ist 35Mb groß
                                        2024-04-19 21:31:36.745  - error: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                                        2024-04-19 21:31:36.745  - error: javascript.0 (499664) Error: write EPIPE
                                            at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                                            at writeGeneric (node:internal/stream_base_commons:151:3)
                                            at Socket._writeGeneric (node:net:962:11)
                                            at Socket._write (node:net:974:8)
                                            at writeOrBuffer (node:internal/streams/writable:392:12)
                                            at _write (node:internal/streams/writable:333:10)
                                            at Socket.Writable.write (node:internal/streams/writable:337:10)
                                            at console.value (node:internal/console/constructor:305:16)
                                            at console.warn (node:internal/console/constructor:385:26)
                                            at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
                                          A Former User last edited by
                                          @m-schalk
                                          Dann schau mal in das Redis log, da stimmt was nicht..
                                            Irgendwas mit redis. Und/oder mit dem Dateisystem vielleicht.
                                            902
