    4. jarvis v3.1.x - just another remarkable vis
      Thomas Braun Most Active @MCU last edited by
      @mcu sagte in jarvis v3.1.x - just another remarkable vis:
      Aber auch hier wird nur iobroker runter gefahren, sudo reboot wird nicht mehr ausgeführt.
      Bei einem Aufruf via EXEC aus dem javascript-Adapter? Ja, ist klar, das geht so nicht.
        MCU last edited by
        @thomas-braun Wäre das ein sauberer Neustart?
        4 Sekunden bis zum Neustart
        .... jede Menge weiterer Log-Einträge zum Neustart
        2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
        2024-04-17 20:11:03.023 - warn: host.iobrokerPROD instance system.adapter.telegram.0 terminated due to SIGTERM
        2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.telegram.0 terminated with code null ()
        2024-04-17 20:11:03.023 - warn: host.iobrokerPROD instance system.adapter.pushover.0 terminated due to SIGTERM
        2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.pushover.0 terminated with code null ()
        2024-04-17 20:11:03.023 - warn: host.iobrokerPROD instance system.adapter.telegram.1 terminated due to SIGTERM
        2024-04-17 20:11:03.023 - info: host.iobrokerPROD instance system.adapter.telegram.1 terminated with code null ()
        2024-04-17 20:11:03.024 - warn: host.iobrokerPROD instance system.adapter.zigbee.0 terminated due to SIGTERM
        2024-04-17 20:11:03.024 - info: host.iobrokerPROD instance system.adapter.zigbee.0 terminated with code null ()
        2024-04-17 20:11:03.026 - info: host.iobrokerPROD instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2024-04-17 20:11:03.026 - info: host.iobrokerPROD instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
        2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.sonoff.0 terminated due to SIGTERM
        2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.sonoff.0 terminated with code null ()
        2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.ping.0 terminated due to SIGTERM
        2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.ping.0 terminated with code null ()
        2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.web.0 terminated due to SIGTERM
        2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.web.0 terminated with code null ()
        2024-04-17 20:11:03.027 - warn: host.iobrokerPROD instance system.adapter.echarts.0 terminated due to SIGTERM
        2024-04-17 20:11:03.027 - info: host.iobrokerPROD instance system.adapter.echarts.0 terminated with code null ()
        2024-04-17 20:11:05.405 - info: meross.0 (361) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-04-17 20:11:05.963 - info: host.iobrokerPROD instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-04-17 20:11:05.963 - info: host.iobrokerPROD All instances are stopped.
        2024-04-17 20:11:06.043 - info: host.iobrokerPROD terminated
        ... NEUSTART
        2024-04-17 20:11:10.156 - info: host.iobrokerPROD iobroker.js-controller version 5.0.19 js-controller starting
        2024-04-17 20:11:10.158 - info: host.iobrokerPROD Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2024-04-17 20:11:10.158 - info: host.iobrokerPROD hostname: iobrokerPROD, node: v18.20.2
        2024-04-17 20:11:10.158 - info: host.iobrokerPROD ip addresses: 192.168.178.150 fe80::10:40ff:fe11:7741
        2024-04-17 20:11:11.108 - info: host.iobrokerPROD connected to Objects and States
        2024-04-17 20:11:11.123 - info: host.iobrokerPROD added notifications configuration of host
        2024-04-17 20:11:11.461 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.nodeCurrent"
        2024-04-17 20:11:11.461 - info: host.iobrokerPROD 57 instances found
        2024-04-17 20:11:11.476 - info: host.iobrokerPROD starting 47 instances
        2024-04-17 20:11:11.513 - info: host.iobrokerPROD instance system.adapter.admin.0 started with pid 176
        2024-04-17 20:11:11.555 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.nodeNewest"
        2024-04-17 20:11:11.556 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.nodeNewestNext"
        2024-04-17 20:11:11.557 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.npmCurrent"
        2024-04-17 20:11:11.557 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.npmNewest"
        2024-04-17 20:11:11.558 - info: host.iobrokerPROD Delete state "system.host.iobrokerPROD.versions.npmNewestNext"
        2024-04-17 20:11:11.559 - info: host.iobrokerPROD Some obsolete host states deleted.
        2024-04-17 20:11:12.212 - info: admin.0 (176) starting. Version 6.17.3 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.2, js-controller: 5.0.19
        Ich habe es über einen Dateieintrag gemacht.
        Es läuft ein bash-Script welches alle 30 Sekunden den Inhalt prüft.
        Passt der Inhalt wird zuerst iobroker gestoppt und dann neu gestartet.
        Problem man muss in der bash-Datei das Passwort vom User angeben. Da man sonst immer nach dem Passwort gefragt wird. Sicher?
          Wie sieht das Skript denn konkret aus?
          Sicherheit ist halt relativ. Du könntest ja z. B. die Rechte an der Datei einschränken. Hab ich z. B. mit der Datei, die die Passwörter für eine smb-Freigabe beinhaltet so eingestellt:
          -rw-r----- 1 iobroker iobroker 38 Oct 19 20:16 /home/iobroker/.smbcredentials
            MCU @Thomas Braun last edited by MCU
            @thomas-braun bash script
            #!/bin/bash
            # Pfad zur Datei, deren Inhalt   berpr  ft werden soll
            datei="/opt/iobroker/iobroker-data/files/0_userdata.0/restart.txt"
            #  ^|berpr  fe den Inhalt der Datei
            if [ -f "$datei" ]; then
                inhalt=$(cat "$datei")
                if [ "$inhalt" = "trigger_reboot" ]; then
                    echo "Reboot wird durchgefuehrt..."
                    neuer_inhalt="kein Reboot"
                    sed -i "1s/.*/$neuer_inhalt/" "$datei"
                    iobroker stop
                    echo "DEIN PASSWORT" | sudo -S reboot
                else
                    echo "Neustart nicht erforderlich. Inhalt der Datei: $inhalt"
                fi
            else
                echo "Datei nicht gefunden: $datei"
            fi
            crontab
            * * * * * bash /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.sh >> /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.log 2>&1
            * * * * * sleep 30; bash /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.sh >> /opt/iobroker/iobroker-data/files/0_userdata.0/checkFile.log 2>&1
              @mcu
              Müsste gehen. Wobei ich kein Freund von Crontabs bin. Ich würde eher via inotify schauen ob sich die Datei geändert hat und das als Trigger verwenden.
                @thomas-braun sagte in jarvis v3.1.x - just another remarkable vis:
                inotify
                Wie überwacht man da die Änderung? Wo muss man es eintragen?
                  @mcu
                  Guckstu Wiki von Schnubbibuntu:
                  https://wiki.ubuntuusers.de/inotify/
                    Thomas Braun Most Active @MCU last edited by Thomas Braun
                    @mcu
                    Andere Alternative: Per systemd
                    https://wiki.ubuntuusers.de/systemd/Path_Units/
                    Gefällt mir eigentlich sogar noch besser. Da brauchste im javascript nur sowas wie EXEC touch /pfad/zur/ueberwachtendatei/reboot und schaust mit der PathUnit ob reboot angelegt wurde und in der Unit löschst du die Datei wieder und startest die Kiste neu.
                      @Flowski Habe es nochmal geändert. Jetzt wird erst iob stop und dann sudo reboot ausgeführt.
                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./rebootsystem
                        Flowski @MCU last edited by
                        @mcu vielen Dank werde ich bei Gelegenheit Mal testen. VG
                          sixum last edited by
                          Wie kann man es eigentlich deaktivieren, dass auf dem Smartphone per Doppelklick gezoomt bzw Vollbild genommen wird?
                            MCU last edited by MCU
                            @sixum Welche Version?
                            "Gar nicht", da es versionsabhängig ist.
                            Es gibt aber zurzeit keine fehlerfreie Version mit allen Modulen.
                            Dies hängt davon ab, welche Module man nutzt.
                            Muss man sich selber durchtesten.
                            v3.1.8 bzw v3.1.9-beta.2 sind die "besten" Versionen.
                            v3.2.0-beta.10 -> kein Doppelklick Problem mehr, aber andere siehe Issues
                              sixum @MCU last edited by
                              @mcu habe 3.1.8. Extrem nervig das ganze 😄
                              • U
                                UncleB last edited by
                                Kann sein das aktuell bei Jarvis nix mehr passiert, ich hab leider das letzte Update vor 2 Wochen gemacht, seit dem kann ich Jarvis nicht mehr nutzen, die Seite lädt ständig neu..
                                  MCU @UncleB last edited by MCU
                                  @uncleb Cache löschen.
                                  Und Signatur prüfen
                                  https://github.com/Zefau/ioBroker.jarvis/issues/2613
                                  SlipKoRn88 created this issue in Zefau/ioBroker.jarvis
                                  closed 3.2.0 beta9 Seite läd ununterbrochen neu #2613
                                  • U
                                    UncleB @MCU last edited by
                                    @mcu und wie setzt man eine LEERE signature property manuell?
                                      @uncleb Auf den Wert klicken und dann nochmal in den Editor klicken und nach der Version
                                      die signature einfügen
                                      "signature": 1234,
                                      • U
                                        @mcu said in jarvis v3.1.x - just another remarkable vis:
                                        "signature": 1234,
                                        Auf deinem Video erkenne ich zu wenig, sehe nichtmal wo du hinklickst 😖
                                          @uncleb Klick mal auf das Video dann wird es größer.
                                          Ich klicke nach dem Komma hinter Version.
                                          • U
                                            @mcu ich seh aber nicht auf welchen DP du klickst,
                                            sieht bei mir alles anders aus. Abe rich gebs eh auf für heute.
                                            Danke fürs helfen, ich guck morgen nochmal
                                            92
                                            1819
                                            684329
