    4. Neue stable Versionen der Adapter: web, socketio und ws
      sigi234 Forum Testing Most Active @tobiasp last edited by
      @tobiasp sagte in Neue stable Versionen der Adapter: web, socketio und ws:
      @sigi234
      ja durchaus
      Objekt ID's in den Views checken, und ev. bindings wie @mcm57 schrieb .
        liv-in-sky @tobiasp last edited by
        @tobiasp probier mal
        auf console
        cd /opt/iobroker/iobroker-data/files/vis.0
         grep -r -i "hue.0.Philips_hue"
        damit solltest du das finden
          tobiasp @liv-in-sky last edited by
          @liv-in-sky
          danke erstmal. Das kommt jetzt raus. Wie finde ich es dann?
          pi@raspberrypi:/opt/iobroker/iobroker-data/files/vis.0 $  grep -r -i "hue.0.Philips_hue"
          main/vis-views.json:          "lc-oid": "hue.0.Philips_hue.Hue_lightstrip_Küche.on",
          main/vis-views.json:          "lc-oid": "hue.0.Philips_hue.Schlafzimmer.on",
          main/vis-views.json:          "lc-oid": "hue.0.Philips_hue.Bad.on",
          main/vis-views.json:          "lc-oid": "hue.0.Philips_hue.Büro.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_lightstrip_Küche.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_Schlafzimmer.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Küche_Sensor.presence",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Bad.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Schlafzimmer.level",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_lightstrip_Küche.level",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Bad.level",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_Spot_1.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_Spot_2.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Büro.on",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_Spot_2.level",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Büro.level",
          main/vis-views.json:          "oid": "hue.0.Philips_hue.Hue_Spot_1.level",
          main/vis-views.json:          "visibility-oid": "hue.0.Philips_hue.Küche_Sensor.presence",
            tobiasp @tobiasp last edited by
            @tobiasp
            Danke gefunden
            war eecht ein Symbol das ich nicht gesehen habe.
            vielen Dank
              liv-in-sky @bahnuhr last edited by
              @bahnuhr
              habe das ganze nicht im detail mitbekommen - geht es eigentlich um bestimmte widgets oder querbeet
                trojanhector last edited by
                ich habe ein Raspi Pi 5 mit 8 GB und iobroker komplett neu aufgesetzt.
                Ich bekomme den vis-2 Editor nicht geöffnet. Je nach Konfiguration des Web-Adapters erhalte ich entweder eine weiße Seite oder das iobroker Symbol dreht sich ständig.
                Ich habe beobachtet, dass das nach dem Anlegen eines Projektes passiert. Das gleiche Verhalten habe ich auf meiner alten Installation mit Raspi 4. Hier konnte ich die vis-2 nur einmal am Anfang zum laufen bringen. Nach der Neuanlage eines Projektes und nach dem Neustart des Browsers, incl. Cache leeren, erschien nur eine weiße Seite. Hier half immer nur ein Restore. Habe die verschienen Konfigurationen hier aus dem Forum ohne Erfolg ausprobiert auch die letzte Version von Ro75. Das System ist auf dem aktuellen Stand und iob diag zeigt keine Fehler.
                Hat jemand eine Idee?
                  apollon77 @trojanhector last edited by
                  @trojanhector Siehst du irgendwelche Fehler in der Browser Konsole?
                    @apollon77
                    Habe gerade nochmal ein iob diag laufen lassen. Kann keine Errors erkennen.
                    Pending OS-Updates: 0
                    Pending iob updates: 0
                    Nodejs-Installation: /usr/bin/nodejs v18.20.2
                    /usr/bin/node v18.20.2
                    /usr/bin/npm 10.5.0
                    /usr/bin/npx 10.5.0
                    /usr/bin/corepack 0.25.2
                    Active iob-Instances: 22
                    Active repo(s): stable
                    ioBroker Core: js-controller 5.0.19
                    admin 6.13.16
                    • BananaJoe
                      BananaJoe Most Active @trojanhector last edited by BananaJoe
                      @trojanhector wenn du die Seite aufrufst, also den Editor im Webbrowser, drücke mal F12 und Öffne die Entwicklerkonsole.
                      Da gibt es eine Ansicht "Konsole". Ob und welche Fehlermeldungen dort zu sehen sind wollte @apollon77 wohl wissen (bodenlose Unterstellung durch mich)
                      Beispiel:
                      geht natürlich dann nur auf einem PC, nicht vom Handy oder Tablet aus
                      T OliverIO 2 Replies Last reply Reply Quote 2
                        trojanhector @BananaJoe last edited by Homoran
                        @bananajoe
                        @apollon77
                        Okay, verstanden. Damit kommen auch zweiFehlermeldungen raus.
                        Mein Browser ist Firefox, aber es geht auch auf Chrome oder Edge nicht.
                        TypeError: o.___settings is undefined
                            _ utils.tsx:224
                            children Runtime.jsx:920
                            showSmallProjectsDialog Runtime.jsx:919
                            render App.jsx:1866
                            React 8
                            V scheduler.production.min.js:13
                            j scheduler.production.min.js:14
                        console.ts:40:19
                        Uncaught TypeError: o.___settings is undefined
                            _ utils.tsx:224
                            render App.jsx:1866
                            React 8
                        utils.tsx:224:21
                            _ utils.tsx:224
                            map self-hosted:221
                            render App.jsx:1866
                            React 8
                          @trojanhector Dann am besten bitte mal ein eGitHub Issue anlegen mit dem Fehler. Muss einer der Vis Devs reinschauen
                          • OliverIO
                            OliverIO @BananaJoe last edited by OliverIO
                            @bananajoe sagte in Neue stable Versionen der Adapter: web, socketio und ws:
                            für android basierte geräte geht das ebenfalls.
                            man muss das gerät in den entwicklermodus bringen
                            und das externe debugging aktivieren.
                            danach kann man mit einem beliebigen chrome auf einem PC über die url
                            chrome://inspect
                            die ip adresse des zu debuggenden geräts konfigurieren.
                            im anschluss sollte dann das gerät angezeigt werden.
                            bei klick auf die session öffnet sich eine developer console von chrome, die direkt in den browser des anderen geräts schaut. inklusive aller fehlermeldungen etc.
                            ist aber eher etwas für die fortgeschrittenen
                            https://learn.microsoft.com/de-de/microsoft-edge/devtools-guide-chromium/remote-debugging/
                            (bei edge heißt die seite dann edge://inspect)
                            da ios basierte geräte die webkomponente von safari nutzt geht das dort nicht
                              ralalla last edited by ralalla
                              Verschoben, da im falschen Thread geschrieben.
                              • mcm1957
                                mcm1957 @ralalla last edited by mcm1957
                                @ralalla said in Neue stable Versionen der Adapter: web, socketio und ws:
                                Habe ein Problem mit der vis 2. Kann den Editor in Chrome öffnen.
                                Im Firefox bleibt das Bild jedoch leer.
                                Kann hiermit jemand was anfangen?
                                Hast du dieses Topic zufällig ausgewählt?
                                Oder hast du einen Verdacht dass web / socketio / ws an dem Verhalten Schuld sein könnten?
                                Ich würd dir eher die Suchfunktion und diesen Thread empfehlen:
                                https://forum.iobroker.net/topic/75772/vis2-editor-wird-nicht-angezeigt
                                  ralalla @mcm1957 last edited by
                                  @mcm1957
                                  Stimmt, da sollte das auch hin. Hatte beide Themen offen und den Text falsch eingefügt.
                                  133
                                  16792
