    4. Test Adapter TrashSchedule
      australien @haus-automatisierung last edited by
      das sieht so aus
      Zeit
      Nachricht
      trashschedule.0
      	2024-03-12 12:39:01.826	debug	re-creating refresh timeout in 1263174ms (in 00:21:03)
      trashschedule.0
      	2024-03-12 12:39:01.826	debug	(0) [ical] update started by foreign state value - lc: 2023-12-30T23:00:19.626Z - ts: 2024-03-12T11:30:05.702Z
      trashschedule.0
      	2024-03-12 12:39:01.704	debug	[ical] found ical event(s): {"name":"Leichtverpackungen","enabled":true,"id":"","on":"","off":"","ack":false,"display":true}
      trashschedule.0
      	2024-03-12 12:39:01.703	debug	[ical] found ical event(s): {"name":"Papierbehälter","enabled":true,"id":"","on":"","off":"","ack":false,"display":true}
      trashschedule.0
      	2024-03-12 12:39:01.703	debug	[ical] found ical event(s): {"name":"Restabfallbehälter","enabled":true,"id":"","on":"","off":"","ack":false,"display":true}
      trashschedule.0
      	2024-03-12 12:39:01.703	info	[ical] configurured ical preview is 60 days (until 11.05.2024) - increase this value to find more events in the future
      trashschedule.0
      	2024-03-12 12:39:01.702	debug	[ical] current ical version: 1.13.3
      trashschedule.0
      	2024-03-12 12:39:01.694	debug	found configured trash type: "Leichtverpackungen" with ID "type.leichtverpackungen"
      trashschedule.0
      	2024-03-12 12:39:01.689	debug	found configured trash type: "Papierbehälter" with ID "type.papierbehälter"
      trashschedule.0
      	2024-03-12 12:39:01.681	debug	found configured trash type: "Restabfallbehälter" with ID "type.restabfallbehälter"
      trashschedule.0
      	2024-03-12 12:39:01.681	debug	found existing trash type with ID "type.leichtverpackungen"
      trashschedule.0
      	2024-03-12 12:39:01.680	debug	found existing trash type with ID "type.papierbehälter"
      trashschedule.0
      	2024-03-12 12:39:01.680	debug	found existing trash type with ID "type.restabfallbehälter"
      trashschedule.0
      	2024-03-12 12:39:01.568	info	starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.19.1, js-controller: 5.0.19
      trashschedule.0
      	2024-03-12 12:39:01.388	debug	Plugin sentry Initialize Plugin (enabled=true)
      trashschedule.0
      	2024-03-12 12:38:57.093	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      	2024-03-12 12:38:57.093	debug	Plugin sentry destroyed
      trashschedule.0
      	2024-03-12 12:38:57.093	info	terminating
      trashschedule.0
      	2024-03-12 12:38:57.093	debug	clearing refresh timeout
      trashschedule.0
      	2024-03-12 12:38:57.092	info	cleaned everything up...
      trashschedule.0
      	2024-03-12 12:38:57.092	info	Got terminate signal TERMINATE_YOURSELF
      • haus-automatisierung
        haus-automatisierung Developer Most Active @australien last edited by
        @australien Zeig mal den Inhalt von ical.0.data.table
          australien @haus-automatisierung last edited by australien
          mehr ist da nicht drinnen, habe ich übrigends in allen meiner 3 ical instanzen.
            @australien Dann ist das der Grund. Sorry für die fehlende Meldung in 3.2.0, dass keine Termine existieren. Reiche ich nach.
            iCal-Konfiguration checken.
            • MartinP
              MartinP @haus-automatisierung last edited by
              @haus-automatisierung said in Test Adapter TrashSchedule:
              Konfiguration
              Gelöscht. Bitte die aktuelle Doku nutzen: https://github.com/klein0r/ioBroker.trashschedule/blob/master/docs/de/basics.md
              (Zitat aus dem Thread-Eröffnungs-Beitrag.) Da liegt nichts mehr...
                haus-automatisierung Developer Most Active @MartinP last edited by
                @martinp sagte in Test Adapter TrashSchedule:
                Von 2019 🙂 Danke, ist korrigiert. Zur Doku kommt man aber eh immer am besten über den Admin. Foren-Posts kann ich leider nicht immer alle pflegen und aktuell halten.
                Michael Schmitt 1 Reply Last reply Reply Quote 0
                  Danke für deine Hilfe, die ics Datei war korrupt.
                  Jetzt passt wieder alles.
                  • Michael Schmitt
                    Michael Schmitt @haus-automatisierung last edited by
                    und was macht man nun wenn man diese Einträge auf einmal hat ?
                    trashschedule.0
                    2024-03-19 17:54:36.744	info	Setting "actionNeeded" flag for type.restmülltonne.actionNeeded to true (???)
                    trashschedule.0
                    2024-03-19 17:54:36.721	info	Setting "actionNeeded" flag for type.gelberSack.actionNeeded to true (???)
                      haus-automatisierung Developer Most Active @Michael Schmitt last edited by
                      @michael-schmitt Nix erstmal. Ignorieren
                      • Merlin123
                        Merlin123 last edited by
                        Vis-2: Widget verschwindet manchmal
                        Hab das ein ganz komisches Phänomen:
                        Das Widget geht eigentlich in der Vis2 ganz gut. Aber manchmal ist es auf dem Tablet einfach verschwunden. Ist auf meiner Startseite, da fällt das auf.
                        Manchmal erscheint es wieder, wenn die die Seite neu lade, manchmal muss ich es einen Pixel verschieben.
                        Da ich im Moment viel an der Vis baue, weiß ich nicht, ob es daher irgendwie kommt oder ne andere Ursache hat.
                        Es wird nicht durch was anderes überlagert und es ist immer sichtbar.
                        Hat das noch jemand oder ne Idee, wie ich das verhindern kann?
                        S Xsev 2 Replies Last reply Reply Quote 0
                          schneidy76 @Merlin123 last edited by
                          @merlin123 schau mal hier: https://github.com/klein0r/ioBroker.trashschedule/issues/193
                          schneidy76 created this issue in klein0r/ioBroker.trashschedule
                          open VIS widget not working in VIS 2 (beta) #193
                          • Xsev
                            Xsev @Merlin123 last edited by Xsev
                            @merlin123 Bei mir ist das Widget in Vis2 nur dann sichtbar sobald ich einmal die Seite wechsle. Ich habs auch auf der Startseite, beim ersten laden ist es nicht sichtbar sobald ich einmal eine andere Seite lade (innerhalb dem Vis Projekt) und wieder auf die Startseite zurück gehe, ist es da. Dann bleibt es bei mir auch sichtbar und verschwindet nicht mehr bis ich Vis neu lade.
                            • Merlin123
                              Merlin123 @Xsev last edited by
                              @xsev Kann auch sein, dass es nach nem Umschalten weg ist... Muss ich mal drauf achten.
                              • Merlin123
                                Merlin123 @schneidy76 last edited by
                                @schneidy76 Ah ok. Danke... ich wusste, dass ein neues Widget gemacht werden sollte, aber nicht, dass es so seltsame Anzeigeprobleme gibt.
                                  Siggi0904 last edited by
                                  @haus-automatisierung ich hätte gern zwei Erweiterungswünsche.
                                  Für die Jahresabrechnung benötige die wirklich abgeholten Mülltonnen je Müllart.
                                  Denn gerade der Restabfall wird ja je Tonne berechnet.
                                  Könntest du einen Zähler einbauen, z.b. der completed entsprechend zählt?
                                  Eine Option als Gegenteil zum completed wäre toll.
                                  Wir stellen z.B. nicht bei jedem Termin die Tonne raus, der Termin schlägt aber natürlich trotzdem auf.
                                  Wenn es eine Option gäbe der z.B. "nicht benötigt" heißen würde, je Müllsorte.
                                  So kann man entsprechend vorher quasi die Müllabholung abwählen, da nicht benötigt.
                                  Ich hoffe, meine Wünsche waren verständlich.
                                  Dank dir.
                                    haus-automatisierung Developer Most Active @Siggi0904 last edited by
                                    @siggi0904 Puh, ich finde das jetzt schon alles zu kompliziert mit den ganzen Abläufen. Irgendwann sieht ja niemand mehr durch.
                                    Schreibst Du die Doku dafür? Dann könntet wir drüber reden
                                      Siggi0904 @haus-automatisierung last edited by
                                      @haus-automatisierung kann ich die Doku hier schreiben oder muss das im GIT erfolgen?
                                      Aber ich würde gern mehr am Doku Teil unterstützen, nur ist das mit dem Forken etc. immer sehr nervig,für jemanden der eigentlich keine Repo auf Github führt.
                                      Wie machst du oder die anderen das denn, wenn die Tonne nicht raus gestellt werden muss?
                                      haus-automatisierung DJMarc75 2 Replies Last reply Reply Quote 0
                                        @siggi0904 sagte in Test Adapter TrashSchedule:
                                        Den Fall habe ich nicht. Kommt immer raus wenn der Termin drin steht
                                        • DJMarc75
                                          DJMarc75 @Siggi0904 last edited by
                                          Mal so am Rande: Wir haben eine Jahresmarke auf der Tonne kleben und da ist es Wurscht ob ich die raus stelle oder nicht. Wir zahlen einmalig für die Marke.
                                            @haus-automatisierung wie ich das aktuell im Adapter mit aktueller Stable-Version sehe,
                                            sind ja alle Text zu übersetzen.
                                            Da könnte ich mal eine einleitende Hilfe benötigen zur Übersetzung.
                                            Z.B. auch, wenn an dem Datenwert z.B. "14 days" steht, wie man daraus "14 Tage" macht.
                                            Bei mir werden alle Beschreibungen auf englisch angezeigt.
                                            Was ist eigentlich der Unterschied zwischen trashschedule.0.nextAfter.types und trashschedule.0.nextAfter.typesText? das sind doch beides Texte und sehen spontan identisch aus.
                                            haus-automatisierung 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            454435
