    4. keine Adapter mehr installieren /Updaten
      Thomas Braun Most Active @Farmer-cb last edited by
      @farmer-cb sagte in keine Adapter mehr installieren /Updaten:
      root@iobroker
      Nicht als root herumhampeln...
        Farmer-cb @Thomas Braun last edited by Farmer-cb
        hab ich verschlafen... jetzt umgestellt
        iob diag sagt:
        iob diag (neues system) sagt folgendes:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 5.15.131-2-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         17:33:28 up 31 min,  2 users,  load average: 0.41, 0.53, 0.70
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Thu 2024-04-18 17:33:28 CEST
                   Universal time: Thu 2024-04-18 15:33:28 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        Farmer
        /home/Farmer
        Farmer sudo users
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            4.3G        105M        3.5G        139K        733M        4.2G
        Swap:           4.3G        106K        4.3G
        Total:          8.6G        105M        7.8G
                 4096 M total memory
                  100 M used memory
                  266 M active memory
                  458 M inactive memory
                 3295 M free memory
                    0 M buffer memory
                  699 M swap cache
                 4096 M total swap
                    0 M used swap
                 4095 M free swap
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        * iobroker.service        loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--101--disk--0 ext4       16G  2.1G   13G  14% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
        tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     782M     0  782M   0% /run/user/0
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
        /var:
        479M    /var/
        250M    /var/cache
        246M    /var/cache/apt
        197M    /var/lib
        170M    /var/cache/apt/archives
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        22M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        15M     /opt/iobroker/iobroker-data/files
        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
        652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
        384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.2
        /usr/bin/node           v18.20.2
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.2-1nodesource1
          Candidate: 18.20.2-1nodesource1
          Version table:
         *** 18.20.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security stable-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian stable/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          "admin" not found
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Objects and States
        Objects:        142
        States:         76
        Hit:1 http://security.debian.org/debian-security stable-security InRelease
        Hit:2 http://deb.debian.org/debian stable InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          626469319  300/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          626541046  1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          626541048  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          626467646  1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          626469320  300/master
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          626466679  92/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          626541047  1/init
        udp6       0      0 :::111                  :::*                                0          626541049  1/init
        2024-04-18 17:14:10.977  - info: host.iobroker received SIGTERM
        2024-04-18 17:14:10.977  - info: admin.0 (8788) terminating http server on port 8081
        2024-04-18 17:14:10.978  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
        2024-04-18 17:14:10.979  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2024-04-18 17:14:10.979  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
        2024-04-18 17:14:10.982  - info: backitup.0 (8815) Got terminate signal TERMINATE_YOURSELF
        2024-04-18 17:14:10.981  - info: admin.0 (8788) Got terminate signal TERMINATE_YOURSELF
        2024-04-18 17:14:10.982  - info: discovery.0 (8830) Got terminate signal TERMINATE_YOURSELF
        2024-04-18 17:14:10.983  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
        2024-04-18 17:14:10.983  - info: discovery.0 (8830) terminating
        2024-04-18 17:14:10.983  - info: admin.0 (8788) terminating
        2024-04-18 17:14:10.983  - info: backitup.0 (8815) terminating
        2024-04-18 17:14:10.984  - info: admin.0 (8788) Terminated (NO_ERROR): Without reason
        2024-04-18 17:14:10.983  - info: discovery.0 (8830) Terminated (NO_ERROR): Without reason
        2024-04-18 17:14:10.984  - info: backitup.0 (8815) Terminated (NO_ERROR): Without reason
        2024-04-18 17:14:11.029  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
        2024-04-18 17:14:11.029  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
        2024-04-18 17:14:11.479  - info: discovery.0 (8830) terminating
        2024-04-18 17:14:11.481  - info: backitup.0 (8815) terminating
        2024-04-18 17:14:11.481  - info: admin.0 (8788) terminating
        2024-04-18 17:14:11.528  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-04-18 17:14:11.533  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2024-04-18 17:14:11.537  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
        2024-04-18 17:14:11.537  - info: host.iobroker All instances are stopped.
        2024-04-18 17:14:11.650  - info: host.iobroker terminated
                                v.2023-10-10
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1001
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.20.2
                                /usr/bin/npm            10.5.0
                                /usr/bin/npx            10.5.0
        Recommended versions are nodejs 18.20.2 and npm 10.5.0
        MEMORY:
        Mem:            4.3G        107M        3.4G        139K        740M        4.2G
        Total:          8.6G        107M        7.7G
        Active iob-Instances:   1
        ioBroker Core:          js-controller           5.0.19
                                admin                   "admin" not found
        ioBroker Status:        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects:                142
        States:                 76
        Size of iob-Database:
        4.5M    /opt/iobroker/iobroker-data/objects.jsonl
        28K     /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun Most Active last edited by
          • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          • sys-kernel-config.mount loaded failed failed Kernel Configuration File System
          • iobroker.service loaded failed failed ioBroker Server
          Eher ungünstig, wenn der Service nicht gestartet ist.
          sudo systemctl start iobroker.service
          sagt?
            als normaler user darf ich das nicht, muss ich den user in einer besonderen gruppe eintrage
            meldung:
            Farmer@iobroker:/opt/iobroker$ sudo systemctl start iobroker.service
            [sudo] password for Farmer:
            Sorry, user Farmer is not allowed to execute '/usr/bin/systemctl start iobroker.service' as root on iobroker
              @farmer-cb
              Das muss der Farmer (am Rande: Besser usernames in Kleinschreibung) aber können:
              Farmer
              /home/Farmer
              Farmer sudo users
              Hast du den Farmer mal aus- und wieder eingeloggt? Gruppenrechte werden nur beim einloggen neugelesen.
                habs hinbekommen.
                sudo systemctl start iobroker.service erzeugt keine Meldung.
                Aber:
                Farmer@iobroker:~$ sudo systemctl status iobroker.service
                * iobroker.service - ioBroker Server
                     Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                     Active: active (running) since Thu 2024-04-18 18:02:51 CEST; 31s ago
                       Docs: http://iobroker.net
                   Main PID: 1117 (iobroker.js-con)
                      Tasks: 18 (limit: 9301)
                     Memory: 67.8M
                        CPU: 1.134s
                     CGroup: /system.slice/iobroker.service
                             |-1117 iobroker.js-controller
                             `-1130 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js _restart
                Apr 18 18:02:51 iobroker systemd[1]: Started iobroker.service - ioBroker Server.
                Farmer@iobroker:~$ iobroker status
                No connection to states 127.0.0.1:6379[redis]
                Farmer@iobroker:~$
                  @farmer-cb
                  Ist redis installiert?
                  sudo apt update
                  apt policy redis
                    installiert sich das nicht automatisch bei einer iobroker neuinstallation
                    Farmer@iobroker:/opt/iobroker$ sudo apt update
                    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:3 http://deb.debian.org/debian stable InRelease
                    Reading package lists... Done
                    Building dependency tree... Done
                    All packages are up to date.
                    Farmer@iobroker:/opt/iobroker$ apt policy redis
                    redis:
                      Installed: (none)
                      Candidate: 5:7.0.15-1~deb12u1
                      Version table:
                         5:7.0.15-1~deb12u1 500
                      Nein. Wie du siehst nicht. Ist ein Ding vom Betriebssystem und muss vom Administrator manuell hinzugefügt werden. Der ioBroker läuft ja auch in der Voreinstellung nicht mittels redis.
                      Also jetzt
                      sudo apt install redis
                        was ist eigentlich besser, json/redis.....
                        hab redis installiert und restore läuft gerade
                          Hängt von deinem Setup ab.
                          redis braucht viel RAM, ist aber bei einer großen Zahl von States/Objects schneller als jsonl oder file.
                            Guten Morgen
                            Erst einmal vielen vielen Dank für die Unterstützung, jetzt 🏃‍♂️ der iobroker wieder wie 🐖
                            nun zu:
                            @Thomas-Braun
                            sollte ich hier Objects auch auf redis umstellen???
                            errror npm fehler update
                            1128
