Fehlermeldung beim Update vom Admin
Erschien bei mir genauso. Hab's auch einfach ignoriert...
Bekannt?
Nachforschungswürdig? -
@ofbeqnpolkkl6mby5e13 sagte in Fehlermeldung beim Update vom Admin:
Dito
@mcm57
iot-Update lief auch nicht so ganz "sauber" durch:
2024-04-11 21:52:57.184 - [32minfo[39m: host.iobroker iobroker upgrade iot@3.2.2 --debug 2024-04-11 21:53:02.193 - [32minfo[39m: host.iobroker iobroker Update iot from @3.2.0 to @3.2.2 2024-04-11 21:53:02.441 - [32minfo[39m: host.iobroker iobroker host.iobroker Adapter "system.adapter.iot.0" is stopped. 2024-04-11 21:53:02.488 - [32minfo[39m: host.iobroker "system.adapter.iot.0" disabled 2024-04-11 21:53:02.488 - [32minfo[39m: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true) 2024-04-11 21:53:02.494 - [32minfo[39m: host.iobroker stopInstance system.adapter.iot.0 send kill signal 2024-04-11 21:53:02.496 - [32minfo[39m: iot.0 (11842) Got terminate signal TERMINATE_YOURSELF 2024-04-11 21:53:02.502 - [32minfo[39m: iot.0 (11842) terminating 2024-04-11 21:53:02.504 - [32minfo[39m: iot.0 (11842) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-04-11 21:53:02.554 - [32minfo[39m: iot.0 (11842) Connection changed: disconnect 2024-04-11 21:53:02.555 - [32minfo[39m: iot.0 (11842) Connection lost 2024-04-11 21:53:02.557 - [31merror[39m: iot.0 (11842) uncaught exception: Cannot convert undefined or null to object 2024-04-11 21:53:02.561 - [31merror[39m: iot.0 (11842) TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at RemoteAccess.onCloudDisconnect (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:722:29) at DeviceClient.onDisconnect (/opt/iobroker/node_modules/iobroker.iot/main.js:562:22) at DeviceClient.emit (node:events:517:28) at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:797:12) at MqttClient.emit (node:events:529:35) at TLSSocket.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:360:10) at TLSSocket.emit (node:events:529:35) at node:net:350:12 at TCP.done (node:_tls_wrap:657:7) 2024-04-11 21:53:02.563 - [31merror[39m: iot.0 (11842) Cannot convert undefined or null to object 2024-04-11 21:53:03.008 - [32minfo[39m: iot.0 (11842) terminating 2024-04-11 21:53:03.139 - [32minfo[39m: host.iobroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-04-11 21:53:05.065 - [32minfo[39m: host.iobroker iobroker NPM version: 10.5.0 2024-04-11 21:53:05.067 - [32minfo[39m: host.iobroker iobroker Installing iobroker.iot@3.2.2... (System call) 2024-04-11 21:53:29.417 - [32minfo[39m: host.iobroker iobroker changed 1 package in 23s 2024-04-11 21:53:29.418 - [32minfo[39m: host.iobroker iobroker 2024-04-11 21:53:29.420 - [32minfo[39m: host.iobroker iobroker 253 packages are looking for funding run `npm fund` for details 2024-04-11 21:53:33.660 - [32minfo[39m: host.iobroker iobroker Update "system.adapter.iot.0" 2024-04-11 21:53:35.948 - [32minfo[39m: host.iobroker iobroker upload [160] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript 2024-04-11 21:53:35.984 - [32minfo[39m: host.iobroker iobroker upload [150] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/rules/customRuleBlocks.js.map rules/customRuleBlocks.js.map application/json 2024-04-11 21:53:36.379 - [32minfo[39m: host.iobroker iobroker upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml 2024-04-11 21:53:36.433 - [32minfo[39m: host.iobroker iobroker upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml 2024-04-11 21:53:36.466 - [32minfo[39m: host.iobroker iobroker upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml 2024-04-11 21:53:36.497 - [32minfo[39m: host.iobroker iobroker upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml 2024-04-11 21:53:36.526 - [32minfo[39m: host.iobroker iobroker upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml 2024-04-11 21:53:36.557 - [32minfo[39m: host.iobroker iobroker upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml 2024-04-11 21:53:36.597 - [32minfo[39m: host.iobroker iobroker upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml 2024-04-11 21:53:36.624 - [32minfo[39m: host.iobroker iobroker upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml 2024-04-11 21:53:36.654 - [32minfo[39m: host.iobroker iobroker upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml 2024-04-11 21:53:36.657 - [32minfo[39m: host.iobroker iobroker upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml 2024-04-11 21:53:36.660 - [32minfo[39m: host.iobroker iobroker upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml 2024-04-11 21:53:36.663 - [32minfo[39m: host.iobroker iobroker upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml 2024-04-11 21:53:36.666 - [32minfo[39m: host.iobroker iobroker upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml 2024-04-11 21:53:36.669 - [32minfo[39m: host.iobroker iobroker upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml 2024-04-11 21:53:36.676 - [32minfo[39m: host.iobroker iobroker upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml 2024-04-11 21:53:36.684 - [32minfo[39m: host.iobroker iobroker upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml 2024-04-11 21:53:36.690 - [32minfo[39m: host.iobroker iobroker upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml 2024-04-11 21:53:36.696 - [32minfo[39m: host.iobroker iobroker upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml 2024-04-11 21:53:36.701 - [32minfo[39m: host.iobroker iobroker upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml 2024-04-11 21:53:36.709 - [32minfo[39m: host.iobroker iobroker upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml 2024-04-11 21:53:36.725 - [32minfo[39m: host.iobroker iobroker upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml 2024-04-11 21:53:36.729 - [32minfo[39m: host.iobroker iobroker upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml 2024-04-11 21:53:36.749 - [32minfo[39m: host.iobroker iobroker upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml 2024-04-11 21:53:36.755 - [32minfo[39m: host.iobroker iobroker upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml 2024-04-11 21:53:36.757 - [32minfo[39m: host.iobroker iobroker upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml 2024-04-11 21:53:36.761 - [32minfo[39m: host.iobroker iobroker upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml 2024-04-11 21:53:36.782 - [32minfo[39m: host.iobroker iobroker upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml 2024-04-11 21:53:36.792 - [32minfo[39m: host.iobroker iobroker upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain 2024-04-11 21:53:36.797 - [32minfo[39m: host.iobroker iobroker upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain 2024-04-11 21:53:36.806 - [32minfo[39m: host.iobroker iobroker host.iobroker Adapter "system.adapter.iot.0" is started 2024-04-11 21:53:36.832 - [32minfo[39m: host.iobroker "system.adapter.iot.0" enabled 2024-04-11 21:53:36.948 - [32minfo[39m: host.iobroker instance system.adapter.iot.0 started with pid 7831 2024-04-11 21:53:37.867 - [32minfo[39m: host.iobroker iobroker exit 0 2024-04-11 21:53:39.912 - [32minfo[39m: iot.0 (7831) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system 2024-04-11 21:53:40.170 - [32minfo[39m: iot.0 (7831) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.iot, node: v18.20.1, js-controller: 5.0.19
@mcm57 ja issue erstellen auf jeden Fall, gehört so nicht
@foxriver76 sagte in Fehlermeldung beim Update vom Admin:
Heute wieder so bei Update auf 6.17.5 und das Logo Icon wird nicht mehr erkannt.
Ich warte noch ab wegen einer issue ob es nur bei mir so ist.
@sigi234
Ist bei mir auch. -
@sigi234 bitte issue
Bluefox arbeitet derzeit am Admin, wäre gut dass er es sieht
https://github.com/ioBroker/ioBroker.admin/issues/2436
Edit:
Logo wieder da mit v6.17.6 -
Okay, genau das hatte ich eben in meinem Thread erwähnt.
https://forum.iobroker.net/topic/74204/admin-update-6-17-5-thumbnails-hats-zerissen
