    4. Fehlermeldung beim Update vom Admin
    • mcm1957
      mcm1957 @Rene55 last edited by
      @foxriver76
      Bekannt?
      Nachforschungswürdig?
      O foxriver76 2 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13 sagte in Fehlermeldung beim Update vom Admin:
        @rene55
        Erschien bei mir genauso. Hab's auch einfach ignoriert...
        Dito
        • O
          oFbEQnpoLKKl6mbY5e13 @mcm1957 last edited by
          @mcm57
          iot-Update lief auch nicht so ganz "sauber" durch:
          2024-04-11 21:52:57.184  - info: host.iobroker iobroker upgrade iot@3.2.2 --debug
          2024-04-11 21:53:02.193  - info: host.iobroker iobroker Update iot from @3.2.0 to @3.2.2
          2024-04-11 21:53:02.441  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.iot.0" is stopped.
          2024-04-11 21:53:02.488  - info: host.iobroker "system.adapter.iot.0" disabled
          2024-04-11 21:53:02.488  - info: host.iobroker stopInstance system.adapter.iot.0 (force=false, process=true)
          2024-04-11 21:53:02.494  - info: host.iobroker stopInstance system.adapter.iot.0 send kill signal
          2024-04-11 21:53:02.496  - info: iot.0 (11842) Got terminate signal TERMINATE_YOURSELF
          2024-04-11 21:53:02.502  - info: iot.0 (11842) terminating
          2024-04-11 21:53:02.504  - info: iot.0 (11842) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-04-11 21:53:02.554  - info: iot.0 (11842) Connection changed: disconnect
          2024-04-11 21:53:02.555  - info: iot.0 (11842) Connection lost
          2024-04-11 21:53:02.557  - error: iot.0 (11842) uncaught exception: Cannot convert undefined or null to object
          2024-04-11 21:53:02.561  - error: iot.0 (11842) TypeError: Cannot convert undefined or null to object
              at Function.keys (<anonymous>)
              at RemoteAccess.onCloudDisconnect (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:722:29)
              at DeviceClient.onDisconnect (/opt/iobroker/node_modules/iobroker.iot/main.js:562:22)
              at DeviceClient.emit (node:events:517:28)
              at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:797:12)
              at MqttClient.emit (node:events:529:35)
              at TLSSocket.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:360:10)
              at TLSSocket.emit (node:events:529:35)
              at node:net:350:12
              at TCP.done (node:_tls_wrap:657:7)
          2024-04-11 21:53:02.563  - error: iot.0 (11842) Cannot convert undefined or null to object
          2024-04-11 21:53:03.008  - info: iot.0 (11842) terminating
          2024-04-11 21:53:03.139  - info: host.iobroker instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-04-11 21:53:05.065  - info: host.iobroker iobroker NPM version: 10.5.0
          2024-04-11 21:53:05.067  - info: host.iobroker iobroker Installing iobroker.iot@3.2.2... (System call)
          2024-04-11 21:53:29.417  - info: host.iobroker iobroker changed 1 package in 23s
          2024-04-11 21:53:29.418  - info: host.iobroker iobroker
          2024-04-11 21:53:29.420  - info: host.iobroker iobroker 253 packages are looking for funding  run `npm fund` for details
          2024-04-11 21:53:33.660  - info: host.iobroker iobroker Update "system.adapter.iot.0"
          2024-04-11 21:53:35.948  - info: host.iobroker iobroker upload [160] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
          2024-04-11 21:53:35.984  - info: host.iobroker iobroker upload [150] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/rules/customRuleBlocks.js.map rules/customRuleBlocks.js.map application/json
          2024-04-11 21:53:36.379  - info: host.iobroker iobroker upload [100] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
          2024-04-11 21:53:36.433  - info: host.iobroker iobroker upload [90] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
          2024-04-11 21:53:36.466  - info: host.iobroker iobroker upload [80] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
          2024-04-11 21:53:36.497  - info: host.iobroker iobroker upload [70] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
          2024-04-11 21:53:36.526  - info: host.iobroker iobroker upload [60] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
          2024-04-11 21:53:36.557  - info: host.iobroker iobroker upload [50] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
          2024-04-11 21:53:36.597  - info: host.iobroker iobroker upload [40] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
          2024-04-11 21:53:36.624  - info: host.iobroker iobroker upload [30] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
          2024-04-11 21:53:36.654  - info: host.iobroker iobroker upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
          2024-04-11 21:53:36.657  - info: host.iobroker iobroker upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
          2024-04-11 21:53:36.660  - info: host.iobroker iobroker upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
          2024-04-11 21:53:36.663  - info: host.iobroker iobroker upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
          2024-04-11 21:53:36.666  - info: host.iobroker iobroker upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
          2024-04-11 21:53:36.669  - info: host.iobroker iobroker upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
          2024-04-11 21:53:36.676  - info: host.iobroker iobroker upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
          2024-04-11 21:53:36.684  - info: host.iobroker iobroker upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
          2024-04-11 21:53:36.690  - info: host.iobroker iobroker upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
          2024-04-11 21:53:36.696  - info: host.iobroker iobroker upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
          2024-04-11 21:53:36.701  - info: host.iobroker iobroker upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
          2024-04-11 21:53:36.709  - info: host.iobroker iobroker upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
          2024-04-11 21:53:36.725  - info: host.iobroker iobroker upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
          2024-04-11 21:53:36.729  - info: host.iobroker iobroker upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
          2024-04-11 21:53:36.749  - info: host.iobroker iobroker upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
          2024-04-11 21:53:36.755  - info: host.iobroker iobroker upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
          2024-04-11 21:53:36.757  - info: host.iobroker iobroker upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
          2024-04-11 21:53:36.761  - info: host.iobroker iobroker upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
          2024-04-11 21:53:36.782  - info: host.iobroker iobroker upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
          2024-04-11 21:53:36.792  - info: host.iobroker iobroker upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
          2024-04-11 21:53:36.797  - info: host.iobroker iobroker upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
          2024-04-11 21:53:36.806  - info: host.iobroker iobroker host.iobroker Adapter "system.adapter.iot.0" is started
          2024-04-11 21:53:36.832  - info: host.iobroker "system.adapter.iot.0" enabled
          2024-04-11 21:53:36.948  - info: host.iobroker instance system.adapter.iot.0 started with pid 7831
          2024-04-11 21:53:37.867  - info: host.iobroker iobroker exit 0
          2024-04-11 21:53:39.912  - info: iot.0 (7831) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2024-04-11 21:53:40.170  - info: iot.0 (7831) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.iot, node: v18.20.1, js-controller: 5.0.19
          • foxriver76
            foxriver76 Developer @mcm1957 last edited by
            @mcm57 ja issue erstellen auf jeden Fall, gehört so nicht
              sigi234 Forum Testing Most Active @foxriver76 last edited by sigi234
              @foxriver76 sagte in Fehlermeldung beim Update vom Admin:
              Heute wieder so bei Update auf 6.17.5 und das Logo Icon wird nicht mehr erkannt.
              Ich warte noch ab wegen einer issue ob es nur bei mir so ist.
              Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @sigi234 last edited by
                @sigi234
                Ist bei mir auch.
                • foxriver76
                  foxriver76 Developer @sigi234 last edited by
                  @sigi234 bitte issue
                  Bluefox arbeitet derzeit am Admin, wäre gut dass er es sieht
                    https://github.com/ioBroker/ioBroker.admin/issues/2436
                    Edit:
                    Logo wieder da mit v6.17.6
                    sigi2345 created this issue in ioBroker/ioBroker.admin
                    closed [bug]: Logo Icon wird nicht mehr erkannt #2436
                    • haselchen
                      haselchen Most Active @sigi234 last edited by haselchen
                      @sigi234
                      Okay, genau das hatte ich eben in meinem Thread erwähnt.
                      https://forum.iobroker.net/topic/74204/admin-update-6-17-5-thumbnails-hats-zerissen
                      @foxriver76
                        https://github.com/ioBroker/ioBroker.admin/issues/2437
                        closed [bug]: Typ Error failed to execute #2437
                        402
