    4. npm Error bei mihome-vacuum Adapter Installation
    • Wintermute
      Wintermute @Wintermute last edited by
      @wintermute sagte in npm Error bei mihome-vacuum Adapter Installation:
      Ich habe gerade das Update auf die 4.2.0 und habe das Problem, dass die Installation offenbar sauber durchläuft, der Adapter aber nicht mehr startet ("Verbunden mit Gerät oder Dienst" ist grün, der Rest rot)
      iob update und iob upgrade hab ich probiert, keine Resultate:
      C:\ioBroker>iob update
      Used repository: stable
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "deconz"       : 1.4.0    , installed 1.4.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.1  [Updatable]
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      C:\ioBroker>iob upgrade
      This upgrade of "vis" will introduce the following changes:
      -> 1.5.4:
      added the new binding operation for getting property of JSON or object
      Checked the initialization of the `local_` variables
      fixed subscribeOidAtRuntime
      Added dynamic web manifest
      Optimization for basic-view in widget8
      Changed binding regex to accept umlauts
      Corrected first installation of vis
      Would you like to upgrade vis from @1.5.1 to @1.5.4 now? [(y)es, (n)o]: n
      No upgrade of "vis" desired.
      Vis habe ich aus Gründen nicht aktualisiert, weil ansonsten einige ältere Tablets nicht mehr klarkommen.
      Ein "Iob fix" bringt:
      Need to install the following packages:
        @iobroker/fix@5.0.0
      Ok to proceed? (y) y
      "(" kann syntaktisch an dieser Stelle nicht verarbeitet werden.
      npm notice
      npm notice New major version of npm available! 9.5.0 -> 10.5.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.2
      npm notice Run npm install -g npm@10.5.2 to update!
      npm notice
      Hat das Eine mit dem Anderen zu tun?
      Zusätzlich noch "iob info":
      C:\ioBroker>iob info
      Cannot get disk information: Command failed: df -k /
      Der Befehl "df" ist entweder falsch geschrieben oder
      konnte nicht gefunden werden.
      Platform       : Windows
      os             : win64
      Architecture   : x64
      CPUs           : 2
      Model          : Intel(R) Xeon(R) CPU 8460Y+ @ 2.0 GHz
      RAM            : 126 GB
      System uptime  : 2d. 20:25:52
      Node.js        : v18.15.0
      time           : 1713536349613
      timeOffset     : -120
      NPM            : 9.5.0
      adapters count : 538
        pusemuckel last edited by pusemuckel
        ich habe das gleiche Problem seit dem Update auf die neue Version
        host.iobroker
        	2024-04-19 16:31:31.427	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        	2024-04-19 16:31:31.426	error	Caught by controller[1]: Node.js v20.12.2
        host.iobroker
        	2024-04-19 16:31:31.426	error	Caught by controller[0]: }
        host.iobroker
        	2024-04-19 16:31:31.425	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
        host.iobroker
        	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
        host.iobroker
        	2024-04-19 16:31:31.425	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
        host.iobroker
        	2024-04-19 16:31:31.424	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
        host.iobroker
        	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
        host.iobroker
        	2024-04-19 16:31:31.423	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
        host.iobroker
        	2024-04-19 16:31:31.418	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
        host.iobroker
        	2024-04-19 16:31:31.418	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
        host.iobroker
        	2024-04-19 16:31:31.418	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
        host.iobroker
        	2024-04-19 16:31:31.417	error	Caught by controller[0]: ^
        host.iobroker
        	2024-04-19 16:31:31.417	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
        host.iobroker
        	2024-04-19 16:31:31.416	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
        Hat jemand eine Idee wo man schauen muss um das zu korrigieren ?
        Danke!
          A Former User @Wintermute last edited by
          @wintermute
          bei Windows bin ich raus..
          Wintermute 1 Reply Last reply Reply Quote 0
            A Former User @pusemuckel last edited by
            @pusemuckel
            ist nicht der gleiche Fehler, wie der TE hat, aber irgendein script scheint filename falsch deklariert zu haben.. sofern ich den Fehler richtig verstehe.. ist ja nur n Auschschnitt vom Ende des Fehlers.. man muesste da halt mal wissen:
            welches System?
            welche Version?
            Logfile von Begin an, wenn der Adapter startet...
            Dann natuerlich noch die Grundsaetzlichen infos aus iob diag.
              pusemuckel @Guest last edited by
              @ilovegym
              Danke für Deine Rückmeldung!
              			v.2023-10-10
              model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.2
              Installation: 		Docker
              Kernel: 		x86_64
              Userland: 		amd64
              Timezone: 		Etc/UTC
              User-ID: 		0
              X-Server: 		false
              Pending OS-Updates: 	0
              Pending iob updates: 	0
              Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
              			/usr/bin/node 		v20.12.2
              			/usr/bin/npm 		10.5.0
              			/usr/bin/npx 		10.5.0
              			/usr/bin/corepack 	0.25.2
              Recommended versions are nodejs 18.20.2 and npm 10.5.0
              MEMORY:
              Mem:             12G        6.7G        822M        188M        5.4G        5.7G
              Swap:           9.6G         60M        9.5G
              Total:           21G        6.8G         10G
              Active iob-Instances: 	26
              Active repo(s): stable
              ioBroker Core: 		js-controller 		5.0.19
              			admin 			6.13.16
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: redis
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects: 		15173
              States: 		11749
              Size of iob-Database:
              16M	/opt/iobroker/iobroker-data/objects.jsonl
              13M	/opt/iobroker/iobroker-data/objects.json.migrated
              13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
              3.5M	/opt/iobroker/iobroker-data/states.json.bak
              Adapter Log:
              host.iobroker
              	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
              host.iobroker
              	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker
              	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
              host.iobroker
              	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.iobroker
              	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
              host.iobroker
              	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
              host.iobroker
              	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
              host.iobroker
              	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
              host.iobroker
              	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
              host.iobroker
              	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
              Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
              ? mcm1957 2 Replies Last reply Reply Quote 0
                A Former User @pusemuckel last edited by A Former User
                @pusemuckel
                mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
                In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
                sudo docker exec -tiu username containername /bin/bash
                bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
                sudo docker exec -tiu iobroker iobroker /bin/bash
                danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
                Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
                edit:
                das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
                iob logs --watch
                  @ilovegym said in npm Error bei mihome-vacuum Adapter Installation:
                  Das hatte ich schon gemacht, leider auch ohne Erfolg. Ich konnte es mit
                  npm install iobroker/adapter-core
                  korrigieren, danach lässt sich der Adapter wieder starten!
                  Schönes Wochenende!
                  • Wintermute
                    Wintermute @Guest last edited by
                    @ilovegym ...und ich bei Linux 😀
                    Alle Reparaturversuche sind fehlgeschlagen - Einspielen des Updates von letzter Nacht hat meinem Iobroker und meinem Staubsauger aber wieder auf die Beine geholfen. Das Update auf die 4.2.0 werde ich dann mal besser auslassen...
                      Thomas Braun Most Active @Wintermute last edited by
                      Läuft.
                      • Wintermute
                        Wintermute @Thomas Braun last edited by
                        @thomas-braun sagte in npm Error bei mihome-vacuum Adapter Installation:
                        Läuft.
                        Auf einem Windows-System? Hast Du irgendwelche Verrenkungen gemacht, damit der Adapter läuft?
                          Thomas Braun Most Active @Wintermute last edited by Thomas Braun
                          @wintermute
                          Läuft natürlich auf einem Betriebssystem.
                          Gerade nochmal durchgestartet:
                          2024-04-19 18:46:09.700  - info: mihome-vacuum.0 (1232) Got terminate signal TERMINATE_YOURSELF
                          2024-04-19 18:46:09.727  - error: mihome-vacuum.0 (1232) Socket Close
                          2024-04-19 18:46:09.731  - info: mihome-vacuum.0 (1232) terminating
                          2024-04-19 18:46:09.734  - info: mihome-vacuum.0 (1232) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-04-19 18:46:10.221  - info: mihome-vacuum.0 (1232) terminating
                          2024-04-19 18:46:15.796  - info: mihome-vacuum.0 (680497) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v21.7.3, js-controller: 5.0.19
                          2024-04-19 18:46:15.867  - info: mihome-vacuum.0 (680497) IOT enabled, create state
                          2024-04-19 18:46:16.017  - info: mihome-vacuum.0 (680497) select standard vacuum protocol....
                          2024-04-19 18:46:16.494  - info: mihome-vacuum.0 (680497) create state for carpet_mode
                          2024-04-19 18:46:16.649  - info: mihome-vacuum.0 (680497) settest next timer: not available
                          Kein Ding, kommt sofort wieder hoch.
                          Wintermute 1 Reply Last reply Reply Quote -1
                          • Wintermute
                            @wintermute
                            Da bin ich mir sicher, dass es auf einem Betriebssystem läuft 😉
                            Aber läuft es auch auf Meinem Betriebssystem?
                              @wintermute
                              Natürlich nicht.
                              • mcm1957
                                mcm1957 @pusemuckel last edited by
                                @pusemuckel
                                @wintermute
                                Siehe https://forum.iobroker.net/topic/74221/häufung-von-update-problemen/3
                                • mcm1957
                                  mcm1957 @mcm1957 last edited by
                                  Weiter gehts hier https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
                                  1515
