[gelöst] Sporadische Neustarts des iobroker
@thomas-braun ok, trotzdem Danke, ich schau mal wie es läuft.
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: BU02SMART02-iobroker Icon name: computer-container Chassis: container Virtualization: lxc Operating System: Ubuntu 22.04.4 LTS Kernel: Linux 6.2.16-18-pve Architecture: x86-64 model name : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : amd64 Systemuptime and Load: 22:13:26 up 1:20, 2 users, load average: 5.88, 4.78, 4.63 CPU threads: 4 *** Time and Time Zones *** Local time: Tue 2024-04-16 22:13:26 CEST Universal time: Tue 2024-04-16 20:13:26 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** User and Groups *** mario /home/mario mario sudo iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 4.0G 1.9G 0.0K 2.3G 4.2G Swap: 7.8G 0.0K 7.8G Total: 15G 4.0G 9.6G 8192 M total memory 4020 M used memory 844 M active memory 5138 M inactive memory 1879 M free memory 0 M buffer memory 2292 M swap cache 7759 M total swap 0 M used swap 7759 M free swap *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/loop0 ext4 26G 21G 4.6G 82% / none tmpfs 492K 4.0K 488K 1% /dev tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs tmpfs 3.1G 152K 3.1G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.6G 0 1.6G 0% /run/user/1001 Messages concerning ext4 filesystem in dmesg: dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/loop0 ext4 rw,relatime Files in neuralgic directories: /var: 4.0G /var/ 2.8G /var/log 2.7G /var/log/journal/a4cc250a83fe4944adccd8462a307fa7 2.7G /var/log/journal 781M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 713M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 7.9G /opt/iobroker/iobroker-data/ 6.5G /opt/iobroker/iobroker-data/history 627M /opt/iobroker/iobroker-data/files 487M /opt/iobroker/iobroker-data/esphome.0/.esphome/build 487M /opt/iobroker/iobroker-data/esphome.0/.esphome The five largest files in iobroker-data are: 49M /opt/iobroker/iobroker-data/objects.jsonl 41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 28M /opt/iobroker/iobroker-data/states.jsonl 22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.20.2 /usr/bin/node v18.20.2 /usr/bin/npm 10.5.0 /usr/bin/npx 10.5.0 /usr/bin/corepack 0.25.2 nodejs: Installed: 18.20.2-1nodesource1 Candidate: 18.20.2-1nodesource1 Version table: *** 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages 12.22.9~dfsg-1ubuntu3.5 500 500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages 500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Core adapters versions js-controller: 5.0.19 admin: 6.17.3 javascript: 8.0.3 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : BU02SMART02-iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : BU02SMART02-iobroker - enabled + system.adapter.alexa2.0 : alexa2 : BU02SMART02-iobroker - enabled + system.adapter.backitup.0 : backitup : BU02SMART02-iobroker - enabled + system.adapter.bosesoundtouch.0 : bosesoundtouch : BU02SMART02-iobroker - enabled + system.adapter.daikin.0 : daikin : BU02SMART02-iobroker - enabled + system.adapter.device-reminder.0 : device-reminder : BU02SMART02-iobroker - enabled + system.adapter.device-watcher.1 : device-watcher : BU02SMART02-iobroker - enabled + system.adapter.discovery.0 : discovery : BU02SMART02-iobroker - enabled system.adapter.dwd.0 : dwd : BU02SMART02-iobroker - enabled system.adapter.ecovacs-deebot.0 : ecovacs-deebot : BU02SMART02-iobroker - disabled + system.adapter.ems-esp.0 : ems-esp : BU02SMART02-iobroker - enabled + system.adapter.energiefluss.0 : energiefluss : BU02SMART02-iobroker - enabled + system.adapter.energiefluss.1 : energiefluss : BU02SMART02-iobroker - enabled system.adapter.feiertage.0 : feiertage : BU02SMART02-iobroker - enabled system.adapter.flot.0 : flot : BU02SMART02-iobroker - enabled + system.adapter.followthesun.0 : followthesun : BU02SMART02-iobroker - enabled + system.adapter.ford.0 : ford : BU02SMART02-iobroker - enabled + system.adapter.hass-mqtt.0 : hass-mqtt : BU02SMART02-iobroker - enabled + system.adapter.history.0 : history : BU02SMART02-iobroker - enabled + system.adapter.homeconnect.0 : homeconnect : BU02SMART02-iobroker - enabled system.adapter.ical.0 : ical : BU02SMART02-iobroker - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker - enabled system.adapter.icons-icons8.0 : icons-icons8 : BU02SMART02-iobroker - enabled system.adapter.icons-material-png.0 : icons-material-png : BU02SMART02-iobroker - enabled system.adapter.icons-material-svg.0 : icons-material-svg : BU02SMART02-iobroker - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : BU02SMART02-iobroker - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : BU02SMART02-iobroker - enabled + system.adapter.influxdb.0 : influxdb : BU02SMART02-iobroker - enabled, port: 8086 + system.adapter.info.0 : info : BU02SMART02-iobroker - enabled + system.adapter.iot.0 : iot : BU02SMART02-iobroker - enabled + system.adapter.javascript.0 : javascript : BU02SMART02-iobroker - enabled + system.adapter.linkeddevices.0 : linkeddevices : BU02SMART02-iobroker - enabled system.adapter.material.0 : material : BU02SMART02-iobroker - enabled + system.adapter.mercedesme.0 : mercedesme : BU02SMART02-iobroker - enabled system.adapter.mqtt-client.0 : mqtt-client : BU02SMART02-iobroker - disabled, port: 1892 + system.adapter.mqtt.0 : mqtt : BU02SMART02-iobroker - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.mqtt.1 : mqtt : BU02SMART02-iobroker - enabled, port: 1891, bind: 192.168.2.166 + system.adapter.net-tools.0 : net-tools : BU02SMART02-iobroker - enabled system.adapter.netatmo-crawler.0 : netatmo-crawler : BU02SMART02-iobroker - enabled system.adapter.openweathermap.0 : openweathermap : BU02SMART02-iobroker - enabled system.adapter.pi-hole.0 : pi-hole : BU02SMART02-iobroker - disabled + system.adapter.ping.0 : ping : BU02SMART02-iobroker - enabled system.adapter.proxmox.0 : proxmox : BU02SMART02-iobroker - disabled, port: 8006 + system.adapter.pvforecast.0 : pvforecast : BU02SMART02-iobroker - enabled + system.adapter.ring.0 : ring : BU02SMART02-iobroker - enabled + system.adapter.samsung.0 : samsung : BU02SMART02-iobroker - enabled + system.adapter.shelly.0 : shelly : BU02SMART02-iobroker - enabled, port: 1890, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : BU02SMART02-iobroker - enabled, port: 1890, bind: 192.168.2.166 system.adapter.shuttercontrol.0 : shuttercontrol : BU02SMART02-iobroker - disabled + system.adapter.slideshow.0 : slideshow : BU02SMART02-iobroker - enabled + system.adapter.smartthings.0 : smartthings : BU02SMART02-iobroker - enabled system.adapter.snmp.0 : snmp : BU02SMART02-iobroker - disabled system.adapter.socketio.0 : socketio : BU02SMART02-iobroker - disabled, port: 8084, bind: 192.168.2.166, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : BU02SMART02-iobroker - enabled + system.adapter.telegram.0 : telegram : BU02SMART02-iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tuya.0 : tuya : BU02SMART02-iobroker - enabled system.adapter.tuya.1 : tuya : BU02SMART02-iobroker - disabled system.adapter.unifi.0 : unifi : BU02SMART02-iobroker - disabled + system.adapter.virtualpowermeter.0 : virtualpowermeter : BU02SMART02-iobroker - enabled system.adapter.vis-2-widgets-energy.0 : vis-2-widgets-energy : BU02SMART02-iobroker - enabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : BU02SMART02-iobroker - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker - enabled system.adapter.vis-2.0 : vis-2 : BU02SMART02-iobroker - disabled system.adapter.vis-bars.0 : vis-bars : BU02SMART02-iobroker - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : BU02SMART02-iobroker - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : BU02SMART02-iobroker - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : BU02SMART02-iobroker - enabled system.adapter.vis-history.0 : vis-history : BU02SMART02-iobroker - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : BU02SMART02-iobroker - enabled system.adapter.vis-icontwo.0 : vis-icontwo : BU02SMART02-iobroker - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : BU02SMART02-iobroker - enabled system.adapter.vis-justgage.0 : vis-justgage : BU02SMART02-iobroker - enabled system.adapter.vis-lcars.0 : vis-lcars : BU02SMART02-iobroker - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : BU02SMART02-iobroker - enabled system.adapter.vis-material.0 : vis-material : BU02SMART02-iobroker - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : BU02SMART02-iobroker - enabled system.adapter.vis-plumb.0 : vis-plumb : BU02SMART02-iobroker - enabled system.adapter.vis-rgraph.0 : vis-rgraph : BU02SMART02-iobroker - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : BU02SMART02-iobroker - enabled system.adapter.vis-weather.0 : vis-weather : BU02SMART02-iobroker - enabled system.adapter.vis.0 : vis : BU02SMART02-iobroker - enabled + system.adapter.web.0 : web : BU02SMART02-iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.ws.0 : ws : BU02SMART02-iobroker - disabled, port: 8087, bind: 192.168.2.166, run as: admin + system.adapter.yahka.0 : yahka : BU02SMART02-iobroker - enabled system.adapter.yahka.1 : yahka : BU02SMART02-iobroker - disabled + system.adapter.zigbee.0 : zigbee : BU02SMART02-iobroker - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : BU02SMART02-iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : BU02SMART02-iobroker - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : BU02SMART02-iobroker - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.mqtt.1 : mqtt : BU02SMART02-iobroker - enabled, port: 1891, bind: 192.168.2.166 + system.adapter.shelly.0 : shelly : BU02SMART02-iobroker - enabled, port: 1890, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : BU02SMART02-iobroker - enabled, port: 1890, bind: 192.168.2.166 + system.adapter.telegram.0 : telegram : BU02SMART02-iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : BU02SMART02-iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : BU02SMART02-iobroker - enabled, port: /dev/ttyUSB0 ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Beta (latest) Installed ioBroker-Instances Used repository: Beta (latest) Adapter "admin" : 6.17.3 , installed 6.17.3 Adapter "alarm" : 3.6.0 , installed 3.6.0 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "apcups" : 2.0.0 , installed 2.0.0 Adapter "backitup" : 2.11.0 , installed 2.11.0 Adapter "bosesoundtouch": 0.11.1 , installed 0.11.1 Adapter "daikin" : 1.4.2 , installed 1.4.2 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.12.0 , installed 2.12.0 Adapter "discovery" : 4.4.0 , installed 4.4.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "ecovacs-deebot": 1.4.15 , installed 1.4.15 Adapter "ems-esp" : 3.1.1 , installed 3.1.1 Adapter "energiefluss" : 3.6.0 , installed 3.6.0 Adapter "esphome" : 0.5.0-beta.8, installed 0.5.0-beta.8 Adapter "feiertage" : 1.2.0 , installed 1.2.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.0 , installed 0.5.0 Adapter "ford" : 0.2.0 , installed 0.2.0 Adapter "hass-mqtt" : 0.0.7 , installed 0.0.7 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.3.0 , installed 1.3.0 Adapter "ical" : 1.14.3 , installed 1.14.3 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 3.2.2 , installed 3.2.2 Adapter "javascript" : 8.0.3 , installed 8.0.3 Controller "js-controller": 5.0.19 , installed 5.0.19 Adapter "linkeddevices": 1.5.5 , installed 1.5.5 Adapter "material" : 1.3.1 , installed 1.3.1 Adapter "megaesp" : 0.1.0 , installed 0.1.0 Adapter "mercedesme" : 0.2.2 , installed 0.2.2 Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "mqtt-client" : 1.8.0 , installed 1.8.0 Adapter "net-tools" : 1.0.11 , installed 1.0.11 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "openweathermap": 1.0.4 , installed 1.0.4 Adapter "pi-hole" : 1.3.6 , installed 1.3.6 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "proxmox" : 2.2.3 , installed 2.2.3 Adapter "pvforecast" : 2.9.1 , installed 2.9.1 Adapter "ring" : 5.0.10 , installed 5.0.10 Adapter "samsung" : 0.5.11 , installed 0.5.11 Adapter "shelly" : 6.9.0 , installed 6.9.0 Adapter "shuttercontrol": 1.7.0 , installed 1.7.0 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "slideshow" : 0.1.4 , installed 0.1.4 Adapter "smartthings" : 0.1.1 , installed 0.1.1 Adapter "snmp" : 3.2.0 , installed 3.2.0 Adapter "socketio" : 6.6.1 , installed 6.6.1 Adapter "sourceanalytix": 0.4.14 , installed 0.4.14 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "telegram" : 3.2.1 , installed 3.2.1 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "unifi" : 0.7.0 , installed 0.7.0 Adapter "virtualpowermeter": 1.4.6, installed 1.4.6 Adapter "vis" : 1.5.5 , installed 1.5.5 Adapter "vis-2" : 2.9.49 , installed 2.9.49 Adapter "vis-2-widgets-energy": 0.3.11, installed 0.3.11 Adapter "vis-2-widgets-gauges": 1.0.3, installed 1.0.3 Adapter "vis-2-widgets-material": 1.3.27, installed 1.3.27 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-lcars" : 1.1.1 , installed 1.1.1 Adapter "vis-material" : 0.1.3 , installed 0.1.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.9 , installed 2.5.9 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.5.11 , installed 2.5.11 Adapter "yahka" : 1.0.3 , installed 1.0.3 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Objects and States Please stand by - This may take a while Objects: 49451 States: 42960 *** OS-Repositories and Updates *** Hit:1 https://repos.influxdata.com/debian stable InRelease Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease Hit:3 https://apt.grafana.com stable InRelease Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 134632524 1/init tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1000 134767830 3724/io.mqtt.0 tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 134635725 283/master tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 106 134631393 100/systemd-resolve tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 113 134635550 116/redis-server 12 tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN 1001 134826590 5717/sshd: mario@pt tcp 0 0 0.0.0.0:39227 0.0.0.0:* LISTEN 1000 134773301 4042/io.yahka.0 tcp 0 0 192.168.2.166:1890 0.0.0.0:* LISTEN 1000 134769007 3803/io.shelly.1 tcp 0 0 192.168.2.166:1891 0.0.0.0:* LISTEN 1000 134770223 3841/io.mqtt.1 tcp6 0 0 :::111 :::* LISTEN 0 134632526 1/init tcp6 0 0 :::22 :::* LISTEN 0 134632859 1/init tcp6 0 0 :::3000 :::* LISTEN 112 134639723 339/grafana tcp6 0 0 ::1:25 :::* LISTEN 0 134635726 283/master tcp6 0 0 ::1:6379 :::* LISTEN 113 134635551 116/redis-server 12 tcp6 0 0 ::1:6011 :::* LISTEN 1001 134826589 5717/sshd: mario@pt tcp6 0 0 :::8081 :::* LISTEN 1000 134762300 3585/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1000 134782529 4319/io.web.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 134775091 4042/io.yahka.0 udp 0 0 0.0.0.0:5683 0.0.0.0:* 1000 134773821 3917/io.shelly.0 udp 0 0 0.0.0.0:55014 0.0.0.0:* 1000 135249274 3917/io.shelly.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1000 134765342 3672/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1000 134765343 3672/io.tuya.0 udp 0 0 127.0.0.53:53 0.0.0.0:* 106 134631392 100/systemd-resolve udp 0 0 0.0.0.0:111 0.0.0.0:* 0 134632525 1/init udp6 0 0 :::111 :::* 0 134632527 1/init *** Log File - Last 25 Lines *** 2024-04-16 21:49:27.283 - info: zigbee.0 (13050) 0x84182600000d798a (addr 50622): AB3257001NJ - OSRAM Smart+ plug (Router) 2024-04-16 21:49:27.285 - info: zigbee.0 (13050) 0x7cb03eaa00ad4adf (addr 48445): AB3257001NJ - OSRAM Smart+ plug (Router) 2024-04-16 21:49:27.287 - info: zigbee.0 (13050) 0x7cb03eaa00ad1661 (addr 64742): AB3257001NJ - OSRAM Smart+ plug (Router) 2024-04-16 21:49:27.289 - info: zigbee.0 (13050) 0x8418260000cab6da (addr 26679): 4052899926110 - OSRAM Flex RGBW (Router) 2024-04-16 21:49:27.291 - info: zigbee.0 (13050) 0x5c0272fffe6e55ea (addr 38364): E1746 - IKEA TRADFRI signal repeater (Router) 2024-04-16 21:49:27.294 - info: zigbee.0 (13050) 0x54ef4410005b43d3 (addr 45208): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice) 2024-04-16 21:49:27.297 - info: zigbee.0 (13050) 0x5c0272fffe5b723b (addr 27218): E1746 - IKEA TRADFRI signal repeater (Router) 2024-04-16 21:49:27.298 - info: zigbee.0 (13050) 0x7cb03eaa0a068fec (addr 16021): AB3257001NJ - OSRAM Smart+ plug (Router) 2024-04-16 21:49:27.306 - info: zigbee.0 (13050) 0x00158d0008a6bd14 (addr 37504): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-04-16 21:49:27.308 - info: zigbee.0 (13050) 0x00158d0008834af4 (addr 53958): MCCGQ11LM - Aqara Door and window sensor (EndDevice) 2024-04-16 21:49:27.309 - info: zigbee.0 (13050) Zigbee started 2024-04-16 21:49:27.379 - info: zigbee.0 (13050) debug devices set to [] 2024-04-16 21:49:35.454 - info: admin.0 (3585) ==> Connected system.user.admin from ::ffff:192.168.2.160 2024-04-16 21:49:35.812 - info: zigbee.0 (13050) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}] 2024-04-16 21:50:03.153 - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa0a068fec Plug 01 2024-04-16 21:59:03.751 - info: feiertage.0 (14906) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19 2024-04-16 21:59:03.864 - info: feiertage.0 (14906) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024 2024-04-16 21:59:03.874 - info: feiertage.0 (14906) all objects written 2024-04-16 21:59:03.883 - info: feiertage.0 (14906) Terminated (NO_ERROR): Without reason 2024-04-16 22:00:09.226 - info: feiertage.0 (15092) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v18.20.2, js-controller: 5.0.19 2024-04-16 22:00:09.729 - info: feiertage.0 (15092) Next holiday: Tag der Arbeit is in 15 days on 01.05.2024 2024-04-16 22:00:09.875 - info: feiertage.0 (15092) all objects written 2024-04-16 22:00:09.889 - info: feiertage.0 (15092) Terminated (NO_ERROR): Without reason 2024-04-16 22:00:21.817 - warn: netatmo-crawler.0 (15192) slow connection to objects DB. Still waiting ... 2024-04-16 22:06:45.998 - warn: zigbee.0 (13050) DeviceAvailability:Failed to ping 0x7cb03eaa00ad1661 Plug 01
@m-schalk sagte in Sporadische Neustarts des iobroker:
Wenn die Kiste jetzt nicht stabiler läuft:
Ich vermute hier ein Skript, das ungünstig angelegt wurde. -
@thomas-braun Hallo Thomas, die Restarts sind weniger geworden, aber leider sind es immer noch 2 am Tag. Was kann ich noch prüfen? Skripte?
Ja, i.d.R. ist dann ein Skript falsch/ungünstig angelegt.
@thomas-braun leider weiß ich nicht, wie ich das überprüfen kann.
Ich auch nicht.
oder Backup? Backups fressen Speicher und Ressourcen.. nicht, dass hier die Luft aus geht..?
Bei den Skripten bleibt nur eins, der Reihe nach ausschalten oder alle Aus, und dann der Reihe nach ein..
Es hilft auch, die Uhrzeiten zu protokollieren, und dann im Log zu sehen, was vorher passiert ist.. auch Skripte, die kurz vorher starten, mal anschauen..
@thomas-braun was kannst du dazu sagen? Das habe ich ca 1000
2024-04-19 21:30:47.475 - [31merror[39m: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2024-04-19 21:30:47.475 - [31merror[39m: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.475 - [31merror[39m: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14) 2024-04-19 21:30:47.823 - [31merror[39m: shelly.0 (470312) MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.829 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.833 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.835 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.841 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.843 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.846 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.850 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.850 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.851 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.855 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.859 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.861 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.862 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.862 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.864 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.866 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.869 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.870 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.872 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.872 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.875 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.876 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.877 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.879 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.881 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.884 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.886 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.887 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.888 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.889 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.892 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.893 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.894 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.897 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.899 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.901 - [31merror[39m: host.BU02SMART02-iobroker Could not set notifications state for scope "system": MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.831 - [31merror[39m: shelly.0 (470312) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2024-04-19 21:30:47.831 - [31merror[39m: shelly.0 (470312) unhandled promise rejection: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. 2024-04-19 21:30:47.831 - [31merror[39m: shelly.0 (470312) ReplyError: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error. at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
@thomas-braun das ist als letztes im log vor dem Restart, mindestens 10.000 mal
der Logfile ist 35Mb groß
2024-04-19 21:31:36.745 - [31merror[39m: javascript.0 (499664) An error happened which is most likely from one of your scripts, but the originating script could not be detected. 2024-04-19 21:31:36.745 - [31merror[39m: javascript.0 (499664) Error: write EPIPE 2024-04-19 21:31:36.745 - [31merror[39m: javascript.0 (499664) Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:962:11) at Socket._write (node:net:974:8) at writeOrBuffer (node:internal/streams/writable:392:12) at _write (node:internal/streams/writable:333:10) at Socket.Writable.write (node:internal/streams/writable:337:10) at console.value (node:internal/console/constructor:305:16) at console.warn (node:internal/console/constructor:385:26) at /opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:15:13
Dann schau mal in das Redis log, da stimmt was nicht..
Irgendwas mit redis. Und/oder mit dem Dateisystem vielleicht.
@ilovegym wo liegt das?
@ilovegym hallo, scheint ein Problem bei Redis zu sein.
=== REDIS BUG REPORT START: Cut & paste starting from here === 535888:C 19 Apr 2024 21:30:47.166 # Redis 6.0.16 crashed by signal: 11, si_code: 1 535888:C 19 Apr 2024 21:30:47.166 # Crashed running the instruction at: 0x562658427528 535888:C 19 Apr 2024 21:30:47.166 # Accessing address: 0x76 535888:C 19 Apr 2024 21:30:47.166 # Failed assertion: <no assertion failed> (<no file>:0) ------ STACK TRACE ------ EIP: redis-rdb-bgsave 127.0.0.1:6379(lzf_compress+0x238)[0x562658427528] Backtrace: redis-rdb-bgsave 127.0.0.1:6379(logStackTrace+0x5c)[0x56265847d83c] redis-rdb-bgsave 127.0.0.1:6379(sigsegvHandler+0xd0)[0x562658480320] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7ff189042520] redis-rdb-bgsave 127.0.0.1:6379(lzf_compress+0x238)[0x562658427528] redis-rdb-bgsave 127.0.0.1:6379(+0x7543c)[0x56265845543c] redis-rdb-bgsave 127.0.0.1:6379(rdbSaveRawString+0x115)[0x56265844ab05] redis-rdb-bgsave 127.0.0.1:6379(rdbSaveKeyValuePair+0x74)[0x56265844fea4] redis-rdb-bgsave 127.0.0.1:6379(rdbSaveRio+0x25d)[0x56265845028d] redis-rdb-bgsave 127.0.0.1:6379(rdbSave+0x117)[0x5626584508c7] redis-rdb-bgsave 127.0.0.1:6379(rdbSaveBackground+0xf3)[0x562658450be3] redis-rdb-bgsave 127.0.0.1:6379(serverCron+0x6ff)[0x56265841fd2f] redis-rdb-bgsave 127.0.0.1:6379(aeProcessEvents+0x477)[0x562658416ca7] redis-rdb-bgsave 127.0.0.1:6379(aeMain+0x1d)[0x562658416edd] redis-rdb-bgsave 127.0.0.1:6379(main+0x466)[0x5626584125f6] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7ff189029d90] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7ff189029e40] redis-rdb-bgsave 127.0.0.1:6379(_start+0x25)[0x5626584129d5] ------ INFO OUTPUT ------ # Server redis_version:6.0.16 redis_git_sha1:00000000 redis_git_dirty:0 redis_build_id:a3fdef44459b3ad6 redis_mode:standalone os:Linux 6.2.16-18-pve x86_64 arch_bits:64 multiplexing_api:epoll atomicvar_api:atomic-builtin gcc_version:11.2.0 process_id:535888 run_id:dd81208470d24e21da30c3db467aa897a35ea818 tcp_port:6379 uptime_in_seconds:261470 uptime_in_days:3 hz:10 configured_hz:10 lru_clock:2279014 executable:/usr/bin/redis-server config_file:/etc/redis/redis.conf io_threads_active:0 # Clients connected_clients:256 client_recent_max_input_buffer:8 client_recent_max_output_buffer:0 blocked_clients:0 tracking_clients:0 clients_in_timeout_table:0 # Memory used_memory:775250136 used_memory_human:739.34M used_memory_rss:245919744 used_memory_rss_human:234.53M used_memory_peak:881964608 used_memory_peak_human:841.11M used_memory_peak_perc:87.90% used_memory_overhead:13684328 used_memory_startup:809688 used_memory_dataset:761565808 used_memory_dataset_perc:98.34% allocator_allocated:775604592 allocator_active:792817664 allocator_resident:800509952 total_system_memory:16581869568 total_system_memory_human:15.44G used_memory_lua:109568 used_memory_lua_human:107.00K used_memory_scripts:6136 used_memory_scripts_human:5.99K number_of_cached_scripts:9 maxmemory:0 maxmemory_human:0B maxmemory_policy:noeviction allocator_frag_ratio:1.02 allocator_frag_bytes:17213072 allocator_rss_ratio:1.01 allocator_rss_bytes:7692288 rss_overhead_ratio:0.31 rss_overhead_bytes:-554590208 mem_fragmentation_ratio:0.32 mem_fragmentation_bytes:-529328744 mem_not_counted_for_evict:0 mem_replication_backlog:0 mem_clients_slaves:0 mem_clients_normal:5250392 mem_aof_buffer:0 mem_allocator:jemalloc-5.2.1 active_defrag_running:0 lazyfree_pending_objects:0 # Persistence loading:0 rdb_changes_since_last_save:24388 rdb_bgsave_in_progress:0 rdb_last_save_time:1713554985 rdb_last_bgsave_status:ok rdb_last_bgsave_time_sec:17 rdb_current_bgsave_time_sec:-1 rdb_last_cow_size:18829312 aof_enabled:0 aof_rewrite_in_progress:0 aof_rewrite_scheduled:0 aof_last_rewrite_time_sec:-1 aof_current_rewrite_time_sec:-1 aof_last_bgrewrite_status:ok aof_last_write_status:ok aof_last_cow_size:0 module_fork_in_progress:0 module_fork_last_cow_size:0 # Stats total_connections_received:14976 total_commands_processed:449758358 instantaneous_ops_per_sec:2860 total_net_input_bytes:58896855285 total_net_output_bytes:214360874435 instantaneous_input_kbps:435.56 instantaneous_output_kbps:1362.81 rejected_connections:0 sync_full:0 sync_partial_ok:0 sync_partial_err:0 expired_keys:24495 expired_stale_perc:0.12 expired_time_cap_reached_count:8 expire_cycle_cpu_milliseconds:15200 evicted_keys:0 keyspace_hits:285673939 keyspace_misses:127276 pubsub_channels:2 pubsub_patterns:1262 latest_fork_usec:13497 migrate_cached_sockets:0 slave_expires_tracked_keys:0 active_defrag_hits:0 active_defrag_misses:0 active_defrag_key_hits:0 active_defrag_key_misses:0 tracking_total_keys:0 tracking_total_items:0 tracking_total_prefixes:0 unexpected_error_replies:0 total_reads_processed:274021057 total_writes_processed:390387317 io_threaded_reads_processed:0 io_threaded_writes_processed:0 # Replication role:master connected_slaves:0 master_replid:6337f54d611b8afb4d7975cbb532388dde9afb63 master_replid2:0000000000000000000000000000000000000000 master_repl_offset:0 second_repl_offset:-1 repl_backlog_active:0 repl_backlog_size:1048576 repl_backlog_first_byte_offset:0 repl_backlog_histlen:0 # CPU used_cpu_sys:0.135472 used_cpu_user:0.617154 used_cpu_sys_children:0.000000 used_cpu_user_children:0.000000 # Modules # Commandstats cmdstat_config:calls=5033,usec=42748,usec_per_call=8.49 cmdstat_srem:calls=314,usec=2890,usec_per_call=9.20 cmdstat_info:calls=14974,usec=1485972,usec_per_call=99.24 cmdstat_get:calls=272987760,usec=16400864140,usec_per_call=60.08 cmdstat_subscribe:calls=5040,usec=31871,usec_per_call=6.32 cmdstat_del:calls=869,usec=25238,usec_per_call=29.04 cmdstat_script:calls=2521,usec=14960,usec_per_call=5.93 cmdstat_publish:calls=79624645,usec=12933656279,usec_per_call=162.43 cmdstat_punsubscribe:calls=15348,usec=588714,usec_per_call=38.36 cmdstat_exists:calls=6388310,usec=9550202,usec_per_call=1.49 cmdstat_sadd:calls=50301,usec=150896,usec_per_call=3.00 cmdstat_client:calls=14884,usec=44135,usec_per_call=2.97 cmdstat_sscan:calls=4510522,usec=3550650881,usec_per_call=787.19 cmdstat_psubscribe:calls=43946,usec=563994,usec_per_call=12.83 cmdstat_eval:calls=7,usec=146,usec_per_call=20.86 cmdstat_mget:calls=15049,usec=3330837,usec_per_call=221.33 cmdstat_exec:calls=1025,usec=23588,usec_per_call=23.01 cmdstat_keys:calls=2495,usec=65446235,usec_per_call=26230.96 cmdstat_setex:calls=8017443,usec=33961328,usec_per_call=4.24 cmdstat_multi:calls=1025,usec=831,usec_per_call=0.81 cmdstat_scan:calls=2283566,usec=780487989,usec_per_call=341.78 cmdstat_set:calls=71254075,usec=272358535,usec_per_call=3.82 cmdstat_evalsha:calls=4519206,usec=5476911394,usec_per_call=1211.92 # Cluster cluster_enabled:0 # Keyspace db0:keys=137336,expires=464,avg_ttl=16479 ------ CLIENT LIST OUTPUT ------ id=13183 addr=127.0.0.1:39196 fd=141 name=device-reminder.0(470397) age=33997 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13154 addr=127.0.0.1:45368 fd=130 name=zigbee.0(470296) age=34019 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13222 addr=127.0.0.1:59174 fd=192 name=mercedesme.0(470506) age=33970 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13223 addr=127.0.0.1:59186 fd=193 name=mercedesme.0(470506) age=33970 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13224 addr=127.0.0.1:59190 fd=194 name=mercedesme.0(470506) age=33970 idle=25805 flags=P db=0 sub=0 psub=9 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13155 addr=127.0.0.1:45372 fd=131 name=zigbee.0(470296) age=34019 idle=65 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13052 addr=127.0.0.1:36000 fd=40 name=influxdb.0(469983) age=34090 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13053 addr=127.0.0.1:36016 fd=41 name=influxdb.0(469983) age=34090 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13096 addr=127.0.0.1:35420 fd=84 name=daikin.0(470131) age=34059 idle=59 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=14152 addr=127.0.0.1:52682 fd=24 name=telegram.0(503220) age=16613 idle=647 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13084 addr=127.0.0.1:42226 fd=72 name=alexa2.0(470089) age=34067 idle=16 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13282 addr=127.0.0.1:59872 fd=246 name=followthesun.0(470656) age=33924 idle=15 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13085 addr=127.0.0.1:42228 fd=73 name=alexa2.0(470089) age=34067 idle=34066 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13207 addr=127.0.0.1:55612 fd=179 name=smartthings.0(470485) age=33982 idle=60 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13214 addr=127.0.0.1:53582 fd=184 name=alarm.0(470466) age=33976 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13215 addr=127.0.0.1:53598 fd=185 name=alarm.0(470466) age=33976 idle=628 flags=P db=0 sub=0 psub=14 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13240 addr=127.0.0.1:60810 fd=210 name=discovery.0(470599) age=33958 idle=33942 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13241 addr=127.0.0.1:60818 fd=211 name=discovery.0(470599) age=33958 idle=33947 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13242 addr=127.0.0.1:60824 fd=212 name=discovery.0(470599) age=33958 idle=33958 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=14173 addr=127.0.0.1:43172 fd=123 name=ecovacs-deebot.0(503417) age=16528 idle=12 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=14174 addr=127.0.0.1:43184 fd=124 name=ecovacs-deebot.0(503417) age=16528 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14175 addr=127.0.0.1:43196 fd=125 name=ecovacs-deebot.0(503417) age=16528 idle=24 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13086 addr=127.0.0.1:42242 fd=74 name=alexa2.0(470089) age=34067 idle=1214 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13031 addr=127.0.0.1:52088 fd=19 name=history.0(469942) age=34103 idle=34102 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13087 addr=127.0.0.1:42258 fd=75 name=alexa2.0(470089) age=34066 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13174 addr=127.0.0.1:58878 fd=150 name=pvforecast.0(470374) age=34007 idle=44 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13205 addr=127.0.0.1:55582 fd=177 name=sourceanalytix.0(470442) age=33983 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13206 addr=127.0.0.1:55598 fd=178 name=sourceanalytix.0(470442) age=33983 idle=2 flags=P db=0 sub=0 psub=33 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13246 addr=127.0.0.1:35880 fd=186 name=web.0(470634) age=33950 idle=557 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13247 addr=127.0.0.1:35892 fd=187 name=web.0(470634) age=33950 idle=26233 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13248 addr=127.0.0.1:35900 fd=188 name=web.0(470634) age=33950 idle=34 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13088 addr=127.0.0.1:42272 fd=76 name=alexa2.0(470089) age=34066 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13089 addr=127.0.0.1:42278 fd=77 name=alexa2.0(470089) age=34066 idle=16 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13153 addr=127.0.0.1:45358 fd=129 name=zigbee.0(470296) age=34019 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13032 addr=127.0.0.1:52104 fd=20 name=history.0(469942) age=34103 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13102 addr=127.0.0.1:35470 fd=90 name=shelly.1(470150) age=34055 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13273 addr=127.0.0.1:35616 fd=237 name=ring.0(470618) age=33934 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13301 addr=127.0.0.1:51126 fd=267 name=ford.0(470702) age=33916 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13302 addr=127.0.0.1:51136 fd=268 name=ford.0(470702) age=33916 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=285 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13274 addr=127.0.0.1:35632 fd=238 name=ring.0(470618) age=33934 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13275 addr=127.0.0.1:35634 fd=239 name=ring.0(470618) age=33934 idle=65 flags=P db=0 sub=0 psub=10 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13103 addr=127.0.0.1:35480 fd=91 name=shelly.1(470150) age=34055 idle=34054 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13104 addr=127.0.0.1:35492 fd=92 name=shelly.1(470150) age=34055 idle=34055 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13253 addr=127.0.0.1:35940 fd=217 name=ring.0(470618) age=33949 idle=33934 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13254 addr=127.0.0.1:35954 fd=218 name=ring.0(470618) age=33949 idle=33948 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13213 addr=127.0.0.1:53574 fd=183 name=alarm.0(470466) age=33976 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13135 addr=127.0.0.1:41296 fd=111 name=bosesoundtouch.0(470241) age=34035 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13136 addr=127.0.0.1:41302 fd=112 name=bosesoundtouch.0(470241) age=34035 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13137 addr=127.0.0.1:41304 fd=113 name=bosesoundtouch.0(470241) age=34035 idle=545 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13090 addr=127.0.0.1:42282 fd=78 name=net-tools.0(470107) age=34063 idle=34062 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=exists user=default id=13091 addr=127.0.0.1:42292 fd=79 name=net-tools.0(470107) age=34063 idle=34062 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13204 addr=127.0.0.1:55568 fd=176 name=sourceanalytix.0(470442) age=33983 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13092 addr=127.0.0.1:42306 fd=80 name=net-tools.0(470107) age=34063 idle=34063 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13025 addr=127.0.0.1:52036 fd=13 name=admin.0(469915) age=34107 idle=34107 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13138 addr=127.0.0.1:36250 fd=114 name=samsung.0(470260) age=34030 idle=34029 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13139 addr=127.0.0.1:36258 fd=115 name=samsung.0(470260) age=34030 idle=34030 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13140 addr=127.0.0.1:36270 fd=116 name=samsung.0(470260) age=34030 idle=34030 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13316 addr=127.0.0.1:48924 fd=253 name=info.0(470787) age=33904 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13317 addr=127.0.0.1:48930 fd=254 name=info.0(470787) age=33904 idle=33904 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13027 addr=127.0.0.1:52052 fd=15 name=admin.0(469915) age=34107 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13028 addr=127.0.0.1:52056 fd=16 name=admin.0(469915) age=34107 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13029 addr=127.0.0.1:52072 fd=17 name=admin.0(469915) age=34107 idle=2 flags=P db=0 sub=0 psub=27 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13300 addr=127.0.0.1:51116 fd=266 name=ford.0(470702) age=33917 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=4 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default id=13030 addr=127.0.0.1:52084 fd=18 name=history.0(469942) age=34103 idle=34102 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20568 events=r cmd=evalsha user=default id=13026 addr=127.0.0.1:52046 fd=14 name=admin.0(469915) age=34107 idle=33 flags=P db=0 sub=0 psub=8 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13099 addr=127.0.0.1:35442 fd=87 name=daikin.0(470131) age=34058 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13252 addr=127.0.0.1:35938 fd=216 name=ring.0(470618) age=33949 idle=65 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13100 addr=127.0.0.1:35454 fd=88 name=daikin.0(470131) age=34058 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14059 addr=127.0.0.1:38274 fd=33 name=javascript.0(499664) age=18386 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default id=14060 addr=127.0.0.1:38288 fd=34 name=javascript.0(499664) age=18386 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14061 addr=127.0.0.1:38292 fd=35 name=javascript.0(499664) age=18386 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13286 addr=127.0.0.1:51006 fd=250 name=virtualpowermeter.0(470758) age=33921 idle=33908 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13287 addr=127.0.0.1:51010 fd=251 name=virtualpowermeter.0(470758) age=33921 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13101 addr=127.0.0.1:35456 fd=89 name=daikin.0(470131) age=34058 idle=59 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13121 addr=127.0.0.1:34590 fd=97 name=mqtt.1(470205) age=34043 idle=34043 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13122 addr=127.0.0.1:34596 fd=98 name=mqtt.1(470205) age=34043 idle=34043 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13075 addr=127.0.0.1:58572 fd=63 name=mqtt.0(470053) age=34074 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13076 addr=127.0.0.1:58582 fd=64 name=mqtt.0(470053) age=34074 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13193 addr=127.0.0.1:55464 fd=165 name=sourceanalytix.0(470442) age=33990 idle=33983 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13194 addr=127.0.0.1:55480 fd=166 name=sourceanalytix.0(470442) age=33990 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13077 addr=127.0.0.1:58598 fd=65 name=mqtt.0(470053) age=34074 idle=2 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13057 addr=127.0.0.1:36058 fd=45 name=tuya.0(470002) age=34085 idle=4 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13058 addr=127.0.0.1:36066 fd=46 name=tuya.0(470002) age=34085 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13059 addr=127.0.0.1:36080 fd=47 name=tuya.0(470002) age=34085 idle=56 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13171 addr=127.0.0.1:58850 fd=147 name=iot.0(470354) age=34009 idle=15 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13202 addr=127.0.0.1:55548 fd=174 name=yahka.0(470426) age=33984 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13203 addr=127.0.0.1:55560 fd=175 name=yahka.0(470426) age=33984 idle=1 flags=P db=0 sub=0 psub=43 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13315 addr=127.0.0.1:48918 fd=252 name=info.0(470787) age=33904 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13172 addr=127.0.0.1:58856 fd=148 name=iot.0(470354) age=34009 idle=6 flags=P db=0 sub=2 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13173 addr=127.0.0.1:58866 fd=149 name=iot.0(470354) age=34009 idle=4312 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13020 addr=127.0.0.1:51992 fd=8 name=host.BU02SMART02-iobroker age=34110 idle=29 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20536 events=r cmd=evalsha user=default id=13120 addr=127.0.0.1:34578 fd=96 name=mqtt.1(470205) age=34043 idle=1546 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13021 addr=127.0.0.1:52008 fd=9 name=host.BU02SMART02-iobroker age=34109 idle=6 flags=P db=0 sub=2 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13168 addr=127.0.0.1:58826 fd=144 name=iot.0(470354) age=34011 idle=4312 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13169 addr=127.0.0.1:58834 fd=145 name=iot.0(470354) age=34011 idle=34009 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13195 addr=127.0.0.1:55482 fd=167 name=linkeddevices.0(470413) age=33988 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13196 addr=127.0.0.1:55486 fd=168 name=linkeddevices.0(470413) age=33988 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13197 addr=127.0.0.1:55498 fd=169 name=linkeddevices.0(470413) age=33988 idle=1 flags=P db=0 sub=0 psub=51 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13192 addr=127.0.0.1:55456 fd=164 name=sourceanalytix.0(470442) age=33990 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13170 addr=127.0.0.1:58846 fd=146 name=iot.0(470354) age=34011 idle=34 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13201 addr=127.0.0.1:55536 fd=173 name=yahka.0(470426) age=33985 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13022 addr=127.0.0.1:52016 fd=10 name=host.BU02SMART02-iobroker age=34109 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13129 addr=127.0.0.1:41266 fd=105 name=ems-esp.0(470223) age=34039 idle=3 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13130 addr=127.0.0.1:41270 fd=106 name=ems-esp.0(470223) age=34039 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13131 addr=127.0.0.1:41272 fd=107 name=ems-esp.0(470223) age=34039 idle=6 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13259 addr=127.0.0.1:36002 fd=223 name=followthesun.0(470656) age=33944 idle=33924 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13260 addr=127.0.0.1:36004 fd=224 name=followthesun.0(470656) age=33944 idle=33944 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13105 addr=127.0.0.1:35494 fd=93 name=shelly.1(470150) age=34054 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default id=13117 addr=127.0.0.1:34552 fd=69 name=homeconnect.0(470186) age=34047 idle=10 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13118 addr=127.0.0.1:34556 fd=70 name=homeconnect.0(470186) age=34047 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13119 addr=127.0.0.1:34572 fd=71 name=homeconnect.0(470186) age=34047 idle=28323 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13277 addr=127.0.0.1:35660 fd=241 name=vis-inventwo.0(470717) age=33933 idle=33911 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13278 addr=127.0.0.1:35674 fd=242 name=vis-inventwo.0(470717) age=33933 idle=33933 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13106 addr=127.0.0.1:35500 fd=94 name=shelly.1(470150) age=34054 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13107 addr=127.0.0.1:35516 fd=95 name=shelly.1(470150) age=34054 idle=1 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13156 addr=127.0.0.1:45378 fd=132 name=shelly.0(470312) age=34019 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default id=13270 addr=127.0.0.1:35588 fd=234 name=web.0(470634) age=33935 idle=13 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13271 addr=127.0.0.1:35592 fd=235 name=web.0(470634) age=33935 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13272 addr=127.0.0.1:35600 fd=236 name=web.0(470634) age=33935 idle=0 flags=P db=0 sub=0 psub=400 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14170 addr=127.0.0.1:43140 fd=120 name=ecovacs-deebot.0(503417) age=16528 idle=24 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=14171 addr=127.0.0.1:43156 fd=121 name=ecovacs-deebot.0(503417) age=16528 idle=16528 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14172 addr=127.0.0.1:43170 fd=122 name=ecovacs-deebot.0(503417) age=16528 idle=16528 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13255 addr=127.0.0.1:35964 fd=219 name=discovery.0(470599) age=33947 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13256 addr=127.0.0.1:35970 fd=220 name=discovery.0(470599) age=33947 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13257 addr=127.0.0.1:35982 fd=221 name=discovery.0(470599) age=33947 idle=33947 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13157 addr=127.0.0.1:45388 fd=133 name=shelly.0(470312) age=34019 idle=34016 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13158 addr=127.0.0.1:45392 fd=134 name=shelly.0(470312) age=34019 idle=34019 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13023 addr=127.0.0.1:52018 fd=11 name=host.BU02SMART02-iobroker age=34109 idle=2 flags=P db=0 sub=2 psub=8 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13073 addr=127.0.0.1:58550 fd=61 name=mqtt.0(470053) age=34074 idle=34074 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13226 addr=127.0.0.1:59206 fd=196 name=slideshow.0(470538) age=33969 idle=33960 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13258 addr=127.0.0.1:35988 fd=222 name=followthesun.0(470656) age=33944 idle=76 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13227 addr=127.0.0.1:59216 fd=197 name=slideshow.0(470538) age=33969 idle=33969 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13150 addr=127.0.0.1:45318 fd=126 name=zigbee.0(470296) age=34020 idle=65 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13276 addr=127.0.0.1:35650 fd=240 name=vis-inventwo.0(470717) age=33933 idle=33910 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13151 addr=127.0.0.1:45332 fd=127 name=zigbee.0(470296) age=34020 idle=34019 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13285 addr=127.0.0.1:59886 fd=249 name=virtualpowermeter.0(470758) age=33922 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13152 addr=127.0.0.1:45348 fd=128 name=zigbee.0(470296) age=34020 idle=34020 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13074 addr=127.0.0.1:58566 fd=62 name=mqtt.0(470053) age=34074 idle=34074 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13069 addr=127.0.0.1:58516 fd=57 name=device-watcher.1(470034) age=34077 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13070 addr=127.0.0.1:58522 fd=58 name=device-watcher.1(470034) age=34077 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13177 addr=127.0.0.1:58912 fd=155 name=pvforecast.0(470374) age=34003 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13178 addr=127.0.0.1:58914 fd=156 name=pvforecast.0(470374) age=34003 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13179 addr=127.0.0.1:58916 fd=157 name=pvforecast.0(470374) age=34003 idle=44 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13199 addr=127.0.0.1:55514 fd=171 name=alarm.0(470466) age=33985 idle=33976 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13200 addr=127.0.0.1:55530 fd=172 name=alarm.0(470466) age=33985 idle=33985 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13071 addr=127.0.0.1:58528 fd=59 name=device-watcher.1(470034) age=34077 idle=2 flags=P db=0 sub=0 psub=178 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13024 addr=127.0.0.1:52020 fd=12 name=admin.0(469915) age=34107 idle=685 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13072 addr=127.0.0.1:58536 fd=60 name=mqtt.0(470053) age=34074 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13297 addr=127.0.0.1:51100 fd=263 name=info.0(470787) age=33917 idle=1497 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13298 addr=127.0.0.1:51102 fd=264 name=info.0(470787) age=33917 idle=33904 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13299 addr=127.0.0.1:51112 fd=265 name=info.0(470787) age=33917 idle=33917 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13048 addr=127.0.0.1:35962 fd=36 name=influxdb.0(469983) age=34090 idle=34088 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20568 events=r cmd=evalsha user=default id=13049 addr=127.0.0.1:35972 fd=37 name=influxdb.0(469983) age=34090 idle=34089 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13050 addr=127.0.0.1:35974 fd=38 name=influxdb.0(469983) age=34090 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13220 addr=127.0.0.1:53636 fd=190 name=smartthings.0(470485) age=33973 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13221 addr=127.0.0.1:53642 fd=191 name=smartthings.0(470485) age=33973 idle=60 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13229 addr=127.0.0.1:59236 fd=199 name=energiefluss.0(470561) age=33966 idle=33956 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13230 addr=127.0.0.1:59240 fd=200 name=energiefluss.0(470561) age=33966 idle=33966 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13186 addr=127.0.0.1:39218 fd=158 name=linkeddevices.0(470413) age=33992 idle=1 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13280 addr=127.0.0.1:59850 fd=244 name=hass-mqtt.0(470737) age=33927 idle=33910 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13281 addr=127.0.0.1:59866 fd=245 name=hass-mqtt.0(470737) age=33927 idle=33927 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13187 addr=127.0.0.1:39228 fd=159 name=linkeddevices.0(470413) age=33992 idle=33988 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13188 addr=127.0.0.1:39232 fd=160 name=linkeddevices.0(470413) age=33992 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14155 addr=127.0.0.1:52694 fd=27 name=telegram.0(503220) age=16612 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=14156 addr=127.0.0.1:52698 fd=28 name=telegram.0(503220) age=16612 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14157 addr=127.0.0.1:52708 fd=29 name=telegram.0(503220) age=16612 idle=5 flags=P db=0 sub=0 psub=7 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13033 addr=127.0.0.1:52118 fd=21 name=history.0(469942) age=34103 idle=4 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13034 addr=127.0.0.1:52128 fd=22 name=history.0(469942) age=34103 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14056 addr=127.0.0.1:38240 fd=30 name=javascript.0(499664) age=18386 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default id=14057 addr=127.0.0.1:38252 fd=31 name=javascript.0(499664) age=18386 idle=18384 flags=P db=0 sub=0 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14058 addr=127.0.0.1:38262 fd=32 name=javascript.0(499664) age=18386 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13061 addr=127.0.0.1:36104 fd=49 name=ping.0(470017) age=34083 idle=34082 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13141 addr=127.0.0.1:36276 fd=117 name=samsung.0(470260) age=34030 idle=8 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13142 addr=127.0.0.1:36292 fd=118 name=samsung.0(470260) age=34030 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13211 addr=127.0.0.1:53552 fd=154 name=mercedesme.0(470506) age=33978 idle=33970 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13212 addr=127.0.0.1:53564 fd=182 name=mercedesme.0(470506) age=33978 idle=33978 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13143 addr=127.0.0.1:36298 fd=119 name=samsung.0(470260) age=34030 idle=34029 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13198 addr=127.0.0.1:55504 fd=170 name=alarm.0(470466) age=33985 idle=883 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13062 addr=127.0.0.1:36118 fd=50 name=ping.0(470017) age=34083 idle=34083 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13054 addr=127.0.0.1:36028 fd=42 name=tuya.0(470002) age=34086 idle=56 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13225 addr=127.0.0.1:59204 fd=195 name=slideshow.0(470538) age=33970 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13055 addr=127.0.0.1:36044 fd=43 name=tuya.0(470002) age=34086 idle=34085 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13056 addr=127.0.0.1:36056 fd=44 name=tuya.0(470002) age=34086 idle=34086 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13228 addr=127.0.0.1:59222 fd=198 name=energiefluss.0(470561) age=33966 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default id=13235 addr=127.0.0.1:59300 fd=205 name=energiefluss.1(470579) age=33962 idle=33949 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13238 addr=127.0.0.1:60792 fd=208 name=slideshow.0(470538) age=33960 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13239 addr=127.0.0.1:60800 fd=209 name=slideshow.0(470538) age=33960 idle=33957 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13267 addr=127.0.0.1:35562 fd=231 name=ford.0(470702) age=33937 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default id=13268 addr=127.0.0.1:35578 fd=232 name=ford.0(470702) age=33937 idle=33917 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13269 addr=127.0.0.1:35580 fd=233 name=ford.0(470702) age=33937 idle=33937 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13236 addr=127.0.0.1:59312 fd=206 name=energiefluss.1(470579) age=33962 idle=33962 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13219 addr=127.0.0.1:53628 fd=189 name=smartthings.0(470485) age=33973 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13133 addr=127.0.0.1:41282 fd=109 name=bosesoundtouch.0(470241) age=34035 idle=34035 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13134 addr=127.0.0.1:41290 fd=110 name=bosesoundtouch.0(470241) age=34035 idle=34035 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13060 addr=127.0.0.1:36090 fd=48 name=ping.0(470017) age=34083 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13066 addr=127.0.0.1:58484 fd=54 name=device-watcher.1(470034) age=34079 idle=2 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13067 addr=127.0.0.1:58496 fd=55 name=device-watcher.1(470034) age=34079 idle=34077 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13189 addr=127.0.0.1:55424 fd=161 name=yahka.0(470426) age=33991 idle=5366 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13190 addr=127.0.0.1:55432 fd=162 name=yahka.0(470426) age=33991 idle=33985 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13191 addr=127.0.0.1:55444 fd=163 name=yahka.0(470426) age=33991 idle=33991 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13127 addr=127.0.0.1:41248 fd=103 name=ems-esp.0(470223) age=34039 idle=34039 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13303 addr=127.0.0.1:48822 fd=269 name=vis-inventwo.0(470717) age=33911 idle=10 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13304 addr=127.0.0.1:48826 fd=270 name=vis-inventwo.0(470717) age=33911 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13305 addr=127.0.0.1:48834 fd=271 name=vis-inventwo.0(470717) age=33911 idle=33910 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13306 addr=127.0.0.1:48840 fd=272 name=hass-mqtt.0(470737) age=33910 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13307 addr=127.0.0.1:48848 fd=273 name=hass-mqtt.0(470737) age=33910 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13308 addr=127.0.0.1:48852 fd=274 name=hass-mqtt.0(470737) age=33910 idle=33908 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13210 addr=127.0.0.1:53548 fd=153 name=mercedesme.0(470506) age=33978 idle=1565 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13160 addr=127.0.0.1:45396 fd=136 name=shelly.0(470312) age=34016 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13244 addr=127.0.0.1:60828 fd=214 name=energiefluss.0(470561) age=33956 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13245 addr=127.0.0.1:60844 fd=215 name=energiefluss.0(470561) age=33956 idle=0 flags=P db=0 sub=0 psub=13 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13161 addr=127.0.0.1:45408 fd=137 name=shelly.0(470312) age=34016 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13128 addr=127.0.0.1:41264 fd=104 name=ems-esp.0(470223) age=34039 idle=34039 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13068 addr=127.0.0.1:58508 fd=56 name=device-watcher.1(470034) age=34079 idle=34 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13114 addr=127.0.0.1:34524 fd=66 name=homeconnect.0(470186) age=34047 idle=28323 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13115 addr=127.0.0.1:34536 fd=67 name=homeconnect.0(470186) age=34047 idle=34047 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13116 addr=127.0.0.1:34546 fd=68 name=homeconnect.0(470186) age=34047 idle=34047 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13279 addr=127.0.0.1:59838 fd=243 name=hass-mqtt.0(470737) age=33928 idle=33898 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20496 events=r cmd=mget user=default id=13310 addr=127.0.0.1:48866 fd=276 name=virtualpowermeter.0(470758) age=33908 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13311 addr=127.0.0.1:48872 fd=277 name=virtualpowermeter.0(470758) age=33908 idle=5 flags=P db=0 sub=0 psub=3 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13250 addr=127.0.0.1:35926 fd=202 name=energiefluss.1(470579) age=33949 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13251 addr=127.0.0.1:35932 fd=203 name=energiefluss.1(470579) age=33949 idle=0 flags=P db=0 sub=0 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13237 addr=127.0.0.1:60782 fd=207 name=slideshow.0(470538) age=33960 idle=7 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13132 addr=127.0.0.1:41278 fd=108 name=bosesoundtouch.0(470241) age=34035 idle=545 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13181 addr=127.0.0.1:39176 fd=139 name=device-reminder.0(470397) age=34001 idle=33997 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13182 addr=127.0.0.1:39180 fd=140 name=device-reminder.0(470397) age=34001 idle=34001 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13035 addr=127.0.0.1:52136 fd=23 name=history.0(469942) age=34103 idle=0 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=277 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13063 addr=127.0.0.1:36126 fd=51 name=ping.0(470017) age=34082 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13126 addr=127.0.0.1:41246 fd=102 name=ems-esp.0(470223) age=34039 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13159 addr=127.0.0.1:45394 fd=135 name=shelly.0(470312) age=34016 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default id=13064 addr=127.0.0.1:36132 fd=52 name=ping.0(470017) age=34082 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13093 addr=127.0.0.1:42316 fd=81 name=net-tools.0(470107) age=34062 idle=11 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13097 addr=127.0.0.1:35428 fd=85 name=daikin.0(470131) age=34059 idle=34058 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13243 addr=127.0.0.1:60826 fd=213 name=energiefluss.0(470561) age=33956 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default id=13184 addr=127.0.0.1:39202 fd=142 name=device-reminder.0(470397) age=33997 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13185 addr=127.0.0.1:39214 fd=143 name=device-reminder.0(470397) age=33997 idle=33997 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13123 addr=127.0.0.1:34602 fd=99 name=mqtt.1(470205) age=34043 idle=6 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13124 addr=127.0.0.1:34614 fd=100 name=mqtt.1(470205) age=34043 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13125 addr=127.0.0.1:34620 fd=101 name=mqtt.1(470205) age=34043 idle=1546 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14153 addr=127.0.0.1:52684 fd=25 name=telegram.0(503220) age=16613 idle=16612 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=14154 addr=127.0.0.1:52688 fd=26 name=telegram.0(503220) age=16613 idle=33 flags=P db=0 sub=0 psub=1 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13249 addr=127.0.0.1:35916 fd=201 name=energiefluss.1(470579) age=33949 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61472 events=r cmd=publish user=default id=13098 addr=127.0.0.1:35432 fd=86 name=daikin.0(470131) age=34059 idle=34059 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13094 addr=127.0.0.1:42320 fd=82 name=net-tools.0(470107) age=34062 idle=6 flags=P db=0 sub=2 psub=6 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13309 addr=127.0.0.1:48856 fd=275 name=virtualpowermeter.0(470758) age=33908 idle=5 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default id=13234 addr=127.0.0.1:59292 fd=204 name=energiefluss.1(470579) age=33962 idle=0 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=32768 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=61456 events=r cmd=get user=default id=13283 addr=127.0.0.1:59880 fd=247 name=followthesun.0(470656) age=33924 idle=6 flags=P db=0 sub=2 psub=5 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13284 addr=127.0.0.1:59884 fd=248 name=followthesun.0(470656) age=33924 idle=33917 flags=P db=0 sub=0 psub=2 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13208 addr=127.0.0.1:55620 fd=180 name=smartthings.0(470485) age=33982 idle=33973 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13209 addr=127.0.0.1:55622 fd=181 name=smartthings.0(470485) age=33982 idle=33982 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13095 addr=127.0.0.1:42330 fd=83 name=net-tools.0(470107) age=34062 idle=34062 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13180 addr=127.0.0.1:58924 fd=138 name=device-reminder.0(470397) age=34002 idle=33993 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=get user=default id=13175 addr=127.0.0.1:58894 fd=151 name=pvforecast.0(470374) age=34007 idle=34003 flags=P db=0 sub=0 psub=4 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20504 events=r cmd=psubscribe user=default id=13176 addr=127.0.0.1:58908 fd=152 name=pvforecast.0(470374) age=34007 idle=34007 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13065 addr=127.0.0.1:36146 fd=53 name=ping.0(470017) age=34082 idle=34082 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=client user=default id=13051 addr=127.0.0.1:35986 fd=39 name=influxdb.0(469983) age=34090 idle=9 flags=N db=0 sub=0 psub=0 multi=-1 qbuf=0 qbuf-free=0 argv-mem=0 obl=0 oll=0 omem=0 tot-mem=20520 events=r cmd=publish user=default ------ REGISTERS ------ 535888:C 19 Apr 2024 21:30:47.271 # RAX:0000000000000076 RBX:00007ffc3041ee00 RCX:00007ff1781ef1e1 RDX:00007ff15d50b514 RDI:0000000000000063 RSI:00007ff1781ef1e0 RBP:00007ff1781ef1c0 RSP:00007ffc3041ede0 R8 :00007ff15d509b43 R9 :00007ff15d509b63 R10:00007ff1781ef212 R11:00007ff15d509b97 R12:0000000065766963 R13:0000000000000020 R14:0000000000000000 R15:00007ff15d509b99 RIP:0000562658427528 EFL:0000000000010246 CSGSFS:002b000000000033 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edef) -> 00002b930000085b 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edee) -> 00000076000009df 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041eded) -> 0000236e00006365 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edec) -> 00000ea500001126 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edeb) -> 0000531800000a34 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041edea) -> 000010ed00000e2e 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede9) -> 00007f3f00003d25 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede8) -> 00004e90000012c4 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede7) -> 0000029a00000965 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede6) -> 000000a800000242 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede5) -> 0000002e00001599 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede4) -> 0000068800001aed 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede3) -> 00007ff172a30f8b 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede2) -> 00007ff1714583a0 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede1) -> 0000000000000030 535888:C 19 Apr 2024 21:30:47.271 # (00007ffc3041ede0) -> 0000000000000000 ------ MODULES INFO OUTPUT ------
@ilovegym und @Thomas-Braun so, ich denke es lag an redis und der Einstellung in der Redis config.
ALT:
save 900 1
save 300 10
save 60 10000NEU:
save 900 1
#save 300 10
#save 60 10000Diskbelastung ist merklich reduziert und auch keine Reboots mehr zu sehen.
Damit macht Redis weniger snapshots und verbraucht weniger Ressourcen.
