    4. npm Error bei mihome-vacuum Adapter Installation
      pusemuckel @Guest last edited by
      @ilovegym
      Danke für Deine Rückmeldung!
      			v.2023-10-10
      model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.2
      Installation: 		Docker
      Kernel: 		x86_64
      Userland: 		amd64
      Timezone: 		Etc/UTC
      User-ID: 		0
      X-Server: 		false
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v20.12.2
      			/usr/bin/node 		v20.12.2
      			/usr/bin/npm 		10.5.0
      			/usr/bin/npx 		10.5.0
      			/usr/bin/corepack 	0.25.2
      Recommended versions are nodejs 18.20.2 and npm 10.5.0
      MEMORY:
      Mem:             12G        6.7G        822M        188M        5.4G        5.7G
      Swap:           9.6G         60M        9.5G
      Total:           21G        6.8G         10G
      Active iob-Instances: 	26
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.19
      			admin 			6.13.16
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: redis
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects: 		15173
      States: 		11749
      Size of iob-Database:
      16M	/opt/iobroker/iobroker-data/objects.jsonl
      13M	/opt/iobroker/iobroker-data/objects.json.migrated
      13M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      3.5M	/opt/iobroker/iobroker-data/states.json.bak
      Adapter Log:
      host.iobroker
      	2024-04-19 17:08:23.959	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.iobroker
      	2024-04-19 17:08:23.959	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      	2024-04-19 17:08:23.959	error	Caught by controller[0]: Node.js v20.12.2
      host.iobroker
      	2024-04-19 17:08:23.959	error	Caught by controller[0]: }
      host.iobroker
      	2024-04-19 17:08:23.958	error	Caught by controller[0]: code: 'ERR_INVALID_ARG_VALUE'
      host.iobroker
      	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14) {
      host.iobroker
      	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
      host.iobroker
      	2024-04-19 17:08:23.958	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.iobroker
      	2024-04-19 17:08:23.958	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      host.iobroker
      	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1022:12)
      host.iobroker
      	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1206:32)
      host.iobroker
      	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
      host.iobroker
      	2024-04-19 17:08:23.957	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1369:14)
      host.iobroker
      	2024-04-19 17:08:23.956	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
      host.iobroker
      	2024-04-19 17:08:23.956	error	Caught by controller[0]: at createRequire (node:internal/modules/cjs/loader:1506:13)
      host.iobroker
      	2024-04-19 17:08:23.956	error	Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
      host.iobroker
      	2024-04-19 17:08:23.956	error	Caught by controller[0]: ^
      host.iobroker
      	2024-04-19 17:08:23.955	error	Caught by controller[0]: throw new ERR_INVALID_ARG_VALUE('filename', filename,
      host.iobroker
      	2024-04-19 17:08:23.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1506
      host.iobroker
      	2024-04-19 17:08:23.723	info	instance system.adapter.mihome-vacuum.0 started with pid 5691
      Mehr log habe ich bzw. wo kann ich mehr log des Adapters finden ?
      ? mcm1957 2 Replies Last reply Reply Quote 0
        A Former User @pusemuckel last edited by A Former User
        @pusemuckel
        mach mal in der Konsole des iobroker dockers ein "iob upload mihome-vacuum" und starte dann den Adapter nochmal.
        In die Konsole des Dockers kommst du im Terminal des Hosts (Synology? Proxmox? ) mit dem command
        sudo docker exec -tiu username containername /bin/bash
        bei mir ist das als user iobroker und der container heisst auch iobroker dann ein
        sudo docker exec -tiu iobroker iobroker /bin/bash
        danach bist du in /opt/iobroker und kannst als user iobroker die iob commands ausfuehren, ausser diejenigen, die ein iob maintenance brauchen..
        Ich gehe davon aus, dass du das buanet-docker-Image benutzt?
        edit:
        das Logfile bekommt man am schoensten, finde ich, in der Konsole mit dem command
        iob logs --watch
          @ilovegym said in npm Error bei mihome-vacuum Adapter Installation:
          Das hatte ich schon gemacht, leider auch ohne Erfolg. Ich konnte es mit
          npm install iobroker/adapter-core
          korrigieren, danach lässt sich der Adapter wieder starten!
          Schönes Wochenende!
          • Wintermute
            Wintermute @Guest last edited by
            @ilovegym ...und ich bei Linux 😀
            Alle Reparaturversuche sind fehlgeschlagen - Einspielen des Updates von letzter Nacht hat meinem Iobroker und meinem Staubsauger aber wieder auf die Beine geholfen. Das Update auf die 4.2.0 werde ich dann mal besser auslassen...
              Thomas Braun Most Active @Wintermute last edited by
              Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
              Läuft.
              Wintermute 1 Reply Last reply Reply Quote 0
              • Wintermute
                Wintermute @Thomas Braun last edited by
                @thomas-braun sagte in npm Error bei mihome-vacuum Adapter Installation:
                Läuft.
                Auf einem Windows-System? Hast Du irgendwelche Verrenkungen gemacht, damit der Adapter läuft?
                  Thomas Braun Most Active @Wintermute last edited by Thomas Braun
                  @wintermute
                  Läuft natürlich auf einem Betriebssystem.
                  Gerade nochmal durchgestartet:
                  2024-04-19 18:46:09.700  - info: mihome-vacuum.0 (1232) Got terminate signal TERMINATE_YOURSELF
                  2024-04-19 18:46:09.727  - error: mihome-vacuum.0 (1232) Socket Close
                  2024-04-19 18:46:09.731  - info: mihome-vacuum.0 (1232) terminating
                  2024-04-19 18:46:09.734  - info: mihome-vacuum.0 (1232) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-04-19 18:46:10.221  - info: mihome-vacuum.0 (1232) terminating
                  2024-04-19 18:46:15.796  - info: mihome-vacuum.0 (680497) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v21.7.3, js-controller: 5.0.19
                  2024-04-19 18:46:15.867  - info: mihome-vacuum.0 (680497) IOT enabled, create state
                  2024-04-19 18:46:16.017  - info: mihome-vacuum.0 (680497) select standard vacuum protocol....
                  2024-04-19 18:46:16.494  - info: mihome-vacuum.0 (680497) create state for carpet_mode
                  2024-04-19 18:46:16.649  - info: mihome-vacuum.0 (680497) settest next timer: not available
                  Kein Ding, kommt sofort wieder hoch.
                  Wintermute 1 Reply Last reply Reply Quote -1
                  • Wintermute
                    @wintermute
                    Da bin ich mir sicher, dass es auf einem Betriebssystem läuft 😉
                    Aber läuft es auch auf Meinem Betriebssystem?
                      @wintermute
                      Natürlich nicht.
                      • mcm1957
                        mcm1957 @pusemuckel last edited by
                        @pusemuckel
                        @wintermute
                        Siehe https://forum.iobroker.net/topic/74221/häufung-von-update-problemen/3
                        • mcm1957
                          mcm1957 @mcm1957 last edited by
                          Weiter gehts hier https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
                          1516
