    4. Update von Telegram und Alexa2 führt zu Fehler
    • DJMarc75
      DJMarc75 @Jup_HX last edited by
      @jup_hx
      Bitte das LOG nicht als Bild sondern auch als Text hier in Codetags posten und zusätzlich die Langfassung von iob diag.
        Jup_HX @DJMarc75 last edited by
        Hier die Langfassung:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Failed to query system properties: Connection timed out
        model name	: Intel(R) Core(TM) i5-4250U CPU @ 1.30GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         17:13:56 up 112 days, 17:30,  3 users,  load average: 0.84, 0.57, 0.64
        CPU threads: 4
        *** Time and Time Zones ***
        Failed to query server: Connection timed out
        *** User and Groups ***
        thorsten
        /home/thorsten
        thorsten sudo iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal:
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            6.4G        2.1G        3.4G         45K        1.0G        4.4G
        Swap:           4.3G         13M        4.3G
        Total:           10G        2.1G        7.6G
                 6144 M total memory
                 1959 M used memory
                  493 M active memory
                 2205 M inactive memory
                 3203 M free memory
                    0 M buffer memory
                  980 M swap cache
                 4096 M total swap
                   13 M used swap
                 4082 M free swap
        *** FAILED SERVICES ***
          UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount      loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount   loaded failed failed Kernel Configuration File System
        * logrotate.service         loaded failed failed Rotate log files
        * man-db.service            loaded failed failed Daily man-db regeneration
        * systemd-hostnamed.service loaded failed failed Hostname Service
        * systemd-logind.service    loaded failed failed User Login Management
        * systemd-timedated.service loaded failed failed Time & Date Service
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        7 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--100--disk--0 ext4       30G  9.4G   19G  34% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
        tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs                            tmpfs     1.6G   88K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
        tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
        tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
        tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
        /var:
        1.9G	/var/
        1.1G	/var/log
        975M	/var/log/journal/1942570c893249e8b5e5f9a3f5b1745b
        576M	/var/cache
        Archived and active journals take up 106.7M in the file system.
        /opt/iobroker/backups:
        2.0G	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        474M	/opt/iobroker/iobroker-data/
        306M	/opt/iobroker/iobroker-data/files
        109M	/opt/iobroker/iobroker-data/backup-objects
        57M	/opt/iobroker/iobroker-data/files/javascript.admin
        45M	/opt/iobroker/iobroker-data/files/devices.admin/static
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        22M	/opt/iobroker/iobroker-data/objects.jsonl
        22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.12.2
        /usr/bin/node 		v20.12.2
        /usr/bin/npm 		10.5.0
        /usr/bin/npx 		10.5.0
        /usr/bin/corepack 	0.25.2
        nodejs:
          Installed: 20.12.2-1nodesource1
          Candidate: 20.12.2-1nodesource1
          Version table:
         *** 20.12.2-1nodesource1 500
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.12.1-1nodesource1 500
             20.12.0-1nodesource1 500
             20.11.1-1nodesource1 500
             20.11.0-1nodesource1 500
             20.10.0-1nodesource1 500
             20.9.0-1nodesource1 500
             20.8.1-1nodesource1 500
             20.8.0-1nodesource1 500
             20.7.0-1nodesource1 500
             20.6.1-1nodesource1 500
             20.6.0-1nodesource1 500
             20.5.1-1nodesource1 500
             20.5.0-1nodesource1 500
             20.4.0-1nodesource1 500
             20.3.1-1nodesource1 500
             20.3.0-1nodesource1 500
             20.2.0-1nodesource1 500
             20.1.0-1nodesource1 500
             20.0.0-1nodesource1 500
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.19
        admin: 		6.13.16
        javascript: 	7.8.0
        Adapters from github: 	2
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
        + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.psa.0                    : psa                   : iobroker                                 - disabled
          system.adapter.psa.1                    : psa                   : iobroker                                 - disabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
          system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "evcc"         : 0.1.1    , installed 0.1.1
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "ical"         : 1.14.3   , installed 1.14.3
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "psa"          : 0.0.11   , installed 0.0.11
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "shelly"       : 6.8.0    , installed 6.8.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 3.2.1    , installed 3.2.1
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Objects and States
        Objects: 	16930
        States: 	14891
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        471677702  132/influxd
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       1064786022 611149/io.mqtt.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1064786021 611149/io.mqtt.0
        tcp        0      0 127.0.0.1:37931         0.0.0.0:*               LISTEN      1000       1064790494 611717/io.yahka.0
        tcp        0      0 10.10.10.10:2010        0.0.0.0:*               LISTEN      1000       1064788392 611401/io.hm-rpc.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1064782154 610907/iobroker.js-
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1064783272 610907/iobroker.js-
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       1064790872 611818/io.jarvis.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          766916284  286454/master
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          471678077  159/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          471674796  1/systemd
        tcp6       0      0 :::8086                 :::*                    LISTEN      998        471679201  132/influxd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1064794285 612151/io.simple-ap
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1064784166 610928/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1064792179 611753/io.web.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          766916285  286454/master
        tcp6       0      0 :::45203                :::*                    LISTEN      1000       1064789621 611717/io.yahka.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          471678079  159/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          471674798  1/systemd
        udp        0      0 0.0.0.0:52232           0.0.0.0:*                           1000       1064792748 611971/io.broadlink
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          471674797  1/systemd
        udp        0      0 10.10.10.10:123         0.0.0.0:*                           0          766917331  286563/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          766917329  286563/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          766916506  286563/ntpd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1064789622 611717/io.yahka.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1064785222 611178/io.shelly.0
        udp        0      0 0.0.0.0:43150           0.0.0.0:*                           1000       1064793401 611971/io.broadlink
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       1064792591 611971/io.broadlink
        udp6       0      0 :::111                  :::*                                0          471674799  1/systemd
        udp6       0      0 2003:f3:4703:b800:1:123 :::*                                113        1014880858 286563/ntpd
        udp6       0      0 fe80::10ec:11ff:fe7:123 :::*                                0          766917337  286563/ntpd
        udp6       0      0 ::1:123                 :::*                                0          766917333  286563/ntpd
        udp6       0      0 :::123                  :::*                                0          766917325  286563/ntpd
        2024-04-19 17:14:52.482  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
        2024-04-19 17:14:52.482  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
        2024-04-19 17:14:52.482  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1022:12)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/index.js:35:30)
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18) {
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]: }
        2024-04-19 17:14:52.483  - error: host.iobroker Caught by controller[0]: Node.js v20.12.2
        2024-04-19 17:14:52.483  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-04-19 17:14:52.483  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
        J Thomas Braun 2 Replies Last reply Reply Quote 0
          Jup_HX @Jup_HX last edited by
          Logausgabe
          2024-04-19 17:13:09.486  - info: host.iobroker "system.adapter.alexa2.0" enabled
          2024-04-19 17:13:09.545  - info: host.iobroker instance system.adapter.alexa2.0 started with pid 634271
          2024-04-19 17:13:09.704  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1506
          2024-04-19 17:13:09.704  - error: host.iobroker Caught by controller[0]:       throw new ERR_INVALID_ARG_VALUE('filename', filename,
          2024-04-19 17:13:09.704  - error: host.iobroker Caught by controller[0]:       ^
          2024-04-19 17:13:09.704  - error: host.iobroker Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at createRequire (node:internal/modules/cjs/loader:1506:13)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1022:12)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14) {
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]: }
          2024-04-19 17:13:09.705  - error: host.iobroker Caught by controller[0]: Node.js v20.12.2
          2024-04-19 17:13:09.705  - error: host.iobroker instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-04-19 17:13:09.705  - info: host.iobroker Restart adapter system.adapter.alexa2.0 because enabled
          2024-04-19 17:13:12.401  - info: host.iobroker "system.adapter.telegram.0" enabled
          2024-04-19 17:13:12.458  - info: host.iobroker instance system.adapter.telegram.0 started with pid 634278
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1506
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:       throw new ERR_INVALID_ARG_VALUE('filename', filename,
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:       ^
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at createRequire (node:internal/modules/cjs/loader:1506:13)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1022:12)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/index.js:35:30)
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18) {
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]: }
          2024-04-19 17:13:12.831  - error: host.iobroker Caught by controller[0]: Node.js v20.12.2
          2024-04-19 17:13:12.831  - error: host.iobroker instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-04-19 17:13:12.831  - info: host.iobroker Restart adapter system.adapter.telegram.0 because enabled
          2024-04-19 17:13:13.886  - info: host.iobroker instance system.adapter.telegram.0 started with pid 634285
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1506
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:       throw new ERR_INVALID_ARG_VALUE('filename', filename,
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:       ^
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]: TypeError [ERR_INVALID_ARG_VALUE]: The argument 'filename' must be a file URL object, file URL string, or absolute path string. Received 'file:// /opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/helpers.js'
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at createRequire (node:internal/modules/cjs/loader:1506:13)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/helpers.js:36:53)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1022:12)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-04-19 17:13:14.268  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:34:22)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1022:12)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.telegram/node_modules/@iobroker/adapter-core/build/cjs/index.js:35:30)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1369:14)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1427:10)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1206:32)
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18) {
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]:   code: 'ERR_INVALID_ARG_VALUE'
          2024-04-19 17:13:14.269  - error: host.iobroker Caught by controller[0]: }
            Thomas Braun Most Active @Jup_HX last edited by
            @jup_hx sagte in Update von Telegram und Alexa2 führt zu Fehler:
            Wassen da mit deinem Container los?
            mcm1957 J 2 Replies Last reply Reply Quote 0
            • mcm1957
              mcm1957 @Thomas Braun last edited by
              Es gab heute kurze Zeit (ca 30 Minuten) ein fehlerhaftes Downloadpaket. Durch eine Neuinstallation bzw ein Update eines Adapters sollte der Fehler automatisch behoben werden.
              Bitte diesbezügliche Diskussion primär in diesem Topic führen um Parallelitäten zu minimieren.
                Jup_HX @mcm1957 last edited by
                @mcm57
                Vielen Dank für die Info. Da war ich wohl "zum falschen Zeitpunkt am falschen Ort". Nach Neuinstallation läuft wieder alles wie gewohnt!
                  Jup_HX @Thomas Braun last edited by
                  @thomas-braun Ich habe keine Ahnung. Muss ich mir mal anschauen. Hast Du einen Tipp für mich, wo ich da ansetzen könnte?
                    Von Containern hab ich keine Ahnung. Schaut aber komisch aus.
                      Henny112 @Jup_HX last edited by
                      @mcm57
                      Habe auch alles neu gemacht läuft wieder. Bis auf ein Backup vom Conbee war etwas alt das hat ein wenig Arbeit gemacht.
                      • mcm1957
                        mcm1957 @Henny112 last edited by
                        Für das zugrundeliegende Problem gibts nun einen eigenen Topic mit Erläuterung. Falls noch wer Hilfe braucht bitte dort melden:
                        https://forum.iobroker.net/topic/74237/lösung-für-fehler-typeerror-err_invalid_arg_value
                          Wolhem last edited by
                          Bei mir läuft nach updates auch Alexa, telegram und zigbee nicht mehr.```
                          Bildschirmfoto vom 2024-04-21 12-29-35.png code_text
                            Thomas Braun Most Active @Wolhem last edited by Thomas Braun
                            @wolhem
                            Bitte das LogFile als TEXT in CodeTags eingebettet posten. Und in richtiger zeitlicher Abfolge.
                            Und zuvor das versuchen:
                            https://forum.iobroker.net/topic/74238/lösung-für-fehler-typeerror-err_invalid_arg_value
                              Homoran Global Moderator Administrators @Wolhem last edited by
                              @wolhem ein Bild in code-tags setzen macht daraus keinen Text 😁
                              BTW
                                Wolhem @Thomas Braun last edited by
                                Bei allen dreien finde ich den 3.1.2
                                  @wolhem sagte in Update von Telegram und Alexa2 führt zu Fehler:
                                  Das ist schön. Dann hast du den Fehler ja gefunden. Fix wie oben.
                                    @thomas-braun Supi, läuft wieder👍 👍 👍
                                      Weißt du vielleicht wodurch Funk-Rolladenmotoren gestört werden können?
                                        durch Funkstörungen 😁
                                        Was genau willst du wissen?
                                        1147
