    4. [Adapter] - Mihome
    [Adapter] - Mihome
    • fischi87
      fischi87 last edited by
      Hallo iobroker gemeinde, ich habe nun auch versucht mein mihome gatway mit iobroker zu verbinden leider ohne erfolg.
      ich bekomm im log diesen Fehler und das licht in Instanzen bleibt rot:
      	instance system.adapter.mihome.0 terminated with code 0 (OK)
      Caught	2017-12-22 08:10:47.499	error	by controller[2]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      Caught	2017-12-22 08:10:47.499	error	by controller[2]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2017-12-22 08:10:47.499	error	by controller[2]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2017-12-22 08:10:47.499	error	by controller[2]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      Caught	2017-12-22 08:10:47.499	error	by controller[2]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2017-12-22 08:10:47.499	error	by controller[2]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1330:35)
      Caught	2017-12-22 08:10:47.498	error	by controller[2]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1442:21
      Caught	2017-12-22 08:10:47.498	error	by controller[2]: at /opt/iobroker/node_modules/iobroker.mihome/main.js:1053:21
      Caught	2017-12-22 08:10:47.498	error	by controller[2]: at startMihome (/opt/iobroker/node_modules/iobroker.mihome/main.js:1102:11)
      Caught	2017-12-22 08:10:47.498	error	by controller[2]: at new Hub (/opt/iobroker/node_modules/iobroker.mihome/lib/mihome/Hub.js:31:20)
      Caught	2017-12-22 08:10:47.498	error	by controller[2]: 2017-12-22 08:10:47.454 - mihome.0 TypeError: function from() { [native code] } is not a constructor
      Caught	2017-12-22 08:10:47.498	error	by controller[1]: 2017-12-22 08:10:47.441 - mihome.0 uncaught exception: function from() { [native code] } is not a constructor
      Caught	2017-12-22 08:10:47.497	error	by controller[0]: [TypeError: function from() { [native code] } is not a constructor]
      kann mir jemand weiterhelfen? ich habe natürlich den key eingegeben und so weiter.
      danke Mit freundlichen Grüßen
      • eumats
        eumats last edited by
        Guten Morgen,
        nach 6 Wochen warten, konnte ich nun auch meine China-Sensoren in Betrieb nehmen.
        Wie schon von einigen beschrieben habe ich auch das Phänomen, das die Daten der Temperatursensoren "veraltet" sind.
        Im Datenpunkt mit der Temperatur/Luftfeuchtigkeit steht dann bei letzter Änderung z.B. eine Uhrzeit von vor 6 Stunden.
        Die Frage ist nun, aber die Daten gleich geblieben sind oder die Aktualisierung nicht funktioniert hat. Aber das sich die Temperatur/Luftfeuchtigkeit bei 1 bzw 2 Nachkommastellen in 6 Stunden gar nicht ändert, ist eher unwahrscheinlich.
        Wie ist denn der Adapter programmiert? Werden nur Änderungen, die der Sensor erkennt, "gepusht" oder holt sich der Adapter ach zyklisch neue Daten ohne "push" vom Sensor?
        Die Lösungen der anderen mit einem ähnlichen Fehler greifen bei mir nicht.
        Björn
        • eumats
          @fischi87:
          ich bekomm im log diesen Fehler und das licht in Instanzen bleibt rot: `
          Hmm. Bei mir lief die Ersteinrichtung gestern ohne Probleme. Hast Du die aktuelle Version des Adapters installiert?
          Poste mal einen Screenshot Deiner Einstellungen. Vielleicht ist es da nur eine Kleinigkeit.
          • fischi87
            @eumats:
            @fischi87:
            Poste mal einen Screenshot Deiner Einstellungen. Vielleicht ist es da nur eine Kleinigkeit. `
            danke für deine Antwort, hier mal der screenshot.
              hast du ein oder mehrere gateways?? wenn nur ein warum steht da eine ip in der Tabelle
              • fischi87
                @arteck:
                hast du ein oder mehrere gateways?? wenn nur ein warum steht da eine ip in der Tabelle `
                ja habe nur ein, hab in einem video gesehen das da eine rein muss. ich werde diese mal entfernen.
                der Fehler bleibt bestehen :?: :?: :?:
                • eumats
                  @fischi87:
                  danke für deine Antwort, hier mal der screenshot. `
                  Sicht bei mir ähnlich aus. Außer das ich bei ioBroker IP mein eth0 Device eingetragen. Bei Gateway Keys habe ich auch mein Gateway eingetragen, obwohl ich nur eines habe…
                  Vielleicht ein Fehler beim Key. Meiner hat 16 Zeichen...
                  Hast Du alle Einstellungen wie unter https://github.com/ioBroker/ioBroker.mihome beschrieben vorgenommen?
                  • fischi87
                    @eumats:
                    @fischi87:
                    Hast Du alle Einstellungen wie unter https://github.com/ioBroker/ioBroker.mihome beschrieben vorgenommen? `
                    ja genau so habe ich dies gemacht wie bei GitHub beschrieben. hab schon alles versucht aber es kommt immer der gleiche Fehler :evil:
                    • eumats
                      @fischi87:
                      ja genau so habe ich dies gemacht wie bei GitHub beschrieben. hab schon alles versucht aber es kommt immer der gleiche Fehler :evil: `
                      Schalte mal das Debüt vom Adapter ein. Vielleicht bringt das etwas mehr Informationen…
                      • fischi87
                        @eumats:
                        @fischi87:
                        Schalte mal das Debüt vom Adapter ein. Vielleicht bringt das etwas mehr Informationen… `
                        Was meinst du? Das log ist im debug
                        • eumats
                          Ich meinte das Log. Ich dachte das wäre der normale "info" Level. Hast du den Adapter mal deinstalliert und nicht installiert?
                          • fischi87
                            @eumats:
                            Ich meinte das Log. Ich dachte das wäre der normale "info" Level. Hast du den Adapter mal deinstalliert und nicht installiert? `
                            ja alles versucht, per Konsole installiert über die Katze, normal. alle Wege versucht, immer der gleiche Fehler. nervt mich, hab schon gesucht hab noch keinen ähnlichen Beitrag gefunden.
                            was mir auffällt, dieser search Button funktioniert bei mir nicht, auch wenn ich diesen drücke, findet der Adapter keine ip vom gateway. das gateway ist natürlich im wlan, hab ich geprüft und hat auch empfang etc. ist da vielleicht schon was nicht richtig oder funktioniert die search Funktion nicht immer?
                              die Suchfunktion spielt bei dir keine Rolle..die ist nur dafür da wenn du mehrere Gateways hast ..
                              stelle bitte in der combobox die IP von iobroker ein und nicht die 0.0.0.0.0
                              kannst du den über die App das Teil ansteuern ?? ein aus heller dunkler ??
                                Habe kein mihome, kenne den Adapter auch nicht;
                                Aber:
                                @fischi87:
                                per Konsole installiert über die Katze, normal `
                                Hast du vorher die alte Version restlos entfernt und den Cache geleert?
                                Hast du die neue Version auch in deine Installation geladen?
                                Also:
                                • Mihome Instanz in den Mülleimer
                                • Mihome Adapter in den Mülleimer
                                • auf die Konsole:
                                sudo npm cache clean
                                • im Admin:
                                • Über Octocat Icon neu installieren
                                Wieder auf die Konsole
                                cd /opt/iobroker
                                sudo iobroker upload mihome
                                oder wie der Adapter richtig heisst.
                                • im Admin:
                                • Neue Instanz erzeugen
                                Vor dem PC:
                                • Hoffen :lol:
                                Rainer
                                • fischi87
                                  @Homoran:
                                  Aber:
                                  @fischi87:
                                  Also:
                                  • auf die Konsole:
                                  • im Admin:
                                  cd /opt/iobroker
                                  • im Admin:
                                  Vor dem PC:
                                  • Hoffen :lol:
                                  Rainer `
                                  Hallo Rainer, ja hab ich erneut wieder so gemacht wie du geschrieben hast, der selbe Fehler!!!
                                  • fischi87
                                    @arteck:
                                    kannst du den über die App das Teil ansteuern ?? ein aus heller dunkler ?? `
                                    Ja kann ich alles tun von der app aus. Hab auch die ip vom iobroker eingetragen, trotzdem gleicher Fehler!!!
                                      Dann bin ich wieder ganz still
                                      Viel Glück weiterhin
                                      Rainer
                                        stell den adapter mal auf debug und poste mal ….
                                        das kann doch nicht
                                        • fischi87
                                          @arteck:
                                          das kann doch nicht `
                                          Hab doch geschrieben das die log Ausgabe im debug schon ist!
                                            dann setzt den Filter im Log auf mihome und poste den mal.
                                            wo läuft dein iobroker ?? darf der lokal überall zugreifen oder hast du ne sperre auf ip/port ebene (firewall)??
                                            darf das gateway ins netz lokal ?? (nach aussen gaht ja sonst würde es über dein handy nicht funktioniren)
                                            Fragen über fragen :roll:
                                            1.0k
                                            mihome
                                            111
                                            559
                                            171852
