    5. Daten aus XML URL auslesen und verwenden
    • mickym
      mickym Most Active @MiSchu 0 last edited by mickym
      @mischu-0 Na mit dem request Puzzleteil
      Ich glaube man muss eine Variable result erstellen.
      Probiere es mal so:
       <variables>
         <variable id="8=$*!H(xy1^`AZEQeNE~">Objekt</variable>
         <variable id="Zz(+DtU$uPpEY:Mgo{C~">result</variable>
       </variables>
       <block type="request" id="uHm%I5YOd^y41[[D6p:y" x="-987" y="-512">
         <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
         <field name="WITH_STATEMENT">FALSE</field>
         <field name="LOG"></field>
         <value name="URL">
           <shadow type="text" id="b%X0a{d#6T?*GNP;Nqg6">
             <field name="TEXT">http://</field>
           <block type="variables_set" id="765/wUu!s58uh0I_gH(-">
             <field name="VAR" id="8=$*!H(xy1^`AZEQeNE~">Objekt</field>
               <block type="get_attr" id="Qr)T/h2jra_zYko_$T{=">
                 <value name="PATH">
                   <shadow type="text" id="U!ym|5$}*dIpoTyCS^H@">
                     <field name="TEXT">data</field>
                 <value name="OBJECT">
                   <block type="variables_get" id="i,D8WS38zv_n#y`DuZyQ">
                     <field name="VAR" id="Zz(+DtU$uPpEY:Mgo{C~">result</field>
               <block type="debug" id="h36.2[I}R`=v`,|uz~%_">
                 <value name="TEXT">
                   <shadow type="text" id="V-n!Em:i+u+~7EZl#o:p">
                   <block type="variables_get" id="z1fV)iBgJq7n!Hfk;;D6">
                   <block type="debug" id="UGFUJqPd{S+@hd9xcfS%">
                     <value name="TEXT">
                       <shadow type="text" id="XJi1WK{gHhP=Yv#Wi=?3">
                       <block type="convert_jsonata" id="$,zuxsq(^[:9@-cHs(8g">
                         <value name="EXPRESSION">
                           <shadow type="text" id="1zurDIuQyI-K,qys$w0Z">
                             <field name="TEXT">$.*</field>
                         <value name="TARGET">
                           <block type="variables_get" id="})8i.I6Q#G`[n`vS?0;t">
                       <block type="debug" id=",svsp;khW{!T$+BV*(c}">
                         <value name="TEXT">
                           <shadow type="text" id=")9%NhZ9}C(]{SsWQp~OE">
                           <block type="get_attr" id="xHiM0scKFVv[.SafIhs#">
                             <value name="PATH">
                               <shadow type="text" id="{N1rfGmojLyWd?m,kK9|">
                                 <field name="TEXT">20240421</field>
                               <block type="variables_get" id="-huXr#6}lL6HM@]yP%yb">
      Ggf. mach nochmal eine debug Ausgabe der result Variable und schau ob der JSON da rauskommt. Die URL musst halt noch eintragen
        MiSchu 0 @mickym last edited by
        @mickym
        20240421 ändert sich aber für jeden Tag
        • mickym
          @mischu-0
          Probier das mal so.
           <variables>
           </variables>
             <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
             <field name="WITH_STATEMENT">TRUE</field>
             <value name="URL">
                     <value name="PATH">
                 <value name="TEXT">
                     <value name="TEXT">
                         <value name="TEXT">
                             <value name="PATH">
          @mickym
          Ja deswegen wird nur die JSONATA Lösung funktionieren - also kannst das mit dem Attribut löschen. Das dient nur mal der Veranschaulichung.
          Mach vielleicht noch ein debug für das result rein
          damit man sieht ob der Abruf klappt.
          M paul53 2 Replies Last reply Reply Quote 0
            MiSchu 0 @mickym last edited by MiSchu 0
            @mickym
            hinbekommen
            VIELEN DANK
            ich muss jetzt erstmal ins Bett
            • mickym
              @mischu-0 Ja das Objekt kannst auch außerhalb der Klammer verwenden und dann das Array wegschreiben, oder was Du sonst damit machen willst.
              • mickym
                @mischu-0 sagte in Daten aus XML URL auslesen und verwenden:
                Dann gute Nacht. Du findest sicher eine Menge Helfer - ich bin wie gesagt, kein Freund der Puzzleteile.
                  Also den Wert habe ich jetzt ja. Verwenden innerhalb des Blocklys ist nun kein Problem.
                  Aber kann ich diesen Wert nun auch in ein iobrocker - objekt senden, so das ich ihn in anderen Skripten verwenden kann ?
                  • Codierknecht
                    Codierknecht Developer Most Active @MiSchu 0 last edited by
                    @mischu-0
                    Klar!
                    Einfach einen eigenen DP unterhalb von 0_userdata.0 anlegen und den Wert per "Aktualisiere" dort reinschreiben.
                      MiSchu 0 @Codierknecht last edited by MiSchu 0
                      @codierknecht
                      ok
                        paul53 @mickym last edited by paul53
                        @mickym sagte: deswegen wird nur die JSONATA Lösung funktionieren
                        Es geht auch ohne JSONATA.
                        1274
