    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Adapter Tuya 3.15.0
    Adapter Tuya 3.15.0
      Thomas Braun Most Active @biker1602 last edited by
      @biker1602
      Bei LogLevel 'silly' ist es auch kein Wunder, wenn das Log 'megalang' wird.
      iob stop
      sudo systemctl set-default multi-user.target
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
        biker1602 @Thomas Braun last edited by
        Alles gemacht LogLevel auf Debug Richtig?
        2024-03-06 13:28:28.430 - info: tuya.1 (1536) Got terminate signal TERMINATE_YOURSELF
        2024-03-06 13:28:31.431 - info: tuya.1 (1536) terminating
        2024-03-06 13:28:31.432 - debug: tuya.1 (1536) Plugin sentry destroyed
        2024-03-06 13:28:31.432 - info: tuya.1 (1536) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-03-06 13:28:36.538 - debug: tuya.1 (1556) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-03-06 13:28:36.570 - debug: tuya.1 (1556) Objects client ready ... initialize now
        2024-03-06 13:28:36.571 - debug: tuya.1 (1556) Objects create System PubSub Client
        2024-03-06 13:28:36.572 - debug: tuya.1 (1556) Objects create User PubSub Client
        2024-03-06 13:28:36.625 - debug: tuya.1 (1556) Objects client initialize lua scripts
        2024-03-06 13:28:36.628 - debug: tuya.1 (1556) Objects connected to redis: 127.0.0.1:9001
        2024-03-06 13:28:36.662 - debug: tuya.1 (1556) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-03-06 13:28:36.681 - debug: tuya.1 (1556) States create System PubSub Client
        2024-03-06 13:28:36.681 - debug: tuya.1 (1556) States create User PubSub Client
        2024-03-06 13:28:36.766 - debug: tuya.1 (1556) States connected to redis: 127.0.0.1:9000
        2024-03-06 13:28:36.804 - debug: tuya.1 (1556) Plugin sentry Initialize Plugin (enabled=true)
        2024-03-06 13:28:36.953 - info: tuya.1 (1556) starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.19.1, js-controller: 5.0.19
        2024-03-06 13:28:36.962 - debug: tuya.1 (1556) http-mitm-proxy/lib/ca.js already patched to only generate 1 year long certificates
        2024-03-06 13:28:37.044 - debug: tuya.1 (1556) init 3 known devices
        2024-03-06 13:28:37.048 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68: Init device with data (after merge): {"data":{"virtual":false,"lon":"0.0000","ownerId":"175238259","uuid":"b478ed0893c6fb5d","mac":"508a0643de99","accessType":0,"otaInfo":{"supportAuto":true,"otaUpgradeModes":[0],"otaModuleMap":{"wifi":{"upgradeStatus":0,"cdv":"1.0.0","bv":"40.00","verSw":"1.0.3"},"mcu":{"upgradeStatus":0,"cdv":"","verSw":"1.0.3"}}},"iconUrl":"https://images.tuyaeu.com/smart/icon/bay1581409214911SvxF/7e5a9daf7f3bbfe91ab192f6c0b4aa63.jpg","communication":{"mqttTopicAttr":1,"communicationNode":"bfaa96647aea5d03eacw68","communicationModes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"dataModel":1,"connectionStatus":1},"gatewayVerCAD":"1.0.2","lat":"0.0000","runtimeEnv":"prod","devKey":"","devId":"bfaa96647aea5d03eacw68","productId":"mrerultqnbwpx2jt","activeTime":1701952521,"cloudOnline":true,"baseAttribute":1024,"virtualExperience":false,"devAttribute":515,"dataPointInfo":{"dpMaxTime":1709548004276,"dpName":{},"dps":{"20":false,"21":0,"22":17,"23":220,"24":"003c03e802f8","25":"000d0d0000000000000000460000","26":0,"27":"","28":"","30":"AAAAfwUBBgAAAAAAAAABBh4AAAAAFBkBCQAAAAAAZGQBFAAAAAAAUDIBFx4AAAAAAAA=","31":"AAA=","32":"AAA=","101":true},"dpsTime":{"20":1709548004276,"21":1706790900787,"22":1709408638654,"23":1706790900788,"24":1706790643509,"25":1704913926411,"26":1702120453612,"27":1701952521419,"28":1701952521419,"30":1709286729273,"31":1709286729304,"32":1709286729335,"101":1702120453617}},"meta":{},"name":"Lampe Fensterbank","timezoneId":"Europe/Berlin","deviceTopo":{},"localKey":"JWlb;o{|2fO3)-j4","dpName":{},"groudId":175238259,"schema":[{"code":"switch_led","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editPermission":false},{"code":"work_mode","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editPermission":false},{"code":"bright_value","defaultValue":"","canTrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editPermission":false},{"code":"temp_value","defaultValue":"","canTrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editPermission":false},{"code":"colour_data","defaultValue":"","canTrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editPermission":false},{"code":"scene_data","defaultValue":"","canTrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editPermission":false},{"code":"countdown","defaultValue":"","canTrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editPermission":false},{"code":"music_data","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultRecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editPermission":true},{"code":"control_data","defaultValue":"","canTrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultRecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editPermission":false},{"code":"rhythm_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editPermission":false},{"code":"sleep_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editPermission":false},{"code":"wakeup_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editPermission":false},{"code":"remote_switch","defaultValue":"false","canTrigger":true,"type":"obj","executable":true,"mode":"rw","defaultRecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editPermission":false}],"productKey":"mrerultqnbwpx2jt","schemaExt":[{"complexType":"","id":22,"inputStyle":"bright","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"temp","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}],"version":"","dpCodes":{"switch_led":{"code":"switch_led","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editPermission":false},"work_mode":{"code":"work_mode","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editPermission":false},"bright_value":{"code":"bright_value","defaultValue":"","canTrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editPermission":false},"temp_value":{"code":"temp_value","defaultValue":"","canTrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editPermission":false},"colour_data":{"code":"colour_data","defaultValue":"","canTrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editPermission":false},"scene_data":{"code":"scene_data","defaultValue":"","canTrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editPermission":false},"countdown":{"code":"countdown","defaultValue":"","canTrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editPermission":false},"music_data":{"code":"music_data","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultRecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editPermission":true},"control_data":{"code":"control_data","defaultValue":"","canTrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultRecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editPermission":false},"rhythm_mode":{"code":"rhythm_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editPermission":false},"sleep_mode":{"code":"sleep_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editPermission":false},"wakeup_mode":{"code":"wakeup_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editPermission":false},"remote_switch":{"code":"remote_switch","defaultValue":"false","canTrigger":true,"type":"obj","executable":true,"mode":"rw","defaultRecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editPermission":false}}},"errorcount":0}
        2024-03-06 13:28:37.052 - debug: tuya.1 (1556) connected set to false
        2024-03-06 13:28:37.052 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68: Create device objects if not exist
        2024-03-06 13:28:37.054 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch","native":{"code":"switch_led","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editPermission":false}},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level","native":{"code":"work_mode","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editPermission":false}},{"type":"number","unit":"%","min":1,"max":100,"scale":1,"read":true,"write":true,"name":"bright_value","id":22,"role":"level","native":{"code":"bright_value","defaultValue":"","canTrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editPermission":false}},{"type":"number","unit":"%","min":0,"max":1000,"read":true,"write":true,"name":"temp_value","id":23,"role":"level","native":{"code":"temp_value","defaultValue":"","canTrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text","native":{"code":"colour_data","defaultValue":"","canTrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text","native":{"code":"scene_data","defaultValue":"","canTrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editPermission":false}},{"type":"number","unit":"s","min":0,"max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level","native":{"code":"countdown","defaultValue":"","canTrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text","native":{"code":"music_data","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultRecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editPermission":true}},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text","native":{"code":"control_data","defaultValue":"","canTrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultRecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"rhythm_mode","id":30,"role":"text","native":{"code":"rhythm_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"sleep_mode","id":31,"role":"text","native":{"code":"sleep_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"wakeup_mode","id":32,"role":"text","native":{"code":"wakeup_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editPermission":false}},{"type":"boolean","read":true,"write":true,"name":"remote_switch","id":101,"role":"switch","native":{"code":"remote_switch","defaultValue":"false","canTrigger":true,"type":"obj","executable":true,"mode":"rw","defaultRecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editPermission":false}}]
        2024-03-06 13:28:37.055 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 20
        2024-03-06 13:28:37.055 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 21
        2024-03-06 13:28:37.056 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 22
        2024-03-06 13:28:37.056 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 23
        2024-03-06 13:28:37.056 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 24
        2024-03-06 13:28:37.057 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 25
        2024-03-06 13:28:37.057 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 26
        2024-03-06 13:28:37.057 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 27
        2024-03-06 13:28:37.057 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 28
        2024-03-06 13:28:37.057 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 30
        2024-03-06 13:28:37.058 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 31
        2024-03-06 13:28:37.058 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 32
        2024-03-06 13:28:37.058 - debug: tuya.1 (1556) bfaa96647aea5d03eacw68 Register onChange for 101
        2024-03-06 13:28:37.059 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4: Init device with data (after merge): {"data":{"virtual":false,"lon":"0.0000","ownerId":"175238259","uuid":"8e28f7d76f9af82a","mac":"508a0643cc55","accessType":0,"otaInfo":{"supportAuto":true,"otaUpgradeModes":[0],"otaModuleMap":{"wifi":{"upgradeStatus":0,"cdv":"1.0.0","bv":"40.00","verSw":"1.0.3"},"mcu":{"upgradeStatus":0,"cdv":"","verSw":"1.0.3"}}},"iconUrl":"https://images.tuyaeu.com/smart/icon/bay1581409214911SvxF/7e5a9daf7f3bbfe91ab192f6c0b4aa63.jpg","communication":{"mqttTopicAttr":1,"communicationNode":"bff18e0a272d5feaf3qka4","communicationModes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"dataModel":1,"connectionStatus":1},"gatewayVerCAD":"1.0.2","lat":"0.0000","runtimeEnv":"prod","devKey":"","devId":"bff18e0a272d5feaf3qka4","productId":"mrerultqnbwpx2jt","activeTime":1709299360,"cloudOnline":true,"baseAttribute":1024,"virtualExperience":false,"devAttribute":515,"dataPointInfo":{"dpMaxTime":1709722358359,"dpName":{},"dps":{"20":false,"21":1,"22":2,"23":660,"24":"015c03840064","25":"000e0d0000000000000000c80000","26":0,"27":"","28":"","30":"AAAAAAA=","31":"AAA=","32":"AAA=","101":true},"dpsTime":{"20":1709722358359,"21":1709722211999,"22":1709722091821,"23":1709722111588,"24":1709636713989,"25":1709299363509,"26":1709716986399,"27":1709299360771,"28":1709299360771,"30":1709299363516,"31":1709299363600,"32":1709299363713,"101":1709545046269}},"meta":{},"name":"LDVWIFIA100E27RGBW 3","timezoneId":"Europe/Berlin","deviceTopo":{},"localKey":";|=~CZFs3%yjveS*","dpName":{},"groudId":175238259,"schema":[{"code":"switch_led","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editPermission":false},{"code":"work_mode","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editPermission":false},{"code":"bright_value","defaultValue":"","canTrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editPermission":false},{"code":"temp_value","defaultValue":"","canTrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editPermission":false},{"code":"colour_data","defaultValue":"","canTrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editPermission":false},{"code":"scene_data","defaultValue":"","canTrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editPermission":false},{"code":"countdown","defaultValue":"","canTrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editPermission":false},{"code":"music_data","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultRecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editPermission":true},{"code":"control_data","defaultValue":"","canTrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultRecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editPermission":false},{"code":"rhythm_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editPermission":false},{"code":"sleep_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editPermission":false},{"code":"wakeup_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editPermission":false},{"code":"remote_switch","defaultValue":"false","canTrigger":true,"type":"obj","executable":true,"mode":"rw","defaultRecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editPermission":false}],"productKey":"mrerultqnbwpx2jt","schemaExt":[{"complexType":"","id":22,"inputStyle":"bright","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"temp","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}],"version":"","dpCodes":{"switch_led":{"code":"switch_led","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editPermission":false},"work_mode":{"code":"work_mode","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editPermission":false},"bright_value":{"code":"bright_value","defaultValue":"","canTrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editPermission":false},"temp_value":{"code":"temp_value","defaultValue":"","canTrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editPermission":false},"colour_data":{"code":"colour_data","defaultValue":"","canTrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editPermission":false},"scene_data":{"code":"scene_data","defaultValue":"","canTrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editPermission":false},"countdown":{"code":"countdown","defaultValue":"","canTrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editPermission":false},"music_data":{"code":"music_data","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultRecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editPermission":true},"control_data":{"code":"control_data","defaultValue":"","canTrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultRecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editPermission":false},"rhythm_mode":{"code":"rhythm_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editPermission":false},"sleep_mode":{"code":"sleep_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editPermission":false},"wakeup_mode":{"code":"wakeup_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editPermission":false},"remote_switch":{"code":"remote_switch","defaultValue":"false","canTrigger":true,"type":"obj","executable":true,"mode":"rw","defaultRecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editPermission":false}}},"errorcount":0}
        2024-03-06 13:28:37.105 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4: Create device objects if not exist
        2024-03-06 13:28:37.106 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch","native":{"code":"switch_led","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editPermission":false}},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level","native":{"code":"work_mode","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editPermission":false}},{"type":"number","unit":"%","min":1,"max":100,"scale":1,"read":true,"write":true,"name":"bright_value","id":22,"role":"level","native":{"code":"bright_value","defaultValue":"","canTrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editPermission":false}},{"type":"number","unit":"%","min":0,"max":1000,"read":true,"write":true,"name":"temp_value","id":23,"role":"level","native":{"code":"temp_value","defaultValue":"","canTrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text","native":{"code":"colour_data","defaultValue":"","canTrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text","native":{"code":"scene_data","defaultValue":"","canTrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editPermission":false}},{"type":"number","unit":"s","min":0,"max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level","native":{"code":"countdown","defaultValue":"","canTrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text","native":{"code":"music_data","defaultValue":"","canTrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultRecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editPermission":true}},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text","native":{"code":"control_data","defaultValue":"","canTrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultRecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"rhythm_mode","id":30,"role":"text","native":{"code":"rhythm_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"sleep_mode","id":31,"role":"text","native":{"code":"sleep_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editPermission":false}},{"type":"string","read":true,"write":true,"name":"wakeup_mode","id":32,"role":"text","native":{"code":"wakeup_mode","defaultValue":"","canTrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultRecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editPermission":false}},{"type":"boolean","read":true,"write":true,"name":"remote_switch","id":101,"role":"switch","native":{"code":"remote_switch","defaultValue":"false","canTrigger":true,"type":"obj","executable":true,"mode":"rw","defaultRecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editPermission":false}}]
        2024-03-06 13:28:37.107 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 20
        2024-03-06 13:28:37.107 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 21
        2024-03-06 13:28:37.107 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 22
        2024-03-06 13:28:37.107 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 23
        2024-03-06 13:28:37.107 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 24
        2024-03-06 13:28:37.108 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 25
        2024-03-06 13:28:37.108 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 26
        2024-03-06 13:28:37.108 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 27
        2024-03-06 13:28:37.108 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 28
        2024-03-06 13:28:37.108 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 30
        2024-03-06 13:28:37.109 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 31
        2024-03-06 13:28:37.109 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 32
        2024-03-06 13:28:37.109 - debug: tuya.1 (1556) bff18e0a272d5feaf3qka4 Register onChange for 101
        2024-03-06 13:28:37.109 - debug: tuya.1 (1556) bf56eab5f9bb071534bifs: Init device with data (after merge): {"data":{"virtual":false,"lon":"0.0000","ownerId":"175238259","uuid":"23b60bbc36324721","mac":"508a0643e7bb","accessType":0,"otaInfo":{"supportAuto":true,"otaUpgradeModes":[0],"otaModuleMap":{"wifi":{"upgradeStatus":0,"cdv":"1.0.0","bv":"40.00","verSw":"1.0.3"},"mcu":{"upgradeStatus":0,"cdv":"","verSw":"1.0.3"}}},"iconUrl":"https://images.tuyaeu.com/smart/icon/bay1581409214911SvxF/7e5a9daf7f3bbfe91ab192f6c0b4aa63.jpg","communication":{"mqttTopicAttr":1,"communicationNode":"bf56eab5f9bb071534bifs","communicationModes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"dataModel":1,"connectionStatus":1},"gatewayVerCAD":"1.0.2","lat":"0.0000","runtimeEnv":"prod","devKey":"","devId":"bf56eab5f9bb071534bifs","productId":"mrerultqnbwpx2jt","activeTime":1702120351,"cloudOnline":true,"baseAttribute":1024,"virtualExperience":false,"devAttribute":515,"dataPointInfo":{"dpMaxTime":1709713886045,"dpName":{},"dps":{"20":false,"21":0,"22":5,"23":200,"24":"00f003e80258","25":"000e0d0000000000000000c80000","26":0,"27":"","28":"","30":"AAAAAAA=","31":"AAA=","32":"AAA=","101":true},"dpsTime":{"20":1709713886045,"21":1709304060383,"22":1709405584680,"23":1709304057923,"24":1706790643549,"25":1702122643874,"26":1702122643874,"27":1702120351342,"28":1702120351342,"30":1709286732580,"31":1709286732610,"32":1709286732639,"101":1702122643882}},"meta":{},"name":"Lampe Couch ","timezoneId":"Europe/Berlin","deviceTopo":{},"localKey":"Zd65E+81:="" tuya.1="" (1556)="" bf56eab5f9bb071534bifs:="" create="" device="" objects="" if="" not="" exist="" 13:28:37.154="" [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch","native":{"code":"switch_led","defaultvalue":"","cantrigger":true,"iconname":"icon-dp_power","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"开关","property":{"type":"bool"},"id":20,"editpermission":false}},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level","native":{"code":"work_mode","defaultvalue":"","cantrigger":true,"iconname":"icon-dp_mode","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"id":21,"editpermission":false}},{"type":"number","unit":"%","min":1,"max":100,"scale":1,"read":true,"write":true,"name":"bright_value","id":22,"role":"level","native":{"code":"bright_value","defaultvalue":"","cantrigger":true,"iconname":"icon-liangdu1","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"亮度值","property":{"min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"editpermission":false}},{"type":"number","unit":"%","min":0,"max":1000,"read":true,"write":true,"name":"temp_value","id":23,"role":"level","native":{"code":"temp_value","defaultvalue":"","cantrigger":true,"iconname":"icon-dp_half","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"冷暖值","property":{"min":0,"max":1000,"scale":0,"step":1,"type":"value"},"id":23,"editpermission":false}},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text","native":{"code":"colour_data","defaultvalue":"","cantrigger":true,"iconname":"icon-yanse","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"彩光","property":{"type":"string","maxlen":255},"id":24,"editpermission":false}},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text","native":{"code":"scene_data","defaultvalue":"","cantrigger":true,"iconname":"icon-shoucang","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"场景","property":{"type":"string","maxlen":255},"id":25,"editpermission":false}},{"type":"number","unit":"s","min":0,"max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level","native":{"code":"countdown","defaultvalue":"","cantrigger":true,"iconname":"icon-a_nav_timer","type":"obj","executable":true,"mode":"rw","defaultrecommend":true,"name":"倒计时","property":{"unit":"s","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"editpermission":false}},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text","native":{"code":"music_data","defaultvalue":"","cantrigger":true,"iconname":"icon-dp_mic","type":"obj","executable":true,"mode":"wr","defaultrecommend":false,"name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"editpermission":true}},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text","native":{"code":"control_data","defaultvalue":"","cantrigger":false,"iconname":"icon-dp_box2","type":"obj","executable":false,"mode":"wr","defaultrecommend":true,"name":"调节","property":{"type":"string","maxlen":255},"id":28,"editpermission":false}},{"type":"string","read":true,"write":true,"name":"rhythm_mode","id":30,"role":"text","native":{"code":"rhythm_mode","defaultvalue":"","cantrigger":false,"iconname":"icon-dp_time3","type":"raw","executable":false,"mode":"rw","defaultrecommend":false,"name":"生物节律","property":{"type":"raw","maxlen":"255"},"id":30,"editpermission":false}},{"type":"string","read":true,"write":true,"name":"sleep_mode","id":31,"role":"text","native":{"code":"sleep_mode","defaultvalue":"","cantrigger":false,"iconname":"icon-dp_sleep","type":"raw","executable":false,"mode":"rw","defaultrecommend":false,"name":"入睡计划","property":{"type":"raw","maxlen":"255"},"id":31,"editpermission":false}},{"type":"string","read":true,"write":true,"name":"wakeup_mode","id":32,"role":"text","native":{"code":"wakeup_mode","defaultvalue":"","cantrigger":false,"iconname":"icon-dp_sun","type":"raw","executable":false,"mode":"rw","defaultrecommend":false,"name":"唤醒计划","property":{"type":"raw","maxlen":"255"},"id":32,"editpermission":false}},{"type":"boolean","read":true,"write":true,"name":"remote_switch","id":101,"role":"switch","native":{"code":"remote_switch","defaultvalue":"false","cantrigger":true,"type":"obj","executable":true,"mode":"rw","defaultrecommend":false,"name":"遥控器开关","property":{"type":"bool"},"id":101,"editpermission":false}}]="" bf56eab5f9bb071534bifs="" register="" onchange="" for="" 20="" 21="" 13:28:37.155="" 22="" 23="" 24="" 25="" 26="" 27="" 13:28:37.156="" 28="" 30="" 31="" 32="" 101="" 13:28:37.247="" info:="" bff18e0a272d5feaf3qka4:="" do="" connect="" locally="" to="" 13:28:37.295="" 13:28:37.338="" bfaa96647aea5d03eacw68:="" existing="" devices="" initialized="" 13:28:37.340="" try="" sync="" from="" cloud="" using="" stored="" credentials="" 13:28:37.384="" reuse="" session="" id:="" eu170195n24187253zkmxlx372f51c62233c43440334338e27270533="" 13:28:37.429="" warn:="" can="" listen="" encrypted="" udp="" packages:="" error:="" bind="" eaddrinuse="" 0.0.0.0:6666="" 0.0.0.0:6667="" 13:28:37.523="" id="" is="" still="" valid="" 13:28:37.834="" process="" found="" devices:="" [{"a":"tuya.m.my.group.device.list","success":true,"v":"1.0","status":"ok","result":[{"virtual":false,"lon":"0.0000","ownerid":"175238259","uuid":"b478ed0893c6fb5d","mac":"508a0643de99","accesstype":0,"otainfo":{"supportauto":true,"otaupgrademodes":[0],"otamodulemap":{"wifi":{"upgradestatus":0,"cdv":"1.0.0","bv":"40.00","versw":"1.0.3"},"mcu":{"upgradestatus":0,"cdv":"","versw":"1.0.3"}}},"iconurl":"https:="" images.tuyaeu.com="" smart="" icon="" bay1581409214911svxf="" 7e5a9daf7f3bbfe91ab192f6c0b4aa63.jpg","communication":{"mqtttopicattr":1,"communicationnode":"bfaa96647aea5d03eacw68","communicationmodes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"datamodel":1,"connectionstatus":1},"gatewayvercad":"1.0.2","lat":"0.0000","runtimeenv":"prod","devkey":"","devid":"bfaa96647aea5d03eacw68","productid":"mrerultqnbwpx2jt","ip":"84.58.216.67","activetime":1701952521,"cloudonline":true,"baseattribute":1024,"virtualexperience":false,"devattribute":515,"datapointinfo":{"dpmaxtime":1709548004276,"dpname":{},"dps":{"20":false,"21":"white","22":170,"23":220,"24":"003c03e802f8","25":"000d0d0000000000000000460000","26":0,"27":"","28":"","30":"aaaafwubbgaaaaaaaaabbh4aaaaafbkbcqaaaaaazgqbfaaaaaaaudibfx4aaaaaaaa="," 31":"aaa="," 32":"aaa="," 101":true},"dpstime":{"20":1709548004276,"21":1706790900787,"22":1709408638654,"23":1706790900788,"24":1706790643509,"25":1704913926411,"26":1702120453612,"27":1701952521419,"28":1701952521419,"30":1709286729273,"31":1709286729304,"32":1709286729335,"101":1702120453617}},"meta":{},"name":"lampe="" fensterbank","timezoneid":"europe="" berlin","devicetopo":{},"localkey":"jwlb;o{|2fo3)-j4","dps":{"20":false,"21":"white","22":170,"23":220,"24":"003c03e802f8","25":"000d0d0000000000000000460000","26":0,"27":"","28":"","30":"aaaafwubbgaaaaaaaaabbh4aaaaafbkbcqaaaaaazgqbfaaaaaaaudibfx4aaaaaaaa="," 101":true},"dpname":{},"groudid":175238259},{"virtual":false,"lon":"0.0000","ownerid":"175238259","uuid":"8e28f7d76f9af82a","mac":"508a0643cc55","accesstype":0,"otainfo":{"supportauto":true,"otaupgrademodes":[0],"otamodulemap":{"wifi":{"upgradestatus":0,"cdv":"1.0.0","bv":"40.00","versw":"1.0.3"},"mcu":{"upgradestatus":0,"cdv":"","versw":"1.0.3"}}},"iconurl":"https:="" 7e5a9daf7f3bbfe91ab192f6c0b4aa63.jpg","communication":{"mqtttopicattr":1,"communicationnode":"bff18e0a272d5feaf3qka4","communicationmodes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"datamodel":1,"connectionstatus":1},"gatewayvercad":"1.0.2","lat":"0.0000","runtimeenv":"prod","devkey":"","devid":"bff18e0a272d5feaf3qka4","productid":"mrerultqnbwpx2jt","ip":"84.58.217.143","activetime":1709299360,"cloudonline":true,"baseattribute":1024,"virtualexperience":false,"devattribute":515,"datapointinfo":{"dpmaxtime":1709722358359,"dpname":{},"dps":{"20":false,"21":"colour","22":20,"23":660,"24":"015c03840064","25":"000e0d0000000000000000c80000","26":0,"27":"","28":"","30":"aaaaaaa="," 101":true},"dpstime":{"20":1709722358359,"21":1709722211999,"22":1709722091821,"23":1709722111588,"24":1709636713989,"25":1709299363509,"26":1709716986399,"27":1709299360771,"28":1709299360771,"30":1709299363516,"31":1709299363600,"32":1709299363713,"101":1709545046269}},"meta":{},"name":"ldvwifia100e27rgbw="" 3","timezoneid":"europe="" berlin","devicetopo":{},"localkey":";|="~CZFs3%yjveS*","dps":{"20":false,"21":"colour","22":20,"23":660,"24":"015c03840064","25":"000e0d0000000000000000c80000","26":0,"27":"","28":"","30":"AAAAAAA=","31":"AAA=","32":"AAA=","101":true},"dpName":{},"groudId":175238259},{"virtual":false,"lon":"0.0000","ownerId":"175238259","uuid":"23b60bbc36324721","mac":"508a0643e7bb","accessType":0,"otaInfo":{"supportAuto":true,"otaUpgradeModes":[0],"otaModuleMap":{"wifi":{"upgradeStatus":0,"cdv":"1.0.0","bv":"40.00","verSw":"1.0.3"},"mcu":{"upgradeStatus":0,"cdv":"","verSw":"1.0.3"}}},"iconUrl":"https://images.tuyaeu.com/smart/icon/bay1581409214911SvxF/7e5a9daf7f3bbfe91ab192f6c0b4aa63.jpg","communication":{"mqttTopicAttr":1,"communicationNode":"bf56eab5f9bb071534bifs","communicationModes":[{"pv":"","type":0},{"pv":"2.2","type":1}],"dataModel":1,"connectionStatus":1},"gatewayVerCAD":"1.0.2","lat":"0.0000","runtimeEnv":"prod","devKey":"","devId":"bf56eab5f9bb071534bifs","productId":"mrerultqnbwpx2jt","ip":"84.58.216.67","activeTime":1702120351,"cloudOnline":true,"baseAttribute":1024,"virtualExperience":false,"devAttribute":515,"dataPointInfo":{"dpMaxTime":1709713886045,"dpName":{},"dps":{"20":false,"21":"white","22":50,"23":200,"24":"00f003e80258","25":"000e0d0000000000000000c80000","26":0,"27":"","28":"","30":"AAAAAAA=","31":"AAA=","32":"AAA=","101":true},"dpsTime":{"20":1709713886045,"21":1709304060383,"22":1709405584680,"23":1709304057923,"24":1706790643549,"25":1702122643874,"26":1702122643874,"27":1702120351342,"28":1702120351342,"30":1709286732580,"31":1709286732610,"32":1709286732639,"101":1702122643882}},"meta":{},"name":"Lampe" couch="" ","timezoneid":"europe="" berlin","devicetopo":{},"localkey":"zd65e+81
          @biker1602
          Da steht nix auffälliges drin.
            manrum1 @Thomas Braun last edited by
            @thomas-braun Hallo, habe ein sehr ähnliches Verhalten, allerdings mit der Smartlife-App. Habe dafür ebenfalls eine neue Instanz installiert und auch lokalen Zugriff. Kann z.B. die HAMA-Steckdose schalten, erhalte aber nur einmalig die Daten, z.B. Energiewerte. Bitte um Hilfe.
            Hier mein Log:
            tuya.1
            	2024-04-19 11:57:34.558	info	2127736470039f351549: Connect locally to device
            tuya.1
            	2024-04-19 11:57:34.127	info	Cloud MQTT connection established successfully.
            tuya.1
            	2024-04-19 11:57:32.887	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
            tuya.1
            	2024-04-19 11:57:32.886	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
            tuya.1
            	2024-04-19 11:57:32.526	info	Try to sync devices from Cloud using stored cloud credentials
            tuya.1
            	2024-04-19 11:57:32.515	info	Existing devices initialized
            tuya.1
            	2024-04-19 11:57:32.506	info	2127736470039f351549: Connect locally to device
            tuya.1
            	2024-04-19 11:57:31.644	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.19
            tuya.1
            	2024-04-19 11:57:31.218	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            tuya.1
            	2024-04-19 11:57:22.794	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            tuya.1
            	2024-04-19 11:57:22.791	info	terminating
            tuya.1
            	2024-04-19 11:57:19.787	info	Got terminate signal TERMINATE_YOURSELF
            tuya.1
            	2024-04-19 11:57:19.763	info	Set data for tuya.1 to appDeviceId=3jfj8yjeg4n1eqx1vleqntdpmn2sszcexbgz49hj5yin / sid=eu164944S21782365kT3jSJ33deb494522b9f6f01662ddf921d7eae7. Restart adapter now!
            tuya.1
            	2024-04-19 11:57:19.762	info	Cloud login successful. Adapter restarts in 5s
            tuya.1
            	2024-04-19 11:57:09.940	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
            tuya.1
            	2024-04-19 11:57:09.938	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
            tuya.1
            	2024-04-19 11:57:09.422	info	Try to sync devices from Cloud using stored cloud credentials
            tuya.1
            	2024-04-19 11:57:09.409	info	Existing devices initialized
            tuya.1
            	2024-04-19 11:57:09.399	info	2127736470039f351549: Connect locally to device
            tuya.1
            	2024-04-19 11:57:08.241	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.19
            tuya.1
            	2024-04-19 11:57:07.861	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            tuya.1
            	2024-04-19 11:56:59.542	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            tuya.1
            	2024-04-19 11:56:59.538	info	terminating
            tuya.1
            	2024-04-19 11:56:56.531	info	Got terminate signal TERMINATE_YOURSELF
              Thomas Braun Most Active @manrum1 last edited by
              @manrum1 sagte in Adapter Tuya 3.15.0:
              node: v18.17.1
              Nodejs erstmal auf Stand bringen.
              iob stop
              iob fix
              iob nodejs-update
                @thomas-braun Da ändert sich leider nichts:
                tuya.1
                	2024-04-21 10:52:13.300	info	2127736470039f351549: Connect locally to device
                tuya.1
                	2024-04-21 10:52:12.982	info	Cloud MQTT connection established successfully.
                tuya.1
                	2024-04-21 10:52:11.680	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
                tuya.1
                	2024-04-21 10:52:11.679	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
                tuya.1
                	2024-04-21 10:52:11.285	info	Try to sync devices from Cloud using stored cloud credentials
                tuya.1
                	2024-04-21 10:52:11.279	info	Existing devices initialized
                tuya.1
                	2024-04-21 10:52:11.274	info	2127736470039f351549: Connect locally to device
                tuya.1
                	2024-04-21 10:52:09.763	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.20.2, js-controller: 5.0.19
                  @manrum1
                  Langfassung von
                  iob diag
                  bitte.
                    @thomas-braun Hier die Summary. Langfassung? Wie geht das?
                    v.2023-10-10
                    Static hostname: iob1
                    Icon name: computer
                    Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
                    Installation: native
                    Kernel: aarch64
                    Userland: arm64
                    Timezone: Europe/Berlin (CEST, +0200)
                    User-ID: 1000
                    X-Server: false
                    Boot Target: multi-user.target
                    Pending OS-Updates: 0
                    Pending iob updates: 0
                    Nodejs-Installation: /usr/bin/nodejs v18.20.2
                    /usr/bin/node v18.20.2
                    /usr/bin/npm 10.5.0
                    /usr/bin/npx 10.5.0
                    /usr/bin/corepack 0.25.2
                    Recommended versions are nodejs 18.20.2 and npm 10.5.0
                    MEMORY:
                    total used free shared buff/cache available
                    Mem: 7.8G 4.5G 501M 1.0M 2.8G 3.2G
                    Swap: 99M 0B 99M
                    Total: 7.9G 4.5G 601M
                    Active iob-Instances: 33
                    Active repo(s): stable
                    ioBroker Core: js-controller 5.0.19
                    admin 6.13.16
                    ioBroker Status: iobroker is running on this host.
                    Objects type: jsonl
                    States type: jsonl
                    • system.adapter.admin.0 : admin : iob1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    • system.adapter.web.0 : web : iob1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects: 21112
                    States: 19547
                    Size of iob-Database:
                    42M /opt/iobroker/iobroker-data/objects.jsonl
                    18M /opt/iobroker/iobroker-data/states.jsonl
                    === Mark text until here for copying ===
                      Genau so? Text innerhalb der vorgegebenen Kopiermarken kopieren, hier wieder einfügen.
                        @thomas-braun Danke für Deine Hilfe, anbei:
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : arm64
                        Systemuptime and Load:
                         11:01:05 up 3 days, 13:56,  1 user,  load average: 1.24, 1.62, 1.68
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Mon 2024-04-22 11:01:05 CEST
                                   Universal time: Mon 2024-04-22 09:01:05 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        3.9G        1.0G        1.0M        2.9G        3.8G
                        Swap:            99M          0B         99M
                        Total:          7.9G        3.9G        1.1G
                                 7811 M total memory
                                 3930 M used memory
                                 4289 M active memory
                                 2166 M inactive memory
                                 1028 M free memory
                                  177 M buffer memory
                                 2674 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/root      ext4      118G   12G  102G  11% /
                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                        /dev/sda1      vfat      255M   31M  225M  13% /boot
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                        [Thu Apr 18 21:04:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DB:77:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=c1b1c35a-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                        [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): write access will be enabled during recovery
                        [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                        [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): 21 orphan inodes deleted
                        [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): recovery complete
                        [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Thu Apr 18 21:04:39 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                        [Thu Apr 18 21:04:41 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        TARGET  SOURCE    FSTYPE OPTIONS
                        /       /dev/sda2 ext4   rw,noatime
                        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        4.1G    /var/
                        1.9G    /var/lib
                        1.7G    /var/lib/influxdb/engine/data
                        Archived and active journals take up 504.5M in the file system.
                        /opt/iobroker/backups:
                        3.2G    /opt/iobroker/backups/
                        3.6M    /opt/iobroker/backups/tmp
                        /opt/iobroker/iobroker-data:
                        365M    /opt/iobroker/iobroker-data/
                        216M    /opt/iobroker/iobroker-data/files
                        96M     /opt/iobroker/iobroker-data/backup-objects
                        57M     /opt/iobroker/iobroker-data/files/javascript.admin
                        45M     /opt/iobroker/iobroker-data/files/devices.admin/static
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                        9.6M    /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /usr/bin/npm            10.5.0
                        /usr/bin/npx            10.5.0
                        nodejs:
                          Installed: 18.20.2-1nodesource1
                          Candidate: 18.20.2-1nodesource1
                          Version table:
                         *** 18.20.2-1nodesource1 1001
                                100 /var/lib/dpkg/status
                             18.20.1-1nodesource1 1001
                             18.20.0-1nodesource1 1001
                             18.19.1-1nodesource1 1001
                             18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        admin:          6.13.16
                        javascript:     7.8.0
                        Adapters from github:   2
                        Adapter State
                        + system.adapter.accuweather.0            : accuweather           : iob1                                     -  enabled
                        + system.adapter.accuweather.1            : accuweather           : iob1                                     -  enabled
                        + system.adapter.admin.0                  : admin                 : iob1                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : iob1                                     -  enabled
                        + system.adapter.cloud.0                  : cloud                 : iob1                                     -  enabled
                          system.adapter.devices.0                : devices               : iob1                                     -  enabled
                        + system.adapter.discovery.0              : discovery             : iob1                                     -  enabled
                        + system.adapter.email.0                  : email                 : iob1                                     -  enabled
                        + system.adapter.ems-esp.0                : ems-esp               : iob1                                     -  enabled
                        + system.adapter.ems-esp.1                : ems-esp               : iob1                                     -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : iob1                                     -  enabled
                        + system.adapter.energiefluss.1           : energiefluss          : iob1                                     -  enabled
                        + system.adapter.energiefluss.2           : energiefluss          : iob1                                     -  enabled
                        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob1                                     -  enabled
                        + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iob1                                     -  enabled
                        + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iob1                                     -  enabled
                        + system.adapter.fritzdect.0              : fritzdect             : iob1                                     -  enabled
                        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iob1                                     -  enabled
                          system.adapter.habpanel.0               : habpanel              : iob1                                     -  enabled
                        + system.adapter.history.0                : history               : iob1                                     -  enabled
                        + system.adapter.influxdb.0               : influxdb              : iob1                                     -  enabled, port: 8086
                        + system.adapter.influxdb.1               : influxdb              : iob1                                     -  enabled, port: 8086
                        + system.adapter.javascript.0             : javascript            : iob1                                     -  enabled
                        + system.adapter.maxcube.0                : maxcube               : iob1                                     -  enabled, port: 62910, bind: 0.0.0.0
                          system.adapter.mercedesme.0             : mercedesme            : iob1                                     - disabled
                        + system.adapter.modbus.0                 : modbus                : iob1                                     -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iob1                                     -  enabled, port: 1886, bind: 0.0.0.0
                        + system.adapter.ping.0                   : ping                  : iob1                                     -  enabled
                        + system.adapter.shelly.0                 : shelly                : iob1                                     -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.sonoff.0                 : sonoff                : iob1                                     -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.statistics.0             : statistics            : iob1                                     -  enabled
                          system.adapter.tr-064.0                 : tr-064                : iob1                                     - disabled
                        + system.adapter.tuya.0                   : tuya                  : iob1                                     -  enabled
                        + system.adapter.tuya.1                   : tuya                  : iob1                                     -  enabled
                        + system.adapter.web.0                    : web                   : iob1                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.wolf-smartset.0          : wolf-smartset         : iob1                                     -  enabled
                          system.adapter.wolf.0                   : wolf                  : iob1                                     - disabled, port: 12004, bind: 0.0.0.0
                        + instance is alive
                        ioBroker-Repositories
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                        Adapter    "email"        : 1.2.2    , installed 1.2.2
                        Adapter    "ems-esp"      : 3.0.3    , installed 3.0.3
                        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.10
                        Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                        Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
                        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                        Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                        Adapter    "wolf"         : 1.7.0    , installed 1.7.0
                        Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                        Adapter    "ws"           : 2.5.11   , installed 2.5.11
                        Objects and States
                        Objects:        21112
                        States:         19547
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:5 https://apt.grafana.com stable InRelease
                        Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       2172496    55740/io.shelly.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       2172506    55761/io.sonoff.0
                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       2174631    55854/io.mqtt.0
                        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       2174632    55854/io.mqtt.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2167748    55542/iobroker.js-c
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2167755    55542/iobroker.js-c
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14013      532/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2169751    55563/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2174816    55944/io.web.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        14230      638/influxd
                        tcp6       0      0 :::3000                 :::*                    LISTEN      110        13205      748/grafana
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14015      532/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12906      391/avahi-daemon: r
                        udp        0      0 0.0.0.0:58791           0.0.0.0:*                           108        12908      391/avahi-daemon: r
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2171528    55797/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2171529    55797/io.tuya.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14035      634/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        12907      391/avahi-daemon: r
                        udp6       0      0 :::45321                :::*                                108        12909      391/avahi-daemon: r
                        2024-04-22 11:02:00.156  - info: javascript.0 (55589) script.js.Tuya.0-run.tuya_wallbox_map_objects: Wallbox SG 0data updated
                        2024-04-22 11:02:00.156  - info: javascript.0 (55589) script.js.Tuya.0-run.tuya_wallbox_map_objects: Wallbox SF 0data updated
                        2024-04-22 11:02:00.171  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Wolf 0data updated
                        2024-04-22 11:02:00.172  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Solar 0data updated
                        2024-04-22 11:02:00.173  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Solar Pumpe aus: 2 Watt
                        2024-04-22 11:02:00.187  - info: javascript.0 (55589) script.js.Wandthermostat.0-run.wt_map_0data: Map HB Temperaturen
                        2024-04-22 11:02:00.205  - info: javascript.0 (55589) script.js.Thermostat.0-run.comet-map-0data: Comet Data updated
                        2024-04-22 11:02:00.234  - info: javascript.0 (55589) script.js.Thermostat.0-run.max-map-0data: Max Data updated
                        2024-04-22 11:02:00.248  - info: javascript.0 (55589) script.js.Strommessung.0-run.strom_sg_pzem: Strom SG Werte geschrieben
                        2024-04-22 11:02:00.264  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_SF: Strom SF Werte geschrieben
                        2024-04-22 11:02:00.275  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_SG: Strom SG Werte geschrieben
                        2024-04-22 11:02:00.287  - info: javascript.0 (55589) script.js.Strommessung.0-run.strom_pool_heizung: Strom Pool geschrieben:
                        2024-04-22 11:02:08.239  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_HB: Strom HichiHB Werte geschrieben
                        2024-04-22 11:02:10.003  - info: javascript.0 (55589) script.js.PV.Fronius.0-run.fronius_map_0data: Fronius 0data updated, Tag: 19
                        2024-04-22 11:02:10.010  - info: javascript.0 (55589) script.js.PV.MTec.0-run.mtec_run: PV 0data geschrieben
                        2024-04-22 11:02:10.020  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Einspeisung
                        2024-04-22 11:02:10.020  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SF Einspeisung
                        2024-04-22 11:02:10.021  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SG Einspeisung
                        2024-04-22 11:02:10.022  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Laden
                        2024-04-22 11:02:20.005  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Einspeisung
                        2024-04-22 11:02:20.005  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SF Einspeisung
                        2024-04-22 11:02:20.006  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SG Einspeisung
                        2024-04-22 11:02:20.006  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Laden
                        2024-04-22 11:02:20.028  - info: javascript.0 (55589) script.js.PV.MTec.0-run.mtec_run: PV 0data geschrieben
                        2024-04-22 11:02:20.072  - info: javascript.0 (55589) script.js.PV.Fronius.0-run.fronius_map_0data: Fronius 0data updated, Tag: 19
                        und noch mal die Summary:
                                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               arm64
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            10.5.0
                                                /usr/bin/npx            10.5.0
                        MEMORY:
                        Mem:            7.8G        4.0G        916M        1.0M        2.9G        3.6G
                        Swap:            99M          0B         99M
                        Total:          7.9G        4.0G        1.0G
                                                admin                   6.13.16
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                21112
                        States:                 19547
                        14M     /opt/iobroker/iobroker-data/states.jsonl
                          Dein Dateisystem weist erhebliche Defekte auf.
                          Installier die Choose neu auf einem frischen Datenträger.
                          Dann kannste auch direkt Debian 12 'Bookworm' installieren.
                          Dein 'Bullseye' erreicht im Sommer '24 eh das Lebensende.
                          Und knall der Kiste NIE, NIE, NIE plötzlich den Strom weg.
                            @thomas-braun Danke für die Info. Bin leider nicht so der LINUX-Freak. Kann ich ein fertiges iobroker-Image verwenden und dann meine Backups wieder einspielen?
                              Thomas Braun Most Active @manrum1 last edited by Thomas Braun
                              @manrum1
                              Ein Freak bin ich auch nicht.
                              Aber ich mach das immer danach:
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              Von den vorgekochten ioBroker-Images halte ich nicht viel.
                              Die sind soweit ich das weiß ohnehin gerade mal wieder auf Eis gelegt worden.
                              ledvance wifi tuya adapter gelb
                              1092
