    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Adapter Tuya 3.15.0
    Adapter Tuya 3.15.0
      Thomas Braun Most Active @biker1602 last edited by
      @biker1602
      Da steht nix auffälliges drin.
        manrum1 @Thomas Braun last edited by
        @thomas-braun Hallo, habe ein sehr ähnliches Verhalten, allerdings mit der Smartlife-App. Habe dafür ebenfalls eine neue Instanz installiert und auch lokalen Zugriff. Kann z.B. die HAMA-Steckdose schalten, erhalte aber nur einmalig die Daten, z.B. Energiewerte. Bitte um Hilfe.
        Hier mein Log:
        tuya.1
        	2024-04-19 11:57:34.558	info	2127736470039f351549: Connect locally to device
        tuya.1
        	2024-04-19 11:57:34.127	info	Cloud MQTT connection established successfully.
        tuya.1
        	2024-04-19 11:57:32.887	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
        tuya.1
        	2024-04-19 11:57:32.886	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
        tuya.1
        	2024-04-19 11:57:32.526	info	Try to sync devices from Cloud using stored cloud credentials
        tuya.1
        	2024-04-19 11:57:32.515	info	Existing devices initialized
        tuya.1
        	2024-04-19 11:57:32.506	info	2127736470039f351549: Connect locally to device
        tuya.1
        	2024-04-19 11:57:31.644	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.19
        tuya.1
        	2024-04-19 11:57:31.218	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        tuya.1
        	2024-04-19 11:57:22.794	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        tuya.1
        	2024-04-19 11:57:22.791	info	terminating
        tuya.1
        	2024-04-19 11:57:19.787	info	Got terminate signal TERMINATE_YOURSELF
        tuya.1
        	2024-04-19 11:57:19.763	info	Set data for tuya.1 to appDeviceId=3jfj8yjeg4n1eqx1vleqntdpmn2sszcexbgz49hj5yin / sid=eu164944S21782365kT3jSJ33deb494522b9f6f01662ddf921d7eae7. Restart adapter now!
        tuya.1
        	2024-04-19 11:57:19.762	info	Cloud login successful. Adapter restarts in 5s
        tuya.1
        	2024-04-19 11:57:09.940	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
        tuya.1
        	2024-04-19 11:57:09.938	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
        tuya.1
        	2024-04-19 11:57:09.422	info	Try to sync devices from Cloud using stored cloud credentials
        tuya.1
        	2024-04-19 11:57:09.409	info	Existing devices initialized
        tuya.1
        	2024-04-19 11:57:09.399	info	2127736470039f351549: Connect locally to device
        tuya.1
        	2024-04-19 11:57:08.241	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.19
        tuya.1
        	2024-04-19 11:57:07.861	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        tuya.1
        	2024-04-19 11:56:59.542	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        tuya.1
        	2024-04-19 11:56:59.538	info	terminating
        tuya.1
        	2024-04-19 11:56:56.531	info	Got terminate signal TERMINATE_YOURSELF
          Thomas Braun Most Active @manrum1 last edited by
          @manrum1 sagte in Adapter Tuya 3.15.0:
          node: v18.17.1
          Nodejs erstmal auf Stand bringen.
          iob stop
          iob fix
          iob nodejs-update
            @thomas-braun Da ändert sich leider nichts:
            tuya.1
            	2024-04-21 10:52:13.300	info	2127736470039f351549: Connect locally to device
            tuya.1
            	2024-04-21 10:52:12.982	info	Cloud MQTT connection established successfully.
            tuya.1
            	2024-04-21 10:52:11.680	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
            tuya.1
            	2024-04-21 10:52:11.679	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
            tuya.1
            	2024-04-21 10:52:11.285	info	Try to sync devices from Cloud using stored cloud credentials
            tuya.1
            	2024-04-21 10:52:11.279	info	Existing devices initialized
            tuya.1
            	2024-04-21 10:52:11.274	info	2127736470039f351549: Connect locally to device
            tuya.1
            	2024-04-21 10:52:09.763	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.20.2, js-controller: 5.0.19
              @manrum1
              Langfassung von
              iob diag
              bitte.
                @thomas-braun Hier die Summary. Langfassung? Wie geht das?
                v.2023-10-10
                Static hostname: iob1
                Icon name: computer
                Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
                Architecture: arm64
                Installation: native
                Kernel: aarch64
                Userland: arm64
                Timezone: Europe/Berlin (CEST, +0200)
                User-ID: 1000
                X-Server: false
                Boot Target: multi-user.target
                Pending OS-Updates: 0
                Pending iob updates: 0
                Nodejs-Installation: /usr/bin/nodejs v18.20.2
                /usr/bin/node v18.20.2
                /usr/bin/npm 10.5.0
                /usr/bin/npx 10.5.0
                /usr/bin/corepack 0.25.2
                Recommended versions are nodejs 18.20.2 and npm 10.5.0
                MEMORY:
                total used free shared buff/cache available
                Mem: 7.8G 4.5G 501M 1.0M 2.8G 3.2G
                Swap: 99M 0B 99M
                Total: 7.9G 4.5G 601M
                Active iob-Instances: 33
                Active repo(s): stable
                ioBroker Core: js-controller 5.0.19
                admin 6.13.16
                ioBroker Status: iobroker is running on this host.
                Objects type: jsonl
                States type: jsonl
                • system.adapter.admin.0 : admin : iob1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                • system.adapter.web.0 : web : iob1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects: 21112
                States: 19547
                Size of iob-Database:
                42M /opt/iobroker/iobroker-data/objects.jsonl
                18M /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                  Genau so? Text innerhalb der vorgegebenen Kopiermarken kopieren, hier wieder einfügen.
                    @thomas-braun Danke für Deine Hilfe, anbei:
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : arm64
                    Systemuptime and Load:
                     11:01:05 up 3 days, 13:56,  1 user,  load average: 1.24, 1.62, 1.68
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Mon 2024-04-22 11:01:05 CEST
                               Universal time: Mon 2024-04-22 09:01:05 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.8G        3.9G        1.0G        1.0M        2.9G        3.8G
                    Swap:            99M          0B         99M
                    Total:          7.9G        3.9G        1.1G
                             7811 M total memory
                             3930 M used memory
                             4289 M active memory
                             2166 M inactive memory
                             1028 M free memory
                              177 M buffer memory
                             2674 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4      118G   12G  102G  11% /
                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                    /dev/sda1      vfat      255M   31M  225M  13% /boot
                    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                    [Thu Apr 18 21:04:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DB:77:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=c1b1c35a-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                    [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): write access will be enabled during recovery
                    [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                    [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): 21 orphan inodes deleted
                    [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): recovery complete
                    [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Thu Apr 18 21:04:39 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    [Thu Apr 18 21:04:41 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    TARGET  SOURCE    FSTYPE OPTIONS
                    /       /dev/sda2 ext4   rw,noatime
                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    4.1G    /var/
                    1.9G    /var/lib
                    1.7G    /var/lib/influxdb/engine/data
                    Archived and active journals take up 504.5M in the file system.
                    /opt/iobroker/backups:
                    3.2G    /opt/iobroker/backups/
                    3.6M    /opt/iobroker/backups/tmp
                    /opt/iobroker/iobroker-data:
                    365M    /opt/iobroker/iobroker-data/
                    216M    /opt/iobroker/iobroker-data/files
                    96M     /opt/iobroker/iobroker-data/backup-objects
                    57M     /opt/iobroker/iobroker-data/files/javascript.admin
                    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                    9.6M    /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    *** NodeJS-Installation ***
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    nodejs:
                      Installed: 18.20.2-1nodesource1
                      Candidate: 18.20.2-1nodesource1
                      Version table:
                     *** 18.20.2-1nodesource1 1001
                            100 /var/lib/dpkg/status
                         18.20.1-1nodesource1 1001
                         18.20.0-1nodesource1 1001
                         18.19.1-1nodesource1 1001
                         18.19.0-1nodesource1 1001
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    admin:          6.13.16
                    javascript:     7.8.0
                    Adapters from github:   2
                    Adapter State
                    + system.adapter.accuweather.0            : accuweather           : iob1                                     -  enabled
                    + system.adapter.accuweather.1            : accuweather           : iob1                                     -  enabled
                    + system.adapter.admin.0                  : admin                 : iob1                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : iob1                                     -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iob1                                     -  enabled
                      system.adapter.devices.0                : devices               : iob1                                     -  enabled
                    + system.adapter.discovery.0              : discovery             : iob1                                     -  enabled
                    + system.adapter.email.0                  : email                 : iob1                                     -  enabled
                    + system.adapter.ems-esp.0                : ems-esp               : iob1                                     -  enabled
                    + system.adapter.ems-esp.1                : ems-esp               : iob1                                     -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : iob1                                     -  enabled
                    + system.adapter.energiefluss.1           : energiefluss          : iob1                                     -  enabled
                    + system.adapter.energiefluss.2           : energiefluss          : iob1                                     -  enabled
                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob1                                     -  enabled
                    + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iob1                                     -  enabled
                    + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iob1                                     -  enabled
                    + system.adapter.fritzdect.0              : fritzdect             : iob1                                     -  enabled
                    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iob1                                     -  enabled
                      system.adapter.habpanel.0               : habpanel              : iob1                                     -  enabled
                    + system.adapter.history.0                : history               : iob1                                     -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iob1                                     -  enabled, port: 8086
                    + system.adapter.influxdb.1               : influxdb              : iob1                                     -  enabled, port: 8086
                    + system.adapter.javascript.0             : javascript            : iob1                                     -  enabled
                    + system.adapter.maxcube.0                : maxcube               : iob1                                     -  enabled, port: 62910, bind: 0.0.0.0
                      system.adapter.mercedesme.0             : mercedesme            : iob1                                     - disabled
                    + system.adapter.modbus.0                 : modbus                : iob1                                     -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iob1                                     -  enabled, port: 1886, bind: 0.0.0.0
                    + system.adapter.ping.0                   : ping                  : iob1                                     -  enabled
                    + system.adapter.shelly.0                 : shelly                : iob1                                     -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.sonoff.0                 : sonoff                : iob1                                     -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.statistics.0             : statistics            : iob1                                     -  enabled
                      system.adapter.tr-064.0                 : tr-064                : iob1                                     - disabled
                    + system.adapter.tuya.0                   : tuya                  : iob1                                     -  enabled
                    + system.adapter.tuya.1                   : tuya                  : iob1                                     -  enabled
                    + system.adapter.web.0                    : web                   : iob1                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wolf-smartset.0          : wolf-smartset         : iob1                                     -  enabled
                      system.adapter.wolf.0                   : wolf                  : iob1                                     - disabled, port: 12004, bind: 0.0.0.0
                    + instance is alive
                    ioBroker-Repositories
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
                    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                    Adapter    "email"        : 1.2.2    , installed 1.2.2
                    Adapter    "ems-esp"      : 3.0.3    , installed 3.0.3
                    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.10
                    Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                    Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
                    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                    Adapter    "wolf"         : 1.7.0    , installed 1.7.0
                    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                    Adapter    "ws"           : 2.5.11   , installed 2.5.11
                    Objects and States
                    Objects:        21112
                    States:         19547
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://apt.grafana.com stable InRelease
                    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       2172496    55740/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       2172506    55761/io.sonoff.0
                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       2174631    55854/io.mqtt.0
                    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       2174632    55854/io.mqtt.0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2167748    55542/iobroker.js-c
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2167755    55542/iobroker.js-c
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14013      532/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2169751    55563/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2174816    55944/io.web.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        14230      638/influxd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      110        13205      748/grafana
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14015      532/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12906      391/avahi-daemon: r
                    udp        0      0 0.0.0.0:58791           0.0.0.0:*                           108        12908      391/avahi-daemon: r
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2171528    55797/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2171529    55797/io.tuya.0
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14035      634/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        12907      391/avahi-daemon: r
                    udp6       0      0 :::45321                :::*                                108        12909      391/avahi-daemon: r
                    2024-04-22 11:02:00.156  - info: javascript.0 (55589) script.js.Tuya.0-run.tuya_wallbox_map_objects: Wallbox SG 0data updated
                    2024-04-22 11:02:00.156  - info: javascript.0 (55589) script.js.Tuya.0-run.tuya_wallbox_map_objects: Wallbox SF 0data updated
                    2024-04-22 11:02:00.171  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Wolf 0data updated
                    2024-04-22 11:02:00.172  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Solar 0data updated
                    2024-04-22 11:02:00.173  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Solar Pumpe aus: 2 Watt
                    2024-04-22 11:02:00.187  - info: javascript.0 (55589) script.js.Wandthermostat.0-run.wt_map_0data: Map HB Temperaturen
                    2024-04-22 11:02:00.205  - info: javascript.0 (55589) script.js.Thermostat.0-run.comet-map-0data: Comet Data updated
                    2024-04-22 11:02:00.234  - info: javascript.0 (55589) script.js.Thermostat.0-run.max-map-0data: Max Data updated
                    2024-04-22 11:02:00.248  - info: javascript.0 (55589) script.js.Strommessung.0-run.strom_sg_pzem: Strom SG Werte geschrieben
                    2024-04-22 11:02:00.264  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_SF: Strom SF Werte geschrieben
                    2024-04-22 11:02:00.275  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_SG: Strom SG Werte geschrieben
                    2024-04-22 11:02:00.287  - info: javascript.0 (55589) script.js.Strommessung.0-run.strom_pool_heizung: Strom Pool geschrieben:
                    2024-04-22 11:02:08.239  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_HB: Strom HichiHB Werte geschrieben
                    2024-04-22 11:02:10.003  - info: javascript.0 (55589) script.js.PV.Fronius.0-run.fronius_map_0data: Fronius 0data updated, Tag: 19
                    2024-04-22 11:02:10.010  - info: javascript.0 (55589) script.js.PV.MTec.0-run.mtec_run: PV 0data geschrieben
                    2024-04-22 11:02:10.020  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Einspeisung
                    2024-04-22 11:02:10.020  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SF Einspeisung
                    2024-04-22 11:02:10.021  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SG Einspeisung
                    2024-04-22 11:02:10.022  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Laden
                    2024-04-22 11:02:20.005  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Einspeisung
                    2024-04-22 11:02:20.005  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SF Einspeisung
                    2024-04-22 11:02:20.006  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SG Einspeisung
                    2024-04-22 11:02:20.006  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Laden
                    2024-04-22 11:02:20.028  - info: javascript.0 (55589) script.js.PV.MTec.0-run.mtec_run: PV 0data geschrieben
                    2024-04-22 11:02:20.072  - info: javascript.0 (55589) script.js.PV.Fronius.0-run.fronius_map_0data: Fronius 0data updated, Tag: 19
                    und noch mal die Summary:
                                            v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               arm64
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            10.5.0
                                            /usr/bin/npx            10.5.0
                    MEMORY:
                    Mem:            7.8G        4.0G        916M        1.0M        2.9G        3.6G
                    Swap:            99M          0B         99M
                    Total:          7.9G        4.0G        1.0G
                                            admin                   6.13.16
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                21112
                    States:                 19547
                    14M     /opt/iobroker/iobroker-data/states.jsonl
                      Dein Dateisystem weist erhebliche Defekte auf.
                      Installier die Choose neu auf einem frischen Datenträger.
                      Dann kannste auch direkt Debian 12 'Bookworm' installieren.
                      Dein 'Bullseye' erreicht im Sommer '24 eh das Lebensende.
                      Und knall der Kiste NIE, NIE, NIE plötzlich den Strom weg.
                        @thomas-braun Danke für die Info. Bin leider nicht so der LINUX-Freak. Kann ich ein fertiges iobroker-Image verwenden und dann meine Backups wieder einspielen?
                          Thomas Braun Most Active @manrum1 last edited by Thomas Braun
                          @manrum1
                          Ein Freak bin ich auch nicht.
                          Aber ich mach das immer danach:
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          Von den vorgekochten ioBroker-Images halte ich nicht viel.
                          Die sind soweit ich das weiß ohnehin gerade mal wieder auf Eis gelegt worden.
                          ledvance wifi tuya adapter gelb
                          1092
