    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Adapter Tuya 3.15.0
    Adapter Tuya 3.15.0
      manrum1 @Thomas Braun last edited by
      @thomas-braun Hallo, habe ein sehr ähnliches Verhalten, allerdings mit der Smartlife-App. Habe dafür ebenfalls eine neue Instanz installiert und auch lokalen Zugriff. Kann z.B. die HAMA-Steckdose schalten, erhalte aber nur einmalig die Daten, z.B. Energiewerte. Bitte um Hilfe.
      Hier mein Log:
      tuya.1
      	2024-04-19 11:57:34.558	info	2127736470039f351549: Connect locally to device
      tuya.1
      	2024-04-19 11:57:34.127	info	Cloud MQTT connection established successfully.
      tuya.1
      	2024-04-19 11:57:32.887	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
      tuya.1
      	2024-04-19 11:57:32.886	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
      tuya.1
      	2024-04-19 11:57:32.526	info	Try to sync devices from Cloud using stored cloud credentials
      tuya.1
      	2024-04-19 11:57:32.515	info	Existing devices initialized
      tuya.1
      	2024-04-19 11:57:32.506	info	2127736470039f351549: Connect locally to device
      tuya.1
      	2024-04-19 11:57:31.644	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.19
      tuya.1
      	2024-04-19 11:57:31.218	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      tuya.1
      	2024-04-19 11:57:22.794	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      tuya.1
      	2024-04-19 11:57:22.791	info	terminating
      tuya.1
      	2024-04-19 11:57:19.787	info	Got terminate signal TERMINATE_YOURSELF
      tuya.1
      	2024-04-19 11:57:19.763	info	Set data for tuya.1 to appDeviceId=3jfj8yjeg4n1eqx1vleqntdpmn2sszcexbgz49hj5yin / sid=eu164944S21782365kT3jSJ33deb494522b9f6f01662ddf921d7eae7. Restart adapter now!
      tuya.1
      	2024-04-19 11:57:19.762	info	Cloud login successful. Adapter restarts in 5s
      tuya.1
      	2024-04-19 11:57:09.940	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
      tuya.1
      	2024-04-19 11:57:09.938	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
      tuya.1
      	2024-04-19 11:57:09.422	info	Try to sync devices from Cloud using stored cloud credentials
      tuya.1
      	2024-04-19 11:57:09.409	info	Existing devices initialized
      tuya.1
      	2024-04-19 11:57:09.399	info	2127736470039f351549: Connect locally to device
      tuya.1
      	2024-04-19 11:57:08.241	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.17.1, js-controller: 5.0.19
      tuya.1
      	2024-04-19 11:57:07.861	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      tuya.1
      	2024-04-19 11:56:59.542	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      tuya.1
      	2024-04-19 11:56:59.538	info	terminating
      tuya.1
      	2024-04-19 11:56:56.531	info	Got terminate signal TERMINATE_YOURSELF
        Thomas Braun Most Active @manrum1 last edited by
        @manrum1 sagte in Adapter Tuya 3.15.0:
        node: v18.17.1
        Nodejs erstmal auf Stand bringen.
        iob stop
        iob fix
        iob nodejs-update
          @thomas-braun Da ändert sich leider nichts:
          tuya.1
          	2024-04-21 10:52:13.300	info	2127736470039f351549: Connect locally to device
          tuya.1
          	2024-04-21 10:52:12.982	info	Cloud MQTT connection established successfully.
          tuya.1
          	2024-04-21 10:52:11.680	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6667
          tuya.1
          	2024-04-21 10:52:11.679	warn	Can not Listen for Encrypted UDP packages: Error: bind EADDRINUSE 0.0.0.0:6666
          tuya.1
          	2024-04-21 10:52:11.285	info	Try to sync devices from Cloud using stored cloud credentials
          tuya.1
          	2024-04-21 10:52:11.279	info	Existing devices initialized
          tuya.1
          	2024-04-21 10:52:11.274	info	2127736470039f351549: Connect locally to device
          tuya.1
          	2024-04-21 10:52:09.763	info	starting. Version 3.15.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v18.20.2, js-controller: 5.0.19
            @manrum1
            Langfassung von
            iob diag
            bitte.
              @thomas-braun Hier die Summary. Langfassung? Wie geht das?
              v.2023-10-10
              Static hostname: iob1
              Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
              Kernel: Linux 6.1.21-v8+
              Architecture: arm64
              Installation: native
              Kernel: aarch64
              Userland: arm64
              Timezone: Europe/Berlin (CEST, +0200)
              User-ID: 1000
              X-Server: false
              Boot Target: multi-user.target
              Pending OS-Updates: 0
              Pending iob updates: 0
              Nodejs-Installation: /usr/bin/nodejs v18.20.2
              /usr/bin/node v18.20.2
              /usr/bin/npm 10.5.0
              /usr/bin/npx 10.5.0
              /usr/bin/corepack 0.25.2
              Recommended versions are nodejs 18.20.2 and npm 10.5.0
              MEMORY:
              total used free shared buff/cache available
              Mem: 7.8G 4.5G 501M 1.0M 2.8G 3.2G
              Swap: 99M 0B 99M
              Total: 7.9G 4.5G 601M
              Active iob-Instances: 33
              Active repo(s): stable
              ioBroker Core: js-controller 5.0.19
              admin 6.13.16
              ioBroker Status: iobroker is running on this host.
              Objects type: jsonl
              States type: jsonl
              • system.adapter.admin.0 : admin : iob1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
              • system.adapter.web.0 : web : iob1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects: 21112
              States: 19547
              Size of iob-Database:
              42M /opt/iobroker/iobroker-data/objects.jsonl
              18M /opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
                Genau so? Text innerhalb der vorgegebenen Kopiermarken kopieren, hier wieder einfügen.
                  @thomas-braun Danke für Deine Hilfe, anbei:
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   11:01:05 up 3 days, 13:56,  1 user,  load average: 1.24, 1.62, 1.68
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Mon 2024-04-22 11:01:05 CEST
                             Universal time: Mon 2024-04-22 09:01:05 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.8G        3.9G        1.0G        1.0M        2.9G        3.8G
                  Swap:            99M          0B         99M
                  Total:          7.9G        3.9G        1.1G
                           7811 M total memory
                           3930 M used memory
                           4289 M active memory
                           2166 M inactive memory
                           1028 M free memory
                            177 M buffer memory
                           2674 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4      118G   12G  102G  11% /
                  devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                  tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                  /dev/sda1      vfat      255M   31M  225M  13% /boot
                  tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                  [Thu Apr 18 21:04:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DB:77:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=c1b1c35a-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                  [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): write access will be enabled during recovery
                  [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
                  [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): 21 orphan inodes deleted
                  [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): recovery complete
                  [Thu Apr 18 21:04:39 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Thu Apr 18 21:04:39 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Thu Apr 18 21:04:41 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  TARGET  SOURCE    FSTYPE OPTIONS
                  /       /dev/sda2 ext4   rw,noatime
                  `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  4.1G    /var/
                  1.9G    /var/lib
                  1.7G    /var/lib/influxdb/engine/data
                  Archived and active journals take up 504.5M in the file system.
                  /opt/iobroker/backups:
                  3.2G    /opt/iobroker/backups/
                  3.6M    /opt/iobroker/backups/tmp
                  /opt/iobroker/iobroker-data:
                  365M    /opt/iobroker/iobroker-data/
                  216M    /opt/iobroker/iobroker-data/files
                  96M     /opt/iobroker/iobroker-data/backup-objects
                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                  45M     /opt/iobroker/iobroker-data/files/devices.admin/static
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                  9.6M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  *** NodeJS-Installation ***
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Installed: 18.20.2-1nodesource1
                    Candidate: 18.20.2-1nodesource1
                    Version table:
                   *** 18.20.2-1nodesource1 1001
                          100 /var/lib/dpkg/status
                       18.20.1-1nodesource1 1001
                       18.20.0-1nodesource1 1001
                       18.19.1-1nodesource1 1001
                       18.19.0-1nodesource1 1001
                       18.18.2-1nodesource1 1001
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapters from github:   2
                  Adapter State
                  + system.adapter.accuweather.0            : accuweather           : iob1                                     -  enabled
                  + system.adapter.accuweather.1            : accuweather           : iob1                                     -  enabled
                  + system.adapter.admin.0                  : admin                 : iob1                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : iob1                                     -  enabled
                  + system.adapter.cloud.0                  : cloud                 : iob1                                     -  enabled
                    system.adapter.devices.0                : devices               : iob1                                     -  enabled
                  + system.adapter.discovery.0              : discovery             : iob1                                     -  enabled
                  + system.adapter.email.0                  : email                 : iob1                                     -  enabled
                  + system.adapter.ems-esp.0                : ems-esp               : iob1                                     -  enabled
                  + system.adapter.ems-esp.1                : ems-esp               : iob1                                     -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : iob1                                     -  enabled
                  + system.adapter.energiefluss.1           : energiefluss          : iob1                                     -  enabled
                  + system.adapter.energiefluss.2           : energiefluss          : iob1                                     -  enabled
                  + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob1                                     -  enabled
                  + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iob1                                     -  enabled
                  + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iob1                                     -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : iob1                                     -  enabled
                  + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iob1                                     -  enabled
                    system.adapter.habpanel.0               : habpanel              : iob1                                     -  enabled
                  + system.adapter.history.0                : history               : iob1                                     -  enabled
                  + system.adapter.influxdb.0               : influxdb              : iob1                                     -  enabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : iob1                                     -  enabled, port: 8086
                  + system.adapter.javascript.0             : javascript            : iob1                                     -  enabled
                  + system.adapter.maxcube.0                : maxcube               : iob1                                     -  enabled, port: 62910, bind: 0.0.0.0
                    system.adapter.mercedesme.0             : mercedesme            : iob1                                     - disabled
                  + system.adapter.modbus.0                 : modbus                : iob1                                     -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iob1                                     -  enabled, port: 1886, bind: 0.0.0.0
                  + system.adapter.ping.0                   : ping                  : iob1                                     -  enabled
                  + system.adapter.shelly.0                 : shelly                : iob1                                     -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonoff.0                 : sonoff                : iob1                                     -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.statistics.0             : statistics            : iob1                                     -  enabled
                    system.adapter.tr-064.0                 : tr-064                : iob1                                     - disabled
                  + system.adapter.tuya.0                   : tuya                  : iob1                                     -  enabled
                  + system.adapter.tuya.1                   : tuya                  : iob1                                     -  enabled
                  + system.adapter.web.0                    : web                   : iob1                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wolf-smartset.0          : wolf-smartset         : iob1                                     -  enabled
                    system.adapter.wolf.0                   : wolf                  : iob1                                     - disabled, port: 12004, bind: 0.0.0.0
                  + instance is alive
                  ioBroker-Repositories
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                  Adapter    "email"        : 1.2.2    , installed 1.2.2
                  Adapter    "ems-esp"      : 3.0.3    , installed 3.0.3
                  Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                  Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                  Adapter    "fritzdect"    : 2.5.9    , installed 2.5.10
                  Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
                  Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                  Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                  Adapter    "wolf"         : 1.7.0    , installed 1.7.0
                  Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                  Objects and States
                  Objects:        21112
                  States:         19547
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://apt.grafana.com stable InRelease
                  Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       2172496    55740/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       2172506    55761/io.sonoff.0
                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       2174631    55854/io.mqtt.0
                  tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       2174632    55854/io.mqtt.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2167748    55542/iobroker.js-c
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2167755    55542/iobroker.js-c
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14013      532/sshd: /usr/sbin
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2169751    55563/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2174816    55944/io.web.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        14230      638/influxd
                  tcp6       0      0 :::3000                 :::*                    LISTEN      110        13205      748/grafana
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14015      532/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12906      391/avahi-daemon: r
                  udp        0      0 0.0.0.0:58791           0.0.0.0:*                           108        12908      391/avahi-daemon: r
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2171528    55797/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2171529    55797/io.tuya.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14035      634/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        12907      391/avahi-daemon: r
                  udp6       0      0 :::45321                :::*                                108        12909      391/avahi-daemon: r
                  2024-04-22 11:02:00.156  - info: javascript.0 (55589) script.js.Tuya.0-run.tuya_wallbox_map_objects: Wallbox SG 0data updated
                  2024-04-22 11:02:00.156  - info: javascript.0 (55589) script.js.Tuya.0-run.tuya_wallbox_map_objects: Wallbox SF 0data updated
                  2024-04-22 11:02:00.171  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Wolf 0data updated
                  2024-04-22 11:02:00.172  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Solar 0data updated
                  2024-04-22 11:02:00.173  - info: javascript.0 (55589) script.js.Wolf.0-run.wolf_hb_mapdata: Solar Pumpe aus: 2 Watt
                  2024-04-22 11:02:00.187  - info: javascript.0 (55589) script.js.Wandthermostat.0-run.wt_map_0data: Map HB Temperaturen
                  2024-04-22 11:02:00.205  - info: javascript.0 (55589) script.js.Thermostat.0-run.comet-map-0data: Comet Data updated
                  2024-04-22 11:02:00.234  - info: javascript.0 (55589) script.js.Thermostat.0-run.max-map-0data: Max Data updated
                  2024-04-22 11:02:00.248  - info: javascript.0 (55589) script.js.Strommessung.0-run.strom_sg_pzem: Strom SG Werte geschrieben
                  2024-04-22 11:02:00.264  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_SF: Strom SF Werte geschrieben
                  2024-04-22 11:02:00.275  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_SG: Strom SG Werte geschrieben
                  2024-04-22 11:02:00.287  - info: javascript.0 (55589) script.js.Strommessung.0-run.strom_pool_heizung: Strom Pool geschrieben:
                  2024-04-22 11:02:08.239  - info: javascript.0 (55589) script.js.Strommessung.0-run.hichi_HB: Strom HichiHB Werte geschrieben
                  2024-04-22 11:02:10.003  - info: javascript.0 (55589) script.js.PV.Fronius.0-run.fronius_map_0data: Fronius 0data updated, Tag: 19
                  2024-04-22 11:02:10.010  - info: javascript.0 (55589) script.js.PV.MTec.0-run.mtec_run: PV 0data geschrieben
                  2024-04-22 11:02:10.020  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Einspeisung
                  2024-04-22 11:02:10.020  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SF Einspeisung
                  2024-04-22 11:02:10.021  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SG Einspeisung
                  2024-04-22 11:02:10.022  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Laden
                  2024-04-22 11:02:20.005  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Einspeisung
                  2024-04-22 11:02:20.005  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SF Einspeisung
                  2024-04-22 11:02:20.006  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: SG Einspeisung
                  2024-04-22 11:02:20.006  - info: javascript.0 (55589) script.js.Dashboard.0-run.dashb_mapdata: HB Laden
                  2024-04-22 11:02:20.028  - info: javascript.0 (55589) script.js.PV.MTec.0-run.mtec_run: PV 0data geschrieben
                  2024-04-22 11:02:20.072  - info: javascript.0 (55589) script.js.PV.Fronius.0-run.fronius_map_0data: Fronius 0data updated, Tag: 19
                  und noch mal die Summary:
                                          v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               arm64
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            10.5.0
                                          /usr/bin/npx            10.5.0
                  MEMORY:
                  Mem:            7.8G        4.0G        916M        1.0M        2.9G        3.6G
                  Swap:            99M          0B         99M
                  Total:          7.9G        4.0G        1.0G
                                          admin                   6.13.16
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                21112
                  States:                 19547
                  14M     /opt/iobroker/iobroker-data/states.jsonl
                    Dein Dateisystem weist erhebliche Defekte auf.
                    Installier die Choose neu auf einem frischen Datenträger.
                    Dann kannste auch direkt Debian 12 'Bookworm' installieren.
                    Dein 'Bullseye' erreicht im Sommer '24 eh das Lebensende.
                    Und knall der Kiste NIE, NIE, NIE plötzlich den Strom weg.
                      @thomas-braun Danke für die Info. Bin leider nicht so der LINUX-Freak. Kann ich ein fertiges iobroker-Image verwenden und dann meine Backups wieder einspielen?
                        Thomas Braun Most Active @manrum1 last edited by Thomas Braun
                        @manrum1
                        Ein Freak bin ich auch nicht.
                        Aber ich mach das immer danach:
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        Von den vorgekochten ioBroker-Images halte ich nicht viel.
                        Die sind soweit ich das weiß ohnehin gerade mal wieder auf Eis gelegt worden.
                        ledvance wifi tuya adapter gelb
                        1092
