    5. Aus Blockly's sind Rules geworden - Warum?
    • qqolli
      qqolli @Homoran last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.5.13-5-pve
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       19:58:59 up 12 days,  6:24,  1 user,  load average: 0.22, 0.34, 0.35
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Sun 2024-04-21 19:58:59 CEST
                 Universal time: Sun 2024-04-21 17:58:59 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      olli
      /home/olli
      olli sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            8.2G        3.9G        2.6G        0.0K        1.7G        4.3G
      Swap:           512M          0B        512M
      Total:          8.7G        3.9G        3.1G
               8192 M total memory
               3894 M used memory
               3613 M active memory
               1682 M inactive memory
               2577 M free memory
                  0 M buffer memory
               1719 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      /dev/loop1     ext4      8.8G  6.3G  2.1G  76% /
      none           tmpfs     492K  4.0K  488K   1% /dev
      udev           devtmpfs  7.8G     0  7.8G   0% /dev/tty
      tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs          tmpfs     3.2G  108K  3.2G   1% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE     FSTYPE OPTIONS
      /      /dev/loop1 ext4   rw,relatime
      /var:
      840M    /var/
      604M    /var/log
      597M    /var/log/journal/096f475719974738990de8370ea361d9
      136M    /var/lib
      Archived and active journals take up 325.5M in the file system.
      /opt/iobroker/backups:
      317M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      928M    /opt/iobroker/iobroker-data/
      770M    /opt/iobroker/iobroker-data/files
      164M    /opt/iobroker/iobroker-data/files/vis-2
      114M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: moment@2.29.4 /opt/iobroker/node_modules/moment
      npm ERR! missing: chroma-js@^2.4.2, required by iobroker.javascript@7.8.0
      npm ERR! missing: mathjs@^12.3.2, required by iobroker.javascript@7.8.0
      npm ERR! missing: moment-duration-format@^2.3.2, required by iobroker.javascript@7.8.0
      npm ERR! A complete log of this run can be found in: /home/olli/.npm/_logs/2024-04-21T17_59_01_762Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.bydhvs.0                 : bydhvs                : ioBroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
        system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.eusec.0                  : eusec                 : ioBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
      + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : ioBroker                                 -  enabled
      + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 12010
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      + system.adapter.octoprint.0              : octoprint             : ioBroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
      + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
      + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 192.168.178.104, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
        system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : ioBroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : ioBroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.90:6638
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
      Adapter    "eusec"        : 1.2.1    , installed 1.2.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
      Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
      Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "reolink"      : 1.0.3    , installed 1.0.3
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yeelight-2"   : 1.3.1    , installed 1.3.1
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        12629
      States:         11483
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          33314      1/init
      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1001       57322877   599236/go2rtc
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       57318074   599047/io.mqtt.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       57318075   599047/io.mqtt.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       57318365   599102/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       57321514   599118/io.sonoff.0
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       59013813   620010/nc
      tcp        0      0 192.168.178.104:12001   0.0.0.0:*               LISTEN      1001       58273969   610840/io.hm-rpc.1
      tcp        0      0 192.168.178.104:12010   0.0.0.0:*               LISTEN      1001       58273974   610847/io.hm-rpc.2
      tcp        0      0 192.168.178.104:18701   0.0.0.0:*               LISTEN      1001       58273971   610833/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       57315067   598764/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       57317094   598764/iobroker.js-
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          33785      328/master
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        34277      128/systemd-resolve
      tcp        0      0 192.168.178.104:8087    0.0.0.0:*               LISTEN      1001       57322358   599357/io.simple-ap
      tcp        0      0 0.0.0.0:39321           0.0.0.0:*               LISTEN      1001       57327259   599586/io.yahka.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        34283      128/systemd-resolve
      tcp6       0      0 :::111                  :::*                    LISTEN      0          33316      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          34172      1/init
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       57322872   599236/go2rtc
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       57322871   599236/go2rtc
      tcp6       0      0 :::20002                :::*                    LISTEN      1001       57327069   599538/io.web.1
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        34280      128/systemd-resolve
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          33786      328/master
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       57317158   598785/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57326707   599434/io.web.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       57327256   599586/io.yahka.0
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        34276      128/systemd-resolve
      udp        0      0 0.0.0.0:39438           0.0.0.0:*                           1001       57321869   599208/io.eusec.0
      udp        0      0 0.0.0.0:48422           0.0.0.0:*                           1001       57321874   599208/io.eusec.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        34282      128/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          33315      1/init
      udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1001       57322873   599236/go2rtc
      udp6       0      0 :::5355                 :::*                                104        34279      128/systemd-resolve
      udp6       0      0 :::111                  :::*                                0          33317      1/init
      2024-04-21 19:56:55.548  - debug: yeelight-2.0 (599449) DEVICE FOUND IN CONFIG: {"name":"color-0x00000000036d9805","ip":"192.168.178.125","port":"55443","smart_name":"Schlafzimmerlicht","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
      2024-04-21 19:56:57.352  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayHeightPixels" has to be type "string" but received type "number"
      2024-04-21 19:56:57.352  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayWidthPixels" has to be type "string" but received type "number"
      2024-04-21 19:57:25.551  - debug: yeelight-2.0 (599449) RESPONSE MESSAGE: from: 0x000000000000000, id: 1137, result:[off,25,16711680,2,3030]}
      2024-04-21 19:57:25.551  - debug: yeelight-2.0 (599449) DEVICE FOUND IN CONFIG: {"name":"color-0x00000000036d9805","ip":"192.168.178.125","port":"55443","smart_name":"Schlafzimmerlicht","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
      2024-04-21 19:57:27.631  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayHeightPixels" has to be type "string" but received type "number"
      2024-04-21 19:57:27.632  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayWidthPixels" has to be type "string" but received type "number"
      2024-04-21 19:57:42.954  - info: admin.0 (598785) ==> Connected system.user.admin from ::ffff:192.168.178.49
      2024-04-21 19:57:55.555  - debug: yeelight-2.0 (599449) RESPONSE MESSAGE: from: 0x000000000000000, id: 1138, result:[off,25,16711680,2,3030]}
      2024-04-21 19:57:55.555  - debug: yeelight-2.0 (599449) DEVICE FOUND IN CONFIG: {"name":"color-0x00000000036d9805","ip":"192.168.178.125","port":"55443","smart_name":"Schlafzimmerlicht","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
      2024-04-21 19:57:57.899  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayHeightPixels" has to be type "string" but received type "number"
      2024-04-21 19:57:57.900  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayWidthPixels" has to be type "string" but received type "number"
      2024-04-21 19:58:25.557  - debug: yeelight-2.0 (599449) RESPONSE MESSAGE: from: 0x000000000000000, id: 1139, result:[off,25,16711680,2,3030]}
      2024-04-21 19:58:25.559  - debug: yeelight-2.0 (599449) DEVICE FOUND IN CONFIG: {"name":"color-0x00000000036d9805","ip":"192.168.178.125","port":"55443","smart_name":"Schlafzimmerlicht","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
      2024-04-21 19:58:26.422  - error: eusec.0 (599208) Station: T8030P23225109DD command CMD_SDINFO_EX failed with error: undefined (-148)
      2024-04-21 19:58:29.140  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayHeightPixels" has to be type "string" but received type "number"
      2024-04-21 19:58:29.140  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayWidthPixels" has to be type "string" but received type "number"
      2024-04-21 19:58:55.561  - debug: yeelight-2.0 (599449) RESPONSE MESSAGE: from: 0x000000000000000, id: 1140, result:[off,25,16711680,2,3030]}
      2024-04-21 19:58:55.561  - debug: yeelight-2.0 (599449) DEVICE FOUND IN CONFIG: {"name":"color-0x00000000036d9805","ip":"192.168.178.125","port":"55443","smart_name":"Schlafzimmerlicht","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
      2024-04-21 19:58:59.356  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayHeightPixels" has to be type "string" but received type "number"
      2024-04-21 19:58:59.357  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayWidthPixels" has to be type "string" but received type "number"
      2024-04-21 19:59:25.568  - debug: yeelight-2.0 (599449) RESPONSE MESSAGE: from: 0x000000000000000, id: 1141, result:[off,25,16711680,2,3030]}
      2024-04-21 19:59:25.569  - debug: yeelight-2.0 (599449) DEVICE FOUND IN CONFIG: {"name":"color-0x00000000036d9805","ip":"192.168.178.125","port":"55443","smart_name":"Schlafzimmerlicht","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
      2024-04-21 19:59:29.732  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayHeightPixels" has to be type "string" but received type "number"
      2024-04-21 19:59:29.732  - info: fully-tablet-control.0 (599288) State value to set for "fully-tablet-control.0.device.kg_fire_hd_7.device_info.displayWidthPixels" has to be type "string" but received type "number"
        Homoran Global Moderator Administrators @qqolli last edited by
        @qqolli Danke!
        Da läuft es nicht ganz rund
        da:
        @qqolli sagte in Aus Blockly's sind Rules geworden - Warum?:
        und da:
        Errors in npm tree:
        hier ist js mit betroffen.
        Was dagegen zu tun ist kann ich dir leider nicht sagen, das übersteigt mein Können.
        Vielleicht kann da @thomas-braun helfen
        qqolli 1 Reply Last reply Reply Quote 1
        • qqolli
          @homoran Vielen Dank erstmal für deine Hilfe und deine Zeit!
          @thomas-braun Hättest du vielleicht noch eine Idee?
            Thomas Braun Most Active @qqolli last edited by
            @qqolli
            Zu LXCs fällt mir nix ein, nutze die Dinger nicht.
            Errors in npm tree:
            Da scheint mir das Modul 'moment' im Javascript-Adapter nicht mit um's Eck zu kommen. Leg das nochmal an. Und/oder schau, wo es genau klemmt:
            cd /opt/iobroker && npm ls moment
            Bullsyeye läuft auch in ein paar Wochen aus. Kümmer dich um den Absprung.
            qqolli 1 Reply Last reply Reply Quote 0
            • qqolli
              qqolli @Thomas Braun last edited by
              olli@ioBroker:~$ cd /opt/iobroker && npm ls moment
              [sudo] password for olli:
              iobroker.inst@3.0.0 /opt/iobroker
              +-- iobroker.countdown@2.2.0
              | `-- moment@2.29.4 invalid: "^2.30.1" from node_modules/iobroker.javascript
              +-- iobroker.echarts@1.7.2
              | `-- moment@2.29.4 deduped
              +-- iobroker.javascript@7.8.0
              | +-- moment-timezone@0.5.45
              | | `-- moment@2.29.4 deduped invalid: "^2.30.1" from node_modules/iobroker.javascript
              +-- iobroker.js-controller@5.0.19
              | `-- @iobroker/js-controller-common@5.0.19
              |   `-- winston-daily-rotate-file@4.7.1
              |     `-- file-stream-rotator@0.6.1
              `-- iobroker.synology@3.0.1
              Was ist dieses moment und wie kann ich es neu installieren/reparieren? Javascript-Adapter löschen und neu installieren?
                Da klemmt es:
                Schau in die Einstellunge des javascript-Adapters. Hast du da 'moment' als zusätzliches Modul eingetragen?
                • qqolli
                  Hab ich tatsächlich, wobei, wenn ich ehrlich bin, gar nicht mehr weiß warum und wofür 😞
                  Soll ich die drei moment- ... rauswerfen? Oder wie kann man die ggf. updaten (wenn das möglich ist)?
                    Ich würde mein System da 'sauber halten wollen'.
                    Btw ist ein Spiegel innerhalb von /opt/iobroker wenig sinnvoll. Ich würde (bzw. habe) das bei mir nach /home/iobroker/ spiegeln.
                    • qqolli
                      Ok, d. h. ich würde den bestehenden Eintrag von
                      /opt/iobroker/scripts
                      nach
                      /opt/iobroker/
                      ändern und die 3 moment-Einträge löschen, zumal ich nicht mehr weiß, wozu die gut waren?
                      Kann ich das "umspiegeln" 🙂 so machen, oder muss ich dabei noch etwas beachten? Sorry schon mal für all die nervigen Fragen.
                        @qqolli
                        Nein, nach
                        Ich schrieb doch, das macht keinen Sinn das nach /opt zu schreiben.
                        • qqolli
                          Ja, stimmt allerdings. Wer lesen kann, ist da deutlich im Vorteil, sorry 🙂
                          Dann werde ich das mal ändern. Aber Probleme wird es dann hoffentlich keine geben oder?
                            Hier nicht.
                            • qqolli
                              Mit
                              /home/iobroker/skripte
                              und ohne die moment-Einträge läuft
                              iob diag
                              jetzt auch ohne "Errors in npm tree" durch, aber jetzt bekomme ich den folgenden für "Failed Services":
                                @qqolli
                                Zu den failed services kann ich dir nix sagen. Hat mit dem LXC Krams zu tun. Ich hab keine Ahnung ob die laufen müssten.
                                • qqolli
                                  Ich habe gerade gesehen, das doch wieder Fehler im npm tree aufgetreten sind:
                                  Errors in npm tree:
                                  Hättest du eine Idee, warum und wie ich das ggf. wieder i. O. bringen könnte?
                                    Thomas Braun Most Active @qqolli last edited by Thomas Braun
                                    Der muss in einer validen Version installiert werden/sein.
                                    Schau dir
                                    cd /opt/iobroker/ && npm ls moment
                                    an.
                                    • qqolli
                                      zeigt folgendes an:
                                      `-- iobroker.synology@3.1.0
                                        `-- moment@2.30.1
                                      Wie kann ich den in einer validen Version re-installieren oder ganz entfernen?
                                        @qqolli
                                        Hast du moment im Javascript-Adapter als zusätzliches Modul eingetragen?
                                        Auf der HP von moment steht auch:
                                        Moment.js is a legacy project, now in maintenance mode. In most cases, you should choose a different library.
                                        • qqolli
                                          Der war bis vor kurzem im Javascript-Adapter eingetragen. Zur Zeit sind dort nur noch diese zwei eingetragen:
                                          Wie könnte ich denn dieses Modul (moment) komplett entfernen?
                                            @qqolli
                                            Viel fällt mir dazu nicht ein. Jag vielleicht mal ein
                                            npm prune
                                            über das Verzeichnis.
                                            blockly javascript
                                            2798
