    4. ioBroker friert ein: "Request actual repository...".....
      Thomas Braun Most Active @Clyde last edited by
      @clyde
      Und hast du auch die Langfassung von
      iob diag
      gepostet?
        Clyde @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.64-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         15:57:44 up 1 day, 21:51,  2 users,  load average: 0.93, 1.07, 1.00
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2024-04-22 15:57:44 CEST
                   Universal time: Mon 2024-04-22 13:57:44 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            1.8G        1.1G        263M        0.0K        477M        673M
        Swap:            99M         23M         76M
        Total:          1.9G        1.1G        340M
                 1847 M total memory
                 1106 M used memory
                  966 M active memory
                  453 M inactive memory
                  263 M free memory
                   46 M buffer memory
                  431 M swap cache
                   99 M total swap
                   23 M used swap
                   76 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   36G   21G  64% /
        devtmpfs       devtmpfs  666M     0  666M   0% /dev
        tmpfs          tmpfs     924M     0  924M   0% /dev/shm
        tmpfs          tmpfs     370M  1.1M  369M   1% /run
        /dev/sda1      vfat      253M   60M  193M  24% /boot
        tmpfs          tmpfs     185M  4.0K  185M   1% /run/user/1000
        [Sat Apr 20 18:06:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enab                   le_hdmi=0  smsc95xx.macaddr=E4:5F:01:A3:D6:28 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=811c5af8-02 rootfstype=ext4 fsck.repai                   r=yes rootwait
        [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): write access will be enabled during recovery
        [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): 1 orphan inode deleted
        [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): recovery complete
        [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Apr 20 18:06:24 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Apr 20 18:06:26 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        802M    /var/
        543M    /var/cache
        538M    /var/cache/apt
        473M    /var/cache/apt/archives
        101M    /var/lib
        Archived and active journals take up 55.0M in the file system.
        /opt/iobroker/backups:
        84M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        31G     /opt/iobroker/iobroker-data/history
        324M    /opt/iobroker/iobroker-data/files
        99M     /opt/iobroker/iobroker-data/history/20230624
        98M     /opt/iobroker/iobroker-data/history/20230702
        31M     /opt/iobroker/iobroker-data/objects.jsonl
        27M     /opt/iobroker/iobroker-data/states.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.2
        /usr/bin/node           v18.20.2
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.2-1nodesource1
          Candidate: 18.20.2-1nodesource1
          Version table:
         *** 18.20.2-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.1-1nodesource1 500
             18.20.0-1nodesource1 500
             18.19.1-1nodesource1 500
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.1.204, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
        + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
        + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        + system.adapter.viessmann.0              : viessmann             : raspberrypi                              -  enabled, port: 3002
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
        Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
        Adapter    "fronius"      : 2.0.2    , installed 1.1.6  [Updatable]
        Adapter    "go-e"         : 1.0.29   , installed 1.0.29
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "shelly"       : 6.8.0    , installed 6.8.0
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "telegram"     : 3.2.1    , installed 3.1.0  [Updatable]
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "viessmann"    : 1.4.7    , installed 1.4.7
        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "ws"           : 2.5.11   , installed 2.5.11
        Objects and States
        Objects:        12641
        States:         14186
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.1.204:18701     0.0.0.0:*               LISTEN      1001       3132060    32457/io.hm-rpc.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3131143    32322/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3128867    32322/iobroker.js-c
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3129144    32517/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3132545    32547/io.sonoff.0
        tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          3693       542/vcontrold
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15542      533/sshd: /usr/sbin
        tcp        0      0 192.168.1.204:8081      0.0.0.0:*               LISTEN      1001       3128918    32343/io.admin.0
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        15578      506/redis-server 12
        tcp        0      0 192.168.1.204:12010     0.0.0.0:*               LISTEN      1001       3132463    32487/io.hm-rpc.2
        tcp        0      0 192.168.1.204:12001     0.0.0.0:*               LISTEN      1001       3132423    32472/io.hm-rpc.1
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3138863    1257/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15552      533/sshd: /usr/sbin
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        15579      506/redis-server 12
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14644      711/dhcpcd
        udp        0      0 0.0.0.0:53397           0.0.0.0:*                           108        12267      392/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12265      392/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        12266      392/avahi-daemon: r
        udp6       0      0 :::41461                :::*                                108        12268      392/avahi-daemon: r
        2024-04-22 15:46:57.720  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for vis-material-advanced
        2024-04-22 15:46:58.251  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 states (system.adapter.vis-material-advanced.*) from states
        2024-04-22 15:47:03.233  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced deleted
        2024-04-22 15:47:03.316  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced.html deleted
        2024-04-22 15:47:03.415  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
        2024-04-22 15:47:03.486  - info: host.raspberrypi iobroker host.raspberrypi file vis-material-advanced.admin deleted
        2024-04-22 15:47:03.514  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced deleted
        2024-04-22 15:47:03.576  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced.admin deletedhost.raspberrypi Deleting 3 object(s).
        2024-04-22 15:47:03.726  - info: host.raspberrypi object deleted system.adapter.vis-material-advanced.0
        2024-04-22 15:47:03.731  - info: host.raspberrypi iobroker host.raspberrypi Deleting 1 state(s).
        2024-04-22 15:47:08.787  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
        2024-04-22 15:47:08.824  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 vis.0
        2024-04-22 15:47:08.827  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
        2024-04-22 15:47:11.243  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
        2024-04-22 15:47:12.265  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
        2024-04-22 15:47:19.819  - info: vis.0 (1239) Uploaded. 0
        2024-04-22 15:47:20.142  - info: host.raspberrypi iobroker removed 1 package in 15s266 packages are looking for funding  run `npm fund` for details
        2024-04-22 15:47:20.273  - info: host.raspberrypi "system.adapter.vis.0" disabled
        2024-04-22 15:47:20.274  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
        2024-04-22 15:47:20.302  - info: host.raspberrypi "system.adapter.vis.0" enabled
        2024-04-22 15:47:20.302  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
        2024-04-22 15:47:20.307  - info: host.raspberrypi iobroker Adapter "system.adapter.vis.0" restarted.
        2024-04-22 15:47:20.335  - info: vis.0 (1239) Terminated (NO_ERROR): Without reason
        2024-04-22 15:47:20.983  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2024-04-22 15:47:21.349  - info: host.raspberrypi iobroker exit 0
        ============ Mark until here for C&P =============```
          Lollo_C @Clyde last edited by Lollo_C
          @clyde sagte in ioBroker friert ein: "Request actual repository...".....:
          @lollo_c Bist du schon schlauer geworden?
          Wie ich weiter oben angekündigt hatte, habe ich den Fehler genutzt und meine Hardware umgestellt. Der Master läuft nun auf einem Raspberry Pi 5 mit 8 GB und der Slave auf einem Raspberry Pi 4 mit 4 GB.
          Das System läuft nun seit über einer Woche ohne Probleme, obwohl jeden Tag auf Updates überprüft wird.
          Das "alte" System läuft noch leer nebenher und ich denke mal, dass er in 2 Tagen wieder einfrieren wird. Dann sind die 14 Tage um und er wird wieder nach Updates suchen wollen.
            @clyde
            Stell es auf ein reines 64Bit 'Bookworm' um.
            Und 2GB RAM sind für einen 'normalen' Betrieb unterdimensioniert.
            Dann hast du Einschläge auf dem Dateisystem:
            Bei den ioBroker-Adaptern herrscht Update-Stau.
              Clyde @Thomas Braun last edited by Clyde
              @thomas-braun lief über Jahre mit den 2 GB.
              Wie stelle ich auf Bookworm um?
              Vor zwei Wochen alles geupdadet, aber ja, müsste ich mal wieder machen.
              Was bedeutet das mit den Einschlägen? 18:06 am 20. April war übrigens direkt zum Reboot nach dem letzten Hänger. Also beim Hochfahren nach dem Fehler und dementsprechend eher nicht ursächlich.
                Das ist immer so. Irgendwann läuft es eben nicht mehr.
                Komplette Neuinstallation, weil du da im Userland auf 32Bit hängst.
                Dann machst du es deutlich zu selten. Die 8 Updates sind doch nicht alle aus den letzten zwei Wochen? Nicht im Stable-Repo...
                Das bedeutet, dass nach deiner Exekution durch Stromentzug das System einige Dateien nicht wieder reanimieren konnte und die beerdigt/gelöscht hat.
                Nö, vielleicht nicht, aber da hat es die nächsten Rumms im Dateisystem gegeben, trägt alles nicht zu einem stabilen System bei. Im Gegenteil.
                  Alle zwei Wochen ist zu selten? Dachte eigentlich, dass iobroker für mich arbeitet und nicht umgekehrt. Bis auf den Fronius-Adapter war vor zwei Wochen alles aktuell. Bei dem gibt es wohl ein größere Update mit Objektänderungen, was ich mal irgendwann mache, wenn ich mehr Zeit habe.
                  Vermutlich dann im Zuge der 64-Bit-Umstellung.
                  Der "Einschlag" war wie gesagt nach dem harten Reset; vermutlich einfach dem geschuldet. Was bleibt: "wir haben keine Ahnung, also Neuinstallation." Ärgerlich aber nach ein paar Jahren ohne Probleme wohl mal verschmerzbar.
                  Thomas Braun Homoran Codierknecht 3 Replies Last reply Reply Quote 0
                    Ich habe genug Ahnung und ich sage dir, das eine Umstellung des Userlands von 32Bit auf 64Bit nicht per Upgrade sondern nur per kompletter Neuinstallation geht.
                    Und meine Ahnung lässt mich auch wissen, das gelöschte Inodes halt gelöscht sind und nicht wiederhergestellt werden konnten. Auch das bekommst du nur durch eine Neuinstallation und Einspielen eines hoffentlich vorhandenen Backups geheilt.
                      Homoran Global Moderator Administrators @Clyde last edited by
                      dann ist gut,
                      @thomas-braun sagte in ioBroker friert ein: "Request actual repository...".....:
                      ich habe im stable keine 8 updates in den letzten 2 Wochen gehabt, höchstens 3.
                      nicht ernst gemeint, oder doch?
                      • Codierknecht
                        Codierknecht Developer Most Active @Clyde last edited by
                        Was - wenn auch mit einem gewissen Risiko verbunden - auch noch gehen würde, wäre ein automatisches Update per Script.
                        Wenn man eh nur alles durchwinken würde, kommt das aufs Gleiche raus.
                        Damit lassen sich sowohl die Adapter als auch das OS immer aktuell halten.
                          leif1 last edited by
                          Ich hab ein ähnliches Problem. Bei mir läuft es auf einem ausgemusterten Laptop unter Debian Bookworm im Docker / Portainer.
                          crash log:
                          2024-05-24 03:40:29.848 - info: admin.0 (168) Request actual repository...
                          2024-05-24 03:40:30.341 - info: host.b925cd8b2911 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                          2024-05-24 03:40:34.189 - error: sonoff.0 (472) Objects database error: read ECONNRESET
                          2024-05-24 03:40:34.186 - error: zigbee.0 (502) Objects database error: read ECONNRESET
                          2024-05-24 03:40:39.163 - error: bambulab.0 (113047) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2024-05-24 03:40:39.164 - error: bambulab.0 (113047) States database error: connect ECONNREFUSED 127.0.0.1:9000
                          2024-05-24 03:40:39.180 - error: bambulab.1 (648) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          2024-05-24 03:40:39.191 - error: mqtt.1 (429) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          iob diag
                          Skript v.2024-04-21
                          *** BASE SYSTEM ***
                          Hardware Vendor : Timi
                          Kernel          : x86_64
                          Userland        : 64 bit
                          Docker          : v9.1.2
                          Virtualization  : Docker
                          Kernel          : x86_64
                          Userland        : 64 bit
                           17:05:23 up 43 days, 14:40,  0 user,  load average: 0.43, 0.38, 0.35
                          CPU threads: 4
                          Fri May 24 15:05:23 UTC 2024
                          Fri May 24 17:05:23 CEST 2024
                          CEST +0200
                          Etc/UTC
                          *** Users and Groups ***
                          User that called 'iob diag':
                          root
                          HOME=/root
                          GROUPS=root
                          iobroker
                          HOME=/opt/iobroker
                          GROUPS=iobroker tty dialout audio video
                          *** Display-Server-Setup ***
                          pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                          Try `pgrep -f' option to match against the complete command line.
                          Display-Server: false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:            4.0G        3.1G        183M         47M        993M        881M
                          Swap:           1.0G        536M        488M
                          Total:          5.0G        3.6G        671M
                          Active iob-Instances:   25
                                   3798 M total memory
                                   2958 M used memory
                                    573 M active memory
                                   2585 M inactive memory
                                    174 M free memory
                                     79 M buffer memory
                                    868 M swap cache
                                    976 M total swap
                                    511 M used swap
                                    465 M free swap
                          top - 17:05:23 up 43 days, 14:40,  0 user,  load average: 0.43, 0.38, 0.35
                          Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3798.3 total,    173.9 free,   2958.8 used,    947.8 buff/cache
                          MiB Swap:    977.0 total,    465.5 free,    511.5 used.    839.5 avail Mem
                          *** FILESYSTEM ***
                          Filesystem     Type     Size  Used Avail Use% Mounted on
                          overlay        overlay  116G   13G   97G  12% /
                          tmpfs          tmpfs     64M     0   64M   0% /dev
                          shm            tmpfs     64M     0   64M   0% /dev/shm
                          /dev/sda2      ext4     116G   13G   97G  12% /opt/iobroker
                          tmpfs          tmpfs    1.9G     0  1.9G   0% /proc/asound
                          tmpfs          tmpfs    1.9G     0  1.9G   0% /proc/acpi
                          tmpfs          tmpfs    1.9G     0  1.9G   0% /sys/firmware
                          tmpfs          tmpfs    1.9G     0  1.9G   0% /sys/devices/virtual/powercap
                          dmesg: read kernel buffer failed: Operation not permitted
                          Show mounted filesystems:
                          /                                 overlay        overlay rw,relatime,lowerdir=/var/lib/docker/overlay2/l/GTMQFZAWFB26W5VQ7BYDASQVNN:/var/lib/docker/overlay2/l/PGLBUKV6RIHYO232G6QI7C3LHM:                                                           /var/lib/docker/overlay2/l/ANPZ2SFP5FKYIIQU2B5PRFNLK2:/var/lib/docker/overlay2/l/TGZICKKI2EYDBDS7HLFBWY4MIT:/var/lib/docker/overlay2/l/3LUUBBYV                                                           GGC76HFJYEFVCBNGHX:/var/lib/docker/overlay2/l/RHORYH5P4PDYH2KBWPSUT3GDLP,upperdir=/var/lib/docker/overlay2/ed6e0cf52866c709d8ca41e6467e95c2841c                                                           2aca934dcd7ce9fac355a5322f12/diff,workdir=/var/lib/docker/overlay2/ed6e0cf52866c709d8ca41e6467e95c2841c2aca934dcd7ce9fac355a5322f12/work
                          |-/proc                           proc        proc    rw,nosuid,nodev,noexec,relatime
                          | |-/proc/bus                     proc[/bus]        proc    ro,nosuid,nodev,noexec,relatime
                          | |-/proc/fs                      proc[/fs]        proc    ro,nosuid,nodev,noexec,relatime
                          | |-/proc/irq                     proc[/irq]        proc    ro,nosuid,nodev,noexec,relatime
                          | |-/proc/sys                     proc[/sys]        proc    ro,nosuid,nodev,noexec,relatime
                          | |-/proc/sysrq-trigger           proc[/sysrq-trigger]        proc    ro,nosuid,nodev,noexec,relatime
                          | |-/proc/asound                  tmpfs        tmpfs   ro,relatime,inode64
                          | |-/proc/acpi                    tmpfs        tmpfs   ro,relatime,inode64
                          | |-/proc/kcore                   tmpfs[/null]        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                          | |-/proc/keys                    tmpfs[/null]        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                          | `-/proc/timer_list              tmpfs[/null]        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                          |-/dev                            tmpfs        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                          | |-/dev/pts                      devpts        devpts  rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
                          | |-/dev/mqueue                   mqueue        mqueue  rw,nosuid,nodev,noexec,relatime
                          | `-/dev/shm                      shm        tmpfs   rw,nosuid,nodev,noexec,relatime,size=65536k,inode64
                          |-/sys                            sysfs        sysfs   ro,nosuid,nodev,noexec,relatime
                          | |-/sys/fs/cgroup                cgroup        cgroup2 ro,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                          | |-/sys/firmware                 tmpfs        tmpfs   ro,relatime,inode64
                          | `-/sys/devices/virtual/powercap tmpfs        tmpfs   ro,relatime,inode64
                          |-/opt/iobroker                   /dev/sda2[/var/lib/docker/volumes/iobroker/_data]        ext4    rw,relatime,errors=remount-ro
                          |-/etc/resolv.conf                /dev/sda2[/var/lib/docker/containers/5841fce69162b678a2fb22a62d339d1ded9c22a653176dd9d649a5c329065cfd/resolv.                                                           conf] ext4    rw,relatime,errors=remount-ro
                          |-/etc/hostname                   /dev/sda2[/var/lib/docker/containers/5841fce69162b678a2fb22a62d339d1ded9c22a653176dd9d649a5c329065cfd/hostnam                                                           e]    ext4    rw,relatime,errors=remount-ro
                          `-/etc/hosts                      /dev/sda2[/var/lib/docker/containers/5841fce69162b678a2fb22a62d339d1ded9c22a653176dd9d649a5c329065cfd/hosts]        ext4    rw,relatime,errors=remount-ro
                          /var:
                          34M     /var/
                          32M     /var/lib
                          19M     /var/lib/apt/lists
                          19M     /var/lib/apt
                          13M     /var/lib/dpkg
                          212M    /opt/iobroker/backups/
                          573M    /opt/iobroker/iobroker-data/
                          434M    /opt/iobroker/iobroker-data/files
                          142M    /opt/iobroker/iobroker-data/files/vis-2
                          138M    /opt/iobroker/iobroker-data/files/javascript.admin
                          118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
                          21M     /opt/iobroker/iobroker-data/objects.jsonl
                          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          HINT:
                          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                          /dev/ttyUSB0
                          /usr/bin/npm            10.5.2
                          /usr/bin/npx            10.5.2
                          nodejs:
                            Candidate: 18.20.3-1nodesource1
                            Version table:
                               18.20.3-1nodesource1 1001
                                 1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           *** 18.20.2-1nodesource1 1001
                               18.20.1-1nodesource1 1001
                               18.20.0-1nodesource1 1001
                               18.19.1-1nodesource1 1001
                               18.19.0+dfsg-6~deb12u1 500
                                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                               18.19.0-1nodesource1 1001
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0+dfsg1-1 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.16
                          javascript:     8.3.1
                          nodejs modules from github:     2
                          +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
                          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : b925cd8b2911                             -  enabled, port: 8081, bind: 0.0.                                                           0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : b925cd8b2911                             -  enabled
                          + system.adapter.alexa2.1                 : alexa2                : b925cd8b2911                             -  enabled
                          + system.adapter.backitup.0               : backitup              : b925cd8b2911                             -  enabled
                          + system.adapter.bambulab.0               : bambulab              : b925cd8b2911                             -  enabled, port: 8883
                          + system.adapter.bambulab.1               : bambulab              : b925cd8b2911                             -  enabled, port: 8883
                          + system.adapter.broadlink2.0             : broadlink2            : b925cd8b2911                             -  enabled
                          + system.adapter.discovery.0              : discovery             : b925cd8b2911                             -  enabled
                          + system.adapter.hue.0                    : hue                   : b925cd8b2911                             -  enabled, port: 80
                          + system.adapter.influxdb.0               : influxdb              : b925cd8b2911                             -  enabled, port: 8086
                            system.adapter.info.0                   : info                  : b925cd8b2911                             - disabled
                          + system.adapter.iot.0                    : iot                   : b925cd8b2911                             -  enabled
                          + system.adapter.javascript.0             : javascript            : b925cd8b2911                             -  enabled
                            system.adapter.mihome.0                 : mihome                : b925cd8b2911                             - disabled, port: 9898, bind: 0.0.                                                           0.0
                          + system.adapter.mqtt.1                   : mqtt                  : b925cd8b2911                             -  enabled, port: 1883, bind: 0.0.                                                           0.0
                          + system.adapter.node-red.0               : node-red              : b925cd8b2911                             -  enabled, port: 1880, bind: 0.0.                                                           0.0
                            system.adapter.parcel.0                 : parcel                : b925cd8b2911                             - disabled
                            system.adapter.radar2.0                 : radar2                : b925cd8b2911                             - disabled
                          + system.adapter.samsung.0                : samsung               : b925cd8b2911                             -  enabled
                          + system.adapter.scenes.0                 : scenes                : b925cd8b2911                             -  enabled
                          + system.adapter.simple-api.0             : simple-api            : b925cd8b2911                             -  enabled, port: 8087, bind: 0.0.                                                           0.0, run as: admin
                          + system.adapter.sonoff.0                 : sonoff                : b925cd8b2911                             -  enabled, port: 1884, bind: 0.0.                                                           0.0
                          + system.adapter.telegram.0               : telegram              : b925cd8b2911                             -  enabled, port: 8443, bind: 0.0.                                                           0.0
                          + system.adapter.text2command.0           : text2command          : b925cd8b2911                             -  enabled
                          + system.adapter.tuya.0                   : tuya                  : b925cd8b2911                             -  enabled
                            system.adapter.tuya.1                   : tuya                  : b925cd8b2911                             - disabled
                            system.adapter.vis-2.0                  : vis-2                 : b925cd8b2911                             - disabled
                          + system.adapter.web.0                    : web                   : b925cd8b2911                             -  enabled, port: 8082, bind: 0.0.                                                           0.0, run as: admin
                          + system.adapter.wled.0                   : wled                  : b925cd8b2911                             -  enabled
                          + system.adapter.zigbee.0                 : zigbee                : b925cd8b2911                             -  enabled, port: /dev/ttyUSB0
                          + instance is alive
                          Stable (default): http://download.iobroker.net/sources-dist.json
                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                          Active repo(s): Stable (default)
                          Used repository: Stable (default)
                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                          Adapter    "broadlink2"   : 2.2.0    , installed 2.2.0
                          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                          Adapter    "hue"          : 3.11.0   , installed 3.11.0
                          Adapter    "iot"          : 3.2.2    , installed 3.2.2
                          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                          Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                          Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                          Adapter    "wled"         : 0.7.2    , installed 0.7.2
                          Adapter    "ws"           : 2.6.1    , installed 2.6.1
                          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                          Objects and States
                          Objects:        13854
                          States:         12028
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 13
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       34915000   -
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       34917401   -
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34917908   -
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       34917657   -
                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       34918648   -
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       34918283   -
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34915677   -
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       34918931   -
                          udp        0      0 0.0.0.0:57826           0.0.0.0:*                           1000       34916954   -
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       34918034   -
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       34918035   -
                          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       34918439   -
                          udp        0      0 0.0.0.0:40108           0.0.0.0:*                           1000       34916955   -
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34918297   -
                          2024-05-24 17:04:29.639  - warn: bambulab.0 (518) Connection to Printer closed
                          2024-05-24 17:04:30.173  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                          2024-05-24 17:04:30.610  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563070606_743
                          2024-05-24 17:04:53.112  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                          2024-05-24 17:04:53.519  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563093518_3560
                          2024-05-24 17:04:53.990  - error: bambulab.1 (632) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.155:8883
                          2024-05-24 17:04:53.991  - warn: bambulab.1 (632) Connection to Printer closed
                          2024-05-24 17:05:02.694  - error: bambulab.0 (518) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.147:8883
                          2024-05-24 17:05:02.695  - warn: bambulab.0 (518) Connection to Printer closed
                          2024-05-24 17:05:04.755  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:04.761  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:16.020  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                          2024-05-24 17:05:17.520  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563117516_3832
                          2024-05-24 17:05:19.756  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:19.762  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:22.463  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:22.467  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:27.046  - error: bambulab.1 (632) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.155:8883
                          2024-05-24 17:05:27.047  - warn: bambulab.1 (632) Connection to Printer closed
                          2024-05-24 17:05:35.750  - error: bambulab.0 (518) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.147:8883
                          2024-05-24 17:05:35.751  - warn: bambulab.0 (518) Connection to Printer closed
                          2024-05-24 17:05:37.465  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:37.468  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                          2024-05-24 17:05:40.021  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                          2024-05-24 17:05:42.673  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563142672_6098
                          (die Bambus sind derzeit nicht aktiv gewesen, daher deren Fehler)
                          • Codierknecht
                            Codierknecht Developer Most Active @leif1 last edited by
                            @leif1 sagte in ioBroker friert ein: "Request actual repository...".....:
                            Und welches genau?
                            Pending Updates: 13
                              leif1 @Codierknecht last edited by leif1
                              @codierknecht said in ioBroker friert ein: "Request actual repository...".....:
                              Und welches genau?
                              Dass sich der ioBroker einfach nach
                              beendet.
                              Pending Updates: 13
                              Die sind nun auf 0. Aber sollte es daran gelegen haben dass ein paar Wochen keine Updates durchgeführt wurden (ca 4-5, die Installation ist noch nicht alt) wäre es ja schon reichlich ungünstig wenn nicht sofort durchgeführte Updates das komplette SmartHome lahmlegen können.
                              In den Jahren zuvor, auf dem Raspi ohne Docker / Portainer, hatte ich das Problem noch nicht. Erscheint mir schon ungewöhnlich und nicht normal.
                                Thomas Braun Most Active @leif1 last edited by
                                @leif1
                                Ich würde ja glatt behaupten, das hängt mit den Eigen- und Besonderheiten von Docker und Portainer zusammen. Da müssen gewisse Dinge anders gemacht werden.
                                  leif1 @Thomas Braun last edited by
                                  @thomas-braun said in ioBroker friert ein: "Request actual repository...".....:
                                  @leif1
                                  Danke für den Input, das klingt so als wenn ich nochmal etwas Zeit in die Pro-/Kontra Abwägung bezüglich Docker investieren und meine Entscheidung evtl. noch einmal überdenken sollte.
                                  • Meister Mopper
                                    Meister Mopper @leif1 last edited by
                                    Du musst doch nur eine Entscheidung treffen, in welche Richtung du lernen möchstest.
                                    Übrigens, die optimale Lösung wäre in alle Richtungen, dann könntest du allen helfen! 😉
                                      leif1 @Meister Mopper last edited by leif1
                                      @meister-mopper
                                      Für noch mehr Hobbys fehlt mir leider die Zeit - in sofern ist die Zeit für Linux beschränkt. In erster Linie soll das SmartHome laufen, und nicht mehr Zeit kosten als es ohne würde. Bzw sollte es im Idealfall Probleme selbst erkennen und zumindest eigenständig einen restart durchführen können - gerade in dem Bereich eines SmartHomes solltes dies doch die oberste Priorität haben dass so wenig wie möglich zu einem totalen Ausfall des Systems führen kann.
                                      Ich bin auf autoheal gestoßen, aber wenn man die Diskussionen dazu ließt scheint das auch nicht zuverlässig zu funktionieren. Da fragt man sich wieso es einen Health Status gibt, wenn es dann an so etwas simplen wie einem automatische restart scheitert.
                                      Heute hatte ich wieder einen Ausfall nach:
                                      "2024-05-27 16:54:14.301 - info: host.b925cd8b2911 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json""
                                      Bin der letzte der nicht auch gern mal nach einem Problem tiefer taucht, aber die Fehlermeldung ist halt nicht wirklich hilfreich wenn das alles ist was man bekommt. Ich mein warum sollte ein laufendes System sich selbst beenden, nur weil ein Update Versuch fehlschlägt. Gib ne Fehlermeldung dass so etwas nicht funktioniert - aber ein crash und beenden des Dienstes? Klingt für mich nicht logisch. Warum schlägt dieser fehl? Ergibt sich mir aus der Fehlermeldung auch nicht.
                                      Die Konnektivität zum repository ist gegeben - daran kann es nicht liegen. Aufgesetzt wurde es damals nach einem Guide - der hoffentlich auch stimmte. Dieses Mal war das System außerdem up to date, also kann es daran auch nicht liegen.
                                      Also komm ich als Linux Laie zu dem Fazit dass ioBroker offenbar für den 08/15 Anwender ohne Docker zuverlässiger läuft. Ohne es irgendwie bös zu meinen, aber getreu dem KISS Prinzip ... keep it simple. Jede extra Ebene schafft offenbar nur mehr potentielle Probleme.
                                      Werd's die Tage nochmal ohne aufsetzen und dann hoffentlich Ruhe haben.
                                      81
                                      5108
