    4. Homebridge Fehler Code 243
      marcelinho @Thomas Braun last edited by
      Copy text starting here:
                              v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     180
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v20.11.0
                              /usr/local/bin/node             v21.1.0
                              /usr/local/bin/npm              10.2.0
                              /usr/local/bin/npx              10.2.0
                              /usr/local/bin/corepack         0.22.0
      Recommended versions are nodejs 18.20.2 and npm 10.5.0
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            4.0G        3.4G        101M         14M        601M        608M
      Swap:           104M        104M        221K
      Total:          4.1G        3.5G        101M
      Active iob-Instances:   24
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.19
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                14990
      States:                 13387
      Size of iob-Database:
      20M     /opt/iobroker/iobroker-data/objects.jsonl
      4.0M    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
        Thomas Braun Most Active @marcelinho last edited by
        @marcelinho sagte in Homebridge Fehler Code 243:
        Stell da um auf multi-user.
        sudo systemctl set-default multi-user.target
        /dev/mmcblk0p2 ext4 29G 26G 2.1G 93% /
        Dein root-Verzeichnis läuft voll.
        Räum da auf.
        nodejs ist hinten und vorne falsch installiert.
        iob nodejs-update
        und nodejs18 darüber sauber installieren lassen.
        Pending Updates: 180
        System regelmäßig (bzw. überhaupt) pflegen.
        Mit der influxdb gibt es wohl auch Trouble.
          @thomas-braun said in Homebridge Fehler Code 243:
          iob nodejs-update
          Danke Dir, wie kann ich root-Verzeichnis aufräumen?
          Influxdb läuft bisher problemlos - was kann ich da tun?
          Thomas Braun Marc Berg 3 Replies Last reply Reply Quote 0
            Erstmal schauen, was da so dickes drin liegt und wo man ansetzen muss.
            Ich mach das immer per
            sudo ncdu /
            ncdu muss u. U. noch nachinstalliert werden.
              Wenn es problemlos liefe hättest du nicht die ganzen Meldungen im LogFile.
              Ich setze influxdb aber nicht ein, muss dir vielleicht wer anders helfen.
              @Marc-Berg ist hier der DB-Spezialist.
              • Marc Berg
                Marc Berg Most Active @marcelinho last edited by Marc Berg
                Ich würde sagen, unter normalen Bedingungen bekommt man eine InfluxDB kaum in solche Größenordnungen wie bei dir. Der Klassiker ist, dass man versehentlich das Logging von Performancedaten aktiviert hat. Du kannst mal diesen Thread anschauen, ob das bei dir der Fall ist:
                https://forum.iobroker.net/topic/73784/speicherplatzbelegung-influxdb2-nach-containerisierung
                  @thomas-braun also nodejs habe ich hinbekommen laut iob diag. Aber in Homebridge funktioniert es noch nicht...
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   12:51:12 up 69 days, 17:46,  4 users,  load average: 0.92, 0.67, 1.32
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Tue 2024-04-23 12:51:12 CEST
                             Universal time: Tue 2024-04-23 10:51:12 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            4.0G        2.9G        321M         17M        878M        1.1G
                  Swap:           104M        104M        389K
                  Total:          4.1G        3.0G        322M
                           3793 M total memory
                           2740 M used memory
                           1102 M active memory
                           2016 M inactive memory
                            306 M free memory
                             36 M buffer memory
                            801 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.3M  379M   1% /run
                  /dev/mmcblk0p2 ext4       29G   27G  1.2G  96% /
                  tmpfs          tmpfs     1.9G  140K  1.9G   1% /dev/shm
                  /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                  tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                  [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200s rootwait quiet splash plymouth.ignore-serial-consoles
                  [Tue Feb 13 18:05:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Feb 13 18:05:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET               SOURCE         FSTYPE      OPTIONS
                  /                    /dev/mmcblk0p2 ext4        rw,noatime
                  |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortnam
                  /var:
                  18G     /var/
                  16G     /var/lib
                  15G     /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                  Archived and active journals take up 699.9M in the file system.
                  /opt/iobroker/backups:
                  213M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  308M    /opt/iobroker/iobroker-data/
                  191M    /opt/iobroker/iobroker-data/files
                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                  52M     /opt/iobroker/iobroker-data/backup-objects
                  38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                  21M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                  8.7M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.20.2
                  /usr/bin/node           v18.20.2
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  /usr/bin/corepack       0.25.2
                  nodejs:
                    Installed: 18.20.2-1nodesource1
                    Candidate: 18.20.2-1nodesource1
                    Version table:
                   *** 18.20.2-1nodesource1 600
                          100 /var/lib/dpkg/status
                       18.20.1-1nodesource1 600
                       18.20.0-1nodesource1 600
                       18.19.1-1nodesource1 600
                       18.19.0+dfsg-6~deb12u1 500
                       18.19.0-1nodesource1 600
                       18.18.2-1nodesource1 600
                       18.18.1-1nodesource1 600
                       18.18.0-1nodesource1 600
                       18.17.1-1nodesource1 600
                       18.17.0-1nodesource1 600
                       18.16.1-1nodesource1 600
                       18.16.0-1nodesource1 600
                       18.15.0-1nodesource1 600
                       18.14.2-1nodesource1 600
                       18.14.1-1nodesource1 600
                       18.14.0-1nodesource1 600
                       18.13.0+dfsg1-1 500
                       18.13.0-1nodesource1 600
                       18.12.0-1nodesource1 600
                       18.11.0-1nodesource1 600
                       18.10.0-1nodesource1 600
                       18.9.1-1nodesource1 600
                       18.9.0-1nodesource1 600
                       18.8.0-1nodesource1 600
                       18.7.0-1nodesource1 600
                       18.6.0-1nodesource1 600
                       18.5.0-1nodesource1 600
                       18.4.0-1nodesource1 600
                       18.3.0-1nodesource1 600
                       18.2.0-1nodesource1 600
                       18.1.0-1nodesource1 600
                       18.0.0-1nodesource1 600
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapters from github:   3
                  Adapter State
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                  + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
                  + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
                  + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled
                  + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
                  + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled
                  + system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              -  enabled
                  + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                  + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                  Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                  Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                  Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                  Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                  Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
                  Adapter    "node-red"     : 5.2.0    , installed 5.2.0
                  Adapter    "openhab"      : 1.1.0    , installed 1.1.0
                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                  Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
                  Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                  Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                  Objects and States
                  Objects:        14990
                  States:         13387
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Hit:8 https://repo.homebridge.io stable InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:39715         0.0.0.0:*               LISTEN      112        46457213   2097759/homebridg
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46540273   2123199/iobroker.
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46539313   2123199/iobroker.
                  tcp        0      0 127.0.0.1:39639         0.0.0.0:*               LISTEN      112        46457242   2097771/homebridg
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          46142328   2081606/cupsd
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17032      803/sshd: /usr/sb
                  tcp        0      0 127.0.0.1:43327         0.0.0.0:*               LISTEN      112        46458116   2097772/homebridg
                  tcp        0      0 127.0.0.1:45013         0.0.0.0:*               LISTEN      112        46455694   2097765/homebridg
                  tcp        0      0 127.0.0.1:34425         0.0.0.0:*               LISTEN      112        46480613   2097757/homebridg
                  tcp        0      0 127.0.0.1:34275         0.0.0.0:*               LISTEN      112        46457194   2097778/homebridg
                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       684423     32124/node
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       46540528   2123279/node-red
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       46541106   2123467/io.shelly
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17024      779/mosquitto
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       46541132   2123482/io.mqtt.0
                  tcp        0      0 127.0.0.1:44081         0.0.0.0:*               LISTEN      112        46456352   2097758/homebridg
                  tcp        0      0 127.0.0.1:33795         0.0.0.0:*               LISTEN      112        46457227   2097785/homebridg
                  tcp6       0      0 :::8581                 :::*                    LISTEN      112        46418999   2094723/hb-servic
                  tcp6       0      0 :::45391                :::*                    LISTEN      112        46458125   2097771/homebridg
                  tcp6       0      0 :::37166                :::*                    LISTEN      112        46456334   2097758/homebridg
                  tcp6       0      0 :::53299                :::*                    LISTEN      112        46456339   2097772/homebridg
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17034      803/sshd: /usr/sb
                  tcp6       0      0 :::3000                 :::*                    LISTEN      113        46530636   2107469/grafana
                  tcp6       0      0 :::52120                :::*                    LISTEN      112        46455673   2097785/homebridg
                  tcp6       0      0 :::47961                :::*                    LISTEN      112        46455615   2097757/homebridg
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          46142327   2081606/cupsd
                  tcp6       0      0 :::39667                :::*                    LISTEN      112        46456297   2097759/homebridg
                  tcp6       0      0 :::51798                :::*                    LISTEN      112        46457171   2097719/homebridg
                  tcp6       0      0 :::44253                :::*                    LISTEN      112        46455623   2097778/homebridg
                  tcp6       0      0 :::52403                :::*                    LISTEN      112        46456301   2097765/homebridg
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46538428   2123223/io.admin.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46541385   2123559/io.web.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        19857      1400/influxd
                  tcp6       0      0 :::1883                 :::*                    LISTEN      114        17025      779/mosquitto
                  udp        0      0 0.0.0.0:47202           0.0.0.0:*                           104        13649      516/avahi-daemon:
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46543999   2123507/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46544000   2123507/io.tuya.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          46142333   2081608/cups-brow
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46458119   2097759/homebridg
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46418996   2094723/hb-servic
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      516/avahi-daemon:
                  udp6       0      0 :::39317                :::*                                104        13650      516/avahi-daemon:
                  udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          20485      651/NetworkManage
                  udp6       0      0 :::5353                 :::*                                104        13648      516/avahi-daemon:
                  2024-04-23 12:51:34.173  - error: zigbee2mqtt.0 (2123452) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'E
                  2024-04-23 12:52:46.833  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:52:46.836  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:35.89unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:52:46.836  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                  2024-04-23 12:52:46.849  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:52:46.850  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:36.51unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:52:46.850  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_P
                  2024-04-23 12:53:05.267  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:53:05.270  - warn: influxdb.0 (2123264) Error on writePoint("{"value":3495,"time":"2024-04-23T10:52:53.02r: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:53:05.270  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                  2024-04-23 12:53:09.343  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:53:09.349  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7381,"time":"2024-04-23T10:52:53.11unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:53:09.350  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                  2024-04-23 12:53:11.700  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:53:11.701  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7,"time":"2024-04-23T10:52:55.155Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:53:11.701  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                  2024-04-23 12:53:13.275  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:53:13.276  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8,"time":"2024-04-23T10:52:59.725Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:53:13.276  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                  2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Error on writePoint("{"value":0.6175750000000001,"time":"2024-04-se}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: t
                  2024-04-23 12:53:13.287  - info: influxdb.0 (2123264) Add point that had error for Netzeinspeisung_Tag_Euro to buffer a
                  2024-04-23 12:53:13.290  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                  2024-04-23 12:53:13.291  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8.8225,"time":"2024-04-23T10:53:00.ror: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 12:53:13.291  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                  iob diag has finished.
                    @marcelinho
                    Bei den Updates war ein Kernel-Update dabei:
                    Neustart der Kiste erforderlich!
                    iob stop
                    sudo reboot
                      marcelinho @Marc Berg last edited by
                      @marc-berg ja das ist bei mir in der Tat so, ich schreibe viele Datenpunkte in die influxdb (siehe screenshot) die Scrapers habe ich nun gelöscht - wie kann ich nun die Daten bereinigen ? Danke auch Dir für deine Mühe/Hilfe. Screenshot 2024-04-23 130336.png
                        @thomas-braun danke habe ich gemacht - Fehler bleibt bestehen 😞
                        • Marc Berg
                          Ja da hast du jetzt ein kleines Problem. Dadurch, dass die zu löschenden Daten mit in deinem ioBroker Bucket gelandet sind (so habe ich es verstanden), musst du diese einzeln auf der Kommandozeile löschen (Bucketname, Organisation und Measurement anpassen)
                          influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home
                          bzw.:
                          influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home -t <token>
                          Ich würde aber dringend empfehlen, die Daten dort rauszulöschen, da man ja in deinen Logs schon sieht, dass die Datenbank Probleme und Timeouts hat.
                          EDIT: hier ein kleines Script zum Löschen der Daten:
                          delete_scraper_data.sh
                            @marc-berg Danke nochmal, Nodered funktioniert jetzt auch - hat nur etwas Zeit gebraucht.
                            Bist der beste - Schönen Abend noch Marc 🙂
                              @thomas-braun wie besprochen die neue Auslesung / Fehler Homebridge bleibt bestehen:
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                               15:54:39 up 22:08,  3 users,  load average: 0.21, 0.31, 0.27
                              CPU threads: 4
                              Current issues:
                                             Local time: Wed 2024-04-24 15:54:39 CEST
                                         Universal time: Wed 2024-04-24 13:54:39 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.0G        2.9G        288M         86K        858M        1.1G
                              Swap:           104M         15M         89M
                              Total:          4.1G        2.9G        378M
                                       3793 M total memory
                                       2774 M used memory
                                       2927 M active memory
                                        374 M inactive memory
                                        274 M free memory
                                         93 M buffer memory
                                        726 M swap cache
                                         99 M total swap
                                         14 M used swap
                                         85 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              tmpfs          tmpfs     380M  1.2M  379M   1% /run
                              /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
                              tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                              tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                              [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                              [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                              [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              11G     /var/
                              8.9G    /var/lib
                              8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                              Archived and active journals take up 739.9M in the file system.
                              215M    /opt/iobroker/backups/
                              320M    /opt/iobroker/iobroker-data/
                              32M     /opt/iobroker/iobroker-data/objects.jsonl
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                              22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                              9.8M    /opt/iobroker/iobroker-data/states.jsonl
                              8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
                              USB-Devices by-id:
                              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              nodejs:
                                Version table:
                                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                                   18.13.0+dfsg1-1 500
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     7.8.0
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                              + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
                              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
                              + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
                              + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                              + instance is alive
                              Objects and States
                              Objects:        14989
                              States:         13387
                              Pending Updates: 3
                              tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
                              tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
                              tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
                              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
                              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
                              tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
                              tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
                              tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
                              tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          343770     9169/cupsd
                              tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
                              tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
                              tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
                              tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
                              tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
                              tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          343769     9169/cupsd
                              tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
                              tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
                              tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
                              tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
                              tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
                              tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
                              tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
                              tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
                              tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
                              udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          343790     9192/cups-browsed
                              udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
                              udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
                              udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
                              2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
                              2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
                              2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
                              2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
                              2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
                              2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
                              2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
                              2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
                              2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
                              2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                              2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
                                Pending Updates: 3
                                Hau die noch rein.
                                Und deiner influxdb geht es immer noch nicht so richtig gut, würde ich sagen.
                                Wenn die da im Millisekundenbereich auf Fehler läuft kann das nicht gesund sein.
                                Zu Homebridge: Mit ist immer noch nicht klar was genau du da machen willst.
                                  @thomas-braun mit sudo apt update & upgrade sollte das gehen oder?
                                  Ich möchte Homebridge aktualisieren bzw alte plugins die nicht mehr benötigt werden löschen.
                                  Influxdb habe ich gestern mit @Marc-Berg bereinigt. Wüsste nicht was da falsch gehen sollte in grafana wird alles korrekt angezeigt.
                                  Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                                    Dann schau in das Log:
                                    Sieht für mich nicht gesund aus. Insbesondere nicht in der Frequenz mit der da Zeug geloggt wird. Das bläst dir alleine das Logfile in kürzester Zeit auf unnötige Größen auf.
                                    Homebridge über den ham-Adapter? Der ist aber gar nicht installiert bei dir.
                                    • Marc Berg
                                      Jain. Du hattest den Speicherzeitraum der InfluxDB auf 90 Tage gesetzt und wir haben gesagt, dass die ungewollt geloggten Daten nach 90 Tagen endgültig raus sind.
                                      Du könntest des Speicherzeitraum jetzt auch noch weiter verkürzen, um den Effekt zu beschleunigen.
                                      Weiterhin kannst du in den Datenpunkteinstellungen des InfluxDB Adapters prüfen, ob du weniger Daten wegschreibst, indem du z.B. die Blockierzeit auf 30 Sekunden setzt.
                                        ham-Adapter
                                        Homebridge habe ich über die SD-Karte über ein Image installiert gehabt
                                        https://smartapfel.de/homebridge/installieren/
                                          @marc-berg ich habe im influx.db Adapter nun auch 90 Tage geändert und die Blockzeit auf 30 gesetzt - ist dies so korrekt?Screenshot 2024-04-25 075854.png
                                            @marcelinho
                                            Und wo ist da jetzt die Verbindung zum ioBroker?
                                            Marc Berg M 2 Replies Last reply Reply Quote 0
                                            3128
