    4. Homebridge Fehler Code 243
      marcelinho @Thomas Braun last edited by
      @thomas-braun also nodejs habe ich hinbekommen laut iob diag. Aber in Homebridge funktioniert es noch nicht...
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       12:51:12 up 69 days, 17:46,  4 users,  load average: 0.92, 0.67, 1.32
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-04-23 12:51:12 CEST
                 Universal time: Tue 2024-04-23 10:51:12 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        2.9G        321M         17M        878M        1.1G
      Swap:           104M        104M        389K
      Total:          4.1G        3.0G        322M
               3793 M total memory
               2740 M used memory
               1102 M active memory
               2016 M inactive memory
                306 M free memory
                 36 M buffer memory
                801 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G   27G  1.2G  96% /
      tmpfs          tmpfs     1.9G  140K  1.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
      [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200s rootwait quiet splash plymouth.ignore-serial-consoles
      [Tue Feb 13 18:05:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Feb 13 18:05:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortnam
      /var:
      18G     /var/
      16G     /var/lib
      15G     /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
      Archived and active journals take up 699.9M in the file system.
      /opt/iobroker/backups:
      213M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      308M    /opt/iobroker/iobroker-data/
      191M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      52M     /opt/iobroker/iobroker-data/backup-objects
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      8.7M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 600
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
      + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled
      + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled
      + system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              -  enabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "node-red"     : 5.2.0    , installed 5.2.0
      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        14990
      States:         13387
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://repo.homebridge.io stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:39715         0.0.0.0:*               LISTEN      112        46457213   2097759/homebridg
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46540273   2123199/iobroker.
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46539313   2123199/iobroker.
      tcp        0      0 127.0.0.1:39639         0.0.0.0:*               LISTEN      112        46457242   2097771/homebridg
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          46142328   2081606/cupsd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17032      803/sshd: /usr/sb
      tcp        0      0 127.0.0.1:43327         0.0.0.0:*               LISTEN      112        46458116   2097772/homebridg
      tcp        0      0 127.0.0.1:45013         0.0.0.0:*               LISTEN      112        46455694   2097765/homebridg
      tcp        0      0 127.0.0.1:34425         0.0.0.0:*               LISTEN      112        46480613   2097757/homebridg
      tcp        0      0 127.0.0.1:34275         0.0.0.0:*               LISTEN      112        46457194   2097778/homebridg
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       684423     32124/node
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       46540528   2123279/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       46541106   2123467/io.shelly
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17024      779/mosquitto
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       46541132   2123482/io.mqtt.0
      tcp        0      0 127.0.0.1:44081         0.0.0.0:*               LISTEN      112        46456352   2097758/homebridg
      tcp        0      0 127.0.0.1:33795         0.0.0.0:*               LISTEN      112        46457227   2097785/homebridg
      tcp6       0      0 :::8581                 :::*                    LISTEN      112        46418999   2094723/hb-servic
      tcp6       0      0 :::45391                :::*                    LISTEN      112        46458125   2097771/homebridg
      tcp6       0      0 :::37166                :::*                    LISTEN      112        46456334   2097758/homebridg
      tcp6       0      0 :::53299                :::*                    LISTEN      112        46456339   2097772/homebridg
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17034      803/sshd: /usr/sb
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        46530636   2107469/grafana
      tcp6       0      0 :::52120                :::*                    LISTEN      112        46455673   2097785/homebridg
      tcp6       0      0 :::47961                :::*                    LISTEN      112        46455615   2097757/homebridg
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          46142327   2081606/cupsd
      tcp6       0      0 :::39667                :::*                    LISTEN      112        46456297   2097759/homebridg
      tcp6       0      0 :::51798                :::*                    LISTEN      112        46457171   2097719/homebridg
      tcp6       0      0 :::44253                :::*                    LISTEN      112        46455623   2097778/homebridg
      tcp6       0      0 :::52403                :::*                    LISTEN      112        46456301   2097765/homebridg
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46538428   2123223/io.admin.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46541385   2123559/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        19857      1400/influxd
      tcp6       0      0 :::1883                 :::*                    LISTEN      114        17025      779/mosquitto
      udp        0      0 0.0.0.0:47202           0.0.0.0:*                           104        13649      516/avahi-daemon:
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46543999   2123507/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46544000   2123507/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          46142333   2081608/cups-brow
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46458119   2097759/homebridg
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46418996   2094723/hb-servic
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      516/avahi-daemon:
      udp6       0      0 :::39317                :::*                                104        13650      516/avahi-daemon:
      udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          20485      651/NetworkManage
      udp6       0      0 :::5353                 :::*                                104        13648      516/avahi-daemon:
      2024-04-23 12:51:34.173  - error: zigbee2mqtt.0 (2123452) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'E
      2024-04-23 12:52:46.833  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:52:46.836  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:35.89unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:52:46.836  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
      2024-04-23 12:52:46.849  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:52:46.850  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:36.51unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:52:46.850  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_P
      2024-04-23 12:53:05.267  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:53:05.270  - warn: influxdb.0 (2123264) Error on writePoint("{"value":3495,"time":"2024-04-23T10:52:53.02r: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:53:05.270  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
      2024-04-23 12:53:09.343  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:53:09.349  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7381,"time":"2024-04-23T10:52:53.11unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:53:09.350  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
      2024-04-23 12:53:11.700  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:53:11.701  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7,"time":"2024-04-23T10:52:55.155Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:53:11.701  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
      2024-04-23 12:53:13.275  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:53:13.276  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8,"time":"2024-04-23T10:52:59.725Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:53:13.276  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
      2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Error on writePoint("{"value":0.6175750000000001,"time":"2024-04-se}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: t
      2024-04-23 12:53:13.287  - info: influxdb.0 (2123264) Add point that had error for Netzeinspeisung_Tag_Euro to buffer a
      2024-04-23 12:53:13.290  - warn: influxdb.0 (2123264) Point could not be written to database: admin
      2024-04-23 12:53:13.291  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8.8225,"time":"2024-04-23T10:53:00.ror: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-23 12:53:13.291  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
      iob diag has finished.
        Thomas Braun Most Active @marcelinho last edited by
        @marcelinho
        Bei den Updates war ein Kernel-Update dabei:
        Neustart der Kiste erforderlich!
        iob stop
        sudo reboot
          marcelinho @Marc Berg last edited by
          @marc-berg ja das ist bei mir in der Tat so, ich schreibe viele Datenpunkte in die influxdb (siehe screenshot) die Scrapers habe ich nun gelöscht - wie kann ich nun die Daten bereinigen ? Danke auch Dir für deine Mühe/Hilfe. Screenshot 2024-04-23 130336.png
            @thomas-braun danke habe ich gemacht - Fehler bleibt bestehen 😞
            • Marc Berg
              Marc Berg Most Active @marcelinho last edited by Marc Berg
              @marcelinho sagte in Homebridge Fehler Code 243:
              Ja da hast du jetzt ein kleines Problem. Dadurch, dass die zu löschenden Daten mit in deinem ioBroker Bucket gelandet sind (so habe ich es verstanden), musst du diese einzeln auf der Kommandozeile löschen (Bucketname, Organisation und Measurement anpassen)
              influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home
              bzw.:
              influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home -t <token>
              Ich würde aber dringend empfehlen, die Daten dort rauszulöschen, da man ja in deinen Logs schon sieht, dass die Datenbank Probleme und Timeouts hat.
              EDIT: hier ein kleines Script zum Löschen der Daten:
              delete_scraper_data.sh
                @marc-berg Danke nochmal, Nodered funktioniert jetzt auch - hat nur etwas Zeit gebraucht.
                Bist der beste - Schönen Abend noch Marc 🙂
                  @thomas-braun wie besprochen die neue Auslesung / Fehler Homebridge bleibt bestehen:
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   15:54:39 up 22:08,  3 users,  load average: 0.21, 0.31, 0.27
                  CPU threads: 4
                  Current issues:
                                 Local time: Wed 2024-04-24 15:54:39 CEST
                             Universal time: Wed 2024-04-24 13:54:39 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        2.9G        288M         86K        858M        1.1G
                  Swap:           104M         15M         89M
                  Total:          4.1G        2.9G        378M
                           3793 M total memory
                           2774 M used memory
                           2927 M active memory
                            374 M inactive memory
                            274 M free memory
                             93 M buffer memory
                            726 M swap cache
                             99 M total swap
                             14 M used swap
                             85 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                  /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
                  tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                  tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                  [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                  [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                  [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  11G     /var/
                  8.9G    /var/lib
                  8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                  Archived and active journals take up 739.9M in the file system.
                  215M    /opt/iobroker/backups/
                  320M    /opt/iobroker/iobroker-data/
                  32M     /opt/iobroker/iobroker-data/objects.jsonl
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                  9.8M    /opt/iobroker/iobroker-data/states.jsonl
                  8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Version table:
                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                  + instance is alive
                  Objects and States
                  Objects:        14989
                  States:         13387
                  Pending Updates: 3
                  tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
                  tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
                  tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
                  tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
                  tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
                  tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          343770     9169/cupsd
                  tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
                  tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
                  tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
                  tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
                  tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          343769     9169/cupsd
                  tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
                  tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
                  tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
                  tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
                  tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
                  tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
                  tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
                  tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
                  tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
                  udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          343790     9192/cups-browsed
                  udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
                  udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
                  udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
                  2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
                  2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
                  2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
                  2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
                  2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
                  2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
                  2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
                  2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
                  2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
                  2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
                    Pending Updates: 3
                    Hau die noch rein.
                    Und deiner influxdb geht es immer noch nicht so richtig gut, würde ich sagen.
                    Wenn die da im Millisekundenbereich auf Fehler läuft kann das nicht gesund sein.
                    Zu Homebridge: Mit ist immer noch nicht klar was genau du da machen willst.
                      @thomas-braun mit sudo apt update & upgrade sollte das gehen oder?
                      Ich möchte Homebridge aktualisieren bzw alte plugins die nicht mehr benötigt werden löschen.
                      Influxdb habe ich gestern mit @Marc-Berg bereinigt. Wüsste nicht was da falsch gehen sollte in grafana wird alles korrekt angezeigt.
                      Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                        Dann schau in das Log:
                        Sieht für mich nicht gesund aus. Insbesondere nicht in der Frequenz mit der da Zeug geloggt wird. Das bläst dir alleine das Logfile in kürzester Zeit auf unnötige Größen auf.
                        Homebridge über den ham-Adapter? Der ist aber gar nicht installiert bei dir.
                        • Marc Berg
                          Jain. Du hattest den Speicherzeitraum der InfluxDB auf 90 Tage gesetzt und wir haben gesagt, dass die ungewollt geloggten Daten nach 90 Tagen endgültig raus sind.
                          Du könntest des Speicherzeitraum jetzt auch noch weiter verkürzen, um den Effekt zu beschleunigen.
                          Weiterhin kannst du in den Datenpunkteinstellungen des InfluxDB Adapters prüfen, ob du weniger Daten wegschreibst, indem du z.B. die Blockierzeit auf 30 Sekunden setzt.
                            @thomas-braun said in Homebridge Fehler Code 243:
                            ham-Adapter
                            Homebridge habe ich über die SD-Karte über ein Image installiert gehabt
                            https://smartapfel.de/homebridge/installieren/
                              @marc-berg ich habe im influx.db Adapter nun auch 90 Tage geändert und die Blockzeit auf 30 gesetzt - ist dies so korrekt?Screenshot 2024-04-25 075854.png
                                @marcelinho
                                Und wo ist da jetzt die Verbindung zum ioBroker?
                                Marc Berg M 2 Replies Last reply Reply Quote 0
                                • Marc Berg
                                  Ob du die Einstellung für die Vorhaltezeit in der Instanz des Adapters änderst oder direkt in der Datenbank-Oberfläche ist völlig egal, das funktioniert beides.
                                  Zur Blockzeit: Du hast jetzt lediglich die "Standardeinstellung" geändert, die angezogen wird, wenn du neue Datenpunkte mit der InfluxDB verbindest. Dies hat keine Auswirkungen auf schon bestehende Datenpunkte.
                                  Du solltest also Datenpunkt für Datenpunkt durchgehen und jeweils schauen, ob du nur geänderte Werte aufzeichnen willst, ob du eine Blockzeit verwendest oder nur Änderungen protokollierst, wenn sich der Wert um x ändert.
                                  Das kann man nicht pauschal empfehlen, es hängt einfach davon ab, welche Daten jeweils in welchen Intervallen reinfliegen. Ziel sollte jedenfalls sein, die Menge an Daten, die (vielleicht unnötigerweise) in die Datenbank geschrieben wird, auf ein sinnvolles Maß zu reduzieren.
                                  EDIT: Außerdem wird die Blockzeit in Millisekunden angegeben
                                  • Marc Berg
                                    Marc Berg Most Active @Thomas Braun last edited by
                                    @thomas-braun sagte in Homebridge Fehler Code 243:
                                    Im Tab "DB Settings"!? 🙂
                                      @marc-berg jetzt sieht es wohl besser aus, habe alle Influxdb Datenpunkte mit Millisekunden angepasst:
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                       09:23:33 up 1 day, 15:37,  3 users,  load average: 0.27, 0.37, 0.33
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Thu 2024-04-25 09:23:33 CEST
                                                 Universal time: Thu 2024-04-25 07:23:33 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            4.0G        2.9G        827M         28K        296M        1.0G
                                      Swap:           104M        104M        278K
                                      Total:          4.1G        3.0G        827M
                                               3793 M total memory
                                               2796 M used memory
                                               2004 M active memory
                                                808 M inactive memory
                                                788 M free memory
                                                 16 M buffer memory
                                                266 M swap cache
                                                 99 M total swap
                                                 99 M used swap
                                                  0 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      11G     /var/
                                      8.9G    /var/lib
                                      217M    /opt/iobroker/backups/
                                      303M    /opt/iobroker/iobroker-data/
                                      18M     /opt/iobroker/iobroker-data/objects.jsonl
                                      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.5.0
                                      /usr/bin/npx            10.5.0
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.13.16
                                      javascript:     7.8.0
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        14991
                                      States:         13387
                                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Pending Updates: 3
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1585299    38874/cupsd
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1585298    38874/cupsd
                                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1586228    38876/cups-browsed
                                      2024-04-25 09:10:38.129  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.gas_savings.total_spent.raw_value" has to be type "number" but received type "string"
                                      2024-04-25 09:10:38.133  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.total_spent.raw_value" has to be type "number" but received type "string"
                                      2024-04-25 09:11:45.291  - info: influxdb.0 (47993) enabled logging of PV Tagesertrag, Alias=true
                                      2024-04-25 09:12:30.314  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTag, Alias=true
                                      2024-04-25 09:12:50.951  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTag, Alias=true
                                      2024-04-25 09:13:25.909  - warn: influxdb.0 (47993) Error in query "from(bucket: "admin")  |> range(start: 1999-12-31T23:00:00.000Z, stop: 2024-04-25T07:12:55.411Z) |> filter(fn: (r) => r["_measurement"] == "BatterieEntladung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns:["_time"], desc: false) |> limit(n: 500)": RequestTimedOutError: Request timed out
                                      2024-04-25 09:14:14.696  - info: influxdb.0 (47993) enabled logging of BatterieEntladung, Alias=true
                                      2024-04-25 09:14:23.823  - info: influxdb.0 (47993) enabled logging of BatterieProzent, Alias=true
                                      2024-04-25 09:14:32.228  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTotal, Alias=true
                                      2024-04-25 09:14:38.869  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTotal, Alias=true
                                      2024-04-25 09:14:42.461  - info: shelly.0 (1561) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
                                      2024-04-25 09:14:57.799  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Accumulated_Energy_Yield, Alias=false
                                      2024-04-25 09:15:10.195  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Active_Power, Alias=false
                                      2024-04-25 09:15:16.964  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Daily_Energy_Yield, Alias=false
                                      2024-04-25 09:15:31.414  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Input_Power, Alias=false
                                      2024-04-25 09:15:42.478  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Internal_Temperature, Alias=false
                                      2024-04-25 09:18:36.103  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_Euro, Alias=true
                                      2024-04-25 09:18:42.306  - info: influxdb.0 (47993) enabled logging of Hausspeicher_gespart, Alias=true
                                      2024-04-25 09:18:48.544  - info: influxdb.0 (47993) enabled logging of Netzbezug_Tag_Euro, Alias=true
                                      2024-04-25 09:19:00.758  - info: influxdb.0 (47993) enabled logging of Netzeinspeisung_Tag_Euro, Alias=true
                                      2024-04-25 09:19:13.266  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_kWh, Alias=true
                                      2024-04-25 09:19:20.297  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, Alias=false
                                      2024-04-25 09:19:26.029  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_W, Alias=false
                                      2024-04-25 09:19:34.118  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_Tag_kWh, Alias=false
                                      2024-04-25 09:19:43.416  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_W, Alias=false
                                        @thomas-braun hast du zufällig noch einen Vorschlag was ich gegen den Fehler machen könnte?
                                          @marcelinho
                                          Nein. Mit GUIs hab ich aber auch wenig am Hut. Und mit Homebridge auch nicht.
                                            marcelinho @marcelinho last edited by
                                            habe nun folgenden Fehler:
                                            npm ERR! code EACCES
                                            npm ERR! syscall rename
                                            npm ERR! path /usr/local/bin/homebridge
                                            npm ERR! dest /usr/local/bin/.homebridge-kaN4ImAr
                                            npm ERR! errno -13
                                            npm ERR! Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'
                                            npm ERR! [Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'] {
                                            npm ERR! errno: -13,
                                            npm ERR! code: 'EACCES',
                                            npm ERR! syscall: 'rename',
                                            npm ERR! path: '/usr/local/bin/homebridge',
                                            npm ERR! dest: '/usr/local/bin/.homebridge-kaN4ImAr'
                                            npm ERR! }
                                            npm ERR!
                                            npm ERR! The operation was rejected by your operating system.
                                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                                            npm ERR!
                                            npm ERR! If you believe this might be a permissions issue, please double-check the
                                            npm ERR! permissions of the file and its containing directories, or try running
                                            npm ERR! the command again as root/Administrator.
                                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-05-06T15_54_11_806Z-debug-0.log
                                            jemand eine Idee?
                                            3130
