    4. io Broker lässt sich nicht updaten (Linux)
    • hans1990
      hans1990 @Homoran last edited by hans1990
      @homoran said in io Broker lässt sich nicht updaten (Linux):
      Hast du jetzt ein Backup gefahren und weggesichert?
      ja ist erledigt
        Homoran Global Moderator Administrators @hans1990 last edited by
        @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
        ja ist erledigt
        Auch history?
        Dann mach mal ein iob nodejs-update
        und poste alles dazu
        hans1990 1 Reply Last reply Reply Quote 0
        • hans1990
          ioBroker nodejs updater 2023-10-13
          No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
          Your current setup is:
          /usr/bin/node           v12.22.12
          /usr/bin/npm            6.14.16
          /usr/bin/npx            6.14.16
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 12.22.12-deb-1nodesource1
            Candidate: 12.22.12-deb-1nodesource1
            Version table:
           *** 12.22.12-deb-1nodesource1 600
                  500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v12.22.12. Do you want to install latest version from nodejs v.18 tree?
          Press <y> to continue or any other key to quit
          Trying to update your installation now. Please be patient.
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [8410 B]
          Fetched 20.6 kB in 1s (26.7 kB/s)
          Installing the recommended nodejs version now!
          /home/iobroker/.nodejs-update.sh: line 329: [: : integer expression expected
          Exact recommended version unknown, installing a fallback!
          (Reading database ... 54833 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.0.0-1nodesource1) over (12.22.12-deb-1nodesource1) ...
          Setting up nodejs (18.0.0-1nodesource1) ...
          Processing triggers for man-db (2.9.4-2) ...
          Updating fallback to latest nodejs v18 release
          (Reading database ... 55694 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.20.2-1nodesource1_armhf.deb ...
          Unpacking nodejs (18.20.2-1nodesource1) over (18.0.0-1nodesource1) ...
          Setting up nodejs (18.20.2-1nodesource1) ...
          v18.20.2 has been installed! You are using the latest version now!
          /home/iobroker/.nodejs-update.sh: line 346: [: : integer expression expected
          Installing the recommended nodejs version!
          We tried our best to update or fix your nodejs. Please run iob diag again to verify.
          *** RESTARTING ioBroker NOW! ***
           Please refresh or restart your browser in a few moments.
            • hans1990
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: rasphj
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : armhf
              Systemuptime and Load:
               16:11:31 up  1:56,  1 user,  load average: 1.13, 0.84, 0.49
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Fri 2024-04-26 16:11:31 CEST
                         Universal time: Fri 2024-04-26 14:11:31 UTC
                               RTC time: n/a
                              Time zone: Europe/Vienna (CEST, +0200)
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        258M        2.5G        0.0K        995M        3.5G
              Swap:            99M          0B         99M
              Total:          3.9G        258M        2.6G
                       3794 M total memory
                        258 M used memory
                        287 M active memory
                        775 M inactive memory
                       2540 M free memory
                        138 M buffer memory
                        856 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       59G  4.1G   52G   8% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  820K  759M   1% /run
              /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
              /var:
              1.7G    /var/
              1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
              1.3G    /var/log
              202M    /var/cache
              Archived and active journals take up 1.2G in the file system.
              /opt/iobroker/backups:
              24M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              202M    /opt/iobroker/iobroker-data/
              87M     /opt/iobroker/iobroker-data/history
              52M     /opt/iobroker/iobroker-data/files
              45M     /opt/iobroker/iobroker-data/backup-objects
              27M     /opt/iobroker/iobroker-data/files/javascript.admin
              9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
              6.4M    /opt/iobroker/iobroker-data/objects.jsonl
              6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
              6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
              4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.20.2
              /usr/bin/node           v18.20.2
              /usr/bin/npm            10.5.0
              /usr/bin/npx            10.5.0
              /usr/bin/corepack       0.25.2
              nodejs:
                Installed: 18.20.2-1nodesource1
                Candidate: 18.20.2-1nodesource1
                Version table:
               *** 18.20.2-1nodesource1 600
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   18.20.1-1nodesource1 600
                   18.20.0-1nodesource1 600
                   18.19.1-1nodesource1 600
                   18.19.0-1nodesource1 600
                   18.18.2-1nodesource1 600
                   18.18.1-1nodesource1 600
                   18.18.0-1nodesource1 600
                   18.17.1-1nodesource1 600
                   18.17.0-1nodesource1 600
                   18.16.1-1nodesource1 600
                   18.16.0-1nodesource1 600
                   18.15.0-1nodesource1 600
                   18.14.2-1nodesource1 600
                   18.14.1-1nodesource1 600
                   18.14.0-1nodesource1 600
                   18.13.0-1nodesource1 600
                   18.12.0-1nodesource1 600
                   18.11.0-1nodesource1 600
                   18.10.0-1nodesource1 600
                   18.9.1-1nodesource1 600
                   18.9.0-1nodesource1 600
                   18.8.0-1nodesource1 600
                   18.7.0-1nodesource1 600
                   18.6.0-1nodesource1 600
                   18.5.0-1nodesource1 600
                   18.4.0-1nodesource1 600
                   18.3.0-1nodesource1 600
                   18.2.0-1nodesource1 600
                   18.1.0-1nodesource1 600
                   18.0.0-1nodesource1 600
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          5.1.25
              javascript:     "javascript" not found
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                system.adapter.history.0                : history               : rasphj                                   -  enabled
                system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
              Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
              Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
              Adapter    "homee"        : 1.2.0    , installed 1.2.0
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Objects and States
              Objects:        3145
              States:         2056
              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       92947      12486/iobroker.js-c
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93230      12486/iobroker.js-c
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90108      12514/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
              udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
              udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
              udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
              2024-04-26 16:11:36.096  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-04-26 16:11:36.097  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
              2024-04-26 16:11:36.103  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
              2024-04-26 16:11:38.074  - info: host.rasphj instance system.adapter.backitup.0 started with pid 12751
              2024-04-26 16:11:42.464  - info: backitup.0 (12751) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.2, js-controller: 5.0.19
              2024-04-26 16:11:42.526  - warn: backitup.0 (12751) Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
              Require stack:
              - /opt/iobroker/node_modules/iobroker.backitup/lib/tools.js
              - /opt/iobroker/node_modules/iobroker.backitup/main.js
              2024-04-26 16:11:52.654  - info: host.rasphj iobroker npm-install: added 28 packages in 16s44 packages are looking for funding  run `npm fund` for details
              2024-04-26 16:11:52.702  - info: host.rasphj iobroker npm-install: host.rasphj install adapter homee@1.2.0
              2024-04-26 16:11:52.836  - info: host.rasphj iobroker npm-install: upload [4] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/custom_m.html custom_m.html text/html
              2024-04-26 16:11:52.851  - info: host.rasphj iobroker npm-install: upload [3] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/homee.png homee.png image/png
              2024-04-26 16:11:52.861  - info: host.rasphj iobroker npm-install: upload [2] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/index_m.html index_m.html text/html
              2024-04-26 16:11:52.871  - info: host.rasphj iobroker npm-install: upload [1] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/jsonCustom.json jsonCustom.json application/json
              2024-04-26 16:11:52.882  - info: host.rasphj iobroker npm-install: upload [0] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/words.js words.js application/javascript
              2024-04-26 16:11:52.982  - info: host.rasphj iobroker npm-install: host.rasphj object system.adapter.homee created/updated
              2024-04-26 16:11:54.057  - info: host.rasphj iobroker npm-install: exit 0
              2024-04-26 16:11:55.059  - warn: host.rasphj startInstance cannot find adapter "synology". Try to install it... 1 attempt
              2024-04-26 16:11:55.060  - info: host.rasphj iobroker install synology using installedVersion
              2024-04-26 16:12:00.183  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
              2024-04-26 16:12:00.188  - info: host.rasphj iobroker npm-install: Installing iobroker.synology@3.1.0... (System call)
              2024-04-26 16:12:43.860  - info: host.rasphj iobroker npm-install:
              2024-04-26 16:12:43.864  - info: host.rasphj iobroker npm-install: added 32 packages, and changed 1 package in 42s45 packages are looking for funding  run `npm fund` for details
              2024-04-26 16:12:43.916  - info: host.rasphj iobroker npm-install: host.rasphj install adapter synology
                Homoran Global Moderator Administrators @hans1990 last edited by Homoran
                Controller "js-controller": 5.0.19 , installed 5.0.19
                hast du sonst noch was gemacht?
                Edit
                möglich dass er jetzt erst mal die Adapter neu baut.
                • hans1990
                  iob stop
                  iob update
                  iob upgrade self
                  Ich hab versucht den Fehler zu reproduzieren.
                  @hans-jürgen-strudler said in io Broker lässt sich nicht updaten (Linux):
                  Leider hab ich nicht gespeichert wie die node Version zu hoch war, aber es sah ca. so aus:
                  Copy to Clipboard
                  npm ERR! notsup Required: {"node":"8<=  node => 13"}
                  npm ERR! notsup Actual:   {"npm":"6.14.16","node":"18.20."}
                  auf der Weboberfläche wurde ich informiert, dass das File System geändert wird. das dürfte gerade laufen.
                  Homoran 3 Replies Last reply Reply Quote 0
                    Ich hab versucht
                    bitte niemals nicht nix eigenmächtig machen, wenn dir verducht wird zu helfen
                    Diesmal Teil 2
                    https://forum.iobroker.net/post/884324
                    bitte unbedingt lesen und beachten!
                      sah ca. so aus:
                      und auch diesmal:
                      aus dem Zusammenhang gerissen nutzt das gar nichts
                      • hans1990
                        Stimmt war eine doofe Idee -
                          @hans-jürgen-strudler Dann warte jetzt mal bis er mit dem Neubau aller Adapter fertig ist.
                            Homoran Global Moderator Administrators @Homoran last edited by
                            @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                            sah ca. so aus:
                            und auch diesmal:
                            @Hans-Jürgen-Strudler
                            auf den controller kann sich das ja nicht bezogen haben, der ist ja jetzt auf v5.x
                            • hans1990
                              ist es normal, dass die Weboberfläche derzeit nicht erreichbar ist?
                                nein!
                                aber du hattest zweimal admin auf dem selben port
                                beobachte dann über Konsole mit iob logs --watch und nicht irgendwo eingreifen
                                • hans1990
                                  Das ist das Ergebnis (nur die letzten Zeilen, da sonst zu lange):
                                  2024-04-26 16:23:05.616  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:23:05.617  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                                  2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                                  2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                                  2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                                  2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:23:05.623  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:23:05.623  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
                                  2024-04-26 16:23:05.624  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
                                  2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                                  2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                                  2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                                  2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                                  2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:23:05.841  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:23:05.841  - info: host.rasphj Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                                  2024-04-26 16:23:05.842  - info: host.rasphj system.adapter.admin.0 will be rebuilt
                                  2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                                  2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                                  2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                                  2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                                  2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:23:05.910  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:23:05.911  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                                  2024-04-26 16:23:05.911  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
                                  2024-04-26 16:23:09.675  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                                  2024-04-26 16:23:09.678  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                                  2024-04-26 16:23:15.923  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_23_10_738Z-debug-0.log
                                  2024-04-26 16:23:15.924  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                  2024-04-26 16:23:16.955  - info: host.rasphj iobroker npm-install: exit 25
                                  2024-04-26 16:23:17.956  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                  2024-04-26 16:23:17.957  - info: host.rasphj iobroker rebuild
                                  2024-04-26 16:23:19.754  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
                                  2024-04-26 16:23:48.352  - info: vis.0 (18269) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
                                  2024-04-26 16:23:48.637  - info: vis.0 (18269) vis license is OK.
                                  2024-04-26 16:23:49.642  - info: vis.0 (18269) Terminated (NO_ERROR): Without reason
                                  2024-04-26 16:24:23.351  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
                                  2024-04-26 16:24:23.385  - info: host.rasphj iobroker npm-rebuild:
                                  2024-04-26 16:24:23.386  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
                                  2024-04-26 16:24:24.399  - info: host.rasphj iobroker npm-rebuild: exit 0
                                  2024-04-26 16:24:24.692  - info: host.rasphj instance system.adapter.discovery.0 started with pid 18660
                                  2024-04-26 16:24:24.702  - info: host.rasphj instance system.adapter.admin.0 started with pid 18661
                                  2024-04-26 16:24:24.711  - info: host.rasphj instance system.adapter.web.0 started with pid 18662
                                  2024-04-26 16:24:25.405  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 4 attempt
                                  2024-04-26 16:24:25.406  - info: host.rasphj iobroker install heytech@1.0.5 using installedVersion
                                  2024-04-26 16:24:26.853  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                                  2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                                  2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                                  2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                                  2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:24:26.861  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:24:26.861  - info: host.rasphj Rebuild for adapter system.adapter.discovery.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  2024-04-26 16:24:26.863  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                                  2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                                  2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                                  2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                                  2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:24:26.870  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:24:26.871  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  2024-04-26 16:24:27.173  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                                  2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                                  2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                                  2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                                  2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:24:27.179  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:24:27.179  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:24:27.179  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                                  2024-04-26 16:24:27.180  - info: host.rasphj system.adapter.web.0 will be rebuilt
                                  2024-04-26 16:24:30.676  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                                  2024-04-26 16:24:30.679  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                                  2024-04-26 16:24:38.037  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_24_31_757Z-debug-0.log
                                  2024-04-26 16:24:38.038  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                  2024-04-26 16:24:39.069  - info: host.rasphj iobroker npm-install: exit 25
                                  2024-04-26 16:24:40.070  - warn: host.rasphj adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                  2024-04-26 16:24:40.071  - info: host.rasphj iobroker rebuild
                                  2024-04-26 16:24:41.868  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
                                  2024-04-26 16:25:11.870  - info: vis.0 (19415) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
                                  2024-04-26 16:25:12.181  - info: vis.0 (19415) vis license is OK.
                                  2024-04-26 16:25:13.263  - info: vis.0 (19415) Terminated (NO_ERROR): Without reason
                                  2024-04-26 16:25:38.876  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
                                  2024-04-26 16:25:38.912  - info: host.rasphj iobroker npm-rebuild:
                                  2024-04-26 16:25:38.913  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
                                  2024-04-26 16:25:39.928  - info: host.rasphj iobroker npm-rebuild: exit 0
                                  2024-04-26 16:25:40.067  - info: host.rasphj instance system.adapter.web.0 started with pid 19767
                                  2024-04-26 16:25:40.931  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                                  2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                  2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   throw err;
                                  2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   ^
                                  2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                                  2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Require stack:
                                  2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                                  2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                  2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                  2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                  2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                  2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                                  2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                  2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                  2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                  2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                  2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                  2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                                  2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]: }
                                  2024-04-26 16:25:41.925  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                  2024-04-26 16:25:41.925  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2024-04-26 16:25:41.925  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  Homoran hans1990 2 Replies Last reply Reply Quote 0
                                    20
                                    da isser ja!
                                    Der Rest ist natürlich Mist.
                                    Jetzt hast du node und Controller upgedatet.
                                    Außerdem hattest du ja noch extraneous im npm log gehabt.
                                    Vielleicht hat @thomas-braun noch ne Idee.
                                    • hans1990
                                      hans1990 @hans1990 last edited by
                                      hier ein Auszug von den Error Zeilen
                                      2024-04-26 16:12:44.343  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
                                      2024-04-26 16:12:46.377  - warn: host.rasphj startInstance cannot find adapter "net-tools". Try to install it... 1 attempt
                                      2024-04-26 16:13:07.751  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=6.13.15"
                                      2024-04-26 16:13:09.784  - warn: host.rasphj startInstance cannot find adapter "ping". Try to install it... 1 attempt
                                      2024-04-26 16:13:24.644  - warn: host.rasphj startInstance cannot find adapter "shuttercontrol@1.2.1". Try to install it... 1 attempt
                                      2024-04-26 16:13:40.311  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 1 attempt
                                      2024-04-26 16:13:50.827  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_13_45_983Z-debug-0.log
                                      2024-04-26 16:13:50.828  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                      2024-04-26 16:13:52.864  - warn: host.rasphj startInstance cannot find adapter "flot". Try to install it... 1 attempt
                                      2024-04-26 16:13:57.708  - warn: host.rasphj startInstance cannot find adapter "elero-usb-transmitter@0.5.2". Try to install it... 1 attempt
                                      2024-04-26 16:16:00.502  - warn: host.rasphj startInstance cannot find adapter "history@1.9.14". Try to install it... 1 attempt
                                      2024-04-26 16:16:18.909  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
                                      2024-04-26 16:16:20.940  - warn: host.rasphj startInstance cannot find adapter "sonoff@2.4.5". Try to install it... 1 attempt
                                      2024-04-26 16:16:36.159  - warn: host.rasphj startInstance cannot find adapter "nuki-extended@2.3.1". Try to install it... 1 attempt
                                      2024-04-26 16:16:55.100  - warn: host.rasphj startInstance cannot find adapter "rpi2@1.3.1". Try to install it... 1 attempt
                                      2024-04-26 16:16:59.371  - warn: nuki-extended.0 (14121) Callback not attached because too many Callbacks attached to the Nuki Bridge already! Please delete a callback!
                                      2024-04-26 16:17:36.447  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                      2024-04-26 16:18:04.280  - warn: host.rasphj Slave controller detected disconnection. Stop all instances.
                                      2024-04-26 16:18:05.121  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                      2024-04-26 16:18:05.123  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                      2024-04-26 16:18:05.124  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                      2024-04-26 16:18:05.144  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                      2024-04-26 16:18:25.102  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                      2024-04-26 16:18:25.103  - error: host.rasphj Caught by controller[0]:   throw err;
                                      2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]:   ^
                                      2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                                      2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: Require stack:
                                      2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                                      2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                      2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                      2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                      2024-04-26 16:18:25.107  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                      2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                                      2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                      2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                      2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                      2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                      2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                      2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                      2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                                      2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]: }
                                      2024-04-26 16:18:25.111  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                      2024-04-26 16:18:25.111  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2024-04-26 16:18:35.188  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_18_29_163Z-debug-0.log
                                      2024-04-26 16:18:35.189  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                      2024-04-26 16:18:37.280  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                      2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                      2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]:   throw err;
                                      2024-04-26 16:18:49.985  - error: host.rasphj Caught by controller[0]:   ^
                                      2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                                      2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Require stack:
                                      2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                                      2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                      2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                      2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                      2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                      2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                                      2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                      2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                      2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                      2024-04-26 16:18:49.991  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                      2024-04-26 16:18:49.992  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                      2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                      2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                                      2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[0]: }
                                      2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[1]: Node.js v18.20.2
                                      2024-04-26 16:18:49.995  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      • hans1990
                                        kann das helfen?
                                          teilweise vollkommen ok!
                                          Die Adapter müssen für das neue node neu gebaut werden. 1st attempt ist also korrekt.
                                          Andere Adapter benötigen eine höhere Version vom admin, bei dem es allerdings klemmt
                                          heytech ist anscheinend zu alt und nicht mehr unterstützt, oder über github installiert worden???
                                          warum das hängt sehe ich jetzt nicht
                                            kann das helfen?
                                            lass erst einmal alle Eingriffe sein!
                                            gibt es neuere log Zeilen als von 16:25?
                                            1857
