    4. io Broker lässt sich nicht updaten (Linux)
      Homoran Global Moderator Administrators @hans1990 last edited by
      @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
      Please run iob diag again to verify.
      hans1990 1 Reply Last reply Reply Quote 0
      • hans1990
        hans1990 @Homoran last edited by
        @homoran said in io Broker lässt sich nicht updaten (Linux):
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: rasphj
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         16:11:31 up  1:56,  1 user,  load average: 1.13, 0.84, 0.49
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2024-04-26 16:11:31 CEST
                   Universal time: Fri 2024-04-26 14:11:31 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        258M        2.5G        0.0K        995M        3.5G
        Swap:            99M          0B         99M
        Total:          3.9G        258M        2.6G
                 3794 M total memory
                  258 M used memory
                  287 M active memory
                  775 M inactive memory
                 2540 M free memory
                  138 M buffer memory
                  856 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G  4.1G   52G   8% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  820K  759M   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        1.7G    /var/
        1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
        1.3G    /var/log
        202M    /var/cache
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        24M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        202M    /opt/iobroker/iobroker-data/
        87M     /opt/iobroker/iobroker-data/history
        52M     /opt/iobroker/iobroker-data/files
        45M     /opt/iobroker/iobroker-data/backup-objects
        27M     /opt/iobroker/iobroker-data/files/javascript.admin
        9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
        6.4M    /opt/iobroker/iobroker-data/objects.jsonl
        6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
        6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.2
        /usr/bin/node           v18.20.2
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        /usr/bin/corepack       0.25.2
        nodejs:
          Installed: 18.20.2-1nodesource1
          Candidate: 18.20.2-1nodesource1
          Version table:
         *** 18.20.2-1nodesource1 600
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.1-1nodesource1 600
             18.20.0-1nodesource1 600
             18.19.1-1nodesource1 600
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          5.1.25
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
          system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
          system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
          system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
          system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
          system.adapter.history.0                : history               : rasphj                                   -  enabled
          system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
          system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
          system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
          system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
          system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
          system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
          system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
          system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
          system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
          system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
          system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
          system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
        Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
        Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
        Adapter    "homee"        : 1.2.0    , installed 1.2.0
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Objects and States
        Objects:        3145
        States:         2056
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       92947      12486/iobroker.js-c
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93230      12486/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90108      12514/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
        udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
        udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
        udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
        2024-04-26 16:11:36.096  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-04-26 16:11:36.097  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
        2024-04-26 16:11:36.103  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
        2024-04-26 16:11:38.074  - info: host.rasphj instance system.adapter.backitup.0 started with pid 12751
        2024-04-26 16:11:42.464  - info: backitup.0 (12751) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.2, js-controller: 5.0.19
        2024-04-26 16:11:42.526  - warn: backitup.0 (12751) Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
        Require stack:
        - /opt/iobroker/node_modules/iobroker.backitup/lib/tools.js
        - /opt/iobroker/node_modules/iobroker.backitup/main.js
        2024-04-26 16:11:52.654  - info: host.rasphj iobroker npm-install: added 28 packages in 16s44 packages are looking for funding  run `npm fund` for details
        2024-04-26 16:11:52.702  - info: host.rasphj iobroker npm-install: host.rasphj install adapter homee@1.2.0
        2024-04-26 16:11:52.836  - info: host.rasphj iobroker npm-install: upload [4] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/custom_m.html custom_m.html text/html
        2024-04-26 16:11:52.851  - info: host.rasphj iobroker npm-install: upload [3] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/homee.png homee.png image/png
        2024-04-26 16:11:52.861  - info: host.rasphj iobroker npm-install: upload [2] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/index_m.html index_m.html text/html
        2024-04-26 16:11:52.871  - info: host.rasphj iobroker npm-install: upload [1] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/jsonCustom.json jsonCustom.json application/json
        2024-04-26 16:11:52.882  - info: host.rasphj iobroker npm-install: upload [0] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/words.js words.js application/javascript
        2024-04-26 16:11:52.982  - info: host.rasphj iobroker npm-install: host.rasphj object system.adapter.homee created/updated
        2024-04-26 16:11:54.057  - info: host.rasphj iobroker npm-install: exit 0
        2024-04-26 16:11:55.059  - warn: host.rasphj startInstance cannot find adapter "synology". Try to install it... 1 attempt
        2024-04-26 16:11:55.060  - info: host.rasphj iobroker install synology using installedVersion
        2024-04-26 16:12:00.183  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
        2024-04-26 16:12:00.188  - info: host.rasphj iobroker npm-install: Installing iobroker.synology@3.1.0... (System call)
        2024-04-26 16:12:43.860  - info: host.rasphj iobroker npm-install:
        2024-04-26 16:12:43.864  - info: host.rasphj iobroker npm-install: added 32 packages, and changed 1 package in 42s45 packages are looking for funding  run `npm fund` for details
        2024-04-26 16:12:43.916  - info: host.rasphj iobroker npm-install: host.rasphj install adapter synology
          Homoran Global Moderator Administrators @hans1990 last edited by Homoran
          Controller "js-controller": 5.0.19 , installed 5.0.19
          hast du sonst noch was gemacht?
          Edit
          möglich dass er jetzt erst mal die Adapter neu baut.
          • hans1990
            hans1990 @Homoran last edited by hans1990
            iob stop
            iob update
            iob upgrade self
            Ich hab versucht den Fehler zu reproduzieren.
            @hans-jürgen-strudler said in io Broker lässt sich nicht updaten (Linux):
            Leider hab ich nicht gespeichert wie die node Version zu hoch war, aber es sah ca. so aus:
            Copy to Clipboard
            npm ERR! notsup Required: {"node":"8<=  node => 13"}
            npm ERR! notsup Actual:   {"npm":"6.14.16","node":"18.20."}
            auf der Weboberfläche wurde ich informiert, dass das File System geändert wird. das dürfte gerade laufen.
            Homoran 3 Replies Last reply Reply Quote 0
              Ich hab versucht
              bitte niemals nicht nix eigenmächtig machen, wenn dir verducht wird zu helfen
              Diesmal Teil 2
              https://forum.iobroker.net/post/884324
              bitte unbedingt lesen und beachten!
                sah ca. so aus:
                und auch diesmal:
                aus dem Zusammenhang gerissen nutzt das gar nichts
                • hans1990
                  Stimmt war eine doofe Idee -
                    @hans-jürgen-strudler Dann warte jetzt mal bis er mit dem Neubau aller Adapter fertig ist.
                      Homoran Global Moderator Administrators @Homoran last edited by
                      @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                      sah ca. so aus:
                      und auch diesmal:
                      @Hans-Jürgen-Strudler
                      auf den controller kann sich das ja nicht bezogen haben, der ist ja jetzt auf v5.x
                      • hans1990
                        ist es normal, dass die Weboberfläche derzeit nicht erreichbar ist?
                          nein!
                          aber du hattest zweimal admin auf dem selben port
                          beobachte dann über Konsole mit iob logs --watch und nicht irgendwo eingreifen
                          • hans1990
                            Das ist das Ergebnis (nur die letzten Zeilen, da sonst zu lange):
                            2024-04-26 16:23:05.616  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:23:05.617  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                            2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                            2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                            2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                            2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:23:05.623  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:23:05.623  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
                            2024-04-26 16:23:05.624  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
                            2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                            2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                            2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                            2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                            2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:23:05.841  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:23:05.841  - info: host.rasphj Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                            2024-04-26 16:23:05.842  - info: host.rasphj system.adapter.admin.0 will be rebuilt
                            2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                            2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                            2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                            2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                            2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:23:05.910  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:23:05.911  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                            2024-04-26 16:23:05.911  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
                            2024-04-26 16:23:09.675  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                            2024-04-26 16:23:09.678  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                            2024-04-26 16:23:15.923  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_23_10_738Z-debug-0.log
                            2024-04-26 16:23:15.924  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                            2024-04-26 16:23:16.955  - info: host.rasphj iobroker npm-install: exit 25
                            2024-04-26 16:23:17.956  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                            2024-04-26 16:23:17.957  - info: host.rasphj iobroker rebuild
                            2024-04-26 16:23:19.754  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
                            2024-04-26 16:23:48.352  - info: vis.0 (18269) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
                            2024-04-26 16:23:48.637  - info: vis.0 (18269) vis license is OK.
                            2024-04-26 16:23:49.642  - info: vis.0 (18269) Terminated (NO_ERROR): Without reason
                            2024-04-26 16:24:23.351  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
                            2024-04-26 16:24:23.385  - info: host.rasphj iobroker npm-rebuild:
                            2024-04-26 16:24:23.386  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
                            2024-04-26 16:24:24.399  - info: host.rasphj iobroker npm-rebuild: exit 0
                            2024-04-26 16:24:24.692  - info: host.rasphj instance system.adapter.discovery.0 started with pid 18660
                            2024-04-26 16:24:24.702  - info: host.rasphj instance system.adapter.admin.0 started with pid 18661
                            2024-04-26 16:24:24.711  - info: host.rasphj instance system.adapter.web.0 started with pid 18662
                            2024-04-26 16:24:25.405  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 4 attempt
                            2024-04-26 16:24:25.406  - info: host.rasphj iobroker install heytech@1.0.5 using installedVersion
                            2024-04-26 16:24:26.853  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                            2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                            2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                            2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                            2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:24:26.861  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:24:26.861  - info: host.rasphj Rebuild for adapter system.adapter.discovery.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            2024-04-26 16:24:26.863  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                            2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                            2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                            2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                            2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:24:26.870  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:24:26.871  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            2024-04-26 16:24:27.173  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                            2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                            2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                            2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                            2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:24:27.179  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:24:27.179  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:24:27.179  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                            2024-04-26 16:24:27.180  - info: host.rasphj system.adapter.web.0 will be rebuilt
                            2024-04-26 16:24:30.676  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                            2024-04-26 16:24:30.679  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                            2024-04-26 16:24:38.037  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_24_31_757Z-debug-0.log
                            2024-04-26 16:24:38.038  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                            2024-04-26 16:24:39.069  - info: host.rasphj iobroker npm-install: exit 25
                            2024-04-26 16:24:40.070  - warn: host.rasphj adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                            2024-04-26 16:24:40.071  - info: host.rasphj iobroker rebuild
                            2024-04-26 16:24:41.868  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
                            2024-04-26 16:25:11.870  - info: vis.0 (19415) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
                            2024-04-26 16:25:12.181  - info: vis.0 (19415) vis license is OK.
                            2024-04-26 16:25:13.263  - info: vis.0 (19415) Terminated (NO_ERROR): Without reason
                            2024-04-26 16:25:38.876  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
                            2024-04-26 16:25:38.912  - info: host.rasphj iobroker npm-rebuild:
                            2024-04-26 16:25:38.913  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
                            2024-04-26 16:25:39.928  - info: host.rasphj iobroker npm-rebuild: exit 0
                            2024-04-26 16:25:40.067  - info: host.rasphj instance system.adapter.web.0 started with pid 19767
                            2024-04-26 16:25:40.931  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                            2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                            2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   throw err;
                            2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   ^
                            2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                            2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Require stack:
                            2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                            2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                            2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                            2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                            2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                            2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                            2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                            2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                            2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                            2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]: }
                            2024-04-26 16:25:41.925  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                            2024-04-26 16:25:41.925  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2024-04-26 16:25:41.925  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                            Homoran hans1990 2 Replies Last reply Reply Quote 0
                              20
                              da isser ja!
                              Der Rest ist natürlich Mist.
                              Jetzt hast du node und Controller upgedatet.
                              Außerdem hattest du ja noch extraneous im npm log gehabt.
                              Vielleicht hat @thomas-braun noch ne Idee.
                              • hans1990
                                hans1990 @hans1990 last edited by
                                hier ein Auszug von den Error Zeilen
                                2024-04-26 16:12:44.343  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
                                2024-04-26 16:12:46.377  - warn: host.rasphj startInstance cannot find adapter "net-tools". Try to install it... 1 attempt
                                2024-04-26 16:13:07.751  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=6.13.15"
                                2024-04-26 16:13:09.784  - warn: host.rasphj startInstance cannot find adapter "ping". Try to install it... 1 attempt
                                2024-04-26 16:13:24.644  - warn: host.rasphj startInstance cannot find adapter "shuttercontrol@1.2.1". Try to install it... 1 attempt
                                2024-04-26 16:13:40.311  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 1 attempt
                                2024-04-26 16:13:50.827  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_13_45_983Z-debug-0.log
                                2024-04-26 16:13:50.828  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                2024-04-26 16:13:52.864  - warn: host.rasphj startInstance cannot find adapter "flot". Try to install it... 1 attempt
                                2024-04-26 16:13:57.708  - warn: host.rasphj startInstance cannot find adapter "elero-usb-transmitter@0.5.2". Try to install it... 1 attempt
                                2024-04-26 16:16:00.502  - warn: host.rasphj startInstance cannot find adapter "history@1.9.14". Try to install it... 1 attempt
                                2024-04-26 16:16:18.909  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
                                2024-04-26 16:16:20.940  - warn: host.rasphj startInstance cannot find adapter "sonoff@2.4.5". Try to install it... 1 attempt
                                2024-04-26 16:16:36.159  - warn: host.rasphj startInstance cannot find adapter "nuki-extended@2.3.1". Try to install it... 1 attempt
                                2024-04-26 16:16:55.100  - warn: host.rasphj startInstance cannot find adapter "rpi2@1.3.1". Try to install it... 1 attempt
                                2024-04-26 16:16:59.371  - warn: nuki-extended.0 (14121) Callback not attached because too many Callbacks attached to the Nuki Bridge already! Please delete a callback!
                                2024-04-26 16:17:36.447  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                2024-04-26 16:18:04.280  - warn: host.rasphj Slave controller detected disconnection. Stop all instances.
                                2024-04-26 16:18:05.121  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                2024-04-26 16:18:05.123  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                2024-04-26 16:18:05.124  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                2024-04-26 16:18:05.144  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                                2024-04-26 16:18:25.102  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                2024-04-26 16:18:25.103  - error: host.rasphj Caught by controller[0]:   throw err;
                                2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]:   ^
                                2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                                2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: Require stack:
                                2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                                2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                2024-04-26 16:18:25.107  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                                2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                                2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]: }
                                2024-04-26 16:18:25.111  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                                2024-04-26 16:18:25.111  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2024-04-26 16:18:35.188  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_18_29_163Z-debug-0.log
                                2024-04-26 16:18:35.189  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                                2024-04-26 16:18:37.280  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                                2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]:   throw err;
                                2024-04-26 16:18:49.985  - error: host.rasphj Caught by controller[0]:   ^
                                2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                                2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Require stack:
                                2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                                2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                                2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                                2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                                2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                                2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                                2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                                2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                                2024-04-26 16:18:49.991  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                                2024-04-26 16:18:49.992  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                                2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                                2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[0]: }
                                2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[1]: Node.js v18.20.2
                                2024-04-26 16:18:49.995  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                • hans1990
                                  kann das helfen?
                                    teilweise vollkommen ok!
                                    Die Adapter müssen für das neue node neu gebaut werden. 1st attempt ist also korrekt.
                                    Andere Adapter benötigen eine höhere Version vom admin, bei dem es allerdings klemmt
                                    heytech ist anscheinend zu alt und nicht mehr unterstützt, oder über github installiert worden???
                                    warum das hängt sehe ich jetzt nicht
                                      kann das helfen?
                                      lass erst einmal alle Eingriffe sein!
                                      gibt es neuere log Zeilen als von 16:25?
                                      • hans1990
                                        Nein. Das war die letzte Zeile
                                          iob stop
                                          hattest du iobroker gestoppt, während dieser dabei war die Adapter neu zu bauen?
                                          • hans1990
                                            Das weiß ich nicht mehr woher ich es installiert habe.
                                            1857
