    4. io Broker lässt sich nicht updaten (Linux)
    • hans1990
      hans1990 @Thomas Braun last edited by
      @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
      iob update
      sagt?
      pi@rasphj:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
      Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
      Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
      Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
      Adapter    "homee"        : 1.2.0    , installed 1.2.0
      Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
      Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
      Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
      Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
      Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
      Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
      Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
      Ist jetzt im LogFile Ruhe eingekehrt?
      ja war ruhig - hab dann einen reboot gemacht und ist wieder hier hängen geblieben
      2024-04-26 17:46:13.582  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
      2024-04-26 17:46:13.929  - error: host.rasphj Caught by controller[0]:   throw err;
      2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]:   ^
      2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
      2024-04-26 17:46:13.930  - error: host.rasphj Caught by controller[0]: Require stack:
      2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
      2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      2024-04-26 17:46:13.931  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
      2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-04-26 17:46:13.932  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
      2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-04-26 17:46:13.933  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-04-26 17:46:13.934  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
      2024-04-26 17:46:13.935  - error: host.rasphj Caught by controller[0]: }
      2024-04-26 17:46:13.936  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
      2024-04-26 17:46:13.936  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-04-26 17:46:13.936  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2024-04-26 17:46:17.534  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
      2024-04-26 17:46:17.538  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
      2024-04-26 17:46:24.616  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T15_46_18_637Z-debug-0.log
      2024-04-26 17:46:24.617  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
      2024-04-26 17:46:25.653  - info: host.rasphj iobroker npm-install: exit 25
      2024-04-26 17:46:26.655  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
        Thomas Braun Most Active @hans1990 last edited by
        @hans-jürgen-strudler
        iob upgrade heytech@1.0.6
        hans1990 1 Reply Last reply Reply Quote 0
        • hans1990
          pi@rasphj:~ $ iob upgrade heytech@1.0.6
          Adapter "heytech"        is not installed.
            Homoran Global Moderator Administrators @hans1990 last edited by
            @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
            Ja da wirst du die Installation unterbrochen haben und der admin ist jetzt in einem undefinierten Zustand.
            ich gab jetzt den vollständigen Pfad zum Adapter directory nicht im Kopf. Thomas wird es dir sagen
              @hans-jürgen-strudler dann hattest du ihn über github installiert. Das konnte wegen der alten Dependencies nicht wiederhergestellt werden.
                iob add heytech
                Homoran hans1990 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                  @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
                  iob add heytech
                  nee, die Instanz ist ja da, das gibt ne zweite!
                  iob install heytech müsste die Basis wieder installieren, ggf, gefolgt von iob upload heytech
                  • hans1990
                    hans1990 @Thomas Braun last edited by hans1990
                    iob add heytech
                    da kam das zurück
                    pi@rasphj:~ $ iob add heytech
                    NPM version: 10.5.0
                    Installing iobroker.heytech@1.0.6... (System call)
                    added 4 packages, removed 639 packages, and changed 1 package in 16s
                    70 packages are looking for funding
                      run `npm fund` for details
                    host.rasphj install adapter heytech
                    upload [4] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/admin.d.ts admin.d.ts video/mp2t
                    upload [3] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/heytech.png heytech.png image/png
                    upload [2] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/index_m.html index_m.html text/html
                    upload [1] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/style.css style.css text/css
                    upload [0] heytech.admin /opt/iobroker/node_modules/iobroker.heytech/admin/words.js words.js application/javascript
                    host.rasphj object system.adapter.heytech created/updated
                    Update "system.adapter.heytech.0"
                    host.rasphj create instance heytech
                    host.rasphj object system.adapter.heytech.1.alive created
                    host.rasphj object system.adapter.heytech.1.connected created
                    host.rasphj object system.adapter.heytech.1.compactMode created
                    host.rasphj object system.adapter.heytech.1.cpu created
                    host.rasphj object system.adapter.heytech.1.cputime created
                    host.rasphj object system.adapter.heytech.1.memHeapUsed created
                    host.rasphj object system.adapter.heytech.1.memHeapTotal created
                    host.rasphj object system.adapter.heytech.1.memRss created
                    host.rasphj object system.adapter.heytech.1.uptime created
                    host.rasphj object system.adapter.heytech.1.inputCount created
                    host.rasphj object system.adapter.heytech.1.outputCount created
                    host.rasphj object system.adapter.heytech.1.eventLoopLag created
                    host.rasphj object system.adapter.heytech.1.sigKill created
                    host.rasphj object system.adapter.heytech.1.logLevel created
                    host.rasphj object system.adapter.heytech.1 created
                    hier die Logs dazu:
                    2024-04-26 17:59:32.438  - info: host.rasphj instance system.adapter.heytech.1 started with pid 4420
                    2024-04-26 17:59:35.225  - info: heytech.1 (4420) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.heytech, node: v18.20.2, js-controller: 5.0.19
                      @hans1990 sagte in io Broker lässt sich nicht updaten (Linux):
                      iob del heytech.1
                      Und dann nochmal
                      iob update
                      iob upgrade all
                      • hans1990
                        iob del heytech.1
                        pi@rasphj:~ $ iob del heytech.1
                        Delete instance "heytech.1"
                        host.rasphj Counted 1 instances of heytech.1
                        host.rasphj Counted 14 states of system.adapter.heytech.1
                        host.rasphj Counted 14 states (system.adapter.heytech.1.*) from states
                        host.rasphj Deleting 15 object(s).
                        host.rasphj Deleting 14 state(s).
                        iob update
                        pi@rasphj:~ $
                        iob update
                        Adapter    "heytech"      : 1.0.6    , installed 1.0.6
                        Ich will alles updaten oder?
                          Ja natürlich.
                          hans1990 1 Reply Last reply Reply Quote 1
                          • hans1990
                            @Homoran
                            DANKE!!! Hat funktioniert. Die Web Oberfläche ist wieder da.
                            bei den Adaptern sind aber zwei admins
                            wäre admin.1 zu löschen?
                              as I told:
                              @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                              du hattest zweimal admin auf dem selben port
                                iob del admin.1
                                Dann zeig jetzt nochmal die Langfassung vom
                                iob diag
                                • hans1990
                                  iob diag
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                     Static hostname: rasphj
                                           Icon name: computer
                                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  Model           : Raspberry Pi 4 Model B Rev 1.1
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : armhf
                                  Systemuptime and Load:
                                   18:25:22 up 42 min,  1 user,  load average: 0.68, 0.68, 0.67
                                  CPU threads: 4
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** Time and Time Zones ***
                                                 Local time: Fri 2024-04-26 18:25:22 CEST
                                             Universal time: Fri 2024-04-26 16:25:22 UTC
                                                   RTC time: n/a
                                                  Time zone: Europe/Vienna (CEST, +0200)
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        747M        1.9G        0.0K        1.1G        3.0G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        747M        2.0G
                                           3794 M total memory
                                            748 M used memory
                                            817 M active memory
                                            866 M inactive memory
                                           1949 M free memory
                                             67 M buffer memory
                                           1029 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       59G  4.8G   52G   9% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                  tmpfs          tmpfs     759M  820K  759M   1% /run
                                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                  [Fri Apr 26 17:42:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Fri Apr 26 17:42:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Fri Apr 26 17:42:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Fri Apr 26 17:42:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  TARGET  SOURCE         FSTYPE OPTIONS
                                  /       /dev/mmcblk0p2 ext4   rw,noatime
                                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                  /var:
                                  1.7G    /var/
                                  1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                                  1.3G    /var/log
                                  202M    /var/cache
                                  Archived and active journals take up 1.2G in the file system.
                                  /opt/iobroker/backups:
                                  24M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  286M    /opt/iobroker/iobroker-data/
                                  127M    /opt/iobroker/iobroker-data/files
                                  87M     /opt/iobroker/iobroker-data/history
                                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  45M     /opt/iobroker/iobroker-data/backup-objects
                                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                                  8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                                  7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                                  6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                                  USB-Devices by-id:
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v18.20.2
                                  /usr/bin/node           v18.20.2
                                  /usr/bin/npm            10.5.0
                                  /usr/bin/npx            10.5.0
                                  /usr/bin/corepack       0.25.2
                                  nodejs:
                                    Installed: 18.20.2-1nodesource1
                                    Candidate: 18.20.2-1nodesource1
                                    Version table:
                                   *** 18.20.2-1nodesource1 600
                                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                          100 /var/lib/dpkg/status
                                       18.20.1-1nodesource1 600
                                       18.20.0-1nodesource1 600
                                       18.19.1-1nodesource1 600
                                       18.19.0-1nodesource1 600
                                       18.18.2-1nodesource1 600
                                       18.18.1-1nodesource1 600
                                       18.18.0-1nodesource1 600
                                       18.17.1-1nodesource1 600
                                       18.17.0-1nodesource1 600
                                       18.16.1-1nodesource1 600
                                       18.16.0-1nodesource1 600
                                       18.15.0-1nodesource1 600
                                       18.14.2-1nodesource1 600
                                       18.14.1-1nodesource1 600
                                       18.14.0-1nodesource1 600
                                       18.13.0-1nodesource1 600
                                       18.12.0-1nodesource1 600
                                       18.11.0-1nodesource1 600
                                       18.10.0-1nodesource1 600
                                       18.9.1-1nodesource1 600
                                       18.9.0-1nodesource1 600
                                       18.8.0-1nodesource1 600
                                       18.7.0-1nodesource1 600
                                       18.6.0-1nodesource1 600
                                       18.5.0-1nodesource1 600
                                       18.4.0-1nodesource1 600
                                       18.3.0-1nodesource1 600
                                       18.2.0-1nodesource1 600
                                       18.1.0-1nodesource1 600
                                       18.0.0-1nodesource1 600
                                       12.22.12~dfsg-1~deb11u4 500
                                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  admin:          6.13.16
                                  javascript:     7.8.0
                                  Adapters from github:   0
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                                  + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                                    system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                                    system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                                    system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                                  + system.adapter.history.0                : history               : rasphj                                   -  enabled
                                    system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                                  + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                                    system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                                  + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                                  + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                                  + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                                    system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                                  + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                                  + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                                  + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                                    system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                                  + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                  Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                  Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                                  Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                                  Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                  Objects and States
                                  Objects:        3204
                                  States:         2100
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34237      5016/io.sonoff.0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14734      495/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14726      495/iobroker.js-con
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      526/sshd: /usr/sbin
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38806      5930/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35305      5219/io.admin.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      526/sshd: /usr/sbin
                                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       37804      5937/io.nuki-extend
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13799      719/dhcpcd
                                  udp        0      0 0.0.0.0:50156           0.0.0.0:*                           108        14626      388/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33185      4843/io.wled.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      388/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36491      5530/io.shelly.0
                                  udp6       0      0 :::546                  :::*                                0          13811      719/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        14625      388/avahi-daemon: r
                                  udp6       0      0 :::40797                :::*                                108        14627      388/avahi-daemon: r
                                  2024-04-26 18:25:45.539  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:25:49.757  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:25:50.522  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                                  2024-04-26 18:25:50.682  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:25:55.853  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:25:56.172  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:01.008  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:02.056  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:06.269  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:07.670  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:11.441  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:13.784  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:16.328  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                                  2024-04-26 18:26:16.714  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:21.881  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:22.508  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:27.151  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:28.463  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-04-26 18:26:28.472  - warn: sonoff.0 (5016) Client [shelly1-E8DB84D63938] has invalid password or username
                                  2024-04-26 18:26:28.898  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                                  2024-04-26 18:26:28.943  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                                  2024-04-26 18:26:28.946  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                                  2024-04-26 18:26:28.985  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                                  2024-04-26 18:26:29.004  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                                  2024-04-26 18:26:29.015  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                                    Wenn das jetzt alles läuft, Backup ziehen und die ganze Kiste NEUinstallieren.
                                    Diesmal als reines 64Bit-Lite-System im 'Bookworm'-Release.
                                    shelly und sonoff auf dem gleichen Port ist bestimmt auch falsch.
                                    Homoran hans1990 2 Replies Last reply Reply Quote 1
                                      @hans1990
                                      und diesmal nach dem Restore die Finger weg!
                                      jegliche Unterbrechung des rebuilds führt zu einem undefinierten Zustand!!
                                      Das kann eine Stunde dauern
                                      • hans1990
                                        hans1990 @hans1990 last edited by hans1990
                                        Danke an @Homoran @Thomas-Braun
                                        Zusammenfassung:
                                        folgende Befehle haben in diesem Fall den Erfolg gebracht und das Update gelingen lassen.
                                        iob stop
                                        iob fix
                                        iob start
                                        iob diag
                                        iob nodejs-update
                                        iob upgrade self
                                        iob add heytech
                                        iob del heytech.1
                                        iob update
                                        iob upgrade all
                                          @hans1990
                                          Da fehlt aber noch ein
                                          iob upgrade self
                                          Und lass die Kiste künftig nicht mehr so versumpfen.
                                          • hans1990
                                            ich werde darauf achten 🙄
                                            1857
