    4. Lovelace start PRoblem
      Esmax666 @Thomas Braun last edited by
      update habe probiert mit
      war das nicht richtig?
      ich bekomme das
      oBroker nodejs updater 2023-10-13
      Recommended nodejs-version is: 18.20.2
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1ubuntu2 500
              500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Nothing to do - Your installation is using the correct paths.
      Nothing to do - Your version is the recommended one.
      You can now keep your whole system up-to-date using the usual 'sudo apt update &                                        & sudo apt full-upgrade' commands.
      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel.                                         They will break your current installation!
      das hatte ich noch gemacht
      iob stop
      sudo apt update && sudo apt full-upgrade
      iob fix
      iob nodejs-update
      sudo reboot
      @david-g said in Lovelace start PRoblem:
      Die Funktion muss glaube nicht sein.
      Dein "view" sieht nicht gleich wie bei mir, da hast du ein Adpater noch dazu oder ? ich dachte man braucht nicht mehr etwas wie linkeddevice oder device?
      Bei mir ist das so (Nativ) <- ich dachte man kann mit nativ Alias arbeiten ohne extra adapter
        Thomas Braun Most Active @Esmax666 last edited by
        @esmax666 sagte in Lovelace start PRoblem:
        Keine Ahnung was du da gemacht hast.
        Aber reboote die Kiste mal sauber, in den 200 Tagen uptime war mit Sicherheit auch ein Update dazwischen, das einen Neustart benötigt.
        iob stop
        sudo reboot
        E 2 Replies Last reply Reply Quote 0
          Esmax666 @Thomas Braun last edited by Esmax666
          ich habe doch oben geschrieben das ich ein restart gemacht habe mit „sudo reboot“. k.a. voher kommen die 200 Tage ohne reboot?
          kein ahnung warum hat er das nichts aktualisiert aber reboot habe ich gemacht…
            Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
            Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
            Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
            Hit:4 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
            Calculating upgrade... Done
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            ioBroker nodejs updater 2023-10-13
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            nodejs:
              Version table:
            You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
              @esmax666
              Dein 'Lunar Lobster' ist ohnehin verendet. Installier da die aktuelle LTS-Version von ubuntu. Oder das aktuelle Debian-Release.
              • David G.
                David G. last edited by
                Hab grad nochmal geschaut. Ist wirklich wohl kein Standarte. Dann inszallier ihn einfach ganz normal nach. Der ist es
                https://github.com/ioBroker/ioBroker.devices
                Findest du ganz normal im iobroker Repro.
                  @thomas-braun Lunar ist doch noch weiter updated, aber ist egal habe ich aktuliasert
                  nodeversion ist auch jetzt updated
                  Hit:1 http://ports.ubuntu.com/ubuntu-ports noble InRelease
                  Hit:2 http://ports.ubuntu.com/ubuntu-ports noble-updates InRelease
                  Hit:3 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease
                  Hit:4 http://ports.ubuntu.com/ubuntu-ports noble-backports InRelease
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Version table:
                       18.19.1+dfsg-6ubuntu5 500
                          500 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 Packages
                    Nein, der hat im Januar 2024 sein EndOfLife gehabt.
                    Und lass das nodesource-Repo aktiv! Bzw. leg das wieder an.
                      Esmax666 @David G. last edited by
                      Also das heisst "lovelace" funtionniert nur mit Device adapter ? slstam ich irgenwo ein Video gesehen wo jemand auch alias arbeitet und trotzdem ein paar gerät erkennt hat 😕
                        @thomas-braun said in Lovelace start PRoblem:
                        Was habe ich gemacht ? 🙄 und wie mache das wieder an, k.a was das ist 😕
                          Das weiß ich nicht. Jedenfalls hat du kein nodesource.list file auf deiner Kiste.
                          iob nodejs-update 18
                            ok fertig
                            ich hoffe das es jetzt ok ist
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            nodejs:
                              Version table:
                            • David G.
                              David G. @Esmax666 last edited by David G.
                              Jain,
                              es liegt daran welche Geräte man hat und wie diese eingebunden sind.
                              Woher soll lovelace wissen was es für ein Gerät ist und welche Datenpunkte dazu gehören, wenn es keine anhaltspunkte hat was was ist?
                              Dein z-wave legt wie es aussieht eine sehr wilde Datenstruktur an und die DPs haben auch keine entsprechenden Rollen. Woher soll da welcher Adapter auch immer was zuordnen können?
                              Ich nutze HomaticIP über eine CCU. Der Adapter legt alles sauber an und es klappt, sobald ich einen Raum vergebe.
                              Das wird dann auch gefunden.
                              Falls du deine Geräte in Alexa oder Google Home bringen möchtest, hast du genau das selbe Vorgehen wie bei lovelace. Auch diese Adapter benötigen ein paar Infos.....
                              Bei Geräten mir nur einem DP, ist es natürlich über das Zahnrad viel leichter.
                                @david-g
                                ok ich werde das adapter später probieren 🙂
                                Das heisst in Home assistant zum beispiel die müssen auch dann mit "Alias" arbeiten oder ?
                                Hast du auch HeatingControl ?
                                könntest du etwas machen für Lovelece ? da ich eher weniger skript erfahung habe denke ich am ende muss VIS + Lovelece haben
                                • David G.
                                  @esmax666
                                  HA geht mit den Sachen ganz anders um.
                                  Da sind die Integration (deren Adapter) schon so geschrieben, dass das alles funktioniert.
                                  Iobroker hatte diesen Ansatz früher noch nicht. So weit ich weiß, wird da aber dran gearbeitet.
                                  Heating Control nutze ich nicht. Aber das hat ja auch nichts mit einer Visualisierung zu tun.
                                  Ich denke, man sollte sich für eins entscheiden. Vis oder lovelace (oder sonst was).
                                    @david-g ach so ok, ja ich habe das heute früh probiert,
                                    also loveless + HA macht das wirklich alles automatisch das ist wirklich crazy, alles zwave geräte sind schon da und sogar auf dashboard. die haben das wirklich gut gemacht aber mit VIS1/2 kann man besser personalisieren (finde ich)
                                    ich will nur ein bisschen beide probieren 🙂
                                    2353
