    4. io Broker lässt sich nicht updaten (Linux)
      Thomas Braun Most Active @hans1990 last edited by
      @hans1990 sagte in io Broker lässt sich nicht updaten (Linux):
      iob del heytech.1
      Und dann nochmal
      iob update
      iob upgrade all
      hans1990 1 Reply Last reply Reply Quote 0
      • hans1990
        hans1990 @Thomas Braun last edited by
        @thomas-braun said in io Broker lässt sich nicht updaten (Linux):
        iob del heytech.1
        pi@rasphj:~ $ iob del heytech.1
        Delete instance "heytech.1"
        host.rasphj Counted 1 instances of heytech.1
        host.rasphj Counted 14 states of system.adapter.heytech.1
        host.rasphj Counted 14 states (system.adapter.heytech.1.*) from states
        host.rasphj Deleting 15 object(s).
        host.rasphj Deleting 14 state(s).
        iob update
        pi@rasphj:~ $
        iob update
        Used repository: stable
        Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
        Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
        Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
        Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
        Adapter    "heytech"      : 1.0.6    , installed 1.0.6
        Adapter    "homee"        : 1.2.0    , installed 1.2.0
        Adapter    "javascript"   : 7.8.0    , installed 5.2.13 [Updatable]
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "nuki"         : 1.6.0    , installed 1.5.0  [Updatable]
        Adapter    "nuki-extended": 2.6.5    , installed 2.3.1  [Updatable]
        Adapter    "octoprint"    : 5.1.0    , installed 1.1.1  [Updatable]
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
        Adapter    "shelly"       : 6.8.0    , installed 4.0.7  [Updatable]
        Adapter    "shuttercontrol": 1.7.0   , installed 1.2.1  [Updatable]
        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
        Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
        Adapter    "web"          : 6.2.5    , installed 3.4.9  [Updatable]
        Adapter    "wled"         : 0.7.2    , installed 0.6.3  [Updatable]
        Ich will alles updaten oder?
          Ja natürlich.
          hans1990 1 Reply Last reply Reply Quote 1
          • hans1990
            @Homoran
            DANKE!!! Hat funktioniert. Die Web Oberfläche ist wieder da.
            bei den Adaptern sind aber zwei admins
            wäre admin.1 zu löschen?
              Homoran Global Moderator Administrators @hans1990 last edited by
              as I told:
              @homoran sagte in io Broker lässt sich nicht updaten (Linux):
              du hattest zweimal admin auf dem selben port
                iob del admin.1
                Dann zeig jetzt nochmal die Langfassung vom
                iob diag
                • hans1990
                  iob diag
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                     Static hostname: rasphj
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : armhf
                  Systemuptime and Load:
                   18:25:22 up 42 min,  1 user,  load average: 0.68, 0.68, 0.67
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Fri 2024-04-26 18:25:22 CEST
                             Universal time: Fri 2024-04-26 16:25:22 UTC
                                   RTC time: n/a
                                  Time zone: Europe/Vienna (CEST, +0200)
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        747M        1.9G        0.0K        1.1G        3.0G
                  Swap:            99M          0B         99M
                  Total:          3.9G        747M        2.0G
                           3794 M total memory
                            748 M used memory
                            817 M active memory
                            866 M inactive memory
                           1949 M free memory
                             67 M buffer memory
                           1029 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4       59G  4.8G   52G   9% /
                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                  tmpfs          tmpfs     759M  820K  759M   1% /run
                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Fri Apr 26 17:42:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Fri Apr 26 17:42:36 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Fri Apr 26 17:42:36 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Fri Apr 26 17:42:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                  /var:
                  1.7G    /var/
                  1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
                  1.3G    /var/log
                  202M    /var/cache
                  Archived and active journals take up 1.2G in the file system.
                  /opt/iobroker/backups:
                  24M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  286M    /opt/iobroker/iobroker-data/
                  127M    /opt/iobroker/iobroker-data/files
                  87M     /opt/iobroker/iobroker-data/history
                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                  45M     /opt/iobroker/iobroker-data/backup-objects
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                  7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
                  6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                  USB-Devices by-id:
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.20.2
                  /usr/bin/node           v18.20.2
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  /usr/bin/corepack       0.25.2
                  nodejs:
                    Installed: 18.20.2-1nodesource1
                    Candidate: 18.20.2-1nodesource1
                    Version table:
                   *** 18.20.2-1nodesource1 600
                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                          100 /var/lib/dpkg/status
                       18.20.1-1nodesource1 600
                       18.20.0-1nodesource1 600
                       18.19.1-1nodesource1 600
                       18.19.0-1nodesource1 600
                       18.18.2-1nodesource1 600
                       18.18.1-1nodesource1 600
                       18.18.0-1nodesource1 600
                       18.17.1-1nodesource1 600
                       18.17.0-1nodesource1 600
                       18.16.1-1nodesource1 600
                       18.16.0-1nodesource1 600
                       18.15.0-1nodesource1 600
                       18.14.2-1nodesource1 600
                       18.14.1-1nodesource1 600
                       18.14.0-1nodesource1 600
                       18.13.0-1nodesource1 600
                       18.12.0-1nodesource1 600
                       18.11.0-1nodesource1 600
                       18.10.0-1nodesource1 600
                       18.9.1-1nodesource1 600
                       18.9.0-1nodesource1 600
                       18.8.0-1nodesource1 600
                       18.7.0-1nodesource1 600
                       18.6.0-1nodesource1 600
                       18.5.0-1nodesource1 600
                       18.4.0-1nodesource1 600
                       18.3.0-1nodesource1 600
                       18.2.0-1nodesource1 600
                       18.1.0-1nodesource1 600
                       18.0.0-1nodesource1 600
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapters from github:   0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
                  + system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
                    system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
                    system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
                    system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
                  + system.adapter.history.0                : history               : rasphj                                   -  enabled
                    system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
                  + system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
                    system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
                  + system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
                  + system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
                  + system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
                    system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
                  + system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
                  + system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
                  + system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
                    system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
                  + system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                  Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                  Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                  Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                  Objects and States
                  Objects:        3204
                  States:         2100
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34237      5016/io.sonoff.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14734      495/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14726      495/iobroker.js-con
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14717      526/sshd: /usr/sbin
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38806      5930/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35305      5219/io.admin.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14719      526/sshd: /usr/sbin
                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       37804      5937/io.nuki-extend
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13799      719/dhcpcd
                  udp        0      0 0.0.0.0:50156           0.0.0.0:*                           108        14626      388/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33185      4843/io.wled.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      388/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36491      5530/io.shelly.0
                  udp6       0      0 :::546                  :::*                                0          13811      719/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        14625      388/avahi-daemon: r
                  udp6       0      0 :::40797                :::*                                108        14627      388/avahi-daemon: r
                  2024-04-26 18:25:45.539  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:49.757  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:50.522  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                  2024-04-26 18:25:50.682  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:55.853  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:25:56.172  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:01.008  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:02.056  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:06.269  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:07.670  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:11.441  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:13.784  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:16.328  - warn: sonoff.0 (5016) Client [EnderPro] has invalid password or username
                  2024-04-26 18:26:16.714  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:21.881  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:22.508  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:27.151  - warn: shelly.0 (5530) [authEnabled] 10.0.0.49 (shellyplug-s / shellyplug-s-577565 / SHPLG-S#577565#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:28.463  - warn: shelly.0 (5530) [authEnabled] 10.0.0.50 (shelly1 / shelly1-C45BBE6BC200 / SHSW-1#C45BBE6BC200#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-04-26 18:26:28.472  - warn: sonoff.0 (5016) Client [shelly1-E8DB84D63938] has invalid password or username
                  2024-04-26 18:26:28.898  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                  2024-04-26 18:26:28.943  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                  2024-04-26 18:26:28.946  - info: web.0 (5930) <== Disconnect system.user.admin from ::ffff:10.0.0.2 flot
                  2024-04-26 18:26:28.985  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                  2024-04-26 18:26:29.004  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                  2024-04-26 18:26:29.015  - info: web.0 (5930) ==> Connected system.user.admin from ::ffff:10.0.0.2
                    Wenn das jetzt alles läuft, Backup ziehen und die ganze Kiste NEUinstallieren.
                    Diesmal als reines 64Bit-Lite-System im 'Bookworm'-Release.
                    shelly und sonoff auf dem gleichen Port ist bestimmt auch falsch.
                    Homoran hans1990 2 Replies Last reply Reply Quote 1
                      Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                      @thomas-braun sagte in io Broker lässt sich nicht updaten (Linux):
                      @hans1990
                      und diesmal nach dem Restore die Finger weg!
                      jegliche Unterbrechung des rebuilds führt zu einem undefinierten Zustand!!
                      Das kann eine Stunde dauern
                      • hans1990
                        hans1990 @hans1990 last edited by hans1990
                        Danke an @Homoran @Thomas-Braun
                        Zusammenfassung:
                        folgende Befehle haben in diesem Fall den Erfolg gebracht und das Update gelingen lassen.
                        iob stop
                        iob fix
                        iob start
                        iob diag
                        iob nodejs-update
                        iob upgrade self
                        iob add heytech
                        iob del heytech.1
                        iob update
                        iob upgrade all
                          @hans1990
                          Da fehlt aber noch ein
                          iob upgrade self
                          Und lass die Kiste künftig nicht mehr so versumpfen.
                          • hans1990
                            ich werde darauf achten 🙄
                            • hans1990
                              Das Betriebssystem ist bereits auf der SD Karte:
                              Raspberry Pi OS Lite
                              Release date: March 15th 2024
                              System: 64-bit
                              Kernel version: 6.6
                              Debian version: 12 (bookworm)
                              IO Broker installieren würde ich mit:
                              curl -sLf https://iobroker.net/install.sh | bash -
                              Backup ziehen
                              Gibt es ein HOW TO, dass du für Migration der Einstellungen empfehlen kannst?
                              lg Hans
                                @hans1990
                                Dann kannst du jetzt dein Backup einspielen. Zum Backitup-Adapter gibt es ausführliche Anleitungen, fall s Fragen sind
                                1857
