Lovelace start PRoblem
@esmax666 sagte in Lovelace start PRoblem:
da hast du ein Adpater noch dazu oder
Hab grad nochmal geschaut. Ist wirklich wohl kein Standarte. Dann inszallier ihn einfach ganz normal nach. Der ist es
https://github.com/ioBroker/ioBroker.devicesFindest du ganz normal im iobroker Repro.
@thomas-braun Lunar ist doch noch weiter updated, aber ist egal habe ich aktuliasert
nodeversion ist auch jetzt updatedHit:1 http://ports.ubuntu.com/ubuntu-ports noble InRelease Hit:2 http://ports.ubuntu.com/ubuntu-ports noble-updates InRelease Hit:3 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease Hit:4 http://ports.ubuntu.com/ubuntu-ports noble-backports InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
ioBroker nodejs updater 2023-10-13 Recommended nodejs-version is: 18.20.2 Checking your installation now. Please be patient! Your current setup is: /usr/bin/nodejs v18.20.2 /usr/bin/node v18.20.2 /usr/bin/npm 10.5.0 /usr/bin/npx 10.5.0 /usr/bin/corepack 0.25.2 We found these nodejs versions available for installation: nodejs: Installed: 18.20.2-1nodesource1 Candidate: 18.20.2-1nodesource1 Version table: *** 18.20.2-1nodesource1 100 100 /var/lib/dpkg/status 18.19.1+dfsg-6ubuntu5 500 500 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 Packages Nothing to do - Your installation is using the correct paths. Nothing to do - Your version is the recommended one. You can now keep your whole system up-to-date using the usual 'sudo apt update & & sudo apt full-upgrade' commands. Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
Nein, der hat im Januar 2024 sein EndOfLife gehabt.
Und lass das nodesource-Repo aktiv! Bzw. leg das wieder an. -
@david-g said in Lovelace start PRoblem:
Findest du ganz normal im iobroker Repro.Also das heisst "lovelace" funtionniert nur mit Device adapter ? slstam ich irgenwo ein Video gesehen wo jemand auch alias arbeitet und trotzdem ein paar gerät erkennt hat
@thomas-braun said in Lovelace start PRoblem:
Was habe ich gemacht ?
und wie mache das wieder an, k.a was das ist
Das weiß ich nicht. Jedenfalls hat du kein nodesource.list file auf deiner Kiste.
iob nodejs-update 18
ok fertigich hoffe das es jetzt ok ist
nodejs updater 2023-10-13 Recommended nodejs-version is: 18.20.2 Checking your installation now. Please be patient! Your current setup is: /usr/bin/nodejs v18.20.2 /usr/bin/node v18.20.2 /usr/bin/npm 10.5.0 /usr/bin/npx 10.5.0 /usr/bin/corepack 0.25.2 We found these nodejs versions available for installation: nodejs: Installed: 18.20.2-1nodesource1 Candidate: 18.20.2-1nodesource1 Version table: *** 18.20.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.20.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.1+dfsg-6ubuntu5 500 500 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 Packages 18.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages Nothing to do - Your installation is using the correct paths. Nothing to do - Your version is the recommended one. You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
Jain,
es liegt daran welche Geräte man hat und wie diese eingebunden sind.
Woher soll lovelace wissen was es für ein Gerät ist und welche Datenpunkte dazu gehören, wenn es keine anhaltspunkte hat was was ist?Dein z-wave legt wie es aussieht eine sehr wilde Datenstruktur an und die DPs haben auch keine entsprechenden Rollen. Woher soll da welcher Adapter auch immer was zuordnen können?
Ich nutze HomaticIP über eine CCU. Der Adapter legt alles sauber an und es klappt, sobald ich einen Raum vergebe.
Das wird dann auch gefunden.Falls du deine Geräte in Alexa oder Google Home bringen möchtest, hast du genau das selbe Vorgehen wie bei lovelace. Auch diese Adapter benötigen ein paar Infos.....
Bei Geräten mir nur einem DP, ist es natürlich über das Zahnrad viel leichter.
@david-g
ok ich werde das adapter später probieren
Das heisst in Home assistant zum beispiel die müssen auch dann mit "Alias" arbeiten oder ?Hast du auch HeatingControl ?
könntest du etwas machen für Lovelece ? da ich eher weniger skript erfahung habe denke ich am ende muss VIS + Lovelece haben -
HA geht mit den Sachen ganz anders um.
Da sind die Integration (deren Adapter) schon so geschrieben, dass das alles funktioniert.Iobroker hatte diesen Ansatz früher noch nicht. So weit ich weiß, wird da aber dran gearbeitet.
Heating Control nutze ich nicht. Aber das hat ja auch nichts mit einer Visualisierung zu tun.
Ich denke, man sollte sich für eins entscheiden. Vis oder lovelace (oder sonst was).
@david-g ach so ok, ja ich habe das heute früh probiert,
also loveless + HA macht das wirklich alles automatisch das ist wirklich crazy, alles zwave geräte sind schon da und sogar auf dashboard. die haben das wirklich gut gemacht aber mit VIS1/2 kann man besser personalisieren (finde ich)
ich will nur ein bisschen beide probieren
