    4. neue Visualisierung "webui" (alternative zu vis & vis-2)
    • Smilie108
      Smilie108 last edited by Smilie108
      @jogibear9988
      mhm habe eigentlich nur an objekten gearbeitet und an javascrips im javascript adapter
      seit kurzen bekomme ich
      ost.server02
      	2024-04-19 22:36:34.744	info	Restart adapter system.adapter.webui.0 because enabled
      host.server02
      	2024-04-19 22:36:34.744	error	instance system.adapter.webui.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: Node.js v18.20.2
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: at async handleMainPromise (node:internal/modules/run_main:106:12)
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: at async loadESM (node:internal/process/esm_loader:34:7)
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: at async ModuleLoader.import (node:internal/modules/esm/loader:337:24)
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: at async ModuleJob.run (node:internal/modules/esm/module_job:191:5)
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: at ModuleJob._instantiate (node:internal/modules/esm/module_job:123:21)
      host.server02
      	2024-04-19 22:36:34.744	error	Caught by controller[0]: SyntaxError: The requested module '@iobroker/adapter-core' does not provide an export named 'default'
      host.server02
      	2024-04-19 22:36:34.743	error	Caught by controller[0]: ^^^^^
      host.server02
      	2024-04-19 22:36:34.743	error	Caught by controller[0]: import utils from '@iobroker/adapter-core';
      host.server02
      	2024-04-19 22:36:34.743	error	Caught by controller[0]: file:///opt/iobroker/node_modules/iobroker.webui/dist/backend/main.js:1
      host.server02
      	2024-04-19 22:36:34.652	info	instance system.adapter.webui.0 started with pid 1818
      Kannst du dir darauf einen reim machen ?
      werd mal paallel noch testen ob ich irgendow an fehler hab
      Webui läuft aber ohne probleme runtime und editor
      • Smilie108
        @jogibear9988 mhm nochmal ne frage
        bekomme folgendes
        im editor
        Error occured, check console
        error parsing javascript - screenviewer - undefined
        in der console
        error parsing javascript - screenviewer - undefined SyntaxError: function statement requires a name IobrokerWebuiAppShell.js:321:12
            error http://192.168.1.173:8082/webui/dist/frontend/config/IobrokerWebuiAppShell.js:321
            assignAllScripts http://192.168.1.173:8082/webui/node_modules/@node-projects/web-component-designer-visualization-addons/dist/scripting/ScriptSystem.js:181
            loadScreenData http://192.168.1.173:8082/webui/dist/frontend/runtime/ScreenViewer.js:92
            provideDemo http://192.168.1.173:8082/webui/dist/frontend/services/IobrokerWebuiDemoProviderService.js:18
            display http://192.168.1.173:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/widgets/demoView/demoView.js:69
            ready http://192.168.1.173:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/documentContainer.js:237
            emit http://192.168.1.173:8082/webui/node_modules/@node-projects/base-custom-webcomponent/dist/TypedEvent.js:35
            _selectedIndexChanged http://192.168.1.173:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/controls/DesignerTabControl.js:232
            onpointerdown http://192.168.1.173:8082/webui/node_modules/@node-projects/web-component-designer/dist/elements/controls/DesignerTabControl.js:197
        Wie komme ich da nun drauf was falsch ist ?
        hab das mal bei dir unter smilie108 elektrische schaltsteckdosen abgelegt / die popups funktionieren
        Smilie108 1 Reply Last reply Reply Quote 0
        • Smilie108
          Smilie108 @Smilie108 last edited by Smilie108
          @jogibear9988 mhm habe jetzt nochmal eine neue vm aufgesetzt mit geleichem ergebniss. bekomme das nicht mehr störungsfrei naja laufen tuts ja mal derweil nur das rote bzw die fehlermeldungen sind irritierend
          wollte nach neuinstall von webui das wired installieren dann sagt webui aber 3c59b18b-0380-4934-89b3-4e6b8dd1cfb3-grafik.png
          • Smilie108
            @jogibear9988 LACH mit der neuen 1.4.8 scheit wieder alles in Ordnung 😉 habe ich zuviel upgedatet ? war ich zu neu ?
            jogibear9988 1 Reply Last reply Reply Quote 0
            • jogibear9988
              jogibear9988 @Smilie108 last edited by
              @smilie108 said in neue Visualisierung "webui" (alternative zu vis & vis-2):
              In iobroker wurde etwas umgebaut wegen ESM modulen und compact mode. Vlt. waren teile davon schon veröffentlicht?
              Ich habe in der neusten version patches von jemand übernommen.
              D.h. alle probleme gelöst?
              • jogibear9988
                jogibear9988 last edited by
                Wenn du die wired elmente aktualisierst, sollte nun auch die value property für das input feld da sein:
                Allerdings musst du das event immer noch selbst eintragen:
                • Smilie108
                  @jogibear9988 ja läuft wieder einwandfrei 😉 Danke vielmals 😉 und auch danke wegen wired. 😉
                  • jogibear9988
                    Auch eine ganz frische installation sollte nun wieder funktionieren.
                    Es waren 2 Dateien nicht im NPM Paket eingebunden.
                    • jogibear9988
                      So, gibt ein kleines Update, hab die 2-way bindings vereinfacht, wenn man einen event namen hinzufügt, wird dieser mit "::eventname" im html code gespeichert, so muss man dazu noch kein json verwenden
                      • jogibear9988
                        Achso, und vlt. hat ja jemand noch ein bisschen was in webui realisiert, dann postet doch hier mal screenshots: https://forum.iobroker.net/topic/72159/zeigt-her-eure-webui-visualisierung
                        • Smilie108
                          Smilie108 @jogibear9988 last edited by
                          @jogibear9988 😉 bin ja grad dabei alles umzustellen 😉 aber zuerst mss oder bin ich noch dabei den Unterbau (iobroker) umzubauen ohne nod-red und ohne s7 steuerung alles in script und via netzwerk 😉 danach bau ich die Visu um dann gibts was neues 😉
                          aber danke im voraus für all deine Leistung
                          Mfg
                          • Smilie108
                            @jogibear9988 kannst du mir eventuell weiterhelfen. habe unter smilie108/start einen screen drinn bei dir am test.
                            habe für den Radioplayer derzeit ein zentrales script laufen das manchmal auch nützlich ist wenn überall die gleiche musik laufen soll. Würde aber gerne als 2.te variante das ganze gerne mal so machen das es "lokal" funktioniert. (das er die ausgewählet ( selected) Url in den player übernimmt. Geht sowas auch ??
                            habe eigentlich :
                            var radioplaylist1 = "0_userdata.0.Multimedia.Radio_Webui.radiosenderauswahl_topplay";
                            var urlpalyer = "0_userdata.0.Multimedia.Radio_Webui.radiosender_top_aktiv_play";
                            var playstatus = "0_userdata.0.Multimedia.Radio_Webui.radisender_top_stopplay";
                            var changesArray3 = [radioplaylist1];
                            on({ id: changesArray3, change: "any" }, function (obj) {
                                var newplay = getState(radioplaylist1).val;
                                var oldplay = getState(urlpalyer).val;
                                if ( newplay || oldplay ) {
                                    setState(playstatus, false);
                              setTimeout(function(){
                                    setState(urlpalyer, newplay);
                                    }, 1000);
                                    setState(playstatus, true);
                                    }, 3000);
                                    }, 5000);
                            else {}
                            Das hier als script laufen wenn url geändert wird dann player stop url tauschen und player start. Allerdings ändert er das für alle da es "global wirkt".
                            Stehe dazu grad auf dem schlauch wie ich das local im browser machen kann es gibt ja keine Session oder sowas wo man sessions variabel setzen könnte oder liege ich da falsch ? wollte das dann via benutzererkennung machen aber das ist auch nicht so einfach weil im ws sehe ich zwar wieviele instanzen offen sind aber die werden alle als noname bezeichnet.
                            kannst du mir da weiterhelfen ? Ein fettes danke im voraus.
                            Und ja installation teste ich voraussichtlich heute noch da ich noch für einen freund eine maschiene aufsetze 😉
                            • jogibear9988
                              du kannst lokale variablen in webui direkt nutzen, wenn sie mit "local_" anfangen. Diese kannst du aber nicht von deinem backendscript beschreiben. Aber du kannst ja in webui dann ein script anlegen, mit blockly oder javascript das deine 3 variablen nacheinander beschreibt
                              • jogibear9988
                                • jogibear9988
                                  Ich hab das "metro-ui" paket mal entfernt. Ist mir eig. zu groß und ich nutze fast nix davon, UI sieht nun so aus:
                                  • jogibear9988
                                    Den rest der optionen hab ich ins contextmenu gepackt:
                                    • Smilie108
                                      @jogibear9988 Super danke dir das past genau so 😉 und das mit menü ist auch super dann bleibt mehr platz für editor 🙂
                                      • jogibear9988
                                        So, kleines neues feature:
                                        Wenn Ihr im Styles TAB auf die überschriften klickt, springt ihr im Styleditor direkt an die stelle wo er definiert ist.
                                        Werd das noch ein bisschen erweitern, das man jede CSS declaration anklicken kann und man springt dann zum style, entweder im style window, oder wenn er inline definiert ist, in das style element, das kommt aber erst noch.
                                        • jogibear9988
                                          jogibear9988 last edited by jogibear9988
                                          So, also nun gibt es "jump to declaration" wenn ein wert vom stylesheet oder einem style tag gesetzt wird.
                                          Wenn es in einem inline style gesetzt wird, switche ich auf den split view (wenn man im design view ist) und selektiere dann die css deklaration.
                                          • jogibear9988
                                            Noch 2 kleine Neuerungen:
                                            Expand/Collapse der Kinder im TreeView:
                                            Undock aller Fenster: (bswp. des Stylesheets)
                                            1100
                                            333554
