    4. Iobroker startet nicht mehr! SD voll
      Bill S. Preston @Homoran last edited by
      @homoran said in Iobroker startet nicht mehr! SD voll:
      sudo ncdu
      pi@iobroker:~ $ sudo ncdu
      ncdu 1.13 ~ Use the arrow keys to navigate, press ? for help
      --- /home/pi -----------------------------------------------------------------------------------------------------------------------------------------------------------
          4,5 GiB [##########] /.config
          1,4 GiB [###       ] /.cache
        430,6 MiB [          ] /grafana-10.1.5
        121,7 MiB [          ] /.npm
        110,4 MiB [          ]  grafana-enterprise-10.1.5.linux-amd64.tar.gz
        102,1 MiB [          ]  grafana-enterprise_10.1.5_amd64.deb
         59,3 MiB [          ] /node_modules
         32,9 MiB [          ]  grafana-rpi_6.6.1_armhf.deb
         26,4 MiB [          ] /.mozilla
         24,0 MiB [          ] /Bookshelf
          1,0 MiB [          ] /.anydesk
        276,0 KiB [          ]  pi_stretch_motion_4.1.1-1_armhf.deb
        196,0 KiB [          ]  package-lock.json
        164,0 KiB [          ] /.claws-mail
        160,0 KiB [          ] /Downloads
        160,0 KiB [          ] /.local
         92,0 KiB [          ] /.pp_backup
         76,0 KiB [          ] /.pki
         44,0 KiB [          ] /iobroker-data
         32,0 KiB [          ] /Mail
         32,0 KiB [          ]  .bash_history
         20,0 KiB [          ] /Desktop
         16,0 KiB [          ]  raspiBackupInstallUI.log
         12,0 KiB [          ] /.thumbnails
         12,0 KiB [          ]  .xscreensaver
         12,0 KiB [          ] /.dbus
         12,0 KiB [          ] /.iobroker
          8,0 KiB [          ] /Videos
          8,0 KiB [          ] /.gnupg
          8,0 KiB [          ]  reinstall.js
      e   4,0 KiB [          ] /onedrive
      e   4,0 KiB [          ] /log
      e   4,0 KiB [          ] /Templates
      e   4,0 KiB [          ] /Public
      e   4,0 KiB [          ] /Pictures
      e   4,0 KiB [          ] /Music
      e   4,0 KiB [          ] /Documents
          4,0 KiB [          ]  .bashrc
          4,0 KiB [          ]  .profile
          4,0 KiB [          ]  .influx_history
       Total disk usage:   6,9 GiB  Apparent size:   6,8 GiB  Items: 528293
        Bill S. Preston @haus-automatisierung last edited by
        Habe auch noch das Programm "Raspberry Backup" drauf.
        Das Erstellt jeden Sonntag ein komplettes Backup des Systems und speichert es auf einem gemountetem USB-Stick
          Homoran Global Moderator Administrators @Bill S. Preston last edited by
          @bill-s-preston sagte in Iobroker startet nicht mehr! SD voll:
          was ist denn das??
          was stimnt denn jetzt?
          /dev/root 59G 56G 0 100% /
            Wenn ich
            df -h
            eingebe kommt:
            pi@iobroker:~ $ df -h
            Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
            devtmpfs        1,8G       0  1,8G    0% /dev
            tmpfs           1,9G     92K  1,9G    1% /dev/shm
            tmpfs           1,9G     65M  1,9G    4% /run
            tmpfs           5,0M    4,0K  5,0M    1% /run/lock
            tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
            /dev/mmcblk0p1  253M     49M  204M   20% /boot
            tmpfs           384M       0  384M    0% /run/user/1000
            tmpfs           384M       0  384M    0% /run/user/109
            Wenn ich:
            sudo ncdu
            eingebe kommt:
              121,7 MiB [          ] /.npm
               76,0 KiB [          ] /.pki
               32,0 KiB [          ] /Mail
               12,0 KiB [          ] /.dbus
                8,0 KiB [          ] /Videos
                8,0 KiB [          ] /.gnupg
            e   4,0 KiB [          ] /log
                4,0 KiB [          ]  .bashrc
            Keine Ahnung was da los ist Leute
            crunchip Homoran 2 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active @Bill S. Preston last edited by
              @bill-s-preston du bist bei ncdu im home Verzeichnis
                Homoran Global Moderator Administrators @Bill S. Preston last edited by Homoran
                --- /home/pi ---
                @crunchip
                Adlerauge
                @bill-s-preston
                cd /
                sudo ncdu
                  Sh..it
                  Sorry Leute.
                  Hatte den USB-Stick nicht drinnen bei den Befehlen.
                  Jetzt nochmal alles mit dem Backup-Stick...
                  tmpfs           1,9G     17M  1,9G    1% /run
                  /dev/sda1        57G     27G   28G   49% /backup
                    121,7 MiB [          ] /.npm
                     76,0 KiB [          ] /.pki
                     32,0 KiB [          ] /Mail
                    Ich hab den zwar vermisst, ist aber "irrelevant"
                    siehe die letzten 2 Posts
                      Bill S. Preston @Homoran last edited by Bill S. Preston
                      cd /
                      sudo ncdu
                      Läuft durch. Ausgabe kommt gleich... dauert jetzt etwas
                        Bill S. Preston @Bill S. Preston last edited by
                        @bill-s-preston said in Iobroker startet nicht mehr! SD voll:
                        cd /
                        sudo ncdu
                        Es scheint so, als würde jetzt der Backup-Stick gescant werden und das dauert ewig.
                        Kann ich den entfernen für den Befehl?
                          könntest du, allerdings läuft ja die aktuelle Abfrage, also, warte einfach
                            ich hoffe das ist nicht die OS Version!
                              --- /home/pi ---
                              @crunchip
                              Adlerauge
                              @bill-s-preston
                              cd /
                              sudo ncdu
                              pi@iobroker:/ $ sudo ncdu
                                 37,1 GiB [##########] /var
                                 26,0 GiB [#######   ] /backup
                                  8,0 GiB [##        ] /home
                                  5,0 GiB [#         ] /opt
                                  4,7 GiB [#         ] /usr
                                477,8 MiB [          ] /lib
                                 48,2 MiB [          ] /boot
                                 24,6 MiB [          ] /run
                                 22,4 MiB [          ] /root
                                 10,3 MiB [          ] /sbin
                                  9,4 MiB [          ] /bin
                                  8,6 MiB [          ] /etc
                                 76,0 KiB [          ]  raspiBackup.log
                                 76,0 KiB [          ] /dev
                                 48,0 KiB [          ] /tmp
                                 20,0 KiB [          ] /pi
                                 16,0 KiB [          ] /media
                              e  16,0 KiB [          ] /lost+found
                                 12,0 KiB [          ] /srv
                                  8,0 KiB [          ] /mnt
                                  0,0   B [          ] /sys
                               Total disk usage:  81,4 GiB  Apparent size:  81,4 GiB  Items: 4909899
                                und wenn? 😵
                                Wie finden wir das raus?
                                • haus-automatisierung
                                  haus-automatisierung Developer Most Active @Bill S. Preston last edited by
                                  lsb_release -a
                                    @bill-s-preston var dürften logs sein und was ist in backup drin?
                                    klapp die mal auf.
                                    Da wird schon was zum löschen zu finden sein.
                                      @haus-automatisierung said in Iobroker startet nicht mehr! SD voll:
                                      lsb_release -a
                                      pi@iobroker:/ $ lsb_release -a
                                      No LSB modules are available.
                                      Distributor ID: Raspbian
                                      Description:    Raspbian GNU/Linux 10 (buster)
                                      Release:        10
                                      Codename:       buster
                                      Homoran haus-automatisierung 2 Replies Last reply Reply Quote 0
                                        klapp die mal auf.
                                        "Backup" wird der gemountete USB Stick sein denke ich
                                          @bill-s-preston nicht ganz so alt, aber auch schon tot!
                                          aber erst mal Platz schaffen, dann neu aufbauen
                                            haus-automatisierung Developer Most Active @Bill S. Preston last edited by haus-automatisierung
                                            @bill-s-preston Wäre eventuell ein guter Zeitpunkt das System mal komplett neu aufzusetzen.
                                            Mit Debian 12 (Bookworm), 64-Bit und mal ohne Desktop-Umgebung 🙃
                                            Denke mal die Daten in var sind von der InfluxDB. Keine Retention Time festgelegt?
                                            Homoran 1 Reply Last reply Reply Quote 2
                                            1776
