    4. <gelöst> Serieller Port defekt
      searcher57 @Homoran last edited by
      @homoran ```
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: Raspi42GB
             Icon name: computer
                Kernel: Linux 6.6.28+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       20:32:33 up  2:40,  2 users,  load average: 0.13, 0.09, 0.09
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-04-29 20:32:33 CEST
                 Universal time: Mon 2024-04-29 18:32:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.2G        978M        6.3G        1.2M        1.0G        7.2G
      Swap:           104M          0B        104M
      Total:          8.3G        978M        6.4G
               7810 M total memory
                933 M used memory
                940 M active memory
                700 M inactive memory
               6042 M free memory
                 53 M buffer memory
                903 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     782M  1.2M  780M   1% /run
      /dev/mmcblk0p2 ext4       59G  3.3G   52G   6% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      /dev/sda1      exfat      29G   29M   29G   1% /mnt/usb0
      tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
      [Mon Apr 29 17:52:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:43:B6:26 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=d1e7c568-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Apr 29 17:52:10 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Mon Apr 29 17:52:12 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      |-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/mnt/usb0      /dev/sda1      exfat  rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
      /var:
      538M    /var/
      205M    /var/cache
      199M    /var/cache/apt
      173M    /var/lib
      141M    /var/lib/apt/lists
      Archived and active journals take up 60.0M in the file system.
      /opt/iobroker/backups:
      1.6M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      107M    /opt/iobroker/iobroker-data/
      77M     /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      37M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      6.4M    /opt/iobroker/iobroker-data/states.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/objects.jsonl
      6.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : Raspi42GB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : Raspi42GB                                -  enabled
      + system.adapter.discovery.0              : discovery             : Raspi42GB                                -  enabled
      + system.adapter.javascript.0             : javascript            : Raspi42GB                                -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : Raspi42GB                                -  enabled
      + system.adapter.shelly.0                 : shelly                : Raspi42GB                                -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartmeter.0             : smartmeter            : Raspi42GB                                -  enabled
        system.adapter.telegram.0               : telegram              : Raspi42GB                                - disabled, port: 8443, bind: 0.0.0.0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "shelly"       : 6.9.0    , installed 6.9.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Objects and States
      Objects:        1023
      States:         676
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4734       694/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4744       694/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5893       701/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5904       701/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       680        781/io.admin.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4652       557/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       6931       1094/io.shelly.0
      udp        0      0 0.0.0.0:43046           0.0.0.0:*                           1001       7414       1094/io.shelly.0
      udp        0      0 0.0.0.0:49027           0.0.0.0:*                           104        4654       557/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        4653       557/avahi-daemon: r
      udp6       0      0 :::39625                :::*                                104        4655       557/avahi-daemon: r
      2024-04-29 20:30:00.035  - info: javascript.0 (1228) script.js.Haushalt.Strom.Verbrauch.Shelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 0
      2024-04-29 20:30:27.300  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /dev/mmcblk0p2  60819080 3435724  54275028    6% /
      /1024
      2024-04-29 20:30:27.302  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /1024
      2024-04-29 20:31:27.305  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /dev/mmcblk0p2  60819080 3435752  54275000    6% /
      /1024
      2024-04-29 20:31:27.306  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /1024
      2024-04-29 20:32:27.299  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /dev/mmcblk0p2  60819080 3435800  54274952    6% /
      /1024
      2024-04-29 20:32:27.301  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /1024
      2024-04-29 20:33:27.262  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /dev/mmcblk0p2  60819080 3324276  54386476    6% /
      /1024
      2024-04-29 20:33:27.263  - error: rpi2.0 (2260) Cannot evaluate: Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /1024
        Homoran Global Moderator Administrators @searcher57 last edited by
        @searcher57 sagte in <gelöst> Serieller Port defekt:
        bookworm
        seltsam, weil
        @laser sagte in <gelöst> Serieller Port defekt:
        der Adapter RPI2.0 kann die GPIO nicht mehr lesen und schreiben. Auch beim Raspi4.
          Thomas Braun Most Active @searcher57 last edited by Thomas Braun
          @searcher57
          Ob/wie das funktioniert kann ich mangels Hardware an den GPIOs nicht verifizieren. Aber die Dateien werden zumindest angelegt:
          echad@chet:~ $ ls -la /dev/gpio*
          crw-rw---- 1 root gpio 254, 0 Apr 29 19:12 /dev/gpiochip0
          crw-rw---- 1 root gpio 254, 1 Apr 29 19:12 /dev/gpiochip1
          crw-rw---- 1 root gpio 238, 0 Apr 29 19:12 /dev/gpiomem
          echad@chet:~ $
          Die user müssen dann hier noch in die Gruppe 'gpio' gepackt werden, falls nicht schon ohnehin drin.
            @homoran Ja, das habe ich doch geschrieben! Die serielle funktioniert, aber RPI2 nicht.
              searcher57 @Thomas Braun last edited by
              @thomas-braun said in <gelöst> Serieller Port defekt:
              Die user müssen dann hier noch in die Gruppe 'gpio' gepackt werden.
              Ok, wie macht man das?
                Erst schauen, ob das überhaupt erforderlich ist.
                sudo -u iobroker id
                Bei mir war das alles schon richtig.
                  Homoran Global Moderator Administrators @searcher57 last edited by Homoran
                  aber @Laser meint dass es auch am 4er nicht klappt.
                  oder wird hier Lesekopf und restliche GPIOs wild durcheinander gewürfelt?
                  Dieser Thread bezieht sich auf TTY Leseköpfe
                    sudo -u iobroker id
                    pi@Raspi42GB:~ $ sudo -u iobroker id
                    uid=1001(iobroker) gid=1001(iobroker) Gruppen=1001(iobroker),5(tty),20(dialout),29(audio),44(video),109(bluetooth),993(gpio),994(i2c)
                      993(gpio)
                      Alles okay, der user iobroker ist in der Gruppe drin.
                        Ich hoffe, dass ich mich richtig ausdrücke.
                        1. Der Stromzähler ist bei mir an GPIO14/15 und 3,3V/0V angeschlossen, nachdem ich die serielle Schnittstelle in der Konsole aktiviert habe.
                        2. Der Gaszähler ist an GPIO22 und +3,3V angeschlossen und funktioniert seit geschätzten 3 Wochen ohne Grund nicht mehr.
                          @searcher57 dann solltest du für den rpi2 einen getrennten Thread aufmachen.
                          Diese GPIOs haben nichts mit dem seriellen Port zu tun.
                          Und genau darum geht es in diesem Thread. So steht es auch im Threadtitel
                          und bitte in diesem Thread diese beiden unterschiedlichen Themen nicht vermischen!
                            searcher57 @Homoran last edited by searcher57
                            Ok, habe ich verstanden. Aber ich habe seit einigen Tagen nur noch Probleme und werfe dadurch einiges durcheinander.
                            Das Problem RPI2 wird wohl nur durch den Entwickler gelöst, leider...!
                              und der braucht dafür strukturiert Informationen, so wie z.B @Thomas-Braun sie hier zusammenträgt.
                              Thomas Braun S 2 Replies Last reply Reply Quote 0
                                @homoran sagte in <gelöst> Serieller Port defekt:
                                Ist aber nur mutmaßen, da ich wie gesagt nix an den GPIOs hängen habe und deswegen da nix testen kann.
                                  Dann danke ich Euch beiden und hoffe, dass es irgendwann eine Lösung gibt!👍 👍
                                    Faxnummer und ich faxe Dir mein PI4 mit Anschlüssen rüber!😁
                                      Entschuldige, wenn ich Dir hier antworte, denn ich weiß nicht, ob das woanders hingehört? Langsam verliere ich die Lust den Befehl: "sudo apt full-upgrade" auszuführen. Denn sehr oft funktionieren anschließend einige Adapter nicht mehr. Siehe heute der smartmeter-Adapter (Auslesen des Stromzählers). Ich warte bis heute auf eine Lösung des rpi2.0 Adapters (Auslesen des Gaszählers). Diese haben monatelang hervorragend funktioniert, aber durch ein regelmäßiges "sudo apt full-upgrade" zerstört man sich ein lauffähiges System! Hoffentlich werde ich nicht gleich wieder von den "Devolepern" an den Pranger gestellt, wie in der Vergangenheit. Wenn das hier nicht der richtige Platz für eine Kritik ist, dann nenne mir doch bitte diesen.
                                        Kurze Antwort:
                                        Quatsch.
                                        S 2 Replies Last reply Reply Quote 1
                                          Kurze Antwort:
                                          Quatsch.
                                          Danke!
                                            Kurze Antwort:
                                            Quatsch.
                                            Das sind die Antworten, die ich in einem Forum erwarte!👍
                                            Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                            362
                                            44593
