    4. S0 Stromzähler umrechnen in aktuelle Verbrauch
      Kev0 @paul53 last edited by
      Muss das hier nochmal aufwärmen, leider scheint die Rechnung falsch zu sein. Es kommen keine passenden Werte raus.
      Hier meine Lösung:
        <variables>
          <variable id="AP1}0!{NwZLxuu@pAF`Z">Wert</variable>
        </variables>
        <block type="on_ext" id="W#4Ls_h_y|cwT?nCY/XR" x="-412" y="-313">
          <value name="OID0">
            <shadow type="field_oid" id="6cdwgAAgS+kz]!+7pnZ)">
              <field name="oid">mqtt.0.Stromzähler.Strom_S0.Time</field>
            <block type="variables_set" id="ogj^ePrs9*@jzEe:R6Km">
              <field name="VAR" id="AP1}0!{NwZLxuu@pAF`Z">Wert</field>
                <block type="math_arithmetic" id="]0M=(k9=r]sxV;nCRTAy">
                  <field name="OP">DIVIDE</field>
                    <shadow type="math_number" id="xc(2ROKN:buynD{lNw[n">
                      <field name="NUM">3600</field>
                    <shadow type="math_number" id="MNkY9Jf5t,f%Q11oIT(1">
                      <field name="NUM">1000</field>
                    <block type="math_arithmetic" id="lZpxQ[,}4+i]5FSu[+[~">
                        <shadow type="math_number" id="UtZ0GU2I6J.}oqT@qDRd">
                          <field name="NUM">0</field>
                        <block type="math_arithmetic" id="b6|Lt+;F9Oq9@:x(*bY9">
                            <shadow type="math_number" id="Qxvf80B#cQ+k.tWypY(2">
                              <field name="NUM">400</field>
                            <shadow type="math_number" id="MuNNnjw#(B-u]9gQSqeO">
                        <shadow type="math_number" id="I3xE42u.NAVO9Y)#f-}q">
                        <block type="math_arithmetic" id="t?g$@EnYr@L(lZzLa3M8">
                            <shadow type="math_number" id="n~NMy}8^69Ds0AgcZL(9">
                              <field name="NUM">1</field>
                            <block type="get_value" id="9)r@Tz4:V@|MA3p$Cqyo">
                              <field name="OID">mqtt.0.Stromzähler.Strom_S0.Time</field>
                            <shadow type="math_number" id="EKd;^a4yAI#3k#Dg0nJW">
                <block type="control" id="Zh:,x@fPl?!iX),z3z_y">
                  <field name="OID">0_userdata.0.Stromzähler.Leistung</field>
                    <block type="math_round" id="sjOp3d8^}jClP_0/9_]Y">
                      <field name="OP">ROUND</field>
                      <value name="NUM">
                        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number">
                          <field name="NUM">3.1</field>
                        <block type="variables_get" id="1_c0K2p^[!Yr.axi5F-e">
        <block type="comment" id="6OGtBrzv6fM;c;:x~bS7" x="-213" y="-262">
          <field name="COMMENT">h in s</field>
        <block type="comment" id="y=^bV{C~DBmN2AzM3bya" x="-87" y="-262">
          <field name="COMMENT">Impulse/kWh</field>
        <block type="comment" id="3(V2ODtu1Kr6+jE;5B{Z" x="38" y="-262">
          <field name="COMMENT">von kW in W</field>
        <block type="comment" id="DbtR1m)Y10ih/#v89g%N" x="287" y="-263">
          <field name="COMMENT">ms in s umrechnen</field>
        <block type="variables_get" id="OQ3o_4[OzW+,pD{vi7=Q" x="913" y="4263">
      • Elektroniker86
        Elektroniker86 last edited by
        ich weiß, das hier ist schon ziemlich alt aber benötige hier Hilfe.
        Und zwar funktioniert das Blockly leider nicht da mir der Datenpunkt "count" fehlt.
        Ich habe ein S0 Zählerimpuls an einem Eingang der LOGO hängen und schleife den direkt durch zu ioBroker wo ich im Blockly mir den Zählerstand hochzählen lasse.
        Es sollte doch möglich sein anhand diesem Wert die momentane Leistung zu berechnen in Blockly?
        Der ändert sich ja nach jedem neuen Impuls.
        Kann mir da jemand helfen?
        Vielen Dank im voraus!
          paul53 @Elektroniker86 last edited by paul53
          @elektroniker86 sagte: Zählerstand hochzählen lasse.
          Elektroniker86 1 Reply Last reply Reply Quote 1
          • Elektroniker86
            Elektroniker86 @paul53 last edited by Elektroniker86
            Hey, das ging ja mal wieder schnell.
            Ich habe derweil doch noch ein altes Thema gefunden mit einem passenden Blockly.
            Allerdings zeigt er mir 163W statt 1600W an was habe ich hier verkehrt?
              @elektroniker86 sagte: mit einem passenden Blockly.
              Ja, mit dem Impulsabstand kann man auch operieren.
              @elektroniker86 sagte in S0 Stromzähler umrechnen in aktuelle Verbrauch:
              Dann passt der Faktor nicht: 100 Impulse/kWh - nicht 1000.
              • Elektroniker86
                Alles klar, ich hab es. Auf dem Zähler steht ja 1000 Impulse/kWh.......
                Das ist für die LED gemeint.
                Der Ausgang taktet mit 100 Imp.
                Super, Du bist der beste!
                Dank Dir vielmals!
                • Elektroniker86
                  Eins noch, wie muss ich den Timer einbauen damit die Werte z.B nach 2 Minuten ohne Impuls wieder auf null gehen?
                  Vielen Dank im Vorraus!
                    @elektroniker86 sagte: wie muss ich den Timer einbauen damit die Werte z.B nach 2 Minuten ohne Impuls wieder auf null gehen?
                    Im Trigger (unten):
                    leovandavart 1 Reply Last reply Reply Quote 1
                    • leovandavart
                      leovandavart @paul53 last edited by
                      Schönen guten tag
                      Wollte einmal fragen ob es auch klappt wenn ich den S0 vom Zähler direkt an einen giop anschließe funktioniert da dieses Skript auch?
                        lumajo @GoodOld last edited by
                        @goodold said in S0 Stromzähler umrechnen in aktuelle Verbrauch:
                        Habe doch etwas gefunden.
                        viewtopic.php?f=21&t=16953&p=178154&hilit=s0#p178154
                        Eddy
                        Leider funktioniert der Link auch nicht mehr. Kann man das reparieren?
                          Homoran Global Moderator Administrators @lumajo last edited by Homoran
                          @lumajo sagte in S0 Stromzähler umrechnen in aktuelle Verbrauch:
                          der ist ja auch von 2018! Wahrscheinlich eh nicht mehr passend.
                          Wenn du einen Snapshot der damaligen Forensoftware hast und mir sagst, wie der Thread hieß, kann ich es mal versuchen
                          EDIT:
                          Weiterlesen!
                          Da hat @GoodOld das Skript mit Modifikationen gepostet
                          https://forum.iobroker.net/post/183614
                            paul53 @leovandavart last edited by paul53
                            @leovandavart sagte: wenn ich den S0 vom Zähler direkt an einen giop anschließe funktioniert da dieses Skript auch?
                            Wenn die kurzen Impulse in ioBroker ankommen und nicht prellen, sollte dieses Skript funktionieren:
                            • leovandavart
                              @paul53 ich hab das so abgebaut nur leider passiert da leider nix
                              gpio bringt dauerhaft true im objekt baum
                                Homoran Global Moderator Administrators @leovandavart last edited by
                                @leovandavart sagte in S0 Stromzähler umrechnen in aktuelle Verbrauch:
                                was für eine Hardware und was für ein OS?
                                Welcher GPIO und womit wird der augelesen?
                                leovandavart 1 Reply Last reply Reply Quote 0
                                • leovandavart
                                  leovandavart @Homoran last edited by
                                  rasberry pi 4 8gb nomrales rasberry os
                                  gpio 20
                                  stromzähler eltako dsz15d 3x80a wo die s0 schnitstelle raus kommt
                                    heisst in "Codenamen" wie?
                                    • leovandavart
                                      @homoran bookworm heißt es
                                        und due gpio willst du über den rpi2 Adapter auslesen?
                                        • leovandavart
                                          @homoran genau sollte ja eigendlich gehen oder gibt es eine andere möglichkeit
                                            Homoran Global Moderator Administrators @leovandavart last edited by Homoran
                                            nicht mehr unter bookworm. Dort werden neue Pakete verwendet.
                                            Dazu müsste der Adapter angepasst werden.
                                            66
                                            7757
