    4. Iobroker nicht mehr erreichbar
    • Sven Muthke
      Sven Muthke @Thomas Braun last edited by
      jetzt hates doch geklappt:
      ======= Start marking the full check here =========
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 400 Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       12:43:55 up 51 min,  2 users,  load average: 5.30, 5.43, 4.78
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-05-01 12:43:55 CEST
                 Universal time: Wed 2024-05-01 10:43:55 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        295M        2.6G        1.0M        925M        3.4G
      Swap:            99M          0B         99M
      Total:          3.9G        295M        2.7G
               3794 M total memory
                295 M used memory
                522 M active memory
                391 M inactive memory
               2572 M free memory
                145 M buffer memory
                780 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G   17G   12G  61% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [sudo] password for iobroker:
      [Wed May  1 11:51:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:3C:72:9F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e6bc09a5-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed May  1 11:51:58 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Wed May  1 11:51:58 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Wed May  1 11:51:59 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Wed May  1 11:51:59 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed May  1 11:51:59 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed May  1 11:52:01 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.1G    /var/
      1022M   /var/log
      897M    /var/log/journal/a6947f3f150d40ff92fc95ef6b744298
      612M    /var/cache
      Archived and active journals take up 896.0M in the file system.
      /opt/iobroker/backups:
      9.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      545M    /opt/iobroker/iobroker-data/
      383M    /opt/iobroker/iobroker-data/files
      102M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      71M     /opt/iobroker/iobroker-data/files/vis
      31M     /opt/iobroker/iobroker-data/states.jsonl
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      8.0M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      /usr/bin/corepack
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      /usr/bin/iobroker: line 12:  3450 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      Core adapters versions
      /usr/bin/iob: line 12:  3469 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      js-controller:
      /usr/bin/iob: line 12:  3498 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      admin:
      /usr/bin/iob: line 12:  3528 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      javascript:
      Adapters from github:   0
      Adapter State
      /usr/bin/iob: line 12:  3542 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      /usr/bin/iob: line 12:  3571 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      ioBroker-Repositories
      /usr/bin/iob: line 12:  3577 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      Installed ioBroker-Instances
      /usr/bin/iob: line 12:  3585 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      Objects and States
      Objects:        0
      States:         0
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
      Get:7 https://apt.grafana.com stable InRelease [7660 B]
      Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
      Err:7 https://apt.grafana.com stable InRelease
      Reading package lists...
      Pending Updates: 0
      [sudo] password for iobroker: *** Listening Ports ***
      Sorry, try again.
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12938      561/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        1710       429/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12940      561/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        20602      2872/grafana
      udp        0      0 0.0.0.0:56384           0.0.0.0:*                           108        12709      373/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12707      373/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14401      627/dhcpcd
      udp6       0      0 :::58098                :::*                                108        12710      373/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12708      373/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13014      627/dhcpcd
      2024-04-26 00:05:55.669  - info: web.0 (1569547) terminated http server on port 8082
      2024-04-26 00:05:55.669  - info: web.0 (1569547) terminating
      2024-04-26 00:05:55.670  - info: web.0 (1569547) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-26 00:06:11.955  - info: web.0 (1569547) terminating with timeout
      2024-04-26 00:05:15.267  - info: volvo.1 (1569537) Got terminate signal TERMINATE_YOURSELF
      2024-04-26 00:06:11.955  - info: volvo.1 (1569537) cleaned everything up...
      2024-04-26 00:06:11.957  - info: volvo.1 (1569537) terminating
      2024-04-26 00:06:20.177  - info: volvo.1 (1569537) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-26 00:06:21.685  - info: volvo.1 (1569537) terminating with timeout
      2024-04-26 00:05:15.150  - info: pollenflug.0 (1569386) Got terminate signal TERMINATE_YOURSELF
      2024-04-26 00:06:11.954  - info: pollenflug.0 (1569386) Closing Adapter
      2024-04-26 00:06:11.954  - info: pollenflug.0 (1569386) terminating
      2024-04-26 00:06:20.177  - info: pollenflug.0 (1569386) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-26 00:06:46.089  - info: pollenflug.0 (1569386) terminating with timeout
      2024-04-26 00:07:01.969  - error: roomba.0 (1569414) Objects database error: read ECONNRESET
      2024-04-26 00:07:01.990  - error: homeconnect.0 (1569254) Objects database error: read ECONNRESET
      2024-04-26 00:07:01.993  - warn: sonoff.0 (1568933) redis get sonoff.0.Stromverbrauch WP.alive, error - DB closed
      2024-04-26 00:07:02.006  - error: admin.0 (1568600) Objects database error: read ECONNRESET
      2024-04-26 00:07:02.044  - error: knx.0 (1569374) Objects database error: read ECONNRESET
      2024-04-26 00:07:10.079  - warn: javascript.0 (1569202) get state error: Connection is closed.
      2024-04-26 00:05:15.161  - info: terminal.0 (1569408) Got terminate signal TERMINATE_YOURSELF
      2024-04-26 00:06:28.386  - info: terminal.0 (1569408) terminated http server on port 8089
      2024-04-26 00:06:28.390  - info: terminal.0 (1569408) terminating
      2024-04-26 00:06:28.392  - info: terminal.0 (1569408) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-04-26 00:07:18.232  - info: terminal.0 (1569408) terminating with timeout
        Thomas Braun Most Active @Sven Muthke last edited by Thomas Braun
        @sven-muthke sagte in Iobroker nicht mehr erreichbar:
        Da ist was mit deinem Dateisystem nicht in Ordnung.
        Lokal vorgehaltene Backups sind nur sehr begrenzt sinnvoll. Immer nach extern auslagern.
        nodejs:
        Dein nodejs-(Repo) ist veraltet. Funktioniert
        iobroker nodejs-update
        noch?
        Dein Grafana-Repo (bzw. der Key dazu) ist veraltet. Leg das nochmal neu an.
        cat /usr/bin/iob
        sagt?
        Sven Muthke 1 Reply Last reply Reply Quote 0
          Wäre vielleicht eine gute Gelegenheit komplett NEU das Bookworm-Release auf die Kiste zu werfen.
          • Sven Muthke
            @thomas-braun said in Iobroker nicht mehr erreichbar:
            Vielen Dank.
            Ich bekomme folgende Meldung:
            sudo iobroker nodejs-update
            You should not use root directly on your system!
            Better use your standard user!
            ioBroker node-update v2023-10-13 is starting. Please be patient!
            /usr/bin/iobroker: line 12:  1995 Bus error               sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
            und dann kommt das:
            ioBroker nodejs updater 2023-10-13
            No recommendation for a nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
            Your current setup is:
            /usr/bin/nodejs
            cat /usr/bin/iob
            #!/usr/bin/bash
            if (( $# == 1 )) && ([ "$1" = "start" ] || [ "$1" = "stop" ] || [ "$1" = "restart" ]); then
            sudo systemctl $1 iobroker
            elif [ "$1" = "fix" ]; then
            curl -sL https://iobroker.net/fix.sh | bash -
            elif [ "$1" = "nodejs-update" ]; then
            sudo -u iobroker curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh && bash /home/iobroker/.nodejs-update.sh "$2"
            elif [ "$1" = "diag" ]; then
             sudo -u iobroker curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh && bash /home/iobroker/.diag.sh | sudo -u iobroker tee /home/iobroker/iob_diag.log
            else
            fi
            Wie kann ich das Backup da runter holen?
            VG Sven
            • Sven Muthke
              @thomas-braun Wie geht das und wie kann ich dann meine Daten wieder herstellen?
              Vielen Dank für die Hilfe!!!
              VG Sven
              • Sven Muthke
                wie kann ich herausfinden, on mein eigentlihcer Host noch läuft? Ich kann mich nur mit dem Iobroker Host einloggen, aber nicht mit meinem eigentlichen.
                  @sven-muthke
                  Und wo bitte stand, dass du das als root/per sudo machen sollst?
                  Pflügst du da immer mit sudo drüber?
                  Dann wundert es mich auch nicht, das die Kiste spinnt.
                  NIE NIE NIE als root anmelden und NIE NIE NIE den iobroker mit sudo anpacken.
                  ausführen.
                  Was meinst du mit 'eigentlichem Host' und 'iobroker Host'?
                  Sven Muthke 1 Reply Last reply Reply Quote 1
                  • Sven Muthke
                    Sorry dachte das muss mit rein.
                    hab es jetzt noch einmal gemacht, läuft aber immer noch nicht.
                    iobroker@iobroker:~ $ curl -sL https://iobroker.net/fix.sh | bash -
                    library: loaded
                    Library version=2024-01-04
                        Welcome to the ioBroker installation fixer!
                        Script version: 2024-01-04
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/5)
                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                    Get:7 https://apt.grafana.com stable InRelease [7,660 B]
                    Reading package lists... Done
                        Checking ioBroker user and directory permissions (2/5)
                    Fixing directory permissions...
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    main: line 14: [: -lt: unary operator expected
                    main: line 8:  3001 Bus error               ( sudo -H -u iobroker npm x --yes @iobroker/jsonltool@latest "$IOB_DIR/iobroker-data" )
                        Checking autostart (5/5)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    Ich hatte damals laut internet Anleitung das ganze auf iobroker@iobroker.local aufgesetzt, bekam dann aber den Hinweis, dass man das ciht macht. Dann habe ich neu installiert und Delapena@delapena.local genommen. Hatte damals auch geklappt, ist jetzt aber nicht mehr vorhanden, bzw. ich komme nur mit dem Login: iobroker und dann das Passwort rein bzw. ssh. Aber die Oberfläche ist nciht erreichbar.
                    Soll ich das neu installieren? Dann muss ich nur irgendiwe an mein lokales Backup kommen.
                    Ich bin leider echt überfragt.
                      Am besten. Wer weiß was da alles verfummelt worden ist.
                      Per SCP/filezilla oder einem anderen Filemanager, der sich auf SCP versteht.
                      • Sven Muthke
                        Dank Dir. Ich komme mit File Zilla nicht drauf. Ich habe das damals schon einmal geschafft, weiß aber nicht mehr wie ich das gemacht habe. IP Adresse vom Iobroker mit den Login daten funktoniert leider nicht.
                        Hast Du da nen Tip?
                        • Sven Muthke
                          Noch eine Frage, welche Version soll ich am besten installieren? Ohne Desktop wenn ich das richtig verstanden habe. 64 BIT?
                            Hast Du da nen Tip?
                            Schau im Router nach, welche IP da vergeben wurde. Oder verwende den hostname.
                            Installation:
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              Homoran Global Moderator Administrators @Sven Muthke last edited by
                              wo willst du genau hin?
                              welche Logindaten?
                              welcher User?
                              Hast du nach deiner exzessiven Nutzung von root/sudo die Rechte mit iob fix wieder geradegezogen?
                              • Sven Muthke
                                hab es neu installiert und per backup wieder hergestellt. Die meisten Adapter laufen noch nicht. Ich kann mich dunkel dran erinnern, dass das etwas dauert.
                                Muss ich Influx und Grafna neu installieren, oder sollte das über das Update passiernen? Influx sehe ich zumindest als Adapter.
                                Vielen Dank für Deine unermüdliche Hilfe!!!
                                VG Sven
                                  Ja, muss separat im Betriebssysytem installiert werden, das ist ja kein Bestandteil des ioBroker.
                                  Kann schon mal 'ne Stunde dauern. Beobachte das LogFile:
                                  iob logs --watch
                                  • Sven Muthke
                                    Dank Dir. Hast Du eine Anleitung zur Installation von Influx und Grafana bzw. passt diese hier:?
                                    wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                    source /etc/os-release
                                    echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                    Danach die Installation durchführen mit diesen beiden Befehlen:
                                    sudo apt-get update
                                    sudo apt-get install influxdb
                                    Und als letzten Schritt erst mal die Datenbank starten:
                                    sudo service influxdb start
                                    Ist diese nun gestartet, so können wir uns mit dem folgenden Befehl einfach diese öffnen:
                                    sudo influx
                                      @sven-muthke
                                      Die Anleitung mit apt-key ist veraltet, macht man nicht mehr so.
                                      Leg die entsprechenden Repos danach an:
                                      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                      Installation dann wie üblich über deinen Paketmanager:
                                      sudo apt update
                                      sudo apt install grafana influxdb (oder influxdb2)
                                      • Sven Muthke
                                        sudo apt install
                                        Hab beides installiert, aber komme mit meinen Login Daten nicht mehr rein. Gibt es da einen Trick, oder ist alles weg?
                                          Du meinst in grafana und influx?
                                          Kann ich dir nicht sagen, verwende weder das eine noch das andere.
                                          • Sven Muthke
                                            Alles klar. Vielen Dank für Deine Hilfe!!!!! Iobroker läuft jetzt wieder und die meinesten Daten sind da.
                                            Wie kann ich verhindern, dass der wieder aus heierem Himmel abstürzt?
                                            VG Sven
                                            Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                            1379
