Editor Oberfläche erscheint nicht
@sigi234
bei mir hat das nicht geholfen -
@faz3rs-adventures sagte in Editor Oberfläche erscheint nicht:
@sigi234
bei mir hat das nicht geholfenhttps mal ausschalten
@sigi234
HTTPS und Authentifikation ausgeschaltet aber immernoch dasselbe "Ladebild" -
@sigi234
HTTPS und Authentifikation ausgeschaltet aber immernoch dasselbe "Ladebild"Was kommt bei F12 in der Konsole?
@sigi234
Auf die Idee bin ich nich gekommeniobroker.vis-2@2.9.32 using theme "dark" Prompt.js:15 ██╗ ██████╗ ██████╗ ██████╗ ██████╗ ██╗ ██╗███████╗██████╗ ██║██╔═══██╗██╔══██╗██╔══██╗██╔═══██╗██║ ██╔╝██╔════╝██╔══██╗ ██║██║ ██║██████╔╝██████╔╝██║ ██║█████╔╝ █████╗ ██████╔╝ ██║██║ ██║██╔══██╗██╔══██╗██║ ██║██╔═██╗ ██╔══╝ ██╔══██╗ ██║╚██████╔╝██████╔╝██║ ██║╚██████╔╝██║ ██╗███████╗██║ ██║ ╚═╝ ╚═════╝ ╚═════╝ ╚═╝ ╚═╝ ╚═════╝ ╚═╝ ╚═╝╚══════╝╚═╝ ╚═╝ Prompt.js:16 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters Prompt.js:17 Help us to create open source project with reactJS! Prompt.js:18 See you :) socket.io.js:66 [2024-04-08T18:57:31.137Z] Try to connect console.ts:40 Sentry initialized console.ts:40 Cannot read project file "main/vis-views.json": Not exists (anonym) @ console.ts:40 1 weiteren Frame anzeigen Weniger anzeigen console.ts:40 TypeError: Cannot read properties of undefined (reading 'permissions') at _ (utils.tsx:224:45) at Runtime.jsx:920:123 at Array.map (<anonymous>) at Gt.showSmallProjectsDialog (Runtime.jsx:919:46) at Gt.render (App.jsx:1866:31) at Ls (react-dom.production.min.js:204:189) at bs (react-dom.production.min.js:203:149) at yi (react-dom.production.min.js:292:172) at xl (react-dom.production.min.js:280:389) at zl (react-dom.production.min.js:280:320) at gl (react-dom.production.min.js:280:180) at rl (react-dom.production.min.js:271:88) at ol (react-dom.production.min.js:268:429) at V (scheduler.production.min.js:13:203) at MessagePort.j (scheduler.production.min.js:14:128) (anonym) @ console.ts:40 1 weiteren Frame anzeigen Weniger anzeigen react-dom.production.min.js:283 Uncaught TypeError: Cannot read properties of undefined (reading 'permissions') at _ (utils.tsx:224:45) at Runtime.jsx:920:123 at Array.map (<anonymous>) at Gt.showSmallProjectsDialog (Runtime.jsx:919:46) at Gt.render (App.jsx:1866:31) at Ls (react-dom.production.min.js:204:189) at bs (react-dom.production.min.js:203:149) at yi (react-dom.production.min.js:292:172) at xl (react-dom.production.min.js:280:389) at zl (react-dom.production.min.js:280:320) at gl (react-dom.production.min.js:280:180) at rl (react-dom.production.min.js:271:88) at ol (react-dom.production.min.js:268:429) at V (scheduler.production.min.js:13:203) at MessagePort.j (scheduler.production.min.js:14:128) [NEW] Explain Console errors by using Copilot in Edge: click to explain an error. Learn more Don't show again
Wenn ich das richtig versteh wurde das nicht angelegt
Hab einen älteren Beitrag (2016) gefunden in dem Bluefox einen Fehler im js-controller als Ursache gfeunden hat. (damals beim Vis)
Könnte das auch daran liegen? -
@faz3rs-adventures
Habe heute nochmal rumexperimentiert und ich bekomme es nachwievor nicht zum laufen
Weiß jemand wie ich händisch die main/vis-view.json anlegen kann?
Läuft es mittlerweile bei dir @sigi234 ? -
@faz3rs-adventures
Erstelle mal ein neues Projekt mit einen anderen Namen.
Läuft es dann? -
@sigi234
so weit schaff ichs in der vis 2 garnicht
der bildschirm bleibt schwarz
hab in der vis ein projekt angelegt weil ich dachte ich kann das evtl in vis 2 integrieren bin aber auch da gescheitert -
liegt das ggf. daran:
using theme "dark"
@faz3rs-adventures Schau doch einmal hier, welche Projekte dort bei dir angelegt sind
Vis2 versucht das vis1 Projekt zu importieren und weiter zu verwenden. Lösche notfalls mal das/die Projekte unter dem vis-2 Ordner weg und schaue ob der Editor dann startet. -
@feuersturm
Der Main Ordner existierte nicht nach der neuinstallation
Jetzt habe ich alle Views und Projekte wieder
