    4. Nach Backup lässt iobroker nicht mehr starten
      djsirius last edited by
      ich habe eben das letzte Backup eingespielt. Leider funktioniert der iobroker nun nicht mehr.
      Kann mir jemand sagen, was ich machen kann?
      Den Fixer habe ich schon drüber laufen lassen, leider startet danach der iobroker immer noch nicht.
      Skript v.2024-04-21
      *** BASE SYSTEM ***
         Static hostname: debian
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-28-amd64
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:39:27 up 17 min,  1 user,  load average: 0.08, 0.18, 0.30
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2024-05-03 18:39:27 CEST
                 Universal time: Fri 2024-05-03 16:39:27 UTC
                       RTC time: Fri 2024-05-03 16:39:27
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        200M        6.5G        5.0M        1.1G        7.4G
      Swap:           4.0G          0B        4.0G
      Total:           11G        200M         10G
      Active iob-Instances:   0
               7864 M total memory
                200 M used memory
                502 M active memory
                548 M inactive memory
               6534 M free memory
                175 M buffer memory
                954 M swap cache
               4015 M total swap
                  0 M used swap
               4015 M free swap
      top - 18:39:27 up 17 min,  1 user,  load average: 0.08, 0.18, 0.30
      Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.6 us,  0.0 sy,  0.0 ni, 98.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7864.9 total,   6534.8 free,    200.3 used,   1129.8 buff/cache
      MiB Swap:   4016.0 total,   4016.0 free,      0.0 used.   7361.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * media-fritzbox.mount loaded failed failed /media/fritzbox
      * iobroker.service     loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     787M  2.5M  785M   1% /run
      /dev/sda2      ext4      454G   45G  386G  11% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/sda1      vfat      511M  5.8M  506M   2% /boot/efi
      tmpfs          tmpfs     787M   40K  787M   1% /run/user/1000
      [Fri May  3 18:22:03 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri May  3 18:22:10 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems:
      TARGET                        SOURCE     FSTYPE     OPTIONS
      /                             /dev/sda2  ext4       rw,relatime,errors=remount-ro
      |-/sys                        sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security      securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup            cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore            pstore     pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/firmware/efi/efivars efivarfs   efivarfs   rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf               none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/tracing       tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug         debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections  fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config        configfs   configfs   rw,nosuid,nodev,noexec,relatime
      |-/proc                       proc       proc       rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc  systemd-1  autofs     rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15049
      |-/dev                        udev       devtmpfs   rw,nosuid,relatime,size=3988540k,nr_inodes=997135,mode=755
      | |-/dev/pts                  devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                  tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/hugepages            hugetlbfs  hugetlbfs  rw,relatime,pagesize=2M
      | `-/dev/mqueue               mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
      |-/run                        tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=805368k,mode=755
      | |-/run/lock                 tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs           sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000            tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=805364k,nr_inodes=201341,mode=700,uid=1000,gid=1000
      `-/boot/efi                   /dev/sda1  vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      7.7G    /var/
      4.5G    /var/log
      4.2G    /var/log/journal/f063d3dd2a6e40efad76adb6a70d9daf
      2.5G    /var/cache/apt
      Archived and active journals take up 3.7G in the file system.
      /opt/iobroker/backups:
      279M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      850M    /opt/iobroker/iobroker-data/
      412M    /opt/iobroker/iobroker-data/files
      362M    /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      49M     /opt/iobroker/iobroker-data/files/vis.0
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      18M     /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
           18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
       *** 18.19.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1137
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.1
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.19.1
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.1
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.1
      javascript:
      nodejs modules from github:     0
      Adapter State
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.19.1
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.19.1
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://ftp.de.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:5 http://ftp.de.debian.org/debian bullseye-updates InRelease
      Hit:6 https://packages.sury.org/php bullseye InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 17
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15768      508/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12916      474/cupsd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13021      794/exim4
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          13062      802/smbd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          13063      802/smbd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1167       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15770      508/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12915      474/cupsd
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13022      794/exim4
      tcp6       0      0 :::443                  :::*                    LISTEN      0          15882      781/apache2
      tcp6       0      0 :::445                  :::*                    LISTEN      0          13060      802/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          13061      802/smbd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1171       1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          15878      781/apache2
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1168       1/init
      udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          15980      533/nmbd
      udp        0      0 192.168.1.16:137        0.0.0.0:*                           0          15979      533/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15960      533/nmbd
      udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          15982      533/nmbd
      udp        0      0 192.168.1.16:138        0.0.0.0:*                           0          15981      533/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15961      533/nmbd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17660      513/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        16652      438/avahi-daemon: r
      udp        0      0 0.0.0.0:38124           0.0.0.0:*                           112        16654      438/avahi-daemon: r
      udp6       0      0 :::43853                :::*                                112        16655      438/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          1174       1/init
      udp6       0      0 fe80::ca9c:dcff:fee:546 :::*                                0          17673      441/NetworkManager
      udp6       0      0 :::5353                 :::*                                112        16653      438/avahi-daemon: r
      2024-05-03 18:21:22.238  - info: host.debian stopInstance system.adapter.trashschedule.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.upnp.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.viessmannapi.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-bars.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-colorpicker.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-fancyswitch.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-history.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
      2024-05-03 18:21:22.239  - info: host.debian stopInstance system.adapter.vis-metro.0 (force=false, process=false)
      2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis-plumb.0 (force=false, process=false)
      2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
      2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis-weather.0 (force=false, process=false)
      2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.vis.0 (force=false, process=false)
      2024-05-03 18:21:22.240  - info: host.debian stopInstance system.adapter.web.0 (force=false, process=false)
      2024-05-03 18:21:24.102  - info: history.0 (97309) Terminated (NO_ERROR): Without reason
      2024-05-03 18:21:28.943  - error: history.0 (97309) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-05-03 18:21:28.946  - warn: history.0 (97309) get state error: Connection is closed.
      2024-05-03 18:21:28.950  - info: history.0 (97309) terminating
      2024-05-03 18:21:33.937  - warn: history.0 (97309) get state error: Connection is closed.
      2024-05-03 18:21:33.938  - info: history.0 (97309) terminating
      2024-05-03 18:21:33.952  - error: history.0 (97309) Cannot find view "system" for search "instance" : Connection is closed.
      Vielen Dank!
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @djsirius last edited by
        @djsirius sagte in Nach Backup lässt iobroker nicht mehr starten:
        aber sicher nicht auf ein neu aufgesetztes Debian.
        Wahrscheinlich drüber gebügelt ?!
        Wenn Backitup dann auf ein frisches und aktuelles Bookworm 😉
          Thomas Braun Most Active @DJMarc75 last edited by
          @djmarc75 sagte in Nach Backup lässt iobroker nicht mehr starten:
          Und mit einem Standarduser, der nicht 'iobroker' heißt...
            djsirius @Thomas Braun last edited by
            @thomas-braun also soll ich erst Bookworm installieren und dann das Backup?
              Thomas Braun Most Active @djsirius last edited by
              @djsirius
              Patch die Kiste auf Stand.
              sudo apt update
              sudo apt full-upgrade
              dann
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                Thomas Braun Most Active @djsirius last edited by Thomas Braun
                Das wäre die gescheiteste Lösung. Bullseye läuft in wenigen Wochen eh aus.
                Und installier das System diesmal gleich von vorneherein ohne Desktop. Und mit einem Username ungleich 'iobroker'. Gibt doch so schöne Vornamen. Oder Forennicks...
                  @thomas-braun said in Nach Backup lässt iobroker nicht mehr starten:
                  Hab alles gemacht. Der iobroker war kurz erreichbar. Dann wieder nicht. 😞
                    Dann muss ich da wohl mal ran! 😞
                      @djsirius
                      Aktuelles
                      iob diag
                      Ich würde aber so oder so eine Neuinstallation von Debian 12 'Bookworm' empfehlen. Wenn du da ohnehin schon schraubst...
                        djsirius @djsirius last edited by
                        iobroker@debian:/opt/iobroker$ iobroker start all
                        code_texnode:internal/modules/cjs/loader:1143
                          throw err;
                        Error: Cannot find module '@iobroker/js-controller-cli'
                        Require stack:
                        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                            at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                            at Module._load (node:internal/modules/cjs/loader:981:27)
                            at Module.require (node:internal/modules/cjs/loader:1231:19)
                            at require (node:internal/modules/helpers:177:18)
                            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js:1:1)
                            at Module._compile (node:internal/modules/cjs/loader:1364:14)
                            at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                            at Module.load (node:internal/modules/cjs/loader:1203:32)
                            at Module._load (node:internal/modules/cjs/loader:1019:12)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma        in:128:12) {
                          requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js        ' ]
                        Node.js v18.20.2
                          Skript v.2024-04-21
                          *** BASE SYSTEM ***
                                     Chassis: desktop
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           19:09:15 up 47 min,  1 user,  load average: 0.28, 1.18, 0.95
                          CPU threads: 4
                                         Local time: Fri 2024-05-03 19:09:15 CEST
                                     Universal time: Fri 2024-05-03 17:09:15 UTC
                                           RTC time: Fri 2024-05-03 17:09:15
                                        NTP service: active
                                    RTC in local TZ: no
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            7.9G        225M        5.8G        5.0M        1.9G        7.3G
                          Swap:           4.0G          0B        4.0G
                          Total:           11G        225M        9.8G
                                   7864 M total memory
                                    225 M used memory
                                    892 M active memory
                                    868 M inactive memory
                                   5761 M free memory
                                    164 M buffer memory
                                   1713 M swap cache
                                   4015 M total swap
                                      0 M used swap
                                   4015 M free swap
                          top - 19:09:15 up 47 min,  1 user,  load average: 0.28, 1.18, 0.95
                          Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  1.6 sy,  1.6 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   7864.9 total,   5761.1 free,    225.1 used,   1878.7 buff/cache
                          MiB Swap:   4016.0 total,   4016.0 free,      0.0 used.   7336.6 avail Mem
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/sda2      ext4      454G   44G  387G  11% /
                          /var:
                          7.7G    /var/
                          4.5G    /var/log
                          2.5G    /var/cache/apt
                          USB-Devices by-id:
                          /usr/bin/nodejs         v18.20.2
                          /usr/bin/node           v18.20.2
                          /usr/bin/npm            10.5.0
                          /usr/bin/npx            10.5.0
                          /usr/bin/corepack       0.25.2
                          nodejs:
                            Installed: 18.20.2-1nodesource1
                            Version table:
                           *** 18.20.2-1nodesource1 1001
                          Errors in npm tree:
                          ioBroker Status
                            throw err;
                          Require stack:
                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                            requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
                          Node.js v18.20.2
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          js-controller:
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          admin:
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          javascript:
                          Adapter State
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                            throw err;
                          Require stack:
                          Node.js v18.20.2
                          Objects and States
                          Objects:        0
                          States:         0
                          Hit:1 http://ftp.de.debian.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:4 http://ftp.de.debian.org/debian bullseye-updates InRelease
                          Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Hit:7 https://packages.sury.org/php bullseye InRelease
                          Pending Updates: 0
                          2024-05-03 19:06:33.548  - info: telegram.0 (29653) Got terminate signal TERMINATE_YOURSELF
                          2024-05-03 19:06:33.553  - info: host.debian stopInstance system.adapter.javascript.0 send kill signal
                          2024-05-03 19:06:33.553  - info: host.debian stopInstance system.adapter.telegram.0 send kill signal
                          2024-05-03 19:06:33.553  - info: host.debian stopInstance system.adapter.backitup.0 send kill signal
                          2024-05-03 19:06:33.556  - info: javascript.0 (29556) Got terminate signal TERMINATE_YOURSELF
                          2024-05-03 19:06:33.564  - info: javascript.0 (29556) terminating
                          2024-05-03 19:06:33.565  - info: javascript.0 (29556) Terminated (NO_ERROR): Without reason
                          2024-05-03 19:06:33.594  - info: backitup.0 (29743) terminating
                          2024-05-03 19:06:33.596  - info: backitup.0 (29743) Terminated (NO_ERROR): Without reason
                          2024-05-03 19:06:34.016  - info: backitup.0 (29743) terminating
                          2024-05-03 19:06:34.018  - info: javascript.0 (29556) terminating
                          2024-05-03 19:06:34.025  - info: telegram.0 (29653) terminating
                          2024-05-03 19:06:34.026  - info: telegram.0 (29653) Terminated (NO_ERROR): Without reason
                          2024-05-03 19:06:34.186  - info: host.debian instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                          2024-05-03 19:06:34.276  - info: host.debian instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                          2024-05-03 19:06:34.539  - warn: host.debian startInstance cannot find adapter "feiertage@1.2.0". Try to install it... 1 attempt
                          2024-05-03 19:06:34.540  - info: host.debian iobroker install feiertage@1.2.0 using installedFrom
                          2024-05-03 19:06:34.609  - error: host.debian iobroker npm-install: node:internal/modules/cjs/loader:1143  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)    at Module._load (node:internal/modules/cjs/loader:981:27)    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)    at node:internal/main/run_main_module:28:49 {  code: 'MODULE_NOT_FOUND',  requireStack: []}Node.js v18.20.2
                          2024-05-03 19:06:34.610  - info: host.debian iobroker npm-install: exit 1
                          2024-05-03 19:06:34.629  - info: host.debian instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
                          2024-05-03 19:06:35.424  - info: history.0 (29452) terminating
                          2024-05-03 19:06:35.425  - info: history.0 (29452) Terminated (NO_ERROR): Without reason
                          2024-05-03 19:06:36.018  - info: host.debian instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                          2024-05-03 19:06:36.018  - info: host.debian All instances are stopped.
                          2024-05-03 19:06:36.196  - info: host.debian terminated
                            @djsirius
                            systemctl status iobroker.service
                            sagt?
                              iobroker@debian:/opt/iobroker$ systemctl status iobroker.service
                              ● iobroker.service - ioBroker Server
                                   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                                   Active: activating (auto-restart) (Result: exit-code) since Fri 2024-05-03 19:23:41 CEST; 1s ago
                                     Docs: http://iobroker.net
                                  Process: 35747 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                                 Main PID: 35747 (code=exited, status=1/FAILURE)
                                      CPU: 56ms
                              Mai 03 19:23:44 debian bash[35757]: /opt/iobroker/node_modules/iobroker.js-controller/build/main.js:1200
                              Mai 03 19:23:44 debian bash[35757]:                     logger.error(`${hostLogPrefix} Invalid versions: ${(_j = (_h = (_g = a === null || a === void 0 ? void 0 : a.value) === null || _g =>
                              Mai 03 19:23:44 debian bash[35757]:        >
                              Mai 03 19:23:44 debian bash[35757]: SyntaxError: Unexpected end of input
                              Mai 03 19:23:44 debian bash[35757]:     at internalCompileFunction (node:internal/vm:76:18)
                              Mai 03 19:23:44 debian bash[35757]:     at wrapSafe (node:internal/modules/cjs/loader:1283:20)
                              Mai 03 19:23:44 debian bash[35757]:     at Module._compile (node:internal/modules/cjs/loader:1328:27)
                              Mai 03 19:23:44 debian bash[35757]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                              Mai 03 19:23:44 debian bash[35757]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                              Mai 03 19:23:44 debian bash[35757]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                              Mai 03 19:23:44 debian bash[35757]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                              Mai 03 19:23:44 debian bash[35757]:     at require (node:internal/modules/helpers:177:18)
                              Mai 03 19:23:44 debian bash[35757]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:9:1)
                              Mai 03 19:23:44 debian bash[35757]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                              Mai 03 19:23:44 debian bash[35757]: Node.js v18.20.2
                                So hab jetzt alles neu installiert. Es läuft auch soweit alles außer:
                                Der Info Adapter
                                  @djsirius
                                  Der ist auch abgekündigt. Deinstallier den, der wird nicht mehr verwendet.
                                    @thomas-braun Dann hatte ich das doch richtig in Erinnerung.
                                    Ist deinstalliert! Vielen Dank!
                                    509
