    4. Alias alias.0.O-DTU-Power.power has no target 8
    • mickym
      mickym Most Active @Homoran last edited by
      @homoran Oder vielleicht den web Adapter mal stoppen und schauen, was dann nicht mehr geht.
        Laser @Homoran last edited by Laser
        @homoran "was läuft denn dann?" x Scripte laufen. VIS läuft.
        99+
        99+
        Log-Größe: 97.3 KB
        Zeit
        debug
        Nachricht
        rpi2.0
        2024-05-03 18:54:01.334	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688948 96325600 12% / /1024
        rpi2.0
        2024-05-03 18:54:01.332	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688948 96325600 12% / /1024
        modbus.0
        2024-05-03 18:53:59.116	warn	Poll error count: 8 code: {"err":"timeout","timeout":5000}
        modbus.0
        2024-05-03 18:53:59.115	error	Request timed out.
        modbus.0
        2024-05-03 18:53:59.115	warn	Error: undefined
        web.0
        2024-05-03 18:53:30.629	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        web.0
        2024-05-03 18:53:24.759	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        rpi2.0
        2024-05-03 18:53:01.339	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688692 96325856 12% / /1024
        rpi2.0
        2024-05-03 18:53:01.338	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688692 96325856 12% / /1024
        web.0
        2024-05-03 18:53:00.671	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        web.0
        2024-05-03 18:52:54.560	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        modbus.0
        2024-05-03 18:52:53.105	warn	Poll error count: 7 code: {"err":"timeout","timeout":5000}
        modbus.0
        2024-05-03 18:52:53.104	error	Request timed out.
        modbus.0
        2024-05-03 18:52:53.103	warn	Error: undefined
        web.0
        2024-05-03 18:52:30.269	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        web.0
        2024-05-03 18:52:15.339	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        rpi2.0
        2024-05-03 18:52:01.334	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688300 96326248 12% / /1024
        rpi2.0
        2024-05-03 18:52:01.333	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688300 96326248 12% / /1024
        web.0
        2024-05-03 18:52:00.305	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        modbus.0
        2024-05-03 18:51:47.096	warn	Poll error count: 6 code: {"err":"timeout","timeout":5000}
        modbus.0
        2024-05-03 18:51:47.096	error	Request timed out.
        modbus.0
        2024-05-03 18:51:47.095	warn	Error: undefined
        web.0
        2024-05-03 18:51:45.283	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        web.0
        2024-05-03 18:51:30.315	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        web.0
        2024-05-03 18:51:14.276	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        web.0
        2024-05-03 18:51:14.214	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
        rpi2.0
        2024-05-03 18:51:01.333	error	Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda2 114865552 12688060 96326488 12% / /1024
        Web- Adapter werde ich mal stoppen. Da wird sicher nichts mehr kommen.
        Homoran mickym 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Laser last edited by
          @laser sagte in Alias alias.0.O-DTU-Power.power has no target 8:
          im Ernst?
          was genau startet zu dieser Sekunde?
          • mickym
            mickym Most Active @Laser last edited by
            Na das ist schon klar. Aber Du siehst dann was vielleicht sonst nicht mehr geht und wer in Deinem System den web Adapter verwendet.
              Laser @mickym last edited by Laser
              @Homoran Habe auf "debug" gestellt. Da kommen noch einige Meldungen mehr. Da muß ich aber erst mal sehen, was das Alles bedeutet!
              Ein kleiner Auszug:
              web.0
              2024-05-03 18:57:35.590	debug	2024-05-03T16:57:35.589Z Request authenticate [system.user.admin]
              web.0
              2024-05-03 18:57:35.586	debug	2024-05-03T16:57:35.586Z Request authenticate [system.user.admin]
              web.0
              2024-05-03 18:57:35.553	debug	2024-05-03T16:57:35.553Z Request authenticate [system.user.admin]
              web.0
              2024-05-03 18:57:34.799	debug	Subscribes: vis-2.0.info.uploaded, vis-2.0.control.instance, vis-2.0.control.data, vis-2.0.control.command, hm-rpc.1.PEQ1630804.4.ACTUAL_TEMPERATURE, hm-rpc.1.PEQ1630804.4.VALVE_STATE, shelly.1.SHSW-25#3C6105E462D5#1.Shutter.Energy, echarts.0.ArbeitszimmerChart, owfs.0.wires.Aussentemperatur, hm-rpc.1.REQ0839212.4.VALVE_STATE, hm-rpc.1.PEQ1630804.4.CONTROL_MODE, hm-rpc.1.REQ0839212.4.CONTROL_MODE, hm-rpc.1.PEQ1630804.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.ACTUAL_TEMPERATURE, opendtu.0.112183225956.ac.phase_1.power, opendtu.0.112183227304.ac.phase_1.power, opendtu.0.total.yieldtotal, opendtu.0.112183225956.dc.input_1.yieldday, opendtu.0.112183227304.dc.input_1.yieldday, opendtu.0.112183225956.dc.input_1.yieldtotal, opendtu.0.112183818346.dc.input_1.yieldday, opendtu.0.112183818346.dc.input_1.yieldtotal, opendtu.0.112183818346.ac.phase_1.power, 0_userdata.0.variables.DP-kWh-ges-solar, alias.0.ShellyEM3Power.Power1EM3, alias.0.ShellyEM3Power.Power0EM3, alias.0.ShellyEM3Power.Power2EM3, vedirect.0.V, vedirect.0.I, vedirect.0.PPV, 0_userdata.0.variables.DP-kW-ges-Zaehler, opendtu.0.total.power, sourceanalytix.0.alias__0__VE-Total__H19.cumulativeReading, alias.0.ZaehlerET.zaehler-Watt, rpi2.0.gpio.12.state, rpi2.0.gpio.16.state, javascript.0.scriptEnabled.Heizung.BoilerHeizen
              web.0
              2024-05-03 18:57:34.798	debug	Subscribes: vis-2.0.info.uploaded, vis-2.0.control.instance, vis-2.0.control.data, vis-2.0.control.command, hm-rpc.1.PEQ1630804.4.ACTUAL_TEMPERATURE, hm-rpc.1.PEQ1630804.4.VALVE_STATE, shelly.1.SHSW-25#3C6105E462D5#1.Shutter.Energy, echarts.0.ArbeitszimmerChart, owfs.0.wires.Aussentemperatur, hm-rpc.1.REQ0839212.4.VALVE_STATE, hm-rpc.1.PEQ1630804.4.CONTROL_MODE, hm-rpc.1.REQ0839212.4.CONTROL_MODE, hm-rpc.1.PEQ1630804.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.SET_TEMPERATURE, hm-rpc.1.REQ0839212.4.ACTUAL_TEMPERATURE, opendtu.0.112183225956.ac.phase_1.power, opendtu.0.112183227304.ac.phase_1.power, opendtu.0.total.yieldtotal, opendtu.0.112183225956.dc.input_1.yieldday, opendtu.0.112183227304.dc.input_1.yieldday, opendtu.0.112183225956.dc.input_1.yieldtotal, opendtu.0.112183818346.dc.input_1.yieldday, opendtu.0.112183818346.dc.input_1.yieldtotal, opendtu.0.112183818346.ac.phase_1.power, 0_userdata.0.variables.DP-kWh-ges-solar, alias.0.ShellyEM3Power.Power1EM3, alias.0.ShellyEM3Power.Power0EM3, alias.0.ShellyEM3Power.Power2EM3, vedirect.0.V, vedirect.0.I, vedirect.0.PPV, 0_userdata.0.variables.DP-kW-ges-Zaehler, opendtu.0.total.power, sourceanalytix.0.alias__0__VE-Total__H19.cumulativeReading, alias.0.ZaehlerET.zaehler-Watt, rpi2.0.gpio.12.state, rpi2.0.gpio.16.state
                wir auch!
                  @laser
                  Danke fürs EDIT!
                  da ist aber noch kein alias Error. nur ganz normale Meldungen.
                  Das einzig interessante ist dass du mit vis2 arbeitest
                    @homoran Das waren ja auch nur Warnmeldungen, die mich zumüllen!
                      Warnungen, dass es einen Fehler mit deinem Alias gibt
                        Laser @Homoran last edited by Homoran
                        @homoran Den Alias hatte ich je gelöscht und neu angelegt. Den Alias mit:
                         web.0 2024-05-03 19:04:32.073	warn	Alias alias.0.TasmoCO2.SENSOR-CO2 has no target 8
                        habe ich komplett gelöscht. Den frage ich auch nicht ab.
                          Homoran Global Moderator Administrators @Laser last edited by Homoran
                          aber irgendwas greift darauf zu
                          wie sieht der alias aus?
                          Objektdaten!
                            @homoran Muß ja. Aber was?
                            EDIT: diese beiden Aliasse gibt es ja nicht mehr!
                              sag du es uns!
                              immer noch keine Meldung im web?
                              statt im Sekundentakt
                                @homoran Den Level habe ich wieder auf "warn" gestellt. (iob Restart.) Waren ja die Warnmeldungen, die mich gestört haben. Zur Zeit kommt keine Warnmeldung. Ich rufe jetzt jede View einzeln auf, um zu sehen, ob eine Meldung kommt. Bisher nichts von diesen beiden Meldungen. Dafür wieder etwas Anders (Eine Quelle, die ich gelöscht habe). Diesen Fehler beseitige ich gleich. Wenn ich eine bestimmte View aufrufe, kommt eine Meldung von: Alias alias.0.O-DTU-Power.power has no target 8
                                Das ist schon mal ein Ansatz!
                                  Wenn ich eine bestimmte View aufrufe, kommt eine Meldung. Das ist schon mal ein Ansatz!
                                  ja
                                    @homoran Ich möchte Dich heute nicht weiter nerven und suche erst mal in dieser Richtung weiter! (Es ist etwas in einem E-Chart. Ich glaube, ich habe noch einige Leichen im Keller!). Danke, daß Ihr mir auf die Sprünge geholfen habt!
                                      Laser @Laser last edited by Laser
                                      @Homoran @mickym Es war tatsächlich der E-Chart, welchen ich als kleines Bild in einem View eingebettet hatte. Dort drin war ein Verweis auf einen gelöschten Alias. Durch die Winzigkeit hatte ich nicht gesehen, daß kein Wert vorhanden war. Außerdem war die Kurve von diesem Alias für mich uninteressant.
                                      Jetzt geht es an die nächsten Warnmeldungen...
                                      1988
