    4. Influxdb restore geht nicht.
    • Marc Berg
      Marc Berg Most Active @Thomas Braun last edited by
      @thomas-braun sagte in Influxdb restore geht nicht.:
      @bill-s-preston
      Influx-Repository in deinem Paketmanager anlegen und dann influxdb daraus installieren.
      Zwei Dumme, … 😁
        Bill S. Preston @Marc Berg last edited by
        @marc-berg
        Und wie bekomme ich die Version 1.8.10 installiert?
        Werde aus der Anleitung überhaupt nicht schlau.
        Sorry bin nicht so fit mit Linux .
          Thomas Braun Most Active @Bill S. Preston last edited by
          @bill-s-preston
          Repo angelegt?
          sudo apt update
          apt policy influx*
          sagt?
            Bill S. Preston @Thomas Braun last edited by Bill S. Preston
            herke@raspberrypi:~ $ sudo apt update
            apt policy influx*
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Get:4 https://repos.influxdata.com/debian bookworm InRelease [12.9 kB]
            Hit:5 https://apt.grafana.com stable InRelease
            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
            Get:7 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
            Hit:8 http://archive.raspberrypi.com/debian bookworm InRelease
            Err:4 https://repos.influxdata.com/debian bookworm InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            Err:7 https://packages.grafana.com/oss/deb stable InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            Reading package lists... Done
            W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is not signed.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            W: GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
            E: The repository 'https://packages.grafana.com/oss/deb stable InRelease' is not signed.
            N: Unable to locate package influxdata-archive_compat.key
            N: Unable to locate package influxdata-archive_compat.key.1
            N: Unable to locate package influxdata-archive_compat.key.2
            N: Unable to locate package influxdata-archive_compat.key.3
            herke@raspberrypi:~ $ apt policy influx*
              @bill-s-preston
              Keine Ahnung was du da angestellt hast, aber das ist Kraut und Rüben...
              Für influxdb:
              rm influx*
              sudo rm /etc/apt/sources.list.d/influ*
              wget -q https://repos.influxdata.com/influxdata-archive_compat.key
              echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
              echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
              rm influxdata-archive_compat.key
              und grafana ist auch nicht korrekt. Versuch es so:
              sudo apt-get install -y apt-transport-https
              sudo apt-get install -y software-properties-common wget
              sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
              echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
              Dann nochmal
              sudo apt update
                Super danke dir! Werde ich heute Abend versuchen. Ich hoffe es wird keine Nachtschicht wieder!
                Muss ich die alte grafana und influx Installation deinstallieren?
                Wenn ja, wie am besten?
                  @bill-s-preston sagte in Influxdb restore geht nicht.:
                  Nein. Du musst aber die Paket-Quellen senkrecht haben.
                    Du musst lediglich die 10 Zeilen per copy&paste in dein Terminal kopieren. Ist eine Sache von 2 Sekunden...
                      sudo apt update
                      apt policy influx*
                      sagt jetzt:
                      apt policy influx*
                      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                      Get:5 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                      Hit:7 https://apt.grafana.com stable InRelease
                      Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Err:5 https://packages.grafana.com/oss/deb stable InRelease
                      influxdb2-cli:
                        Installed: (none)
                        Candidate: 2.7.5-1
                        Version table:
                           2.7.5-1 500
                              500 https://repos.influxdata.com/debian stable/main arm64 Packages
                           2.7.3-1 500
                           2.7.1-2 500
                           2.6.1 500
                           2.6.0 500
                           2.5.0 500
                           2.4.0 500
                           2.3.0 500
                      influxdb-client:
                        Installed: (none)
                        Candidate: 1.6.7~rc0-1+b13
                        Version table:
                           1.6.7~rc0-1+b13 500
                      influxdb-dev:
                        Installed: (none)
                        Candidate: (none)
                        Version table:
                      influxdb2-client:
                        Installed: (none)
                        Candidate: 2.7.1-1
                        Version table:
                           2.7.1-1 500
                      influxdb:
                        Installed: 1.6.7~rc0-1+b13
                        Candidate: 1.8.10-1
                        Version table:
                           1.8.10-1 500
                       *** 1.6.7~rc0-1+b13 500
                              100 /var/lib/dpkg/status
                      influxctl:
                        Installed: (none)
                        Candidate: 2.8.0
                        Version table:
                           2.8.0 500
                           2.7.1 500
                           2.7.0 500
                           2.6.0 500
                           2.5.0 500
                           2.4.4 500
                           2.4.3 500
                           2.4.2 500
                           2.4.1 500
                           2.4.0 500
                           2.3.1 500
                           2.3.0 500
                           2.2.0 500
                           2.1.0 500
                           2.0.4 500
                           2.0.3 500
                           2.0.2 500
                           2.0.1 500
                           2.0.0 500
                      influxdb2:
                        Installed: (none)
                        Candidate: 2.7.6-1
                        Version table:
                           2.7.6-1 500
                           2.7.5-1 500
                           2.7.4-1 500
                           2.7.3-1 500
                           2.7.1-1 500
                           2.7.0-1 500
                           2.6.1-1 500
                           2.6.0-1 500
                           2.5.1-1 500
                           2.4.0-1 500
                           2.3.0-1 500
                           2.2.0 500
                      und...
                      rm influx*
                      herke@raspberrypi:~ $ rm influx*
                      rm: cannot remove 'influx*': No such file or directory
                      und
                      sudo apt update
                      sagt
                      Hit:4 https://apt.grafana.com stable InRelease
                      Hit:5 https://repos.influxdata.com/debian stable InRelease
                      Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
                      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Err:6 https://packages.grafana.com/oss/deb stable InRelease
                        @bill-s-preston
                        Bei grafana hast du einen alten Eintrag irgendwo.
                        Such die Datei:
                        grep -Rnw /etc/apt/ -e packages.grafana
                        Dann dort die Zeile, die den Text packages.grafana.com enthält löschen.
                        Die Zeile mit apt.grafana.com ist die richtige und muss bleiben.
                          @thomas-braun said in Influxdb restore geht nicht.:
                          @bill-s-preston
                          Such die Datei:
                          herke@raspberrypi:~ $ grep -Rnw /etc/apt/ -e packages.grafana
                          /etc/apt/sources.list.d/archive_uri-https_packages_grafana_com_oss_deb-bookworm.
                          list:1:deb https://packages.grafana.com/oss/deb stable main
                          list:2:# deb-src https://packages.grafana.com/oss/deb stable main
                          ist nicht so richtig ersichtlich was ich löschen muss.
                          außerdem wie lösche ich die Zeilen. Hier wird es doch nur gelistet.
                            Lösch die komische Datei komplett. Wo haste die überhaupt her?
                            sudo rm /etc/apt/sources.list.d/archive_uri-https_packages_grafana_com_oss_deb-bookworm.list
                            sudo apt update
                            sudo apt full-upgrade
                              unter
                              wird nun nichts mehr angezeigt.
                              und
                              herke@raspberrypi:~ $ influxd
                               8888888           .d888 888                   8888888b.  888888b.
                                 888            d88P"  888                   888  "Y88b 888  "88b
                                 888            888    888                   888    888 888  .88P
                                 888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
                                 888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
                                 888   888  888 888    888 888  888   X88K   888    888 888    888
                                 888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
                               8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
                              2024-05-04T18:09:02.252026Z     info    InfluxDB starting       {"log_id": "0oyCZoAl000", "versi        on": "1.8.10", "branch": "1.8", "commit": "688e697c51fd"}
                              2024-05-04T18:09:02.252066Z     info    Go runtime      {"log_id": "0oyCZoAl000", "version": "go        1.13.8", "maxprocs": 4}
                              run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
                              sieht nun auch gut aus oder?
                                Thomas Braun Most Active @Bill S. Preston last edited by Thomas Braun
                                Das ist richtig, die Datei hast du ja auch gelöscht.
                                Hast du jetzt grafana wie auch influxdb auf der Kiste?
                                sudo apt update
                                sudo apt install grafana influxdb
                                  sudo apt update sudo apt install grafana influxdb
                                  ja. komme nun in die shell...
                                  Connected to http://localhost:8086 version 1.6.7~rc0
                                  InfluxDB shell version: 1.8.10
                                  Kann ich jetzt einfach via Backitup ein Restore drauf packen?
                                    Ja, sollte.
                                      Homoran Global Moderator Administrators @Bill S. Preston last edited by
                                        Bill S. Preston @Homoran last edited by
                                        8088 wird durch influx genutzt oder sehe ich das falsch?
                                        herke@raspberrypi:~ $ sudo netstat -tulpn | grep LISTEN
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      678/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      665/influxd
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      666/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      666/iobroker.js-con
                                        tcp6       0      0 :::22                   :::*                    LISTEN      678/sshd: /usr/sbin
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      751/grafana
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      918/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      3440/io.admin.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      665/influxd
                                          anscheinend aber nicht nur.
                                          oder interpretiere ich die Meldung falsch?
                                            @bill-s-preston
                                            Reboote die Kiste mal sauber.
                                            1570
