    4. Influxdb restore geht nicht.
      Thomas Braun Most Active @Bill S. Preston last edited by
      @bill-s-preston sagte in Influxdb restore geht nicht.:
      Ich hoffe es wird keine Nachtschicht wieder!
      Du musst lediglich die 10 Zeilen per copy&paste in dein Terminal kopieren. Ist eine Sache von 2 Sekunden...
        Bill S. Preston @Thomas Braun last edited by Bill S. Preston
        sudo apt update
        apt policy influx*
        sagt jetzt:
        herke@raspberrypi:~ $ sudo apt update
        apt policy influx*
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Get:5 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
        Hit:6 https://repos.influxdata.com/debian stable InRelease
        Hit:7 https://apt.grafana.com stable InRelease
        Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
        Err:5 https://packages.grafana.com/oss/deb stable InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        Reading package lists... Done
        W: GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
        E: The repository 'https://packages.grafana.com/oss/deb stable InRelease' is not signed.
        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
        N: See apt-secure(8) manpage for repository creation and user configuration details.
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.5-1
          Version table:
             2.7.5-1 500
                500 https://repos.influxdata.com/debian stable/main arm64 Packages
             2.7.3-1 500
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b13
          Version table:
             1.6.7~rc0-1+b13 500
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb2-client:
          Installed: (none)
          Candidate: 2.7.1-1
          Version table:
             2.7.1-1 500
        influxdb:
          Installed: 1.6.7~rc0-1+b13
          Candidate: 1.8.10-1
          Version table:
             1.8.10-1 500
         *** 1.6.7~rc0-1+b13 500
                100 /var/lib/dpkg/status
        influxctl:
          Installed: (none)
          Candidate: 2.8.0
          Version table:
             2.8.0 500
             2.7.1 500
             2.7.0 500
             2.6.0 500
             2.5.0 500
             2.4.4 500
             2.4.3 500
             2.4.2 500
             2.4.1 500
             2.4.0 500
             2.3.1 500
             2.3.0 500
             2.2.0 500
             2.1.0 500
             2.0.4 500
             2.0.3 500
             2.0.2 500
             2.0.1 500
             2.0.0 500
        influxdb2:
          Installed: (none)
          Candidate: 2.7.6-1
          Version table:
             2.7.6-1 500
             2.7.5-1 500
             2.7.4-1 500
             2.7.3-1 500
             2.7.1-1 500
             2.7.0-1 500
             2.6.1-1 500
             2.6.0-1 500
             2.5.1-1 500
             2.4.0-1 500
             2.3.0-1 500
             2.2.0 500
        und...
        rm influx*
        herke@raspberrypi:~ $ rm influx*
        rm: cannot remove 'influx*': No such file or directory
        und
        sudo apt update
        sagt
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://apt.grafana.com stable InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:8 http://archive.raspberrypi.com/debian bookworm InRelease
        Err:6 https://packages.grafana.com/oss/deb stable InRelease
          @bill-s-preston
          Bei grafana hast du einen alten Eintrag irgendwo.
          Such die Datei:
          grep -Rnw /etc/apt/ -e packages.grafana
          Dann dort die Zeile, die den Text packages.grafana.com enthält löschen.
          Die Zeile mit apt.grafana.com ist die richtige und muss bleiben.
            @thomas-braun said in Influxdb restore geht nicht.:
            @bill-s-preston
            Such die Datei:
            herke@raspberrypi:~ $ grep -Rnw /etc/apt/ -e packages.grafana
            /etc/apt/sources.list.d/archive_uri-https_packages_grafana_com_oss_deb-bookworm.
            list:1:deb https://packages.grafana.com/oss/deb stable main
            list:2:# deb-src https://packages.grafana.com/oss/deb stable main
            ist nicht so richtig ersichtlich was ich löschen muss.
            außerdem wie lösche ich die Zeilen. Hier wird es doch nur gelistet.
              Lösch die komische Datei komplett. Wo haste die überhaupt her?
              sudo rm /etc/apt/sources.list.d/archive_uri-https_packages_grafana_com_oss_deb-bookworm.list
              sudo apt update
              sudo apt full-upgrade
                unter
                wird nun nichts mehr angezeigt.
                und
                herke@raspberrypi:~ $ influxd
                 8888888           .d888 888                   8888888b.  888888b.
                   888            d88P"  888                   888  "Y88b 888  "88b
                   888            888    888                   888    888 888  .88P
                   888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
                   888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
                   888   888  888 888    888 888  888   X88K   888    888 888    888
                   888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
                 8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
                2024-05-04T18:09:02.252026Z     info    InfluxDB starting       {"log_id": "0oyCZoAl000", "versi        on": "1.8.10", "branch": "1.8", "commit": "688e697c51fd"}
                2024-05-04T18:09:02.252066Z     info    Go runtime      {"log_id": "0oyCZoAl000", "version": "go        1.13.8", "maxprocs": 4}
                run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
                sieht nun auch gut aus oder?
                  Thomas Braun Most Active @Bill S. Preston last edited by Thomas Braun
                  Das ist richtig, die Datei hast du ja auch gelöscht.
                  Hast du jetzt grafana wie auch influxdb auf der Kiste?
                  sudo apt update
                  sudo apt install grafana influxdb
                    sudo apt update sudo apt install grafana influxdb
                    ja. komme nun in die shell...
                    Connected to http://localhost:8086 version 1.6.7~rc0
                    InfluxDB shell version: 1.8.10
                    Kann ich jetzt einfach via Backitup ein Restore drauf packen?
                      Ja, sollte.
                        Homoran Global Moderator Administrators @Bill S. Preston last edited by
                          Bill S. Preston @Homoran last edited by
                          8088 wird durch influx genutzt oder sehe ich das falsch?
                          herke@raspberrypi:~ $ sudo netstat -tulpn | grep LISTEN
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      678/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      665/influxd
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      666/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      666/iobroker.js-con
                          tcp6       0      0 :::22                   :::*                    LISTEN      678/sshd: /usr/sbin
                          tcp6       0      0 :::3000                 :::*                    LISTEN      751/grafana
                          tcp6       0      0 :::8082                 :::*                    LISTEN      918/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      3440/io.admin.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      665/influxd
                            anscheinend aber nicht nur.
                            oder interpretiere ich die Meldung falsch?
                              @bill-s-preston
                              Reboote die Kiste mal sauber.
                                Kann es sein, dass 8088 durch Influx für den Restore benutzt wird?
                                So liest es sich jedenfalls auf der Influx Homepage
                                InfluxDB ports
                                8088
                                The default port used by the RPC service for RPC calls made by the CLI for backup and restore operations (influxdb backup and influxd restore). Configure this port in the configuration file.
                                Resources Backup and Restore
                                Ich habe das Influx Restore jetzt nochmal wiederholt. Grafana zeigt noch immer Quatsch an.
                                Auf dem alten System wird Grafana Version 6.6.1 benutzt
                                auf dem Neuen Grafana v10.4.2
                                Wie bekomme ich auf das neue System ebenfalls 6.6.1 ?
                                Kann ich mit diesem Befehl von der Grafana Homepage einfach auf 6.6.1 downgraden?
                                sudo apt-get install -y adduser libfontconfig1 musl
                                wget https://dl.grafana.com/enterprise/release/grafana-enterprise_6.6.1_amd64.deb
                                sudo dpkg -i grafana-enterprise_6.6.1_amd64.deb
                                  Mit deinem Paketmanager? Wie immer unter Linux/Debian. Man installiert i.d.R. nicht irgendwas von irgendwoher, wenn man das auch aus seinen Repos ziehen kann. Was meinst denn du, warum du die beiden Quellen gerade ziehen solltest?
                                  sudo apt install grafana=6.6.1
                                  Auch wenn ich vermute, das es nicht an der Version hängt, sondern an dem noch nicht richtig eingespielten Backup der Datenquelle.
                                    Es scheint so als ob die daten alle da sind
                                    Connected to http://localhost:8086 version 1.8.10
                                    > show databases
                                    name
                                    _internal
                                    iobroker
                                    > list all databases
                                    ERR: error parsing query: found list, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
                                    Warning: It is possible this error is due to not setting a database.
                                    Please set a database with the command "use <database>".
                                    > show databases
                                    name
                                    _internal
                                    iobroker
                                    > show measurements
                                    ERR: database name required
                                    > use iobroker
                                    Using database iobroker
                                    > show measurements
                                    name
                                    0_userdata.0.Gasverbrauch.Gaskosten.Gaskosten_Jahr
                                    0_userdata.0.Gasverbrauch.Gaskosten.Gaskosten_Monat
                                    0_userdata.0.Gasverbrauch.Gaskosten.Gaskosten_Tag
                                    0_userdata.0.Gasverbrauch.Gaskosten.Gaskosten_Woche
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Jahr
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Jahr_in_kwh
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Monat
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Monat_in_kwh
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Stündlich
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Tag
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Tag_in_kwh
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Woche
                                    0_userdata.0.Gasverbrauch.Gasverbrauch_Woche_in_kwh
                                    0_userdata.0.Stromvebrauch.Geschirrspüler.Geschirrspüler_Kosten_Tag
                                    0_userdata.0.Stromvebrauch.Geschirrspüler.Geschirrspüler_Verbrauch_Jahr
                                    0_userdata.0.Stromvebrauch.Geschirrspüler.Geschirrspüler_Verbrauch_Monat
                                    0_userdata.0.Stromvebrauch.Geschirrspüler.Geschirrspüler_Verbrauch_Woche
                                    0_userdata.0.Stromvebrauch.Geschirrspüler.Geschirspüler_Verbrauch
                                    0_userdata.0.Stromvebrauch.Stromkosten.Stromkosten_Jahr
                                    0_userdata.0.Stromvebrauch.Stromkosten.Stromkosten_Monat
                                    0_userdata.0.Stromvebrauch.Stromkosten.Stromkosten_Tag
                                    0_userdata.0.Stromvebrauch.Stromkosten.Stromkosten_Woche
                                    0_userdata.0.Stromvebrauch.Stromverbrauch_Jahr
                                    0_userdata.0.Stromvebrauch.Stromverbrauch_Monat
                                    0_userdata.0.Stromvebrauch.Stromverbrauch_Tag
                                    0_userdata.0.Stromvebrauch.Stromverbrauch_Woche
                                    0_userdata.0.Wasserverbrauch.Wasserverbrauch_Jahr
                                    0_userdata.0.Wasserverbrauch.Wasserverbrauch_Monat
                                    0_userdata.0.Wasserverbrauch.Wasserverbrauch_Tag
                                    0_userdata.0.Wasserverbrauch.Wasserverbrauch_Woche
                                    fullybrowser.0.192_168_178_46.Info.batteryLevel
                                    hm-rpc.1.0001DA49A3412A.6.CURRENT
                                    hm-rpc.1.0001DA49A3412A.6.ENERGY_COUNTER
                                    hm-rpc.1.0001DA49A3412A.6.POWER
                                    hm-rpc.1.000A18A9A302A1.1.LEVEL
                                    hm-rpc.1.000A18A9A302A1.1.SET_POINT_TEMPERATURE
                                    hm-rpc.1.000A18A9A8058A.1.LEVEL
                                    hm-rpc.1.000A1BE9A2971B.1.ACTUAL_TEMPERATURE
                                    hm-rpc.1.000A1BE9A2971B.1.LEVEL
                                    hm-rpc.1.000A9A49969BB9.1.ACTUAL_TEMPERATURE
                                    hm-rpc.1.000A9A49969BB9.1.HUMIDITY
                                    hm-rpc.1.000A9A49969BC0.1.ACTUAL_TEMPERATURE
                                    hm-rpc.1.000A9A49969BC0.1.HUMIDITY
                                    hm-rpc.1.000A9A49995473.1.ACTUAL_TEMPERATURE
                                    hm-rpc.1.000A9A49995473.1.HUMIDITY
                                    hm-rpc.1.002A1BE9A78ADE.0.OPERATING_VOLTAGE
                                    hm-rpc.1.0031DD89994601.1.CURRENT_ILLUMINATION
                                    hm-rpc.1.0031DD89994601.1.ILLUMINATION
                                    hm-rpc.3.MEQ0546462.4.ACTUAL_TEMPERATURE
                                    hm-rpc.3.MEQ0546462.4.SET_TEMPERATURE
                                    hm-rpc.3.MEQ0546462.4.VALVE_STATE
                                    hm-rpc.3.SEQ1374828.1.IEC_ENERGY_COUNTER
                                    hm-rpc.3.SEQ1374828.1.IEC_POWER
                                    javascript.0.Außenthermometer.Außentemperatur
                                    javascript.0.Außenthermometer.Luftfeuchtigkeit_Außen
                                    javascript.0.Entfeuchter_Tagesverbrauch
                                    javascript.0.Entfeuchter_Zähler_an/aus
                                    javascript.0.Gas.BrennerAktiv
                                    javascript.0.Gas.Brennerlaufzeit
                                    javascript.0.Gas.Brennerstarts
                                    javascript.0.Gas.Leistung
                                    javascript.0.Gas.Verbrauch_Energie
                                    javascript.0.Gas.Verbrauch_Volumen
                                    javascript.0.Gasverbrauch.Gas_Jährlich
                                    javascript.0.Gasverbrauch.Gas_Monatlich
                                    javascript.0.Gasverbrauch.Gas_Stündlich_Zähler
                                    javascript.0.Gasverbrauch.Gas_Woche
                                    javascript.0.Gasverbrauch.Gas_heute
                                    javascript.0.Gasverbrauch.Gasverbrauch_täglich_NEU
                                    javascript.0.Luftentfeuchter_Verbrauch_Täglich
                                    javascript.0.Nacht_für_Grafana
                                    javascript.0.Neue_Aufzeichnung_für_Helligkeit.Current_Illumination
                                    javascript.0.Neue_Aufzeichnung_für_Helligkeit.Illumintion
                                    javascript.0.Regenmenge.Regenmenge_Jahr
                                    javascript.0.Regenmenge.Regenmenge_Monat
                                    javascript.0.Regenmenge.Regenmenge_Stunde
                                    javascript.0.Regenmenge.Regenmenge_Tag
                                    javascript.0.Regenmenge.Regenmenge_Woche
                                    javascript.0.Stromverbrauch.Jahr.Verbrauch_Jahr_Neu
                                    javascript.0.Stromverbrauch.Monat.Kosten_Monat
                                    javascript.0.Stromverbrauch.Monat.Verbrauch_Monat
                                    javascript.0.Stromverbrauch.Preis_kW/h
                                    javascript.0.Stromverbrauch.Tag.Kosten_Tag
                                    javascript.0.Stromverbrauch.Tag.Verbrauch_Tag
                                    javascript.0.Stromverbrauch.Trockner.Trockner_Jahr_2021
                                    javascript.0.Stromverbrauch.Trockner.Trockner_Jahr_2022
                                    javascript.0.Stromverbrauch.Trockner.Trockner_Kosten_Tag
                                    javascript.0.Stromverbrauch.Zwischenstecker.Kosten_Tag
                                    javascript.0.Stromverbrauch.Zwischenstecker.Verbrauch_Tag
                                    javascript.0.Stromverbrauch.Zählerstand_per_Script
                                    javascript.0.Wasserzähler.Gestern
                                    javascript.0.Wasserzähler.Heute
                                    javascript.0.Wasserzähler.Jährlich
                                    javascript.0.Wasserzähler.Letztes_Jahr
                                    javascript.0.Wasserzähler.Monatlich
                                    javascript.0.Wasserzähler.Wöchentlich
                                    javascript.0.Wasserzähler.Wöchentlich2
                                    javascript.0.Xiomi_Thermometer_Dachboden.Luftfeuchtigkeit
                                    javascript.0.Xiomi_Thermometer_Dachboden.Temperatur
                                    openweathermap.0.forecast.current.humidity
                                    openweathermap.0.forecast.current.temperature
                                    shelly.0.SHWT-1#AC5BEF#1.rssi
                                    shelly.0.SHWT-1#AC5BEF#1.sensor.battery
                                    shelly.0.SHWT-1#C8AA8B#1.rssi
                                    shelly.0.SHWT-1#C8AA8B#1.sensor.battery
                                    sonoff.0.Gosund1.ENERGY_Power
                                    sonoff.0.Gosund1.ENERGY_Today
                                    sonoff.0.Gosund1.ENERGY_Total
                                    sonoff.0.Gosund3.ENERGY_ApparentPower
                                    sonoff.0.Gosund3.ENERGY_Current
                                    sonoff.0.Gosund3.ENERGY_Factor
                                    sonoff.0.Gosund3.ENERGY_Power
                                    sonoff.0.Gosund3.ENERGY_ReactivePower
                                    sonoff.0.Gosund4.ENERGY_Power
                                    sonoff.0.Gosund4.ENERGY_Today
                                    sonoff.0.Gosund4.ENERGY_Yesterday
                                    worx.0.2022302672080000094F.mower.batteryChargeCycle
                                    worx.0.2022302672080000094F.mower.batteryState
                                    worx.0.2022302672080000094F.mower.batteryTemperature
                                    worx.0.2022302672080000094F.mower.batteryVoltage
                                    worx.0.2022302672080000094F.mower.totalBladeTime
                                    worx.0.2022302672080000094F.mower.totalDistance
                                    worx.0.2022302672080000094F.rawMqtt.battery_charge_cycles
                                    worx.0.2022302672080000094F.rawMqtt.blade_work_time
                                    zigbee.1.00158d00058a6353.humidity
                                    zigbee.1.00158d00058a6353.temperature
                                    zigbee.1.00158d00058ca467.humidity
                                    zigbee.1.00158d00058ca467.temperature
                                    In Grafana kann ich auch was auswählen.
                                    Es wird aber nichts angezeigt
                                    Die Datenbank wurde auch verbunden wie es scheint
                                    Kann der Fehler an einem falschen Passwort liegen?
                                    Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                                      Influxdb operiert soweit ich das weiß mit Tokens. Kann dir aber @Marc-Berg vielleicht besser was zu sagen, ich verwende kein influxdb.
                                      • Marc Berg
                                        Marc Berg Most Active @Bill S. Preston last edited by Marc Berg
                                        Nein. Wenn der Test grün ist, passt das.
                                        Kann es sein, dass nach deinem Restore (eines älteren Backups) in den letzten 6 Stunden keine Daten stecken?
                                          Bill S. Preston @Marc Berg last edited by
                                          @marc-berg
                                          Backup wurde gestern abend erstellt.
                                          • Marc Berg
                                            Hast du ein Log vom erfolgreich durchgeführten Restore? Die Daten, die zu sehen sind, scheinen ja nur die neu hinzugekommenen zu sein.
                                            1570
