    4. Homebridge Fehler Code 243
      Thomas Braun Most Active @marcelinho last edited by
      @marcelinho sagte in Homebridge Fehler Code 243:
      Wüsste nicht was da falsch gehen sollte
      Dann schau in das Log:
      2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
      2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
      2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
      2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
      2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
      2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
      2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
      2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
      2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
      2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
      2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
      Sieht für mich nicht gesund aus. Insbesondere nicht in der Frequenz mit der da Zeug geloggt wird. Das bläst dir alleine das Logfile in kürzester Zeit auf unnötige Größen auf.
      Homebridge über den ham-Adapter? Der ist aber gar nicht installiert bei dir.
      • Marc Berg
        Marc Berg Most Active @marcelinho last edited by
        Influxdb habe ich gestern mit @Marc-Berg bereinigt
        Jain. Du hattest den Speicherzeitraum der InfluxDB auf 90 Tage gesetzt und wir haben gesagt, dass die ungewollt geloggten Daten nach 90 Tagen endgültig raus sind.
        Du könntest des Speicherzeitraum jetzt auch noch weiter verkürzen, um den Effekt zu beschleunigen.
        Weiterhin kannst du in den Datenpunkteinstellungen des InfluxDB Adapters prüfen, ob du weniger Daten wegschreibst, indem du z.B. die Blockierzeit auf 30 Sekunden setzt.
          marcelinho @Thomas Braun last edited by
          @thomas-braun said in Homebridge Fehler Code 243:
          ham-Adapter
          Homebridge habe ich über die SD-Karte über ein Image installiert gehabt
          https://smartapfel.de/homebridge/installieren/
            marcelinho @Marc Berg last edited by
            @marc-berg ich habe im influx.db Adapter nun auch 90 Tage geändert und die Blockzeit auf 30 gesetzt - ist dies so korrekt?Screenshot 2024-04-25 075854.png
              @marcelinho
              Und wo ist da jetzt die Verbindung zum ioBroker?
              Marc Berg M 2 Replies Last reply Reply Quote 0
              • Marc Berg
                Marc Berg Most Active @marcelinho last edited by Marc Berg
                Ob du die Einstellung für die Vorhaltezeit in der Instanz des Adapters änderst oder direkt in der Datenbank-Oberfläche ist völlig egal, das funktioniert beides.
                Zur Blockzeit: Du hast jetzt lediglich die "Standardeinstellung" geändert, die angezogen wird, wenn du neue Datenpunkte mit der InfluxDB verbindest. Dies hat keine Auswirkungen auf schon bestehende Datenpunkte.
                Du solltest also Datenpunkt für Datenpunkt durchgehen und jeweils schauen, ob du nur geänderte Werte aufzeichnen willst, ob du eine Blockzeit verwendest oder nur Änderungen protokollierst, wenn sich der Wert um x ändert.
                Das kann man nicht pauschal empfehlen, es hängt einfach davon ab, welche Daten jeweils in welchen Intervallen reinfliegen. Ziel sollte jedenfalls sein, die Menge an Daten, die (vielleicht unnötigerweise) in die Datenbank geschrieben wird, auf ein sinnvolles Maß zu reduzieren.
                EDIT: Außerdem wird die Blockzeit in Millisekunden angegeben
                • Marc Berg
                  Marc Berg Most Active @Thomas Braun last edited by
                  @thomas-braun sagte in Homebridge Fehler Code 243:
                  Im Tab "DB Settings"!? 🙂
                    @marc-berg jetzt sieht es wohl besser aus, habe alle Influxdb Datenpunkte mit Millisekunden angepasst:
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                     Static hostname: raspberrypi
                           Icon name: computer
                              Kernel: Linux 6.1.0-rpi7-rpi-v8
                        Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : arm64
                    Systemuptime and Load:
                     09:23:33 up 1 day, 15:37,  3 users,  load average: 0.27, 0.37, 0.33
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Thu 2024-04-25 09:23:33 CEST
                               Universal time: Thu 2024-04-25 07:23:33 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            4.0G        2.9G        827M         28K        296M        1.0G
                    Swap:           104M        104M        278K
                    Total:          4.1G        3.0G        827M
                             3793 M total memory
                             2796 M used memory
                             2004 M active memory
                              808 M inactive memory
                              788 M free memory
                               16 M buffer memory
                              266 M swap cache
                               99 M total swap
                               99 M used swap
                                0 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    udev           devtmpfs  1.6G     0  1.6G   0% /dev
                    tmpfs          tmpfs     380M  1.2M  379M   1% /run
                    /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
                    tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                    /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                    tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                    [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                    [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                    [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    TARGET           SOURCE         FSTYPE OPTIONS
                    /                /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    11G     /var/
                    8.9G    /var/lib
                    8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                    Archived and active journals take up 739.9M in the file system.
                    /opt/iobroker/backups:
                    217M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    303M    /opt/iobroker/iobroker-data/
                    191M    /opt/iobroker/iobroker-data/files
                    57M     /opt/iobroker/iobroker-data/files/javascript.admin
                    52M     /opt/iobroker/iobroker-data/backup-objects
                    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                    18M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
                    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                    USB-Devices by-id:
                    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.20.2
                    /usr/bin/node           v18.20.2
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    /usr/bin/corepack       0.25.2
                    nodejs:
                      Installed: 18.20.2-1nodesource1
                      Candidate: 18.20.2-1nodesource1
                      Version table:
                     *** 18.20.2-1nodesource1 600
                            100 /var/lib/dpkg/status
                         18.20.1-1nodesource1 600
                         18.20.0-1nodesource1 600
                         18.19.1-1nodesource1 600
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                         18.19.0-1nodesource1 600
                         18.18.2-1nodesource1 600
                         18.18.1-1nodesource1 600
                         18.18.0-1nodesource1 600
                         18.17.1-1nodesource1 600
                         18.17.0-1nodesource1 600
                         18.16.1-1nodesource1 600
                         18.16.0-1nodesource1 600
                         18.15.0-1nodesource1 600
                         18.14.2-1nodesource1 600
                         18.14.1-1nodesource1 600
                         18.14.0-1nodesource1 600
                         18.13.0+dfsg1-1 500
                         18.13.0-1nodesource1 600
                         18.12.0-1nodesource1 600
                         18.11.0-1nodesource1 600
                         18.10.0-1nodesource1 600
                         18.9.1-1nodesource1 600
                         18.9.0-1nodesource1 600
                         18.8.0-1nodesource1 600
                         18.7.0-1nodesource1 600
                         18.6.0-1nodesource1 600
                         18.5.0-1nodesource1 600
                         18.4.0-1nodesource1 600
                         18.3.0-1nodesource1 600
                         18.2.0-1nodesource1 600
                         18.1.0-1nodesource1 600
                         18.0.0-1nodesource1 600
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.19
                    admin:          6.13.16
                    javascript:     7.8.0
                    Adapters from github:   3
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                    + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
                    + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
                    + system.adapter.cloud.0                  : cloud                 : raspberrypi        -  enabled
                    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi        -  enabled
                    + system.adapter.daikin.0                 : daikin                : raspberrypi        -  enabled
                    + system.adapter.daikin.1                 : daikin                : raspberrypi        -  enabled
                    + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
                    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi        -  enabled
                    + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
                    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi        -  enabled
                    + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
                    + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi        -  enabled
                    + system.adapter.meross.0                 : meross                : raspberrypi        -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.myenergi.0               : myenergi              : raspberrypi        -  enabled
                    + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.smart-eq.0               : smart-eq              : raspberrypi        -  enabled
                    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi        -  enabled
                    + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
                    + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi        -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                    Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
                    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                    Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
                    Adapter    "meross"       : 1.17.0   , installed 1.17.0
                    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
                    Adapter    "node-red"     : 5.2.0    , installed 5.2.0
                    Adapter    "openhab"      : 1.1.0    , installed 1.1.0
                    Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                    Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
                    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                    Adapter    "ws"           : 2.5.11   , installed 2.5.11
                    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                    Objects and States
                    Objects:        14991
                    States:         13387
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                    Hit:6 https://apt.grafana.com stable InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:8 https://repo.homebridge.io stable InRelease
                    Reading package lists...
                    Pending Updates: 3
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
                    tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
                    tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
                    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
                    tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
                    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
                    tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
                    tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1585299    38874/cupsd
                    tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
                    tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
                    tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
                    tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
                    tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1585298    38874/cupsd
                    tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
                    tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
                    tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
                    tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
                    tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
                    tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
                    tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
                    tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
                    tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
                    udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1586228    38876/cups-browsed
                    udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
                    udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
                    udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
                    2024-04-25 09:10:38.129  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.gas_savings.total_spent.raw_value" has to be type "number" but received type "string"
                    2024-04-25 09:10:38.133  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.total_spent.raw_value" has to be type "number" but received type "string"
                    2024-04-25 09:11:45.291  - info: influxdb.0 (47993) enabled logging of PV Tagesertrag, Alias=true
                    2024-04-25 09:12:30.314  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTag, Alias=true
                    2024-04-25 09:12:50.951  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTag, Alias=true
                    2024-04-25 09:13:25.909  - warn: influxdb.0 (47993) Error in query "from(bucket: "admin")  |> range(start: 1999-12-31T23:00:00.000Z, stop: 2024-04-25T07:12:55.411Z) |> filter(fn: (r) => r["_measurement"] == "BatterieEntladung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns:["_time"], desc: false) |> limit(n: 500)": RequestTimedOutError: Request timed out
                    2024-04-25 09:14:14.696  - info: influxdb.0 (47993) enabled logging of BatterieEntladung, Alias=true
                    2024-04-25 09:14:23.823  - info: influxdb.0 (47993) enabled logging of BatterieProzent, Alias=true
                    2024-04-25 09:14:32.228  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTotal, Alias=true
                    2024-04-25 09:14:38.869  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTotal, Alias=true
                    2024-04-25 09:14:42.461  - info: shelly.0 (1561) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
                    2024-04-25 09:14:57.799  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Accumulated_Energy_Yield, Alias=false
                    2024-04-25 09:15:10.195  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Active_Power, Alias=false
                    2024-04-25 09:15:16.964  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Daily_Energy_Yield, Alias=false
                    2024-04-25 09:15:31.414  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Input_Power, Alias=false
                    2024-04-25 09:15:42.478  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Internal_Temperature, Alias=false
                    2024-04-25 09:18:36.103  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_Euro, Alias=true
                    2024-04-25 09:18:42.306  - info: influxdb.0 (47993) enabled logging of Hausspeicher_gespart, Alias=true
                    2024-04-25 09:18:48.544  - info: influxdb.0 (47993) enabled logging of Netzbezug_Tag_Euro, Alias=true
                    2024-04-25 09:19:00.758  - info: influxdb.0 (47993) enabled logging of Netzeinspeisung_Tag_Euro, Alias=true
                    2024-04-25 09:19:13.266  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_kWh, Alias=true
                    2024-04-25 09:19:20.297  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, Alias=false
                    2024-04-25 09:19:26.029  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_W, Alias=false
                    2024-04-25 09:19:34.118  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_Tag_kWh, Alias=false
                    2024-04-25 09:19:43.416  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_W, Alias=false
                      @thomas-braun hast du zufällig noch einen Vorschlag was ich gegen den Fehler machen könnte?
                        @marcelinho
                        Nein. Mit GUIs hab ich aber auch wenig am Hut. Und mit Homebridge auch nicht.
                          marcelinho @marcelinho last edited by
                          habe nun folgenden Fehler:
                          npm ERR! code EACCES
                          npm ERR! syscall rename
                          npm ERR! path /usr/local/bin/homebridge
                          npm ERR! dest /usr/local/bin/.homebridge-kaN4ImAr
                          npm ERR! errno -13
                          npm ERR! Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'
                          npm ERR! [Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'] {
                          npm ERR! errno: -13,
                          npm ERR! code: 'EACCES',
                          npm ERR! syscall: 'rename',
                          npm ERR! path: '/usr/local/bin/homebridge',
                          npm ERR! dest: '/usr/local/bin/.homebridge-kaN4ImAr'
                          npm ERR! }
                          npm ERR!
                          npm ERR! The operation was rejected by your operating system.
                          npm ERR! It is likely you do not have the permissions to access this file as the current user
                          npm ERR!
                          npm ERR! If you believe this might be a permissions issue, please double-check the
                          npm ERR! permissions of the file and its containing directories, or try running
                          npm ERR! the command again as root/Administrator.
                          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-05-06T15_54_11_806Z-debug-0.log
                          jemand eine Idee?
                            jemand eine Idee?
                            Du könntest dazu schreiben welche Aktion mit welchem User zu diesen Meldungen führt.
                            Und welche Berechtigungen für homebridge erforderlich sind.
                            ls -lah  /usr/local/bin/homebridge
                              @thomas-braun wenn ich den Befehl in der Konsole eingebe kommt folgendes:
                              pi@raspberrypi:~ $ ls -lah /usr/local/bin/homebridge
                              lrwxrwxrwx 1 root root 45 May 6 17:51 /usr/local/bin/homebridge -> ../lib/node_ modules/homebridge/bin/homebridge
                              ich bin etwas überfragt, weis nicht genau was du meinst.
                                Thomas Braun Most Active @marcelinho last edited by Thomas Braun
                                @marcelinho
                                Und
                                ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                                sagt?
                                Konsolentext bitte immer in CodeTags setzen. Kann man besser lesen. Danke.
                                Edit: c&p Fehler
                                  @thomas-braun ok sorry
                                  es kommt folgendes:
                                  pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_ modules/homebridge/bin/homebridg                                    e
                                  ls: cannot access '/usr/local/lib/node_': No such file or directory
                                  ls: cannot access 'modules/homebridge/bin/homebridge': No such file or directory
                                  • DJMarc75
                                    DJMarc75 @marcelinho last edited by
                                    @marcelinho
                                    war ein leerzeichen drin
                                      marcelinho @DJMarc75 last edited by
                                      @djmarc75 danke anbei neu
                                      pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                                      -rwxr-xr-x 1 pi root 349 May  6 17:51 /usr/local/lib/node_modules/homebridge/bin               /homebridge
                                      pi@raspberrypi:~ $
                                        Hat jemand bezgl. des Fehler noch eine Idee ? Danke vorab:
                                        [28/05/2024, 15:45:48] [Homebridge UI] Operation failed with code 243.
                                        You can download this log file for future reference.
                                        See https://github.com/homebridge/homebridge-config-ui-x/wiki/Troubleshooting for help.
                                        3128
