    4. heap zu klein?
    heap zu klein?
      pingps last edited by
      ich möchte einige instanzen löschen.
      Leider geht das nicht mit z.B.
      iobroker stop zigbee
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      Für Hilfe wäre ich sehr dankbar!
        Homoran Global Moderator Administrators @pingps last edited by
        @pingps hast du schon iob fix laufen lassen?
          @oliverio Speicherverbrauch ist konstant. Da gibt es keine ansteigenden Speicherverbräuche
          @Homoran iob fix habe ich laufen lassen.
          Hier wiederholt:
           iob fix
          library: loaded
          Library version=2024-01-04
              Welcome to the ioBroker installation fixer!
              Script version: 2024-01-04
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          OK:1 http://ftp.de.debian.org/debian bullseye InRelease
          OK:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
          OK:3 https://security.debian.org/debian-security bullseye-security InRelease
          OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Paketlisten werden gelesen… Fertig
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          <--- Last few GCs --->
          [10880:0x6afa850]     9970 ms: Mark-sweep 1978.7 (2087.8) -> 1976.7 (2087.8) MB, 97.2 / 0.0 ms  (average mu = 0.902, current mu = 0.788) allocation failure; scavenge might not succeed
          [10880:0x6afa850]    10188 ms: Mark-sweep 1992.4 (2087.8) -> 1990.1 (2117.5) MB, 177.8 / 0.0 ms  (average mu = 0.757, current mu = 0.184) allocation failure; scavenge might not succeed
          <--- JS stacktrace --->
          FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
           1: 0xb9a330 node::Abort() [node]
           2: 0xaa07ee  [node]
           3: 0xd71ed0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
           4: 0xd72277 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
           5: 0xf4f635  [node]
           6: 0xf61b0d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
           7: 0xf3c1fe v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
           8: 0xf3d5c7 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node]
           9: 0xf1db40 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node]
          10: 0xf155b4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node]
          11: 0xf17948 v8::internal::FactoryBase<v8::internal::Factory>::NewRawTwoByteString(int, v8::internal::AllocationType) [node]
          12: 0x134923c v8::internal::IncrementalStringBuilder::Extend() [node]
          13: 0x105e5d0 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [node]
          14: 0x105fa71 v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [node]
          15: 0x106164f v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [node]
          16: 0x106164f v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [node]
          17: 0x106164f v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [node]
          18: 0x106164f v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [node]
          19: 0x1063eaf v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<false>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8::internal::Object>) [node]
          20: 0x1064bff v8::internal::JsonStringify(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>) [node]
          21: 0xdf7d57 v8::internal::Builtin_JsonStringify(int, unsigned long*, v8::internal::Isolate*) [node]
          22: 0x1710839  [node]
          Aborted
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          Uli@debian-uli:~/2024-05-05$ ^C
          Uli@debian-uli:~/2024-05-05$  iob fix
          library: loaded
          Done.
          [10880:0x6afa850]     9970 ms: Mark-sweep 1978.7 (2087.8) -> 1976.7 (2087.8) MB, 97.2 / 0.0 ms  (average mu = 0.902, current m==========================================================================
            pingps @pingps last edited by
            @Homoran mir scheint das Problem zu sein, dass linux kein file locken kann
            iob status
            Uli@debian-uli:~$
              Thomas Braun Most Active @pingps last edited by
              @pingps sagte in heap zu klein?:
              ls -lah /opt/iobroker/iobroker-data/objects.jsonl
              und
              getfacl /opt/iobroker/iobroker-data/objects.jsonl
              sagen?
                nicht linux, sondern der user.
                Deswegen den Fixer, damit die Rechte wieder geradegebogen werden.
                Allerdings kann ich mit der dortigen Fehlermeldung nichts anfangen. Da muss ein Wissender ran.
                  pingps @Thomas Braun last edited by
                  -rw-rwxr--+ 1 iobroker iobroker 547M  5. Mai 20:12 /opt/iobroker/iobroker-data/objects.jsonl
                  Uli@debian-uli:~$
                  getfacl: Entferne führende '/' von absoluten Pfadnamen
                  # file: opt/iobroker/iobroker-data/objects.jsonl
                  # owner: iobroker
                  # group: iobroker
                  user::rw-
                  group::r-x
                  group:iobroker:rwx
                  mask::rwx
                  other::r--
                    Thomas Braun Most Active @pingps last edited by Thomas Braun
                    @pingps
                    Die Rechte stehen bei mir anders:
                    echad@chet:~ $ ls -lah /opt/iobroker/iobroker-data/objects.jsonl
                    -rw-rw-r--+ 1 iobroker iobroker 61M May  5 20:23 /opt/iobroker/iobroker-data/objects.jsonl
                    echad@chet:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                    getfacl: Removing leading '/' from absolute path names
                    # owner: iobroker
                    # group: iobroker
                    user::rw-
                    group::r-x                      #effective:r--
                    group:iobroker:rwx              #effective:rw-
                    mask::rw-
                    other::r--
                    echad@chet:~ $
                    Ob das locking aber daran scheitert oder an der Größe der Datei (oder was ganz anderem) kann ich dir auch nicht sagen.
                      @thomas-braun bei mir gibt es ja mehr Rechte
                      -rw-rw-r--+
                      bei mir
                      -rw-rwxr--+ /opt/iobroker/iobroker-data/objects.jsonl
                      für was soll diese jsonl ausführbar sein? (habe dazu leider keine Ahnung!)
                        Das frage ich mich auch. Das ist keine ausführbare Datei.
                          Vielleicht hilft das: Beim Stoppen einiger Adapter gab es komische Ereignisse:
                          Uli@debian-uli:~$ iobroker stop telegram
                           Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          ^C
                          The adapter "telegram.0" was stopped.
                          The adapter "telegram.1" was stopped.
                          The adapter "telegram.2" was stopped.
                          Nach dem Abbrechen durch ^C und neuem Stop funktionierte dann der stop
                            pingps last edited by pingps
                            @pingps werde wohl iobroker auf synology umziehen bzw. neu aufsetzen. Ne DS1621+, die sowieso nur Däumchen dreht, steht hier zur Verfügung.
                            Gute Idee?
                              @pingps ok, habe mal die Synology für iobroker bereit gemacht und den iobroker neu installiert. Natürlich darf ich jetzt alle Adapter... neu installieren. Ich denke mal mit backitup die bestehende Konfiguration einzuspielen wird schief gehen?
                              Oder ist das nicht so toll?
                              Dann gibt es bei der Homematic (nicht IP) Probleme: Bei HM-RPC wird ja als Adapter Adresse die iobroker Adresse eingegeben. Und die hat sich ja i.V. zur alten Konfiguration geändert. Also neue IP. Aber der Zusatz -ens3 wird hier angeboten. Klar, dass die IP eine andere ist aber der Zusatz war früher anders. Ist das ok?
                              Als Homematic Port habe ich 2001 eingetragen. Leider wird der Adapter nicht grün.
                              hm-rega ist ok.
                                pingps @pingps last edited by pingps
                                @pingps Euch vielen Dank. Der richtige Tipp ist wohl das System neu auf neuer HW aufzusetzen. Ob ich bei einem RPI5 die vorhandene Konfiguration verwenden kann? Würde ja viel Arbeit ersparen.
                                RPI5 mit NT ist bestellt!!!
                                Also: DANKE!
                                1145
