    4. Iobroker startet nicht mehr nach Restore
      Thomas Braun Most Active @Bill S. Preston last edited by
      @bill-s-preston sagte in Iobroker startet nicht mehr nach Restore:
      Dauert etwas...
      Klar, bei 29 Adaptern...
        So, update ist fertig. Auch nach nem reboot des Systems ist der Broker still.
          @bill-s-preston
          iob diag
          sagt?
            Bill S. Preston @Thomas Braun last edited by
            @thomas-braun said in Iobroker startet nicht mehr nach Restore:
            @bill-s-preston
            iob diag
            sagt?
            Skript v.2024-04-21
            *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.6.28+rpt-rpi-v8
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             14:34:15 up 4 min,  2 users,  load average: 0.83, 0.74, 0.33
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Mon 2024-05-06 14:34:15 CEST
                       Universal time: Mon 2024-05-06 12:34:15 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            herke
            HOME=/home/herke
            GROUPS=herke adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** Display-Server-Setup ***
            pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
            Try `pgrep -f' option to match against the complete command line.
            Display-Server: false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            4.0G        641M        2.7G        1.2M        669M        3.3G
            Swap:           104M          0B        104M
            Total:          4.1G        641M        2.8G
            Active iob-Instances:   3
                     3792 M total memory
                      612 M used memory
                      871 M active memory
                      200 M inactive memory
                     2613 M free memory
                       64 M buffer memory
                      573 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 14:34:16 up 4 min,  2 users,  load average: 0.83, 0.74, 0.33
            Tasks: 186 total,   2 running, 184 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3792.1 total,   2612.8 free,    613.1 used,    638.6 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3178.9 avail Mem
            *** FAILED SERVICES ***
              UNIT              LOAD   ACTIVE SUB    DESCRIPTION
            * motioneye.service loaded failed failed motionEye Server
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  1.6G     0  1.6G   0% /dev
            tmpfs          tmpfs     380M  1.2M  379M   1% /run
            /dev/mmcblk0p2 ext4      117G  8.1G  103G   8% /
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Mon May  6 14:30:07 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:96:C0:F6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=03edf4a5-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
            [Mon May  6 14:30:09 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
            [Mon May  6 14:30:11 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
            Show mounted filesystems:
            TARGET                                                  SOURCE         FSTYPE      OPTIONS
            /                                                       /dev/mmcblk0p2 ext4        rw,noatime
            |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
            | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
            | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
            |-/proc                                                 proc           proc        rw,relatime
            | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2408
            |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
            |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671304k,nr_inodes=417826,mode=755
            | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
            | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
            |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
            | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
            | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
            | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
            | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
            | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
            | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
            `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.9G    /var/
            1.3G    /var/lib
            1.1G    /var/lib/influxdb/data
            1015M   /var/lib/influxdb/data/iobroker/autogen
            Archived and active journals take up 175.7M in the file system.
            /opt/iobroker/backups:
            522M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            286M    /opt/iobroker/iobroker-data/
            210M    /opt/iobroker/iobroker-data/files
            60M     /opt/iobroker/iobroker-data/backup-objects
            57M     /opt/iobroker/iobroker-data/files/javascript.admin
            38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
            14M     /opt/iobroker/iobroker-data/objects.jsonl
            8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
            8.2M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js
            USB-Devices by-id:
            No Devices found 'by-id'
            HINT:
            Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyACM0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.20.2
            /usr/bin/node           v18.20.2
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            /usr/bin/corepack       0.25.2
            nodejs:
              Installed: 18.20.2-1nodesource1
              Candidate: 18.20.2-1nodesource1
              Version table:
             *** 18.20.2-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 18.20.1-1nodesource1 1001
                 18.20.0-1nodesource1 1001
                 18.19.1-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u1 500
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.19
            admin:          6.13.16
            javascript:     7.8.0
            nodejs modules from github:     1
            +-- iobroker.sourceanalytix@0.4.8-alpha.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#eacbbdeadf4c4bd44636743bc6f52dd21c6f0766)
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
              system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
              system.adapter.email.0                  : email                 : raspberrypi                              - disabled
              system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
              system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
              system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
              system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
              system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
            + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
              system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
              system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
              system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1882, bind: 192.168.178.23
              system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              - disabled, port: 1886, bind: 0.0.0.0
              system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
              system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
              system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
              system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
              system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
              system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1883
              system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
              system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
              system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : raspberrypi                              - disabled
              system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
              system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
              system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
              system.adapter.zigbee.1                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Active repo(s): Stable (default)
            Installed ioBroker-Instances
            Used repository: Stable (default)
            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
            Adapter    "discovery"    : 4.4.0    , installed 4.4.0
            Adapter    "email"        : 1.2.2    , installed 1.2.2
            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
            Adapter    "ical"         : 1.14.3   , installed 1.14.3
            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
            Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "onvif"        : 1.1.3    , installed 1.1.3
            Adapter    "openweathermap": 1.0.4   , installed 1.0.4
            Adapter    "pushover"     : 3.0.6    , installed 3.0.6
            Adapter    "shelly"       : 6.9.0    , installed 6.9.0
            Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "telegram"     : 3.2.1    , installed 3.2.1
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "worx"         : 2.3.4    , installed 2.3.4
            Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        11125
            States:         9533
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://repos.influxdata.com/debian stable InRelease
            Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:6 https://apt.grafana.com stable InRelease
            Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        2951       752/influxd
            tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      108        5759       678/motion
            tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      108        5758       678/motion
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1685       682/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5871       833/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5864       833/iobroker.js-con
            tcp6       0      0 :::3000                 :::*                    LISTEN      107        1857       832/grafana
            tcp6       0      0 :::22                   :::*                    LISTEN      0          1687       682/sshd: /usr/sbin
            tcp6       0      0 :::8086                 :::*                    LISTEN      106        5841       752/influxd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5931       876/io.admin.0
            udp        0      0 0.0.0.0:56049           0.0.0.0:*                           104        5664       534/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5662       534/avahi-daemon: r
            udp6       0      0 :::55982                :::*                                104        5665       534/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        5663       534/avahi-daemon: r
            2024-05-06 14:32:13.828  - error: host.raspberrypi iobroker npm-install: npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_04_539Z-debug-0.log
            2024-05-06 14:32:13.829  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.mihome-vacuum@4.0.0: 127
            2024-05-06 14:32:14.856  - info: host.raspberrypi iobroker npm-install: exit 25
            2024-05-06 14:32:15.856  - warn: host.raspberrypi startInstance cannot find adapter "sayit@1.12.3". Try to install it... 3 attempt
            2024-05-06 14:32:15.857  - info: host.raspberrypi iobroker install sayit@1.12.3 using installedVersion
            2024-05-06 14:32:19.039  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0
            2024-05-06 14:32:19.042  - info: host.raspberrypi iobroker npm-install: Installing iobroker.sayit@1.12.3... (System call)
            2024-05-06 14:32:35.524  - error: host.raspberrypi iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.sayitnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! node:internal/modules/cjs/loader:1143npm ERR!   throw err;npm ERR!   ^npm ERR! npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'npm ERR! Require stack:npm ERR! - /opt/iobroker/node_modules/iobroker.sayit/main.jsnpm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)npm ERR!     at Module._load (node:internal/modules/cjs/loader:981:27)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1231:19)npm ERR!     at require (node:internal/modules/helpers:177:18)npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sayit/main.js:17:61)npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1364:14)npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)npm ERR!     at Module.load (node:internal/modules/cjs/loader:1203:32)npm ERR!     at Module._load (node:internal/modules/cjs/loader:1019:12)npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {npm ERR!   code: 'MODULE_NOT_FOUND',npm ERR!   requireStack: [ '/opt/iobroker/node_modules/iobroker.sayit/main.js' ]npm ERR! }npm ERR! npm ERR! Node.js v18.20.2npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_19_779Z-debug-0.log
            2024-05-06 14:32:35.525  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.sayit@1.12.3: 1
            2024-05-06 14:32:36.555  - info: host.raspberrypi iobroker npm-install: exit 25
            2024-05-06 14:32:37.556  - warn: host.raspberrypi startInstance cannot find adapter "mihome-vacuum@4.0.0". Try to install it... 4 attempt
            2024-05-06 14:32:37.557  - info: host.raspberrypi iobroker install mihome-vacuum@4.0.0 using installedVersion
            2024-05-06 14:32:40.645  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0
            2024-05-06 14:32:40.647  - info: host.raspberrypi iobroker npm-install: Installing iobroker.mihome-vacuum@4.0.0... (System call)
            2024-05-06 14:32:50.493  - error: host.raspberrypi iobroker npm-install: npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_41_399Z-debug-0.loghost.raspberrypi Cannot install iobroker.mihome-vacuum@4.0.0: 127
            2024-05-06 14:32:51.518  - info: host.raspberrypi iobroker npm-install: exit 25
            2024-05-06 14:32:52.519  - warn: host.raspberrypi startInstance cannot find adapter "sayit@1.12.3". Try to install it... 4 attempt
            2024-05-06 14:32:52.519  - info: host.raspberrypi iobroker install sayit@1.12.3 using installedVersion
            2024-05-06 14:32:55.668  - info: host.raspberrypi iobroker npm-install: NPM version: 10.5.0
            2024-05-06 14:32:55.671  - info: host.raspberrypi iobroker npm-install: Installing iobroker.sayit@1.12.3... (System call)
            2024-05-06 14:33:11.937  - error: host.raspberrypi iobroker npm-install: npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/iobroker.sayitnpm ERR! command failednpm ERR! command sh -c node main.js --installnpm ERR! node:internal/modules/cjs/loader:1143npm ERR!   throw err;npm ERR!   ^npm ERR! npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'npm ERR! Require stack:npm ERR! - /opt/iobroker/node_modules/iobroker.sayit/main.jsnpm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)npm ERR!     at Module._load (node:internal/modules/cjs/loader:981:27)npm ERR!     at Module.require (node:internal/modules/cjs/loader:1231:19)npm ERR!     at require (node:internal/modules/helpers:177:18)npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sayit/main.js:17:61)npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1364:14)npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)npm ERR!     at Module.load (node:internal/modules/cjs/loader:1203:32)npm ERR!     at Module._load (node:internal/modules/cjs/loader:1019:12)npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {npm ERR!   code: 'MODULE_NOT_FOUND',npm ERR!   requireStack: [ '/opt/iobroker/node_modules/iobroker.sayit/main.js' ]npm ERR! }npm ERR! npm ERR! Node.js v18.20.2npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-06T12_32_56_377Z-debug-0.log
            2024-05-06 14:33:11.938  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.sayit@1.12.3: 1
            2024-05-06 14:33:12.966  - info: host.raspberrypi iobroker npm-install: exit 25
            2024-05-06 14:33:13.966  - error: host.raspberrypi Cannot download and install adapter "mihome-vacuum@4.0.0". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
            2024-05-06 14:33:14.467  - error: host.raspberrypi Cannot download and install adapter "sayit@1.12.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
              @bill-s-preston
              iob start web
                crunchip Forum Testing Most Active @Bill S. Preston last edited by crunchip
                So viel ich weiß, müssen ggf Ports angepasst werden um Motioneye und iobroker zusammen auf einen Rechner laufen zu lassen
                Unabhängig davon, reichen 4GB RAM da eh nicht aus
                B crunchip 2 Replies Last reply Reply Quote 0
                  @bill-s-preston
                  iob start web
                  Gemacht. Startet noch immer nicht.
                    Bill S. Preston @crunchip last edited by Bill S. Preston
                    @crunchip said in Iobroker startet nicht mehr nach Restore:
                    MoitonEye und Iobroker laufen seit zwei Jahren ohne Probleme zusammen auf einem 4GB Pi.
                    Aber ich habe jetzt bei dem Neuen System versucht MotionEye zu öffnen. Leider ebenfalls Still.
                    MotionEye lläuft aber auf Port 8765. Und wie gesagt, bis gestern vor dem Restore auch ohne Probleme.
                      Homoran Global Moderator Administrators @Bill S. Preston last edited by
                      was genau?
                      wie genau?
                      was passiert?
                        Bill S. Preston @Homoran last edited by
                        @homoran said in Iobroker startet nicht mehr nach Restore:
                        was genau?
                        wie genau?
                        was passiert?
                        Iobroker über den Browser aufrufen (192.168.178.68:8081)
                        Firefox kann keine Verbindung zu dem Server unter 192.168.178.68:8081 aufbauen.
                        Bei MotionEye das gleiche.
                          welcher Browser?
                          und was exakt steht in der Adresszeile?
                            Thomas Braun Most Active last edited by
                            Der Service 'failed' ja auch.
                            Die Adapter 'ws' und 'socketio' bitte auch updaten.
                            War der 'socketio' nicht ohnehin obsolet?
                              welcher Browser?
                              Unter Firefox und Chrome 192.168.178.68:8081 eingegeben.
                                Bill S. Preston last edited by Bill S. Preston
                                Kann es sein, dass sich das Backup vom alten System mit dem neuen beißt?
                                Hier
                                iob start web
                                vom alten noch laufenden System.
                                Skript v.2024-04-21
                                *** BASE SYSTEM ***
                                   Static hostname: iobroker
                                         Icon name: computer
                                  Operating System: Raspbian GNU/Linux 10 (buster)
                                            Kernel: Linux 5.10.103-v7l+
                                      Architecture: arm
                                Model		: Raspberry Pi 4 Model B Rev 1.1
                                Docker          : false
                                Kernel          : armv7l
                                Userland        : 32 bit
                                 11:23:56 up 11:39,  2 users,  load average: 1.59, 1.08, 0.89
                                CPU threads: 4
                                Current issues:
                                               Local time: Mon 2024-05-06 11:23:56 CEST
                                           Universal time: Mon 2024-05-06 09:23:56 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                XDG_CONFIG_HOME=/home/pi/.config
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker myftp
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video bluetooth gpio i2c myftp
                                Display-Server: true
                                Desktop: 	LXDE-pi
                                Terminal: 	x11
                                Boot Target: 	graphical.target
                                *** MEMORY ***
                                Mem:           3.8G        2.0G        260M         92M        1.6G        1.8G
                                Swap:           99M         42M         57M
                                Total:         3.9G        2.0G        317M
                                Active iob-Instances: 	34
                                         3838 M total memory
                                         1980 M used memory
                                          788 M active memory
                                         2619 M inactive memory
                                          259 M free memory
                                          272 M buffer memory
                                         1325 M swap cache
                                           99 M total swap
                                           42 M used swap
                                           57 M free swap
                                top - 11:23:57 up 11:39,  2 users,  load average: 1.59, 1.08, 0.89
                                Tasks: 209 total,   1 running, 207 sleeping,   0 stopped,   1 zombie
                                %Cpu(s):  7.2 us,  5.8 sy,  0.0 ni, 87.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3838.7 total,    259.5 free,   1980.4 used,   1598.8 buff/cache
                                MiB Swap:    100.0 total,     57.7 free,     42.2 used.   1826.4 avail Mem
                                * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
                                1 loaded units listed. Pass --all to see loaded but inactive units, too.
                                To show all installed unit files use 'systemctl list-unit-files'.
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G   22G   34G  40% /
                                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                tmpfs          tmpfs     1.9G  864K  1.9G   1% /dev/shm
                                tmpfs          tmpfs     1.9G   57M  1.9G   3% /run
                                tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                /dev/sda1      ext4       57G   33G   21G  61% /backup
                                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                                tmpfs          tmpfs     384M  4.0K  384M   1% /run/user/1000
                                [Sun May  5 23:44:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1024x768M@60D smsc95xx.macaddr=DC:A6:32:30:EB:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5cd8a1b8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                [Sun May  5 23:44:19 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                [Sun May  5 23:44:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Sun May  5 23:44:22 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                [Sun May  5 23:44:25 2024] EXT4-fs (sda1): recovery complete
                                [Sun May  5 23:44:25 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                                |-/dev                                devtmpfs       devtmpfs        rw,relatime,size=1800568k,nr_inodes=84157,mode=755
                                | `-/dev/mqueue                       mqueue         mqueue          rw,relatime
                                | |-/sys/fs/cgroup                    tmpfs          tmpfs           ro,nosuid,nodev,noexec,mode=755
                                | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate
                                | | |-/sys/fs/cgroup/systemd          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                                | | |-/sys/fs/cgroup/blkio            cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,blkio
                                | | |-/sys/fs/cgroup/pids             cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,pids
                                | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                                | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                                | | |-/sys/fs/cgroup/freezer          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,freezer
                                | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,perf_event
                                | | |-/sys/fs/cgroup/devices          cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,devices
                                | | `-/sys/fs/cgroup/cpuset           cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpuset
                                | |-/sys/fs/bpf                       none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                                | |-/sys/kernel/debug                 debugfs        debugfs         rw,relatime
                                | |-/sys/kernel/config                configfs       configfs        rw,relatime
                                | `-/sys/fs/fuse/connections          fusectl        fusectl         rw,relatime
                                | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs          rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                |-/run                                tmpfs          tmpfs           rw,nosuid,nodev,mode=755
                                | `-/run/user/1000                    tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
                                |   `-/run/user/1000/gvfs             gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                |-/backup                             /dev/sda1      ext4            rw,relatime
                                `-/boot                               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                2.9G	/var/
                                1.4G	/var/lib
                                1.2G	/var/lib/influxdb/data
                                1.1G	/var/lib/influxdb/data/iobroker
                                Archived and active journals take up 55.9M in the file system.
                                6.3G	/opt/iobroker/backups/
                                414M	/opt/iobroker/iobroker-data/
                                195M	/opt/iobroker/iobroker-data/files
                                132M	/opt/iobroker/iobroker-data/backup-objects
                                51M	/opt/iobroker/iobroker-data/files/javascript.admin
                                33M	/opt/iobroker/iobroker-data/files/web.admin/static
                                22M	/opt/iobroker/iobroker-data/objects.jsonl
                                18M	/opt/iobroker/iobroker-data/states.jsonl
                                9.7M	/opt/iobroker/iobroker-data/objects.json.migrated
                                9.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100FNC-if03
                                /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100FNC-if00
                                HINT:
                                /dev/ttyACM0
                                /usr/bin/npm 		10.5.0
                                /usr/bin/npx 		10.5.0
                                nodejs:
                                  Version table:
                                 *** 18.20.2-1nodesource1 600
                                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                     18.20.1-1nodesource1 600
                                     18.20.0-1nodesource1 600
                                     18.19.1-1nodesource1 600
                                     18.19.0-1nodesource1 600
                                     18.18.2-1nodesource1 600
                                     18.18.1-1nodesource1 600
                                     18.18.0-1nodesource1 600
                                     18.17.1-1nodesource1 600
                                     18.17.0-1nodesource1 600
                                     18.16.1-1nodesource1 600
                                     18.16.0-1nodesource1 600
                                     18.15.0-1nodesource1 600
                                     18.14.2-1nodesource1 600
                                     18.14.1-1nodesource1 600
                                     18.14.0-1nodesource1 600
                                     18.13.0-1nodesource1 600
                                     18.12.0-1nodesource1 600
                                     18.11.0-1nodesource1 600
                                     18.10.0-1nodesource1 600
                                     18.9.1-1nodesource1 600
                                     18.9.0-1nodesource1 600
                                     18.8.0-1nodesource1 600
                                     18.7.0-1nodesource1 600
                                     18.6.0-1nodesource1 600
                                     18.5.0-1nodesource1 600
                                     18.4.0-1nodesource1 600
                                     18.3.0-1nodesource1 600
                                     18.2.0-1nodesource1 600
                                     18.1.0-1nodesource1 600
                                     18.0.0-1nodesource1 600
                                     10.24.0~dfsg-1~deb10u3 500
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                js-controller: 	4.0.24
                                admin: 		6.13.16
                                javascript: 	6.1.4
                                nodejs modules from github: 	0
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                  system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                                + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.23
                                + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
                                + system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
                                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883
                                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                + instance is alive
                                Adapter    "cloud"        : 5.0.1    , installed 4.1.0  [Updatable]
                                Adapter    "discovery"    : 4.4.0    , installed 2.6.1  [Updatable]
                                Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
                                Adapter    "email"        : 1.2.2    , installed 1.0.9  [Updatable]
                                Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                                Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
                                Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
                                Adapter    "heatingcontrol": 2.12.5  , installed 2.3.2  [Updatable]
                                Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.16 [Updatable]
                                Adapter    "ical"         : 1.14.3   , installed 1.7.4  [Updatable]
                                Adapter    "icons-mfd-svg": 1.2.0    , installed 1.0.2  [Updatable]
                                Adapter    "javascript"   : 7.8.0    , installed 6.1.4  [Updatable]
                                Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
                                Adapter    "lgtv"         : 2.2.0    , installed 2.1.1  [Updatable]
                                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                Adapter    "mihome-vacuum": 4.2.0    , installed 4.0.0  [Updatable]
                                Adapter    "mqtt"         : 5.2.0    , installed 2.4.0  [Updatable]
                                Adapter    "onvif"        : 1.1.3    , installed 0.4.4  [Updatable]
                                Adapter    "openweathermap": 1.0.4   , installed 0.3.3  [Updatable]
                                Adapter    "paw"          : 0.3.2    , installed 0.3.2
                                Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
                                Adapter    "shelly"       : 6.9.0    , installed 6.3.1  [Updatable]
                                Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                                Adapter    "telegram"     : 3.2.1    , installed 1.8.1  [Updatable]
                                Adapter    "text2command" : 3.0.3    , installed 2.3.0  [Updatable]
                                Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                                Adapter    "vis-icontwo"  : 1.5.0    , installed 0.93.0 [Updatable]
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.3  [Updatable]
                                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                                Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
                                Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
                                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                Objects and States
                                Objects: 	11713
                                States: 	10121
                                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Some index files failed to download. They have been ignored, or old ones used instead.
                                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                Get:2 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
                                Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Err:2 https://repos.influxdata.com/debian buster InRelease
                                Fetched 12.9 kB in 2s (8498 B/s)
                                Pending Updates: 0
                                tcp        0      0 192.168.178.23:2001     0.0.0.0:*               LISTEN      1001       536573     3566/io.hm-rpc.3
                                tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      117        19738      705/proftpd: (accep
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18287      559/sshd
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          41534      3077/cupsd
                                tcp        0      0 0.0.0.0:5656            0.0.0.0:*               LISTEN      0          18860      779/motion
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19649      517/influxd
                                tcp        0      0 192.168.178.23:2010     0.0.0.0:*               LISTEN      1001       539134     3448/io.hm-rpc.1
                                tcp        0      0 192.168.178.23:1882     0.0.0.0:*               LISTEN      1001       539067     3394/io.mqtt.0
                                tcp        0      0 0.0.0.0:9595            0.0.0.0:*               LISTEN      0          18861      779/motion
                                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       539216     3521/io.sonoff.0
                                tcp        0      0 192.168.178.23:8701     0.0.0.0:*               LISTEN      1001       539127     3441/io.hm-rpc.0
                                tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          18979      428/python2
                                tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          14225      526/anydesk
                                tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          18862      779/motion
                                tcp        0      0 0.0.0.0:38149           0.0.0.0:*               LISTEN      0          525839     526/anydesk
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       536192     3307/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       536185     3307/iobroker.js-co
                                tcp        0      0 192.168.178.23:9292     0.0.0.0:*               LISTEN      1001       541006     3463/io.hm-rpc.2
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       541910     3710/io.web.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        22642      517/influxd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          18289      559/sshd
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          41533      3077/cupsd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      110        20755      513/grafana-server
                                tcp6       0      0 :::7777                 :::*                    LISTEN      1001       538566     3325/io.admin.0
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       540354     3502/io.shelly.0
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19750      445/dhcpcd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          41552      3079/cups-browsed
                                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       541081     3536/io.mihome-vacu
                                udp        0      0 192.168.178.23:5353     0.0.0.0:*                           1001       539137     3420/io.tr-064.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17531      374/avahi-daemon: r
                                udp        0      0 0.0.0.0:47875           0.0.0.0:*                           108        17533      374/avahi-daemon: r
                                udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          22556      526/anydesk
                                udp6       0      0 :::5353                 :::*                                108        17532      374/avahi-daemon: r
                                udp6       0      0 :::33120                :::*                                108        17534      374/avahi-daemon: r
                                2024-05-06 11:24:16.473  - warn: javascript.0 (3382)     at processImmediate (node:internal/timers:476:21)
                                2024-05-06 11:24:16.473  - warn: javascript.0 (3382) State "javascript.0.Stromverbrauch.Stromkosten_vorheriger_Tag" not found
                                2024-05-06 11:24:16.475  - warn: javascript.0 (3382)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                                2024-05-06 11:24:16.475  - warn: javascript.0 (3382)     at Object.<anonymous> (script.js.Verbräuche.Stromverbrauch_gestern:5:3)
                                2024-05-06 11:24:16.477  - warn: javascript.0 (3382)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                                2024-05-06 11:24:16.477  - warn: javascript.0 (3382)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                                2024-05-06 11:24:16.478  - warn: javascript.0 (3382)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                                2024-05-06 11:24:16.478  - warn: javascript.0 (3382)     at processImmediate (node:internal/timers:476:21)
                                2024-05-06 11:24:21.813  - info: meross.0 (3483) Can not get Data for Device 1909127883156625186348e1e9034905: Error: Timeout
                                2024-05-06 11:24:21.814  - warn: meross.0 (3483) Can not get Data for Device 1909127883156625186348e1e9034905: undefined
                                2024-05-06 11:24:21.835  - info: meross.0 (3483) Can not get Data for Device 1801301547342725131134298f115e90: Error: Timeout
                                2024-05-06 11:24:21.836  - warn: meross.0 (3483) Can not get Data for Device 1801301547342725131134298f115e90: undefined
                                2024-05-06 11:24:21.864  - info: meross.0 (3483) Can not get Data for Device 1801306356734125131134298f115f59: Error: Timeout
                                2024-05-06 11:24:21.865  - warn: meross.0 (3483) Can not get Data for Device 1801306356734125131134298f115f59: undefined
                                2024-05-06 11:24:21.899  - info: meross.0 (3483) Can not get Data for Device 1801300540186725131134298f115ef4: Error: Timeout
                                2024-05-06 11:24:21.900  - warn: meross.0 (3483) Can not get Data for Device 1801300540186725131134298f115ef4: undefined
                                2024-05-06 11:24:40.484  - debug: onvif.0 (3778) startCameras
                                2024-05-06 11:24:40.521  - debug: onvif.0 (3778) getDevices: [{"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
                                2024-05-06 11:24:40.522  - debug: onvif.0 (3778) setCameras: [{"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
                                2024-05-06 11:24:40.523  - debug: onvif.0 (3778) classCam: item = {"type":"device","common":{"name":"192_168_178_47_8899"},"native":{"id":"192_168_178_47_8899","name":"192.168.178.47:8899","ip":"192.168.178.47","port":"8899","user":"C5Xz73SD","password":"XEDRuAwrFddzE9XP","cam_date":"2021-05-18T14:58:39.000Z","info":{"manufacturer":"WVC","model":"W5S","firmwareVersion":"07.26200.05.04","serialNumber":"WVCA98KGIRPCRUMC","hardwareId":"FFFFFFE0-09-FFFFFFBF-6F-33-15"},"events":true,"subscribeEvents":true,"live_stream_tcp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_udp":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"},"live_stream_multicast":{"uri":"rtsp://192.168.178.47:554/live/ch0?token=12fb11e6e41ab914a76c533db4359c24","invalidAfterConnect":false,"invalidAfterReboot":false,"timeout":"PT0H50M0S"}},"from":"system.adapter.onvif.0","user":"system.user.admin","ts":1676755611510,"_id":"onvif.0.192_168_178_47_8899","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                2024-05-06 11:24:43.681  - error: onvif.0 (3778) classCam. Camera/NVT: "192.168.178.47:8899" Error: connect EHOSTUNREACH 192.168.178.47:8899
                                2024-05-06 11:24:43.682  - debug: onvif.0 (3778) startCameras. cameras: {}
                                2024-05-06 11:24:43.682  - warn: onvif.0 (3778) startCameras: Cameras/NVT unavailables
                                2024-05-06 11:24:52.570  - warn: mqtt.0 (3394) Client [shelly1-E8DB84D496EE] has invalid password(h65cgi) or username(iobroker)
                                2024-05-06 11:25:08.865  - warn: telegram.0 (3790) 1 of 1 recipients are unknown!
                                Hier läuft noch der js-controller: 4.0.24. Im neuen ist der 5.0.19.
                                Wie update ich den ?
                                  Das kann schon sein. Das Alt-System verdient sich diesen Namen ja ganz besonders...
                                  Bring das zuerst mal auf Stand und dann ziehst du mit einem aktuellen Backup um.
                                    Wieso aktualisiert sich der js-controller mit
                                    obroker stop
                                    iobroker update
                                    iobroker upgrade self
                                    iobroker start
                                    nicht?
                                      @bill-s-preston
                                      Ohne Meldungen kann dir das keiner sagen.
                                        korrekt, die Benutzeroberfläche, die cams selbst aber dann 8081, 8082, 8083 usw
                                        daher auch auf deinem Alt System
                                          @crunchip
                                          cd /opt/iobroker
                                          sudo iobroker set admin.0 --port 7777
                                          hat geholfen. Iobroker kann wieder erreicht werden. 👍
                                          Nun fehlt noch MotionEye .
                                          Hier bekomme ich folgende meldung
                                          herke@raspberrypi:~ $ sudo systemctl status motioneye
                                          × motioneye.service - motionEye Server
                                               Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: en>
                                               Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s>
                                             Duration: 1.494s
                                              Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioney>
                                             Main PID: 1403 (code=exited, status=255/EXCEPTION)
                                                  CPU: 1.493s
                                          May 07 07:55:22 raspberrypi systemd[1]: Started motioneye.service - motionEye S>
                                          May 07 07:55:23 raspberrypi meyectl[1403]: configure_logging cmd motioneye: Fal>
                                          May 07 07:55:23 raspberrypi meyectl[1403]: configure logging to file: None
                                          May 07 07:55:23 raspberrypi meyectl[1403]:     INFO: hello! this is motionEye s>
                                          May 07 07:55:23 raspberrypi meyectl[1403]: CRITICAL: pid directory "/var/run" d>
                                          May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Main process exited,>
                                          May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Failed with result '>
                                          May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Consumed 1.493s CPU >
                                          lines 1-16/16 (END)
                                               Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: enabled)
                                               Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s ago
                                             Duration: 1.494s
                                              Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioneye/moti>
                                                  CPU: 1.493s
                                          Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
                                            @bill-s-preston
                                            Bitte NIE, NIE, NIE das iobroker-Kommando per sudo anpacken.
                                            iob stop
                                            iob fix
                                            iob start
                                            2388
