    4. Iobroker startet nicht mehr nach Restore
      Thomas Braun Most Active @Bill S. Preston last edited by
      @bill-s-preston
      Ohne Meldungen kann dir das keiner sagen.
        crunchip Forum Testing Most Active @Bill S. Preston last edited by crunchip
        @bill-s-preston sagte in Iobroker startet nicht mehr nach Restore:
        MotionEye lläuft aber auf Port 8765
        korrekt, die Benutzeroberfläche, die cams selbst aber dann 8081, 8082, 8083 usw
        daher auch auf deinem Alt System
        admin : iobroker - enabled, port: 7777
          Bill S. Preston @crunchip last edited by
          @crunchip
          cd /opt/iobroker
          sudo iobroker set admin.0 --port 7777
          hat geholfen. Iobroker kann wieder erreicht werden. 👍
          Nun fehlt noch MotionEye .
          Hier bekomme ich folgende meldung
          herke@raspberrypi:~ $ sudo systemctl status motioneye
          × motioneye.service - motionEye Server
               Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: en>
               Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s>
             Duration: 1.494s
              Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioney>
             Main PID: 1403 (code=exited, status=255/EXCEPTION)
                  CPU: 1.493s
          May 07 07:55:22 raspberrypi systemd[1]: Started motioneye.service - motionEye S>
          May 07 07:55:23 raspberrypi meyectl[1403]: configure_logging cmd motioneye: Fal>
          May 07 07:55:23 raspberrypi meyectl[1403]: configure logging to file: None
          May 07 07:55:23 raspberrypi meyectl[1403]:     INFO: hello! this is motionEye s>
          May 07 07:55:23 raspberrypi meyectl[1403]: CRITICAL: pid directory "/var/run" d>
          May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Main process exited,>
          May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Failed with result '>
          May 07 07:55:23 raspberrypi systemd[1]: motioneye.service: Consumed 1.493s CPU >
          lines 1-16/16 (END)
               Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; preset: enabled)
               Active: failed (Result: exit-code) since Tue 2024-05-07 07:55:23 CEST; 18s ago
             Duration: 1.494s
              Process: 1403 ExecStart=/usr/local/bin/meyectl startserver -c /etc/motioneye/moti>
                  CPU: 1.493s
          Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
            @bill-s-preston
            Bitte NIE, NIE, NIE das iobroker-Kommando per sudo anpacken.
            iob stop
            iob fix
            iob start
              @bill-s-preston
              Und mach das Fenster von deinem Terminal groß. In der Ausgabe fehlen die Zeilenenden.
                Bill S. Preston @Thomas Braun last edited by
                @thomas-braun said in Iobroker startet nicht mehr nach Restore:
                @bill-s-preston
                iob stop
                iob fix
                iob start
                Alles klar. Was kann passieren wenn sudo benutzt wird?
                  Thomas Braun Most Active last edited by
                  Alles, weil der root halt alles darf.
                  Du verbiegst dir damit aber die vorgesehenen Rechte für die anderen user.
                    Danke für die Info und für die Gedult!
                    Ich werde Shinobi installieren auf dem neuen System. Motioneye wird nicht mehr weiterentwickelt .
                      @bill-s-preston eventuell
                      https://github.com/motioneye-project/motioneye/issues/2657
                      roelvdwater created this issue in motioneye-project/motioneye
                      open Permission issues on a fresh install of Rasperry Pi OS Bullseye #2657
                        Doch es wird an einer neuen Version gearbeitet
                          Bill S. Preston @crunchip last edited by Bill S. Preston
                          @crunchip
                          MotionEye deinstalieren funktionier nicht
                          herke@raspberrypi:~ $ pip uninstall motioneye
                          Found existing installation: motioneye 0.43.1b1
                          Uninstalling motioneye-0.43.1b1:
                            Would remove:
                              /usr/local/bin/motioneye_init
                              /usr/local/lib/python3.11/dist-packages/motioneye-0.43.1b1.dist-info/*
                              /usr/local/lib/python3.11/dist-packages/motioneye/*
                          Proceed (Y/n)? y
                          ERROR: Exception:
                          Traceback (most recent call last):
                            File "/usr/lib/python3.11/shutil.py", line 825, in move
                              os.rename(src, real_dst)
                          PermissionError: [Errno 13] Permission denied: '/usr/local/bin/meyectl' -> '/tmp/pip-uninstall-eit5jf_4/meyectl'
                          During handling of the above exception, another exception occurred:
                            File "/usr/local/lib/python3.11/dist-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper
                              status = run_func(*args)
                            File "/usr/local/lib/python3.11/dist-packages/pip/_internal/commands/uninstall.py", line 105, in run
                              uninstall_pathset = req.uninstall(
                            File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_install.py", line 727, in uninstall
                              uninstalled_pathset.remove(auto_confirm, verbose)
                            File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 380, in remove
                              moved.stash(path)
                            File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 271, in stash
                              renames(path, new_path)
                            File "/usr/local/lib/python3.11/dist-packages/pip/_internal/utils/misc.py", line 358, in renames
                              shutil.move(old, new)
                            File "/usr/lib/python3.11/shutil.py", line 846, in move
                              os.unlink(src)
                          und
                          Shinobi wird nach der Installation auch nicht erreicht über 192.168.178.68:8080
                          herke@raspberrypi:~ $ bash <(curl -s https://gitlab.com/Shinobi-Systems/Shinobi-        Installer/raw/master/shinobi-install.sh)
                          Opening Install Location : "/home"
                          *Shinobi requires being run as root.
                          *Do you want to continue without being root?
                          (Y)es or (n)o? Default : Yes
                          y
                          Install the Development branch?
                          (y)es or (N)o? Default : No
                          n
                          Getting the Master Branch
                          Cloning into 'Shinobi'...
                          remote: Enumerating objects: 23189, done.
                          remote: Counting objects: 100% (148/148), done.
                          remote: Compressing objects: 100% (113/113), done.
                          remote: Total 23189 (delta 61), reused 78 (delta 35), pack-reused 23041 (from 1)
                          Receiving objects: 100% (23189/23189), 16.76 MiB | 11.07 MiB/s, done.
                          Resolving deltas: 100% (15552/15552), done.
                          fatal: detected dubious ownership in repository at '/home/Shinobi'
                          To add an exception for this directory, call:
                                  git config --global --add safe.directory /home/Shinobi
                          ---------- Shinobi Systems ----------
                          Repository : https://gitlab.com/Shinobi-Systems/Shinobi
                          Product : Shinobi Professional (Pro)
                          Branch : master
                          Version :
                          Date : Tue  7 May 10:20:37 CEST 2024
                          Shinobi Installer
                          Select your OS
                          If your OS is not on the list please refer to the docs.
                          1. Ubuntu - Fast and Touchless
                          2. Ubuntu - Advanced
                          3. Alma Linux 9.2 / Rocky 9 / CentOS 8 - Fast and Touchless (Red Hat)
                          4. CentOS
                          5. MacOS
                          6. FreeBSD
                          7. OpenSUSE
                          ==!! Shinobi : The Open Source CCTV and NVR Solution !!==
                          To answer yes type the letter (y) in lowercase and press ENTER.
                          Default is no (N). Skip any components you already have or don't need.
                           Detecting Ubuntu Version
                           Ubuntu Version: 12
                          Shinobi - Do you want to temporarily disable IPv6?
                          Sometimes IPv6 causes Ubuntu package updates to fail. Only do this if your machi        ne doesn't rely on IPv6.
                          (y)es or (N)o
                          y
                          net.ipv6.conf.all.disable_ipv6 = 1
                          net.ipv6.conf.default.disable_ipv6 = 1
                          net.ipv6.conf.lo.disable_ipv6 = 1
                          Reading package lists... Done
                          Building dependency tree... Done
                          gcc is already the newest version (4:12.2.0-3).
                          g++ is already the newest version (4:12.2.0-3).
                          g++ set to manually installed.
                          cmake is already the newest version (3.25.1-1).
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          update-alternatives: error: alternative path /usr/bin/gcc-8 doesn't exist
                          Default Superuser : admin@shinobi.video
                          Default Password : admin
                          * You can edit these settings in "super.json" located in the Shinobi directory.
                          Shinobi - Installing Node.js
                          Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
                          Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                          Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB]
                          Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
                          Get:6 https://apt.grafana.com stable InRelease [7,660 B]
                          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [153 kB]
                          Get:9 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [150 kB]
                          Get:10 http://deb.debian.org/debian-security bookworm-security/main Translation-        en [95.1 kB]
                          Get:11 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [387 k        B]
                          Get:12 https://apt.grafana.com stable/main arm64 Packages [194 kB]
                          Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [397 k        B]
                          Get:14 https://apt.grafana.com stable/main armhf Packages [171 kB]
                          Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [10.7 kB]
                          Fetched 1,699 kB in 2s (1,023 kB/s)
                          ca-certificates is already the newest version (20230311).
                          curl is already the newest version (7.88.1-10+deb12u5).
                          gnupg is already the newest version (2.2.40-1.1).
                          File '/etc/apt/keyrings/nodesource.gpg' exists. Overwrite? (y/N) n
                          Enter new filename: shinobigeil
                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          Hit:6 https://apt.grafana.com stable InRelease
                          nodejs is already the newest version (18.20.2-1nodesource1).
                          make is already the newest version (4.3-4.1).
                          make set to manually installed.
                          zip is already the newest version (3.0-13).
                          FFmpeg Found...
                          Version : ffmpeg version 5.1.4-0+rpt3+deb12u1 Copyright (c) 2000-2023 the FFmpeg        developers
                          built with gcc 12 (Debian 12.2.0-14)
                          configuration: --prefix=/usr --extra-version=0+rpt3+deb12u1 --toolchain=hardened        --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --disa        ble-mmal --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enabl        e-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec        2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetyp        e --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enab        le-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-        libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-libr        ist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr        --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-l        ibtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-lib        vpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable        -libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-ope        nal --enable-opencl --enable-opengl --enable-sand --enable-sdl2 --disable-sndio        --enable-libjxl --enable-neon --enable-v4l2-request --enable-libudev --enable-ep        oxy --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-pocketsphinx --ena        ble-librsvg --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec        61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo        --enable-librav1e --enable-shared
                          libavutil      57. 28.100 / 57. 28.100
                          libavcodec     59. 37.100 / 59. 37.100
                          libavformat    59. 27.100 / 59. 27.100
                          libavdevice    59.  7.100 / 59.  7.100
                          libavfilter     8. 44.100 /  8. 44.100
                          libswscale      6.  7.100 /  6.  7.100
                          libswresample   4.  7.100 /  4.  7.100
                          libpostproc    56.  6.100 / 56.  6.100
                          Shinobi - Installing MariaDB
                          MariaDB will be installed with no password.
                          The following additional packages will be installed:
                            galera-4 gawk libcgi-fast-perl libcgi-pm-perl libclone-perl
                            libconfig-inifiles-perl libdaxctl1 libdbd-mariadb-perl libdbi-perl
                            libencode-locale-perl libfcgi-bin libfcgi-perl libfcgi0ldbl libgpm2
                            libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl
                            libhttp-date-perl libhttp-message-perl libio-html-perl
                            liblwp-mediatypes-perl libncurses6 libndctl6 libpmem1 libregexp-ipv6-perl
                            libsigsegv2 libterm-readkey-perl libtimedate-perl liburi-perl liburing2 lsof
                            mariadb-client mariadb-client-core mariadb-plugin-provider-bzip2
                            mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma
                            mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy
                            mariadb-server-core pv socat
                          Suggested packages:
                            gawk-doc libmldbm-perl libnet-daemon-perl libsql-statement-perl gpm
                            libdata-dump-perl libipc-sharedcache-perl libbusiness-isbn-perl libwww-perl
                            mailx mariadb-test netcat-openbsd doc-base
                          The following NEW packages will be installed:
                            mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy mariadb-server
                          0 upgraded, 42 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 18.1 MB of archives.
                          After this operation, 196 MB of additional disk space will be used.
                          Get:1 http://deb.debian.org/debian bookworm/main arm64 libsigsegv2 arm64 2.14-1        [37.0 kB]
                          Get:2 http://deb.debian.org/debian bookworm/main arm64 gawk arm64 1:5.2.1-2 [640        kB]
                          Get:3 http://deb.debian.org/debian bookworm/main arm64 galera-4 arm64 26.4.13-1        [702 kB]
                          Get:4 http://deb.debian.org/debian bookworm/main arm64 libdbi-perl arm64 1.643-4        [767 kB]
                          Get:5 http://deb.debian.org/debian bookworm/main arm64 lsof arm64 4.95.0-1 [313        kB]
                          Get:6 http://deb.debian.org/debian bookworm/main arm64 libconfig-inifiles-perl a        ll 3.000003-2 [45.9 kB]
                          Get:7 http://deb.debian.org/debian bookworm/main arm64 libncurses6 arm64 6.4-4 [        93.9 kB]
                          Get:8 http://deb.debian.org/debian bookworm/main arm64 mariadb-client-core arm64        1:10.11.6-0+deb12u1 [846 kB]
                          Get:9 http://deb.debian.org/debian bookworm/main arm64 mariadb-client arm64 1:10        .11.6-0+deb12u1 [2,865 kB]
                          Get:10 http://deb.debian.org/debian bookworm/main arm64 libdaxctl1 arm64 76.1-1        [19.8 kB]
                          Get:11 http://deb.debian.org/debian bookworm/main arm64 libndctl6 arm64 76.1-1 [        57.4 kB]
                          Get:12 http://deb.debian.org/debian bookworm/main arm64 libpmem1 arm64 1.12.1-2        [45.7 kB]
                          Get:13 http://deb.debian.org/debian bookworm/main arm64 liburing2 arm64 2.3-3 [1        2.6 kB]
                          Get:14 http://deb.debian.org/debian bookworm/main arm64 mariadb-server-core arm6        4 1:10.11.6-0+deb12u1 [6,734 kB]
                          Get:15 http://deb.debian.org/debian bookworm/main arm64 socat arm64 1.7.4.4-2 [3        66 kB]
                          Get:16 http://deb.debian.org/debian bookworm/main arm64 mariadb-server arm64 1:1        0.11.6-0+deb12u1 [3,447 kB]
                          Get:17 http://deb.debian.org/debian bookworm/main arm64 libhtml-tagset-perl all        3.20-6 [11.7 kB]
                          Get:18 http://deb.debian.org/debian bookworm/main arm64 libregexp-ipv6-perl all        0.03-3 [5,212 B]
                          Get:19 http://deb.debian.org/debian bookworm/main arm64 liburi-perl all 5.17-1 [        90.4 kB]
                          Get:20 http://deb.debian.org/debian bookworm/main arm64 libhtml-parser-perl arm6        4 3.81-1 [98.6 kB]
                          Get:21 http://deb.debian.org/debian bookworm/main arm64 libcgi-pm-perl all 4.55-        1 [220 kB]
                          Get:22 http://deb.debian.org/debian bookworm/main arm64 libfcgi0ldbl arm64 2.4.2        -2 [25.3 kB]
                          Get:23 http://deb.debian.org/debian bookworm/main arm64 libfcgi-perl arm64 0.82+        ds-2 [24.4 kB]
                          Get:24 http://deb.debian.org/debian bookworm/main arm64 libcgi-fast-perl all 1:2        .15-1 [12.1 kB]
                          Get:25 http://deb.debian.org/debian bookworm/main arm64 libclone-perl arm64 0.46        -1 [13.5 kB]
                          Get:26 http://deb.debian.org/debian bookworm/main arm64 libdbd-mariadb-perl arm6        4 1.22-1+b1 [89.1 kB]
                          Get:27 http://deb.debian.org/debian bookworm/main arm64 libencode-locale-perl al        l 1.05-3 [12.9 kB]
                          Get:28 http://deb.debian.org/debian bookworm/main arm64 libfcgi-bin arm64 2.4.2-        2 [12.5 kB]
                          Get:29 http://deb.debian.org/debian bookworm/main arm64 libgpm2 arm64 1.20.7-10+        b1 [14.4 kB]
                          Get:30 http://deb.debian.org/debian bookworm/main arm64 libhtml-template-perl al        l 2.97-2 [66.5 kB]
                          Get:31 http://deb.debian.org/debian bookworm/main arm64 libtimedate-perl all 2.3        300-2 [39.3 kB]
                          Get:32 http://deb.debian.org/debian bookworm/main arm64 libhttp-date-perl all 6.        05-2 [10.5 kB]
                          Get:33 http://deb.debian.org/debian bookworm/main arm64 libio-html-perl all 1.00        4-3 [16.2 kB]
                          Get:34 http://deb.debian.org/debian bookworm/main arm64 liblwp-mediatypes-perl a        ll 6.04-2 [20.2 kB]
                          Get:35 http://deb.debian.org/debian bookworm/main arm64 libhttp-message-perl all        6.44-1 [81.7 kB]
                          Get:36 http://deb.debian.org/debian bookworm/main arm64 libterm-readkey-perl arm        64 2.38-2+b1 [24.1 kB]
                          Get:37 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        bzip2 arm64 1:10.11.6-0+deb12u1 [24.9 kB]
                          Get:38 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lz4 arm64 1:10.11.6-0+deb12u1 [24.8 kB]
                          Get:39 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lzma arm64 1:10.11.6-0+deb12u1 [24.9 kB]
                          Get:40 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        lzo arm64 1:10.11.6-0+deb12u1 [24.8 kB]
                          Get:41 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider-        snappy arm64 1:10.11.6-0+deb12u1 [24.9 kB]
                          Get:42 http://deb.debian.org/debian bookworm/main arm64 pv arm64 1.6.20-1 [58.6        kB]
                          Fetched 18.1 MB in 2s (10.3 MB/s)
                          Extracting templates from packages: 100%
                          Preconfiguring packages ...
                          Selecting previously unselected package libsigsegv2:arm64.
                          (Reading database ... 103045 files and directories currently installed.)
                          Preparing to unpack .../libsigsegv2_2.14-1_arm64.deb ...
                          Unpacking libsigsegv2:arm64 (2.14-1) ...
                          Setting up libsigsegv2:arm64 (2.14-1) ...
                          Selecting previously unselected package gawk.
                          (Reading database ... 103054 files and directories currently installed.)
                          Preparing to unpack .../00-gawk_1%3a5.2.1-2_arm64.deb ...
                          Unpacking gawk (1:5.2.1-2) ...
                          Selecting previously unselected package galera-4.
                          Preparing to unpack .../01-galera-4_26.4.13-1_arm64.deb ...
                          Unpacking galera-4 (26.4.13-1) ...
                          Selecting previously unselected package libdbi-perl:arm64.
                          Preparing to unpack .../02-libdbi-perl_1.643-4_arm64.deb ...
                          Unpacking libdbi-perl:arm64 (1.643-4) ...
                          Selecting previously unselected package lsof.
                          Preparing to unpack .../03-lsof_4.95.0-1_arm64.deb ...
                          Unpacking lsof (4.95.0-1) ...
                          Selecting previously unselected package libconfig-inifiles-perl.
                          Preparing to unpack .../04-libconfig-inifiles-perl_3.000003-2_all.deb ...
                          Unpacking libconfig-inifiles-perl (3.000003-2) ...
                          Selecting previously unselected package libncurses6:arm64.
                          Preparing to unpack .../05-libncurses6_6.4-4_arm64.deb ...
                          Unpacking libncurses6:arm64 (6.4-4) ...
                          Selecting previously unselected package mariadb-client-core.
                          Preparing to unpack .../06-mariadb-client-core_1%3a10.11.6-0+deb12u1_arm64.deb .        ..
                          Unpacking mariadb-client-core (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package mariadb-client.
                          Preparing to unpack .../07-mariadb-client_1%3a10.11.6-0+deb12u1_arm64.deb ...
                          Unpacking mariadb-client (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package libdaxctl1:arm64.
                          Preparing to unpack .../08-libdaxctl1_76.1-1_arm64.deb ...
                          Unpacking libdaxctl1:arm64 (76.1-1) ...
                          Selecting previously unselected package libndctl6:arm64.
                          Preparing to unpack .../09-libndctl6_76.1-1_arm64.deb ...
                          Unpacking libndctl6:arm64 (76.1-1) ...
                          Selecting previously unselected package libpmem1:arm64.
                          Preparing to unpack .../10-libpmem1_1.12.1-2_arm64.deb ...
                          Unpacking libpmem1:arm64 (1.12.1-2) ...
                          Selecting previously unselected package liburing2:arm64.
                          Preparing to unpack .../11-liburing2_2.3-3_arm64.deb ...
                          Unpacking liburing2:arm64 (2.3-3) ...
                          Selecting previously unselected package mariadb-server-core.
                          Preparing to unpack .../12-mariadb-server-core_1%3a10.11.6-0+deb12u1_arm64.deb .        ..
                          Unpacking mariadb-server-core (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package socat.
                          Preparing to unpack .../13-socat_1.7.4.4-2_arm64.deb ...
                          Unpacking socat (1.7.4.4-2) ...
                          Selecting previously unselected package mariadb-server.
                          Preparing to unpack .../14-mariadb-server_1%3a10.11.6-0+deb12u1_arm64.deb ...
                          Unpacking mariadb-server (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package libhtml-tagset-perl.
                          Preparing to unpack .../15-libhtml-tagset-perl_3.20-6_all.deb ...
                          Unpacking libhtml-tagset-perl (3.20-6) ...
                          Selecting previously unselected package libregexp-ipv6-perl.
                          Preparing to unpack .../16-libregexp-ipv6-perl_0.03-3_all.deb ...
                          Unpacking libregexp-ipv6-perl (0.03-3) ...
                          Selecting previously unselected package liburi-perl.
                          Preparing to unpack .../17-liburi-perl_5.17-1_all.deb ...
                          Unpacking liburi-perl (5.17-1) ...
                          Selecting previously unselected package libhtml-parser-perl:arm64.
                          Preparing to unpack .../18-libhtml-parser-perl_3.81-1_arm64.deb ...
                          Unpacking libhtml-parser-perl:arm64 (3.81-1) ...
                          Selecting previously unselected package libcgi-pm-perl.
                          Preparing to unpack .../19-libcgi-pm-perl_4.55-1_all.deb ...
                          Unpacking libcgi-pm-perl (4.55-1) ...
                          Selecting previously unselected package libfcgi0ldbl:arm64.
                          Preparing to unpack .../20-libfcgi0ldbl_2.4.2-2_arm64.deb ...
                          Unpacking libfcgi0ldbl:arm64 (2.4.2-2) ...
                          Selecting previously unselected package libfcgi-perl.
                          Preparing to unpack .../21-libfcgi-perl_0.82+ds-2_arm64.deb ...
                          Unpacking libfcgi-perl (0.82+ds-2) ...
                          Selecting previously unselected package libcgi-fast-perl.
                          Preparing to unpack .../22-libcgi-fast-perl_1%3a2.15-1_all.deb ...
                          Unpacking libcgi-fast-perl (1:2.15-1) ...
                          Selecting previously unselected package libclone-perl:arm64.
                          Preparing to unpack .../23-libclone-perl_0.46-1_arm64.deb ...
                          Unpacking libclone-perl:arm64 (0.46-1) ...
                          Selecting previously unselected package libdbd-mariadb-perl.
                          Preparing to unpack .../24-libdbd-mariadb-perl_1.22-1+b1_arm64.deb ...
                          Unpacking libdbd-mariadb-perl (1.22-1+b1) ...
                          Selecting previously unselected package libencode-locale-perl.
                          Preparing to unpack .../25-libencode-locale-perl_1.05-3_all.deb ...
                          Unpacking libencode-locale-perl (1.05-3) ...
                          Selecting previously unselected package libfcgi-bin.
                          Preparing to unpack .../26-libfcgi-bin_2.4.2-2_arm64.deb ...
                          Unpacking libfcgi-bin (2.4.2-2) ...
                          Selecting previously unselected package libgpm2:arm64.
                          Preparing to unpack .../27-libgpm2_1.20.7-10+b1_arm64.deb ...
                          Unpacking libgpm2:arm64 (1.20.7-10+b1) ...
                          Selecting previously unselected package libhtml-template-perl.
                          Preparing to unpack .../28-libhtml-template-perl_2.97-2_all.deb ...
                          Unpacking libhtml-template-perl (2.97-2) ...
                          Selecting previously unselected package libtimedate-perl.
                          Preparing to unpack .../29-libtimedate-perl_2.3300-2_all.deb ...
                          Unpacking libtimedate-perl (2.3300-2) ...
                          Selecting previously unselected package libhttp-date-perl.
                          Preparing to unpack .../30-libhttp-date-perl_6.05-2_all.deb ...
                          Unpacking libhttp-date-perl (6.05-2) ...
                          Selecting previously unselected package libio-html-perl.
                          Preparing to unpack .../31-libio-html-perl_1.004-3_all.deb ...
                          Unpacking libio-html-perl (1.004-3) ...
                          Selecting previously unselected package liblwp-mediatypes-perl.
                          Preparing to unpack .../32-liblwp-mediatypes-perl_6.04-2_all.deb ...
                          Unpacking liblwp-mediatypes-perl (6.04-2) ...
                          Selecting previously unselected package libhttp-message-perl.
                          Preparing to unpack .../33-libhttp-message-perl_6.44-1_all.deb ...
                          Unpacking libhttp-message-perl (6.44-1) ...
                          Selecting previously unselected package libterm-readkey-perl.
                          Preparing to unpack .../34-libterm-readkey-perl_2.38-2+b1_arm64.deb ...
                          Unpacking libterm-readkey-perl (2.38-2+b1) ...
                          Selecting previously unselected package mariadb-plugin-provider-bzip2.
                          Preparing to unpack .../35-mariadb-plugin-provider-bzip2_1%3a10.11.6-0+deb12u1_a        rm64.deb ...
                          Unpacking mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package mariadb-plugin-provider-lz4.
                          Preparing to unpack .../36-mariadb-plugin-provider-lz4_1%3a10.11.6-0+deb12u1_arm        64.deb ...
                          Unpacking mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package mariadb-plugin-provider-lzma.
                          Preparing to unpack .../37-mariadb-plugin-provider-lzma_1%3a10.11.6-0+deb12u1_ar        m64.deb ...
                          Unpacking mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package mariadb-plugin-provider-lzo.
                          Preparing to unpack .../38-mariadb-plugin-provider-lzo_1%3a10.11.6-0+deb12u1_arm        64.deb ...
                          Unpacking mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package mariadb-plugin-provider-snappy.
                          Preparing to unpack .../39-mariadb-plugin-provider-snappy_1%3a10.11.6-0+deb12u1_        arm64.deb ...
                          Unpacking mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ...
                          Selecting previously unselected package pv.
                          Preparing to unpack .../40-pv_1.6.20-1_arm64.deb ...
                          Unpacking pv (1.6.20-1) ...
                          Setting up libconfig-inifiles-perl (3.000003-2) ...
                          Setting up galera-4 (26.4.13-1) ...
                          Setting up libgpm2:arm64 (1.20.7-10+b1) ...
                          Setting up libfcgi0ldbl:arm64 (2.4.2-2) ...
                          Setting up gawk (1:5.2.1-2) ...
                          Setting up libclone-perl:arm64 (0.46-1) ...
                          Setting up libhtml-tagset-perl (3.20-6) ...
                          Setting up liblwp-mediatypes-perl (6.04-2) ...
                          Setting up libfcgi-bin (2.4.2-2) ...
                          Setting up libencode-locale-perl (1.05-3) ...
                          Setting up socat (1.7.4.4-2) ...
                          Setting up libncurses6:arm64 (6.4-4) ...
                          Setting up libio-html-perl (1.004-3) ...
                          Setting up libdaxctl1:arm64 (76.1-1) ...
                          Setting up lsof (4.95.0-1) ...
                          Setting up libtimedate-perl (2.3300-2) ...
                          Setting up libregexp-ipv6-perl (0.03-3) ...
                          Setting up pv (1.6.20-1) ...
                          Setting up libndctl6:arm64 (76.1-1) ...
                          Setting up libfcgi-perl (0.82+ds-2) ...
                          Setting up libterm-readkey-perl (2.38-2+b1) ...
                          Setting up liburing2:arm64 (2.3-3) ...
                          Setting up libpmem1:arm64 (1.12.1-2) ...
                          Setting up liburi-perl (5.17-1) ...
                          Setting up libdbi-perl:arm64 (1.643-4) ...
                          Setting up libhttp-date-perl (6.05-2) ...
                          Setting up mariadb-client-core (1:10.11.6-0+deb12u1) ...
                          Setting up libdbd-mariadb-perl (1.22-1+b1) ...
                          Setting up libhtml-parser-perl:arm64 (3.81-1) ...
                          Setting up mariadb-server-core (1:10.11.6-0+deb12u1) ...
                          Setting up libhttp-message-perl (6.44-1) ...
                          Setting up mariadb-client (1:10.11.6-0+deb12u1) ...
                          Setting up libcgi-pm-perl (4.55-1) ...
                          Setting up libhtml-template-perl (2.97-2) ...
                          Setting up mariadb-server (1:10.11.6-0+deb12u1) ...
                          Created symlink /etc/systemd/system/multi-user.target.wants/mariadb.service → /l        ib/systemd/system/mariadb.service.
                          Setting up mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ...
                          Setting up mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ...
                          Setting up mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ...
                          Setting up mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ...
                          Setting up libcgi-fast-perl (1:2.15-1) ...
                          Setting up mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ...
                          Processing triggers for man-db (2.11.2-2) ...
                          Processing triggers for libc-bin (2.36-9+rpt2+deb12u6) ...
                          Processing triggers for mariadb-server (1:10.11.6-0+deb12u1) ...
                          Shinobi - Installing Database...
                          Shinobi - Install NPM Libraries
                          npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#dep        recated
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprec        ated
                          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
                          npm WARN deprecated @discordjs/form-data@3.0.1: Package no longer supported. Con        tact Support at https://www.npmjs.com/support for more info.
                          npm WARN deprecated @discordjs/collection@0.1.6: no longer supported
                          npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
                          npm WARN deprecated discord.js@12.2.0: no longer supported
                          added 762 packages, and audited 763 packages in 1m
                          45 packages are looking for funding
                            run `npm fund` for details
                          18 vulnerabilities (16 moderate, 2 critical)
                          To address issues that do not require attention, run:
                            npm audit fix
                          To address all issues (including breaking changes), run:
                            npm audit fix --force
                          Run `npm audit` for details.
                          npm notice
                          npm notice New minor version of npm available! 10.5.0 -> 10.7.0
                          npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.7.0
                          npm notice Run npm install -g npm@10.7.0 to update!
                          npm notice
                          Shinobi - Install PM2
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          added 162 packages in 18s
                          14 packages are looking for funding
                          Shinobi - Finished
                          dos2unix: converting file INSTALL/shinobi to Unix format...
                          Shinobi - Randomizing cron key
                          addToConfig: [object Object]
                          Changes Complete. Here is what it is now.
                            "port": 8080,
                            "debugLog": false,
                            "enableFaceManager": false,
                            "videosDir": "__DIR__/videos",
                            "passwordType": "sha256",
                            "detectorMergePamRegionTriggers": true,
                            "wallClockTimestampAsDefault": true,
                            "useBetterP2P": true,
                            "smtpServerOptions": {
                              "allowInsecureAuth": true
                            "addStorage": [
                                "name": "second",
                                "path": "__DIR__/videos2"
                            "db": {
                              "host": "127.0.0.1",
                              "user": "majesticflame",
                              "password": "",
                              "database": "ccio",
                              "port": 3306
                            "mail": {
                              "service": "gmail",
                              "auth": {
                                "user": "your_email@gmail.com",
                                "pass": "your_password_or_app_specific_password"
                            "cron": {
                              "key": "09e6aa3f65ca6ef81d120889f44dec94e8efc9d92c90615f26a06177af5a"
                            "pluginKeys": {}
                          Shinobi - Starting Shinobi and setting to start on boot
                          __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
                           _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                            _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                             _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                              _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                               _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                                _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                                 _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                                  _\///______________\///______________\///__\///////////////__
                                                    Runtime Edition
                                  PM2 is a Production Process Manager for Node.js applications
                                               with a built-in Load Balancer.
                                          Start and Daemonize any application:
                                          $ pm2 start app.js
                                          Load Balance 4 instances of api.js:
                                          $ pm2 start api.js -i 4
                                          Monitor in production:
                                          $ pm2 monitor
                                          Make pm2 auto-boot at server restart:
                                          $ pm2 startup
                                          To go further checkout:
                                          http://pm2.io/
                          [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2
                          [PM2] PM2 Successfully daemonized
                          [PM2] Starting /home/Shinobi/camera.js in fork_mode (1 instance)
                          [PM2] Done.
                          │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                          │ 0  │ camera    │ default     │ 2.0.0   │ fork    │ 4133     │ 0s     │ 0    │ online    │ 0%       │ 38.8mb   │ root     │ disabled │
                          [PM2] Init System found: systemd
                          Platform systemd
                          Template
                          [Unit]
                          Description=PM2 process manager
                          Documentation=https://pm2.keymetrics.io/
                          After=network.target
                          [Service]
                          Type=forking
                          User=root
                          LimitNOFILE=infinity
                          LimitNPROC=infinity
                          LimitCORE=infinity
                          Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                          Environment=PM2_HOME=/root/.pm2
                          PIDFile=/root/.pm2/pm2.pid
                          Restart=on-failure
                          ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                          ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                          ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                          [Install]
                          WantedBy=multi-user.target
                          Target path
                          /etc/systemd/system/pm2-root.service
                          Command list
                          [ 'systemctl enable pm2-root' ]
                          [PM2] Writing init configuration in /etc/systemd/system/pm2-root.service
                          [PM2] Making script booting at startup...
                          [PM2] [-] Executing: systemctl enable pm2-root...
                          Created symlink /etc/systemd/system/multi-user.target.wants/pm2-root.service → /etc/systemd/system/pm2-root.service.
                          [PM2] [v] Command successfully executed.
                          [PM2] Freeze a process list on reboot via:
                          $ pm2 save
                          [PM2] Remove init script via:
                          $ pm2 unstartup systemd
                          [PM2] Saving current process list...
                          [PM2] Successfully saved in /root/.pm2/dump.pm2
                          │ 0  │ camera    │ default     │ 2.0.0   │ fork    │ 4133     │ 4s     │ 0    │ online    │ 0%       │ 111.5mb  │ root     │ disabled │
                          ||=====   Install Completed   =====||
                          || Login with the Superuser and create a new user!!
                          || Open http://192.168.178.68:8080/super in your web browser.
                          System nochmal neu aufsetzen? Da ist doch was faul
                            @bill-s-preston dann mach mal ein
                            sudo pip....
                              @crunchip said in Iobroker startet nicht mehr nach Restore:
                              sudo pip....
                              herke@raspberrypi:~ $ sudo pip
                              Usage:
                                pip <command> [options]
                              Commands:
                                install                     Install packages.
                                download                    Download packages.
                                uninstall                   Uninstall packages.
                                freeze                      Output installed packages in requirements format.
                                inspect                     Inspect the python environment.
                                list                        List installed packages.
                                show                        Show information about installed packages.
                                check                       Verify installed packages have compatible dependen        cies.
                                config                      Manage local and global configuration.
                                search                      Search PyPI for packages.
                                cache                       Inspect and manage pip's wheel cache.
                                index                       Inspect information available from package indexes        .
                                wheel                       Build wheels from your requirements.
                                hash                        Compute hashes of package archives.
                                completion                  A helper command used for command completion.
                                debug                       Show information useful for debugging.
                                help                        Show help for commands.
                              General Options:
                                -h, --help                  Show help.
                                --debug                     Let unhandled exceptions propagate outside the
                                                            main subroutine, instead of logging them to
                                                            stderr.
                                --isolated                  Run pip in an isolated mode, ignoring
                                                            environment variables and user configuration.
                                --require-virtualenv        Allow pip to only run in a virtual environment;
                                                            exit with an error otherwise.
                                --python <python>           Run pip with the specified Python interpreter.
                                -v, --verbose               Give more output. Option is additive, and can be
                                                            used up to 3 times.
                                -V, --version               Show version and exit.
                                -q, --quiet                 Give less output. Option is additive, and can be
                                                            used up to 3 times (corresponding to WARNING,
                                                            ERROR, and CRITICAL logging levels).
                                --log <path>                Path to a verbose appending log.
                                --no-input                  Disable prompting for input.
                                --keyring-provider <keyring_provider>
                                                            Enable the credential lookup via the keyring
                                                            library if user input is allowed. Specify which
                                                            mechanism to use [disabled, import, subprocess].
                                                            (default: disabled)
                                --proxy <proxy>             Specify a proxy in the form
                                                            scheme://[user:passwd@]proxy.server:port.
                                --retries <retries>         Maximum number of retries each connection should
                                                            attempt (default 5 times).
                                --timeout <sec>             Set the socket timeout (default 15 seconds).
                                --exists-action <action>    Default action when a path already exists:
                                                            (s)witch, (i)gnore, (w)ipe, (b)ackup, (a)bort.
                                --trusted-host <hostname>   Mark this host or host:port pair as trusted,
                                                            even though it does not have valid or any HTTPS.
                                --cert <path>               Path to PEM-encoded CA certificate bundle. If
                                                            provided, overrides the default. See 'SSL
                                                            Certificate Verification' in pip documentation
                                                            for more information.
                                --client-cert <path>        Path to SSL client certificate, a single file
                                                            containing the private key and the certificate
                                                            in PEM format.
                                --cache-dir <dir>           Store the cache data in <dir>.
                                --no-cache-dir              Disable the cache.
                                --disable-pip-version-check
                                                            Don't periodically check PyPI to determine
                                                            whether a new version of pip is available for
                                                            download. Implied with --no-index.
                                --no-color                  Suppress colored output.
                                --no-python-version-warning
                                                            Silence deprecation warnings for upcoming
                                                            unsupported Pythons.
                                --use-feature <feature>     Enable new functionality, that may be backward
                                                            incompatible.
                                --use-deprecated <feature>  Enable deprecated functionality, that will be
                                                            removed in the future.
                                crunchip Forum Testing Most Active @crunchip last edited by
                                @crunchip sagte in Iobroker startet nicht mehr nach Restore:
                                Unabhängig davon, reichen 4GB RAM da eh nicht aus
                                @Bill-S-Preston
                                Wollt ich noch mal anmerken
                                Da auch noch Influx und Grafana laufen
                                  @bill-s-preston natürlich das ganze Kommando, hatte nur abgekürzt, da ich am Handy tippe
                                    @crunchip
                                    Ein neuer Pi4 mit 8GB und M2 SSD wird heute geliefert.
                                    Da werde ich dann nochmal komplett neu anfangen
                                      Du meinst
                                      sudo pip uninstall
                                        @bill-s-preston ja, dein motioneye
                                          @crunchip
                                          herke@raspberrypi:~ $ sudo pip uninstall motioneye
                                            Would remove:
                                          Proceed (Y/n)? y
                                            Successfully uninstalled motioneye-0.43.1b1
                                          WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
                                          Hat geklappt
                                            Wie deinstalliere ich Shinobi?
                                            herke@raspberrypi:~ $ sudo pip uninstall shinobi
                                            WARNING: Skipping shinobi as it is not installed.
                                            So ging es nicht
                                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            2388
