Iobroker startet nicht mehr nach Restore
MotionEye deinstalieren funktionier nicht
herke@raspberrypi:~ $ pip uninstall motioneye Found existing installation: motioneye 0.43.1b1 Uninstalling motioneye-0.43.1b1: Would remove: /usr/local/bin/meyectl /usr/local/bin/motioneye_init /usr/local/lib/python3.11/dist-packages/motioneye-0.43.1b1.dist-info/* /usr/local/lib/python3.11/dist-packages/motioneye/* Proceed (Y/n)? y ERROR: Exception: Traceback (most recent call last): File "/usr/lib/python3.11/shutil.py", line 825, in move os.rename(src, real_dst) PermissionError: [Errno 13] Permission denied: '/usr/local/bin/meyectl' -> '/tmp/pip-uninstall-eit5jf_4/meyectl' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.11/dist-packages/pip/_internal/cli/base_command.py", line 180, in exc_logging_wrapper status = run_func(*args) ^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.11/dist-packages/pip/_internal/commands/uninstall.py", line 105, in run uninstall_pathset = req.uninstall( ^^^^^^^^^^^^^^ File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_install.py", line 727, in uninstall uninstalled_pathset.remove(auto_confirm, verbose) File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 380, in remove moved.stash(path) File "/usr/local/lib/python3.11/dist-packages/pip/_internal/req/req_uninstall.py", line 271, in stash renames(path, new_path) File "/usr/local/lib/python3.11/dist-packages/pip/_internal/utils/misc.py", line 358, in renames shutil.move(old, new) File "/usr/lib/python3.11/shutil.py", line 846, in move os.unlink(src) PermissionError: [Errno 13] Permission denied: '/usr/local/bin/meyectl'
und
Shinobi wird nach der Installation auch nicht erreicht über 192.168.178.68:8080
herke@raspberrypi:~ $ bash <(curl -s https://gitlab.com/Shinobi-Systems/Shinobi- Installer/raw/master/shinobi-install.sh) Opening Install Location : "/home" *--------------------**---------------------* *Shinobi requires being run as root. *Do you want to continue without being root? (Y)es or (n)o? Default : Yes y Install the Development branch? (y)es or (N)o? Default : No n Getting the Master Branch Cloning into 'Shinobi'... remote: Enumerating objects: 23189, done. remote: Counting objects: 100% (148/148), done. remote: Compressing objects: 100% (113/113), done. remote: Total 23189 (delta 61), reused 78 (delta 35), pack-reused 23041 (from 1) Receiving objects: 100% (23189/23189), 16.76 MiB | 11.07 MiB/s, done. Resolving deltas: 100% (15552/15552), done. fatal: detected dubious ownership in repository at '/home/Shinobi' To add an exception for this directory, call: git config --global --add safe.directory /home/Shinobi ------------------------------------- ---------- Shinobi Systems ---------- Repository : https://gitlab.com/Shinobi-Systems/Shinobi Product : Shinobi Professional (Pro) Branch : master Version : Date : Tue 7 May 10:20:37 CEST 2024 ------------------------------------- ------------------------------------- *-----------------------------------* Shinobi Installer ======== Select your OS If your OS is not on the list please refer to the docs. ======== 1. Ubuntu - Fast and Touchless 2. Ubuntu - Advanced 3. Alma Linux 9.2 / Rocky 9 / CentOS 8 - Fast and Touchless (Red Hat) 4. CentOS 5. MacOS 6. FreeBSD 7. OpenSUSE ======== 1 ========================================================= ==!! Shinobi : The Open Source CCTV and NVR Solution !!== ========================================================= To answer yes type the letter (y) in lowercase and press ENTER. Default is no (N). Skip any components you already have or don't need. ============= ============= Detecting Ubuntu Version ============= ============= Ubuntu Version: 12 ============= Shinobi - Do you want to temporarily disable IPv6? Sometimes IPv6 causes Ubuntu package updates to fail. Only do this if your machi ne doesn't rely on IPv6. (y)es or (N)o y net.ipv6.conf.all.disable_ipv6 = 1 net.ipv6.conf.default.disable_ipv6 = 1 net.ipv6.conf.lo.disable_ipv6 = 1 Reading package lists... Done Building dependency tree... Done Reading state information... Done gcc is already the newest version (4:12.2.0-3). g++ is already the newest version (4:12.2.0-3). g++ set to manually installed. cmake is already the newest version (3.25.1-1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. update-alternatives: error: alternative path /usr/bin/gcc-8 doesn't exist ============= Default Superuser : admin@shinobi.video Default Password : admin * You can edit these settings in "super.json" located in the Shinobi directory. ============= Shinobi - Installing Node.js Hit:1 http://deb.debian.org/debian bookworm InRelease Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB ] Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [23.6 kB] Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B] Get:6 https://apt.grafana.com stable InRelease [7,660 B] Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 Package s [153 kB] Get:9 http://deb.debian.org/debian-security bookworm-security/main armhf Package s [150 kB] Get:10 http://deb.debian.org/debian-security bookworm-security/main Translation- en [95.1 kB] Get:11 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [387 k B] Get:12 https://apt.grafana.com stable/main arm64 Packages [194 kB] Get:13 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [397 k B] Get:14 https://apt.grafana.com stable/main armhf Packages [171 kB] Get:15 https://repos.influxdata.com/debian stable/main arm64 Packages [10.7 kB] Fetched 1,699 kB in 2s (1,023 kB/s) Reading package lists... Done Reading package lists... Done Building dependency tree... Done Reading state information... Done ca-certificates is already the newest version (20230311). curl is already the newest version (7.88.1-10+deb12u5). gnupg is already the newest version (2.2.40-1.1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. File '/etc/apt/keyrings/nodesource.gpg' exists. Overwrite? (y/N) n Enter new filename: shinobigeil deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node _18.x nodistro main Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease Hit:5 https://repos.influxdata.com/debian stable InRelease Hit:6 https://apt.grafana.com stable InRelease Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Done Reading package lists... Done Building dependency tree... Done Reading state information... Done nodejs is already the newest version (18.20.2-1nodesource1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Reading package lists... Done Building dependency tree... Done Reading state information... Done make is already the newest version (4.3-4.1). make set to manually installed. zip is already the newest version (3.0-13). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. FFmpeg Found... Version : ffmpeg version 5.1.4-0+rpt3+deb12u1 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr --extra-version=0+rpt3+deb12u1 --toolchain=hardened --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --disa ble-mmal --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enabl e-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec 2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetyp e --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enab le-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable- libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-libr ist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-l ibtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-lib vpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable -libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-ope nal --enable-opencl --enable-opengl --enable-sand --enable-sdl2 --disable-sndio --enable-libjxl --enable-neon --enable-v4l2-request --enable-libudev --enable-ep oxy --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-pocketsphinx --ena ble-librsvg --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec 61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared libavutil 57. 28.100 / 57. 28.100 libavcodec 59. 37.100 / 59. 37.100 libavformat 59. 27.100 / 59. 27.100 libavdevice 59. 7.100 / 59. 7.100 libavfilter 8. 44.100 / 8. 44.100 libswscale 6. 7.100 / 6. 7.100 libswresample 4. 7.100 / 4. 7.100 libpostproc 56. 6.100 / 56. 6.100 ============= Shinobi - Installing MariaDB MariaDB will be installed with no password. Reading package lists... Done Building dependency tree... Done Reading state information... Done The following additional packages will be installed: galera-4 gawk libcgi-fast-perl libcgi-pm-perl libclone-perl libconfig-inifiles-perl libdaxctl1 libdbd-mariadb-perl libdbi-perl libencode-locale-perl libfcgi-bin libfcgi-perl libfcgi0ldbl libgpm2 libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl libhttp-date-perl libhttp-message-perl libio-html-perl liblwp-mediatypes-perl libncurses6 libndctl6 libpmem1 libregexp-ipv6-perl libsigsegv2 libterm-readkey-perl libtimedate-perl liburi-perl liburing2 lsof mariadb-client mariadb-client-core mariadb-plugin-provider-bzip2 mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy mariadb-server-core pv socat Suggested packages: gawk-doc libmldbm-perl libnet-daemon-perl libsql-statement-perl gpm libdata-dump-perl libipc-sharedcache-perl libbusiness-isbn-perl libwww-perl mailx mariadb-test netcat-openbsd doc-base The following NEW packages will be installed: galera-4 gawk libcgi-fast-perl libcgi-pm-perl libclone-perl libconfig-inifiles-perl libdaxctl1 libdbd-mariadb-perl libdbi-perl libencode-locale-perl libfcgi-bin libfcgi-perl libfcgi0ldbl libgpm2 libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl libhttp-date-perl libhttp-message-perl libio-html-perl liblwp-mediatypes-perl libncurses6 libndctl6 libpmem1 libregexp-ipv6-perl libsigsegv2 libterm-readkey-perl libtimedate-perl liburi-perl liburing2 lsof mariadb-client mariadb-client-core mariadb-plugin-provider-bzip2 mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy mariadb-server mariadb-server-core pv socat 0 upgraded, 42 newly installed, 0 to remove and 0 not upgraded. Need to get 18.1 MB of archives. After this operation, 196 MB of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 libsigsegv2 arm64 2.14-1 [37.0 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 gawk arm64 1:5.2.1-2 [640 kB] Get:3 http://deb.debian.org/debian bookworm/main arm64 galera-4 arm64 26.4.13-1 [702 kB] Get:4 http://deb.debian.org/debian bookworm/main arm64 libdbi-perl arm64 1.643-4 [767 kB] Get:5 http://deb.debian.org/debian bookworm/main arm64 lsof arm64 4.95.0-1 [313 kB] Get:6 http://deb.debian.org/debian bookworm/main arm64 libconfig-inifiles-perl a ll 3.000003-2 [45.9 kB] Get:7 http://deb.debian.org/debian bookworm/main arm64 libncurses6 arm64 6.4-4 [ 93.9 kB] Get:8 http://deb.debian.org/debian bookworm/main arm64 mariadb-client-core arm64 1:10.11.6-0+deb12u1 [846 kB] Get:9 http://deb.debian.org/debian bookworm/main arm64 mariadb-client arm64 1:10 .11.6-0+deb12u1 [2,865 kB] Get:10 http://deb.debian.org/debian bookworm/main arm64 libdaxctl1 arm64 76.1-1 [19.8 kB] Get:11 http://deb.debian.org/debian bookworm/main arm64 libndctl6 arm64 76.1-1 [ 57.4 kB] Get:12 http://deb.debian.org/debian bookworm/main arm64 libpmem1 arm64 1.12.1-2 [45.7 kB] Get:13 http://deb.debian.org/debian bookworm/main arm64 liburing2 arm64 2.3-3 [1 2.6 kB] Get:14 http://deb.debian.org/debian bookworm/main arm64 mariadb-server-core arm6 4 1:10.11.6-0+deb12u1 [6,734 kB] Get:15 http://deb.debian.org/debian bookworm/main arm64 socat arm64 1.7.4.4-2 [3 66 kB] Get:16 http://deb.debian.org/debian bookworm/main arm64 mariadb-server arm64 1:1 0.11.6-0+deb12u1 [3,447 kB] Get:17 http://deb.debian.org/debian bookworm/main arm64 libhtml-tagset-perl all 3.20-6 [11.7 kB] Get:18 http://deb.debian.org/debian bookworm/main arm64 libregexp-ipv6-perl all 0.03-3 [5,212 B] Get:19 http://deb.debian.org/debian bookworm/main arm64 liburi-perl all 5.17-1 [ 90.4 kB] Get:20 http://deb.debian.org/debian bookworm/main arm64 libhtml-parser-perl arm6 4 3.81-1 [98.6 kB] Get:21 http://deb.debian.org/debian bookworm/main arm64 libcgi-pm-perl all 4.55- 1 [220 kB] Get:22 http://deb.debian.org/debian bookworm/main arm64 libfcgi0ldbl arm64 2.4.2 -2 [25.3 kB] Get:23 http://deb.debian.org/debian bookworm/main arm64 libfcgi-perl arm64 0.82+ ds-2 [24.4 kB] Get:24 http://deb.debian.org/debian bookworm/main arm64 libcgi-fast-perl all 1:2 .15-1 [12.1 kB] Get:25 http://deb.debian.org/debian bookworm/main arm64 libclone-perl arm64 0.46 -1 [13.5 kB] Get:26 http://deb.debian.org/debian bookworm/main arm64 libdbd-mariadb-perl arm6 4 1.22-1+b1 [89.1 kB] Get:27 http://deb.debian.org/debian bookworm/main arm64 libencode-locale-perl al l 1.05-3 [12.9 kB] Get:28 http://deb.debian.org/debian bookworm/main arm64 libfcgi-bin arm64 2.4.2- 2 [12.5 kB] Get:29 http://deb.debian.org/debian bookworm/main arm64 libgpm2 arm64 1.20.7-10+ b1 [14.4 kB] Get:30 http://deb.debian.org/debian bookworm/main arm64 libhtml-template-perl al l 2.97-2 [66.5 kB] Get:31 http://deb.debian.org/debian bookworm/main arm64 libtimedate-perl all 2.3 300-2 [39.3 kB] Get:32 http://deb.debian.org/debian bookworm/main arm64 libhttp-date-perl all 6. 05-2 [10.5 kB] Get:33 http://deb.debian.org/debian bookworm/main arm64 libio-html-perl all 1.00 4-3 [16.2 kB] Get:34 http://deb.debian.org/debian bookworm/main arm64 liblwp-mediatypes-perl a ll 6.04-2 [20.2 kB] Get:35 http://deb.debian.org/debian bookworm/main arm64 libhttp-message-perl all 6.44-1 [81.7 kB] Get:36 http://deb.debian.org/debian bookworm/main arm64 libterm-readkey-perl arm 64 2.38-2+b1 [24.1 kB] Get:37 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider- bzip2 arm64 1:10.11.6-0+deb12u1 [24.9 kB] Get:38 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider- lz4 arm64 1:10.11.6-0+deb12u1 [24.8 kB] Get:39 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider- lzma arm64 1:10.11.6-0+deb12u1 [24.9 kB] Get:40 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider- lzo arm64 1:10.11.6-0+deb12u1 [24.8 kB] Get:41 http://deb.debian.org/debian bookworm/main arm64 mariadb-plugin-provider- snappy arm64 1:10.11.6-0+deb12u1 [24.9 kB] Get:42 http://deb.debian.org/debian bookworm/main arm64 pv arm64 1.6.20-1 [58.6 kB] Fetched 18.1 MB in 2s (10.3 MB/s) Extracting templates from packages: 100% Preconfiguring packages ... Selecting previously unselected package libsigsegv2:arm64. (Reading database ... 103045 files and directories currently installed.) Preparing to unpack .../libsigsegv2_2.14-1_arm64.deb ... Unpacking libsigsegv2:arm64 (2.14-1) ... Setting up libsigsegv2:arm64 (2.14-1) ... Selecting previously unselected package gawk. (Reading database ... 103054 files and directories currently installed.) Preparing to unpack .../00-gawk_1%3a5.2.1-2_arm64.deb ... Unpacking gawk (1:5.2.1-2) ... Selecting previously unselected package galera-4. Preparing to unpack .../01-galera-4_26.4.13-1_arm64.deb ... Unpacking galera-4 (26.4.13-1) ... Selecting previously unselected package libdbi-perl:arm64. Preparing to unpack .../02-libdbi-perl_1.643-4_arm64.deb ... Unpacking libdbi-perl:arm64 (1.643-4) ... Selecting previously unselected package lsof. Preparing to unpack .../03-lsof_4.95.0-1_arm64.deb ... Unpacking lsof (4.95.0-1) ... Selecting previously unselected package libconfig-inifiles-perl. Preparing to unpack .../04-libconfig-inifiles-perl_3.000003-2_all.deb ... Unpacking libconfig-inifiles-perl (3.000003-2) ... Selecting previously unselected package libncurses6:arm64. Preparing to unpack .../05-libncurses6_6.4-4_arm64.deb ... Unpacking libncurses6:arm64 (6.4-4) ... Selecting previously unselected package mariadb-client-core. Preparing to unpack .../06-mariadb-client-core_1%3a10.11.6-0+deb12u1_arm64.deb . .. Unpacking mariadb-client-core (1:10.11.6-0+deb12u1) ... Selecting previously unselected package mariadb-client. Preparing to unpack .../07-mariadb-client_1%3a10.11.6-0+deb12u1_arm64.deb ... Unpacking mariadb-client (1:10.11.6-0+deb12u1) ... Selecting previously unselected package libdaxctl1:arm64. Preparing to unpack .../08-libdaxctl1_76.1-1_arm64.deb ... Unpacking libdaxctl1:arm64 (76.1-1) ... Selecting previously unselected package libndctl6:arm64. Preparing to unpack .../09-libndctl6_76.1-1_arm64.deb ... Unpacking libndctl6:arm64 (76.1-1) ... Selecting previously unselected package libpmem1:arm64. Preparing to unpack .../10-libpmem1_1.12.1-2_arm64.deb ... Unpacking libpmem1:arm64 (1.12.1-2) ... Selecting previously unselected package liburing2:arm64. Preparing to unpack .../11-liburing2_2.3-3_arm64.deb ... Unpacking liburing2:arm64 (2.3-3) ... Selecting previously unselected package mariadb-server-core. Preparing to unpack .../12-mariadb-server-core_1%3a10.11.6-0+deb12u1_arm64.deb . .. Unpacking mariadb-server-core (1:10.11.6-0+deb12u1) ... Selecting previously unselected package socat. Preparing to unpack .../13-socat_1.7.4.4-2_arm64.deb ... Unpacking socat (1.7.4.4-2) ... Selecting previously unselected package mariadb-server. Preparing to unpack .../14-mariadb-server_1%3a10.11.6-0+deb12u1_arm64.deb ... Unpacking mariadb-server (1:10.11.6-0+deb12u1) ... Selecting previously unselected package libhtml-tagset-perl. Preparing to unpack .../15-libhtml-tagset-perl_3.20-6_all.deb ... Unpacking libhtml-tagset-perl (3.20-6) ... Selecting previously unselected package libregexp-ipv6-perl. Preparing to unpack .../16-libregexp-ipv6-perl_0.03-3_all.deb ... Unpacking libregexp-ipv6-perl (0.03-3) ... Selecting previously unselected package liburi-perl. Preparing to unpack .../17-liburi-perl_5.17-1_all.deb ... Unpacking liburi-perl (5.17-1) ... Selecting previously unselected package libhtml-parser-perl:arm64. Preparing to unpack .../18-libhtml-parser-perl_3.81-1_arm64.deb ... Unpacking libhtml-parser-perl:arm64 (3.81-1) ... Selecting previously unselected package libcgi-pm-perl. Preparing to unpack .../19-libcgi-pm-perl_4.55-1_all.deb ... Unpacking libcgi-pm-perl (4.55-1) ... Selecting previously unselected package libfcgi0ldbl:arm64. Preparing to unpack .../20-libfcgi0ldbl_2.4.2-2_arm64.deb ... Unpacking libfcgi0ldbl:arm64 (2.4.2-2) ... Selecting previously unselected package libfcgi-perl. Preparing to unpack .../21-libfcgi-perl_0.82+ds-2_arm64.deb ... Unpacking libfcgi-perl (0.82+ds-2) ... Selecting previously unselected package libcgi-fast-perl. Preparing to unpack .../22-libcgi-fast-perl_1%3a2.15-1_all.deb ... Unpacking libcgi-fast-perl (1:2.15-1) ... Selecting previously unselected package libclone-perl:arm64. Preparing to unpack .../23-libclone-perl_0.46-1_arm64.deb ... Unpacking libclone-perl:arm64 (0.46-1) ... Selecting previously unselected package libdbd-mariadb-perl. Preparing to unpack .../24-libdbd-mariadb-perl_1.22-1+b1_arm64.deb ... Unpacking libdbd-mariadb-perl (1.22-1+b1) ... Selecting previously unselected package libencode-locale-perl. Preparing to unpack .../25-libencode-locale-perl_1.05-3_all.deb ... Unpacking libencode-locale-perl (1.05-3) ... Selecting previously unselected package libfcgi-bin. Preparing to unpack .../26-libfcgi-bin_2.4.2-2_arm64.deb ... Unpacking libfcgi-bin (2.4.2-2) ... Selecting previously unselected package libgpm2:arm64. Preparing to unpack .../27-libgpm2_1.20.7-10+b1_arm64.deb ... Unpacking libgpm2:arm64 (1.20.7-10+b1) ... Selecting previously unselected package libhtml-template-perl. Preparing to unpack .../28-libhtml-template-perl_2.97-2_all.deb ... Unpacking libhtml-template-perl (2.97-2) ... Selecting previously unselected package libtimedate-perl. Preparing to unpack .../29-libtimedate-perl_2.3300-2_all.deb ... Unpacking libtimedate-perl (2.3300-2) ... Selecting previously unselected package libhttp-date-perl. Preparing to unpack .../30-libhttp-date-perl_6.05-2_all.deb ... Unpacking libhttp-date-perl (6.05-2) ... Selecting previously unselected package libio-html-perl. Preparing to unpack .../31-libio-html-perl_1.004-3_all.deb ... Unpacking libio-html-perl (1.004-3) ... Selecting previously unselected package liblwp-mediatypes-perl. Preparing to unpack .../32-liblwp-mediatypes-perl_6.04-2_all.deb ... Unpacking liblwp-mediatypes-perl (6.04-2) ... Selecting previously unselected package libhttp-message-perl. Preparing to unpack .../33-libhttp-message-perl_6.44-1_all.deb ... Unpacking libhttp-message-perl (6.44-1) ... Selecting previously unselected package libterm-readkey-perl. Preparing to unpack .../34-libterm-readkey-perl_2.38-2+b1_arm64.deb ... Unpacking libterm-readkey-perl (2.38-2+b1) ... Selecting previously unselected package mariadb-plugin-provider-bzip2. Preparing to unpack .../35-mariadb-plugin-provider-bzip2_1%3a10.11.6-0+deb12u1_a rm64.deb ... Unpacking mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ... Selecting previously unselected package mariadb-plugin-provider-lz4. Preparing to unpack .../36-mariadb-plugin-provider-lz4_1%3a10.11.6-0+deb12u1_arm 64.deb ... Unpacking mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ... Selecting previously unselected package mariadb-plugin-provider-lzma. Preparing to unpack .../37-mariadb-plugin-provider-lzma_1%3a10.11.6-0+deb12u1_ar m64.deb ... Unpacking mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ... Selecting previously unselected package mariadb-plugin-provider-lzo. Preparing to unpack .../38-mariadb-plugin-provider-lzo_1%3a10.11.6-0+deb12u1_arm 64.deb ... Unpacking mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ... Selecting previously unselected package mariadb-plugin-provider-snappy. Preparing to unpack .../39-mariadb-plugin-provider-snappy_1%3a10.11.6-0+deb12u1_ arm64.deb ... Unpacking mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ... Selecting previously unselected package pv. Preparing to unpack .../40-pv_1.6.20-1_arm64.deb ... Unpacking pv (1.6.20-1) ... Setting up libconfig-inifiles-perl (3.000003-2) ... Setting up galera-4 (26.4.13-1) ... Setting up libgpm2:arm64 (1.20.7-10+b1) ... Setting up libfcgi0ldbl:arm64 (2.4.2-2) ... Setting up gawk (1:5.2.1-2) ... Setting up libclone-perl:arm64 (0.46-1) ... Setting up libhtml-tagset-perl (3.20-6) ... Setting up liblwp-mediatypes-perl (6.04-2) ... Setting up libfcgi-bin (2.4.2-2) ... Setting up libencode-locale-perl (1.05-3) ... Setting up socat (1.7.4.4-2) ... Setting up libncurses6:arm64 (6.4-4) ... Setting up libio-html-perl (1.004-3) ... Setting up libdaxctl1:arm64 (76.1-1) ... Setting up lsof (4.95.0-1) ... Setting up libtimedate-perl (2.3300-2) ... Setting up libregexp-ipv6-perl (0.03-3) ... Setting up pv (1.6.20-1) ... Setting up libndctl6:arm64 (76.1-1) ... Setting up libfcgi-perl (0.82+ds-2) ... Setting up libterm-readkey-perl (2.38-2+b1) ... Setting up liburing2:arm64 (2.3-3) ... Setting up libpmem1:arm64 (1.12.1-2) ... Setting up liburi-perl (5.17-1) ... Setting up libdbi-perl:arm64 (1.643-4) ... Setting up libhttp-date-perl (6.05-2) ... Setting up mariadb-client-core (1:10.11.6-0+deb12u1) ... Setting up libdbd-mariadb-perl (1.22-1+b1) ... Setting up libhtml-parser-perl:arm64 (3.81-1) ... Setting up mariadb-server-core (1:10.11.6-0+deb12u1) ... Setting up libhttp-message-perl (6.44-1) ... Setting up mariadb-client (1:10.11.6-0+deb12u1) ... Setting up libcgi-pm-perl (4.55-1) ... Setting up libhtml-template-perl (2.97-2) ... Setting up mariadb-server (1:10.11.6-0+deb12u1) ... Created symlink /etc/systemd/system/multi-user.target.wants/mariadb.service → /l ib/systemd/system/mariadb.service. Setting up mariadb-plugin-provider-bzip2 (1:10.11.6-0+deb12u1) ... Setting up mariadb-plugin-provider-lzma (1:10.11.6-0+deb12u1) ... Setting up mariadb-plugin-provider-lzo (1:10.11.6-0+deb12u1) ... Setting up mariadb-plugin-provider-lz4 (1:10.11.6-0+deb12u1) ... Setting up libcgi-fast-perl (1:2.15-1) ... Setting up mariadb-plugin-provider-snappy (1:10.11.6-0+deb12u1) ... Processing triggers for man-db (2.11.2-2) ... Processing triggers for libc-bin (2.36-9+rpt2+deb12u6) ... Processing triggers for mariadb-server (1:10.11.6-0+deb12u1) ... ============= Shinobi - Installing Database... ============= Shinobi - Install NPM Libraries npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#dep recated npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprec ated npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b ecause it extends the now deprecated request package, see https://github.com/req uest/request/issues/3142 npm WARN deprecated @discordjs/form-data@3.0.1: Package no longer supported. Con tact Support at https://www.npmjs.com/support for more info. npm WARN deprecated @discordjs/collection@0.1.6: no longer supported npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older v ersions may use Math.random() in certain circumstances, which is known to be pro blematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://git hub.com/request/request/issues/3142 npm WARN deprecated discord.js@12.2.0: no longer supported added 762 packages, and audited 763 packages in 1m 45 packages are looking for funding run `npm fund` for details 18 vulnerabilities (16 moderate, 2 critical) To address issues that do not require attention, run: npm audit fix To address all issues (including breaking changes), run: npm audit fix --force Run `npm audit` for details. npm notice npm notice New minor version of npm available! 10.5.0 -> 10.7.0 npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.7.0 npm notice Run npm install -g npm@10.7.0 to update! npm notice ============= Shinobi - Install PM2 npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. added 162 packages in 18s 14 packages are looking for funding run `npm fund` for details Shinobi - Finished dos2unix: converting file INSTALL/shinobi to Unix format... Shinobi - Randomizing cron key addToConfig: [object Object] Changes Complete. Here is what it is now. { "port": 8080, "debugLog": false, "enableFaceManager": false, "videosDir": "__DIR__/videos", "passwordType": "sha256", "detectorMergePamRegionTriggers": true, "wallClockTimestampAsDefault": true, "useBetterP2P": true, "smtpServerOptions": { "allowInsecureAuth": true }, "addStorage": [ { "name": "second", "path": "__DIR__/videos2" } ], "db": { "host": "127.0.0.1", "user": "majesticflame", "password": "", "database": "ccio", "port": 3306 }, "mail": { "service": "gmail", "auth": { "user": "your_email@gmail.com", "pass": "your_password_or_app_specific_password" } }, "cron": { "key": "09e6aa3f65ca6ef81d120889f44dec94e8efc9d92c90615f26a06177af5a" }, "pluginKeys": {} } Shinobi - Starting Shinobi and setting to start on boot ------------- __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____ _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___ _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__ _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___ _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____ _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________ _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________ _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_ _\///______________\///______________\///__\///////////////__ Runtime Edition PM2 is a Production Process Manager for Node.js applications with a built-in Load Balancer. Start and Daemonize any application: $ pm2 start app.js Load Balance 4 instances of api.js: $ pm2 start api.js -i 4 Monitor in production: $ pm2 monitor Make pm2 auto-boot at server restart: $ pm2 startup To go further checkout: http://pm2.io/ ------------- [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2 [PM2] PM2 Successfully daemonized [PM2] Starting /home/Shinobi/camera.js in fork_mode (1 instance) [PM2] Done. ┌────┬───────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐ │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │ ├────┼───────────┼─────────────┼─────────┼─────────┼──────────┼────────┼──────┼───────────┼──────────┼──────────┼──────────┼──────────┤ │ 0 │ camera │ default │ 2.0.0 │ fork │ 4133 │ 0s │ 0 │ online │ 0% │ 38.8mb │ root │ disabled │ └────┴───────────┴─────────────┴─────────┴─────────┴──────────┴────────┴──────┴───────────┴──────────┴──────────┴──────────┴──────────┘ [PM2] Init System found: systemd Platform systemd Template [Unit] Description=PM2 process manager Documentation=https://pm2.keymetrics.io/ After=network.target [Service] Type=forking User=root LimitNOFILE=infinity LimitNPROC=infinity LimitCORE=infinity Environment=PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin Environment=PM2_HOME=/root/.pm2 PIDFile=/root/.pm2/pm2.pid Restart=on-failure ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill [Install] WantedBy=multi-user.target Target path /etc/systemd/system/pm2-root.service Command list [ 'systemctl enable pm2-root' ] [PM2] Writing init configuration in /etc/systemd/system/pm2-root.service [PM2] Making script booting at startup... [PM2] [-] Executing: systemctl enable pm2-root... Created symlink /etc/systemd/system/multi-user.target.wants/pm2-root.service → /etc/systemd/system/pm2-root.service. [PM2] [v] Command successfully executed. +---------------------------------------+ [PM2] Freeze a process list on reboot via: $ pm2 save [PM2] Remove init script via: $ pm2 unstartup systemd [PM2] Saving current process list... [PM2] Successfully saved in /root/.pm2/dump.pm2 ┌────┬───────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐ │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │ ├────┼───────────┼─────────────┼─────────┼─────────┼──────────┼────────┼──────┼───────────┼──────────┼──────────┼──────────┼──────────┤ │ 0 │ camera │ default │ 2.0.0 │ fork │ 4133 │ 4s │ 0 │ online │ 0% │ 111.5mb │ root │ disabled │ └────┴───────────┴─────────────┴─────────┴─────────┴──────────┴────────┴──────┴───────────┴──────────┴──────────┴──────────┴──────────┘ ===================================== ||===== Install Completed =====|| ===================================== || Login with the Superuser and create a new user!! ||=================================== || Open http://192.168.178.68:8080/super in your web browser. ||=================================== || Default Superuser : admin@shinobi.video || Default Password : admin
System nochmal neu aufsetzen? Da ist doch was faul
@bill-s-preston dann mach mal ein
sudo pip.... -
@crunchip said in Iobroker startet nicht mehr nach Restore:
sudo pip....herke@raspberrypi:~ $ sudo pip Usage: pip <command> [options] Commands: install Install packages. download Download packages. uninstall Uninstall packages. freeze Output installed packages in requirements format. inspect Inspect the python environment. list List installed packages. show Show information about installed packages. check Verify installed packages have compatible dependen cies. config Manage local and global configuration. search Search PyPI for packages. cache Inspect and manage pip's wheel cache. index Inspect information available from package indexes . wheel Build wheels from your requirements. hash Compute hashes of package archives. completion A helper command used for command completion. debug Show information useful for debugging. help Show help for commands. General Options: -h, --help Show help. --debug Let unhandled exceptions propagate outside the main subroutine, instead of logging them to stderr. --isolated Run pip in an isolated mode, ignoring environment variables and user configuration. --require-virtualenv Allow pip to only run in a virtual environment; exit with an error otherwise. --python <python> Run pip with the specified Python interpreter. -v, --verbose Give more output. Option is additive, and can be used up to 3 times. -V, --version Show version and exit. -q, --quiet Give less output. Option is additive, and can be used up to 3 times (corresponding to WARNING, ERROR, and CRITICAL logging levels). --log <path> Path to a verbose appending log. --no-input Disable prompting for input. --keyring-provider <keyring_provider> Enable the credential lookup via the keyring library if user input is allowed. Specify which mechanism to use [disabled, import, subprocess]. (default: disabled) --proxy <proxy> Specify a proxy in the form scheme://[user:passwd@]proxy.server:port. --retries <retries> Maximum number of retries each connection should attempt (default 5 times). --timeout <sec> Set the socket timeout (default 15 seconds). --exists-action <action> Default action when a path already exists: (s)witch, (i)gnore, (w)ipe, (b)ackup, (a)bort. --trusted-host <hostname> Mark this host or host:port pair as trusted, even though it does not have valid or any HTTPS. --cert <path> Path to PEM-encoded CA certificate bundle. If provided, overrides the default. See 'SSL Certificate Verification' in pip documentation for more information. --client-cert <path> Path to SSL client certificate, a single file containing the private key and the certificate in PEM format. --cache-dir <dir> Store the cache data in <dir>. --no-cache-dir Disable the cache. --disable-pip-version-check Don't periodically check PyPI to determine whether a new version of pip is available for download. Implied with --no-index. --no-color Suppress colored output. --no-python-version-warning Silence deprecation warnings for upcoming unsupported Pythons. --use-feature <feature> Enable new functionality, that may be backward incompatible. --use-deprecated <feature> Enable deprecated functionality, that will be removed in the future.
@crunchip sagte in Iobroker startet nicht mehr nach Restore:
Unabhängig davon, reichen 4GB RAM da eh nicht aus
@Bill-S-Preston
Wollt ich noch mal anmerken
Da auch noch Influx und Grafana laufen -
@bill-s-preston natürlich das ganze Kommando, hatte nur abgekürzt, da ich am Handy tippe
Ein neuer Pi4 mit 8GB und M2 SSD wird heute geliefert.
Da werde ich dann nochmal komplett neu anfangen -
Du meinst
sudo pip uninstall
@bill-s-preston ja, dein motioneye
herke@raspberrypi:~ $ sudo pip uninstall motioneye Found existing installation: motioneye 0.43.1b1 Uninstalling motioneye-0.43.1b1: Would remove: /usr/local/bin/meyectl /usr/local/bin/motioneye_init /usr/local/lib/python3.11/dist-packages/motioneye-0.43.1b1.dist-info/* /usr/local/lib/python3.11/dist-packages/motioneye/* Proceed (Y/n)? y Successfully uninstalled motioneye-0.43.1b1 WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Hat geklappt
Wie deinstalliere ich Shinobi?
herke@raspberrypi:~ $ sudo pip uninstall shinobi WARNING: Skipping shinobi as it is not installed. WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
So ging es nicht
@bill-s-preston sagte in Iobroker startet nicht mehr nach Restore:
Dazu gibt es eine umfangreiche Anleitung auf deren Seite.
@bill-s-preston liest du dich nicht vorher ein?
https://docs.shinobi.video/system/uninstall -
https://docs.shinobi.video/system/uninstallremove nodejs ???
sudo npm uninstall pm2 -g sudo apt remove nodejs -y && sudo apt autoremove -y
Nicht gut oder?
@bill-s-preston du darfst nicht stur nach der Anleitung gehen
Nodejs brauchst du ja -
Nicht gut oder?
Nein, nicht gut, wenn nodejs noch für andere Dinge (wie den ioBroker) notwendig ist.
Solche Anleitungen sind immer noch an die Gegebenheiten auf dem eigenen System anzupassen.
