    4. Homebridge Fehler Code 243
      marcelinho @Marc Berg last edited by
      @marc-berg jetzt sieht es wohl besser aus, habe alle Influxdb Datenpunkte mit Millisekunden angepasst:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       09:23:33 up 1 day, 15:37,  3 users,  load average: 0.27, 0.37, 0.33
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-04-25 09:23:33 CEST
                 Universal time: Thu 2024-04-25 07:23:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        2.9G        827M         28K        296M        1.0G
      Swap:           104M        104M        278K
      Total:          4.1G        3.0G        827M
               3793 M total memory
               2796 M used memory
               2004 M active memory
                808 M inactive memory
                788 M free memory
                 16 M buffer memory
                266 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
      [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
      [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
      [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      11G     /var/
      8.9G    /var/lib
      8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
      Archived and active journals take up 739.9M in the file system.
      /opt/iobroker/backups:
      217M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      303M    /opt/iobroker/iobroker-data/
      191M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      52M     /opt/iobroker/iobroker-data/backup-objects
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 600
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi        -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi        -  enabled
      + system.adapter.daikin.0                 : daikin                : raspberrypi        -  enabled
      + system.adapter.daikin.1                 : daikin                : raspberrypi        -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi        -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi        -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi        -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi        -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.myenergi.0               : myenergi              : raspberrypi        -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smart-eq.0               : smart-eq              : raspberrypi        -  enabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi        -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi        -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "node-red"     : 5.2.0    , installed 5.2.0
      Adapter    "openhab"      : 1.1.0    , installed 1.1.0
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        14991
      States:         13387
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://repo.homebridge.io stable InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
      tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
      tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
      tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
      tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
      tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1585299    38874/cupsd
      tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
      tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
      tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
      tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
      tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1585298    38874/cupsd
      tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
      tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
      tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
      tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
      tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
      tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
      tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
      tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
      udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1586228    38876/cups-browsed
      udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
      udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
      udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
      2024-04-25 09:10:38.129  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.gas_savings.total_spent.raw_value" has to be type "number" but received type "string"
      2024-04-25 09:10:38.133  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.total_spent.raw_value" has to be type "number" but received type "string"
      2024-04-25 09:11:45.291  - info: influxdb.0 (47993) enabled logging of PV Tagesertrag, Alias=true
      2024-04-25 09:12:30.314  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTag, Alias=true
      2024-04-25 09:12:50.951  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTag, Alias=true
      2024-04-25 09:13:25.909  - warn: influxdb.0 (47993) Error in query "from(bucket: "admin")  |> range(start: 1999-12-31T23:00:00.000Z, stop: 2024-04-25T07:12:55.411Z) |> filter(fn: (r) => r["_measurement"] == "BatterieEntladung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns:["_time"], desc: false) |> limit(n: 500)": RequestTimedOutError: Request timed out
      2024-04-25 09:14:14.696  - info: influxdb.0 (47993) enabled logging of BatterieEntladung, Alias=true
      2024-04-25 09:14:23.823  - info: influxdb.0 (47993) enabled logging of BatterieProzent, Alias=true
      2024-04-25 09:14:32.228  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTotal, Alias=true
      2024-04-25 09:14:38.869  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTotal, Alias=true
      2024-04-25 09:14:42.461  - info: shelly.0 (1561) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
      2024-04-25 09:14:57.799  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Accumulated_Energy_Yield, Alias=false
      2024-04-25 09:15:10.195  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Active_Power, Alias=false
      2024-04-25 09:15:16.964  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Daily_Energy_Yield, Alias=false
      2024-04-25 09:15:31.414  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Input_Power, Alias=false
      2024-04-25 09:15:42.478  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Internal_Temperature, Alias=false
      2024-04-25 09:18:36.103  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_Euro, Alias=true
      2024-04-25 09:18:42.306  - info: influxdb.0 (47993) enabled logging of Hausspeicher_gespart, Alias=true
      2024-04-25 09:18:48.544  - info: influxdb.0 (47993) enabled logging of Netzbezug_Tag_Euro, Alias=true
      2024-04-25 09:19:00.758  - info: influxdb.0 (47993) enabled logging of Netzeinspeisung_Tag_Euro, Alias=true
      2024-04-25 09:19:13.266  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_kWh, Alias=true
      2024-04-25 09:19:20.297  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, Alias=false
      2024-04-25 09:19:26.029  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_W, Alias=false
      2024-04-25 09:19:34.118  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_Tag_kWh, Alias=false
      2024-04-25 09:19:43.416  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_W, Alias=false
        marcelinho @Thomas Braun last edited by
        @thomas-braun hast du zufällig noch einen Vorschlag was ich gegen den Fehler machen könnte?
          Thomas Braun Most Active @marcelinho last edited by
          @marcelinho
          Nein. Mit GUIs hab ich aber auch wenig am Hut. Und mit Homebridge auch nicht.
            marcelinho @marcelinho last edited by
            habe nun folgenden Fehler:
            npm ERR! code EACCES
            npm ERR! syscall rename
            npm ERR! path /usr/local/bin/homebridge
            npm ERR! dest /usr/local/bin/.homebridge-kaN4ImAr
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'
            npm ERR! [Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'] {
            npm ERR! errno: -13,
            npm ERR! code: 'EACCES',
            npm ERR! syscall: 'rename',
            npm ERR! path: '/usr/local/bin/homebridge',
            npm ERR! dest: '/usr/local/bin/.homebridge-kaN4ImAr'
            npm ERR! }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator.
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-05-06T15_54_11_806Z-debug-0.log
            jemand eine Idee?
              @marcelinho sagte in Homebridge Fehler Code 243:
              jemand eine Idee?
              Du könntest dazu schreiben welche Aktion mit welchem User zu diesen Meldungen führt.
              Und welche Berechtigungen für homebridge erforderlich sind.
              ls -lah  /usr/local/bin/homebridge
                @thomas-braun wenn ich den Befehl in der Konsole eingebe kommt folgendes:
                pi@raspberrypi:~ $ ls -lah /usr/local/bin/homebridge
                lrwxrwxrwx 1 root root 45 May 6 17:51 /usr/local/bin/homebridge -> ../lib/node_ modules/homebridge/bin/homebridge
                ich bin etwas überfragt, weis nicht genau was du meinst.
                  Thomas Braun Most Active @marcelinho last edited by Thomas Braun
                  @marcelinho
                  Und
                  ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                  sagt?
                  Konsolentext bitte immer in CodeTags setzen. Kann man besser lesen. Danke.
                  Edit: c&p Fehler
                    @thomas-braun ok sorry
                    es kommt folgendes:
                    pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_ modules/homebridge/bin/homebridg                                    e
                    ls: cannot access '/usr/local/lib/node_': No such file or directory
                    ls: cannot access 'modules/homebridge/bin/homebridge': No such file or directory
                    • DJMarc75
                      DJMarc75 @marcelinho last edited by
                      @marcelinho
                      war ein leerzeichen drin
                        marcelinho @DJMarc75 last edited by
                        @djmarc75 danke anbei neu
                        pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                        -rwxr-xr-x 1 pi root 349 May  6 17:51 /usr/local/lib/node_modules/homebridge/bin               /homebridge
                        pi@raspberrypi:~ $
                          Hat jemand bezgl. des Fehler noch eine Idee ? Danke vorab:
                          [28/05/2024, 15:45:48] [Homebridge UI] Operation failed with code 243.
                          You can download this log file for future reference.
                          See https://github.com/homebridge/homebridge-config-ui-x/wiki/Troubleshooting for help.
                          3128
