    4. ZigBee Störung
    ZigBee Störung
      legro @Homoran last edited by
      Hier das Log von einem Neustart ..
      zigbee.0
      2024-05-07 19:32:38.817	info	Device '0x00124b000621ad0e' announced itself
      zigbee.0
      2024-05-07 16:56:41.462	warn	Send command to 0x001788010db82a55 failed with: Code 205 (No network route)
      zigbee.0
      2024-05-07 16:56:19.683	warn	Send command to 0x001788010db82a55 failed with: Code 205 (No network route)
      zigbee.0
      2024-05-07 16:52:55.887	info	Device '0x00124b00077b7fe8' announced itself
      zigbee.0
      2024-05-07 16:52:37.138	info	Device '0x00124b0008a50109' announced itself
      zigbee.0
      2024-05-07 16:52:34.018	info	Device '0x00124b00074e8fdf' announced itself
      zigbee.0
      2024-05-07 16:46:44.677	error	Error 225 on send command to 0x001788010db82a55. Error: Error: ZCL command 0x001788010db82a55/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:411:23) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:79:20) at Endpoint.zclCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:756:28) at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:587:24) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:48:17) at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1131:32) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:36
      zigbee.0
      2024-05-07 16:46:38.827	info	Device '0x00124b00090da34c' announced itself
      zigbee.0
      2024-05-07 16:46:14.310	warn	Send command to 0x001788010db82a55 failed with: Code 205 (No network route)
      zigbee.0
      2024-05-07 16:43:29.298	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyS0"}]
        Homoran Global Moderator Administrators @legro last edited by
        @legro sagte in ZigBee Störung:
        bitte beantworte meine Frage und die von @MartinP
          legro @Homoran last edited by legro
          pi@raspiBullseye:~ $ ls -l /dev/serial/by-id
          total 0
          lrwxrwxrwx 1 root root 13 May  7 16:17 usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00 -> ../../ttyACM0
          lrwxrwxrwx 1 root root 13 May  7 16:17 usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03 -> ../../ttyACM1
          pi@raspiBullseye:~ $ ls -l /dev/tty*
          crw-rw-rw- 1 root tty       5,  0 May  7 16:17 /dev/tty
          crw--w---- 1 root tty       4,  0 May  7 16:17 /dev/tty0
          crw------- 1 pi   tty       4,  1 May  7 16:39 /dev/tty1
          crw--w---- 1 root tty       4, 10 May  7 16:17 /dev/tty10
          crw--w---- 1 root tty       4, 11 May  7 16:17 /dev/tty11
          crw--w---- 1 root tty       4, 12 May  7 16:17 /dev/tty12
          crw--w---- 1 root tty       4, 13 May  7 16:17 /dev/tty13
          crw--w---- 1 root tty       4, 14 May  7 16:17 /dev/tty14
          crw--w---- 1 root tty       4, 15 May  7 16:17 /dev/tty15
          crw--w---- 1 root tty       4, 16 May  7 16:17 /dev/tty16
          crw--w---- 1 root tty       4, 17 May  7 16:17 /dev/tty17
          crw--w---- 1 root tty       4, 18 May  7 16:17 /dev/tty18
          crw--w---- 1 root tty       4, 19 May  7 16:17 /dev/tty19
          crw--w---- 1 root tty       4,  2 May  7 16:17 /dev/tty2
          crw--w---- 1 root tty       4, 20 May  7 16:17 /dev/tty20
          crw--w---- 1 root tty       4, 21 May  7 16:17 /dev/tty21
          crw--w---- 1 root tty       4, 22 May  7 16:17 /dev/tty22
          crw--w---- 1 root tty       4, 23 May  7 16:17 /dev/tty23
          crw--w---- 1 root tty       4, 24 May  7 16:17 /dev/tty24
          crw--w---- 1 root tty       4, 25 May  7 16:17 /dev/tty25
          crw--w---- 1 root tty       4, 26 May  7 16:17 /dev/tty26
          crw--w---- 1 root tty       4, 27 May  7 16:17 /dev/tty27
          crw--w---- 1 root tty       4, 28 May  7 16:17 /dev/tty28
          crw--w---- 1 root tty       4, 29 May  7 16:17 /dev/tty29
          crw--w---- 1 root tty       4,  3 May  7 16:17 /dev/tty3
          crw--w---- 1 root tty       4, 30 May  7 16:17 /dev/tty30
          crw--w---- 1 root tty       4, 31 May  7 16:17 /dev/tty31
          crw--w---- 1 root tty       4, 32 May  7 16:17 /dev/tty32
          crw--w---- 1 root tty       4, 33 May  7 16:17 /dev/tty33
          crw--w---- 1 root tty       4, 34 May  7 16:17 /dev/tty34
          crw--w---- 1 root tty       4, 35 May  7 16:17 /dev/tty35
          crw--w---- 1 root tty       4, 36 May  7 16:17 /dev/tty36
          crw--w---- 1 root tty       4, 37 May  7 16:17 /dev/tty37
          crw--w---- 1 root tty       4, 38 May  7 16:17 /dev/tty38
          crw--w---- 1 root tty       4, 39 May  7 16:17 /dev/tty39
          crw--w---- 1 root tty       4,  4 May  7 16:17 /dev/tty4
          crw--w---- 1 root tty       4, 40 May  7 16:17 /dev/tty40
          crw--w---- 1 root tty       4, 41 May  7 16:17 /dev/tty41
          crw--w---- 1 root tty       4, 42 May  7 16:17 /dev/tty42
          crw--w---- 1 root tty       4, 43 May  7 16:17 /dev/tty43
          crw--w---- 1 root tty       4, 44 May  7 16:17 /dev/tty44
          crw--w---- 1 root tty       4, 45 May  7 16:17 /dev/tty45
          crw--w---- 1 root tty       4, 46 May  7 16:17 /dev/tty46
          crw--w---- 1 root tty       4, 47 May  7 16:17 /dev/tty47
          crw--w---- 1 root tty       4, 48 May  7 16:17 /dev/tty48
          crw--w---- 1 root tty       4, 49 May  7 16:17 /dev/tty49
          crw--w---- 1 root tty       4,  5 May  7 16:17 /dev/tty5
          crw--w---- 1 root tty       4, 50 May  7 16:17 /dev/tty50
          crw--w---- 1 root tty       4, 51 May  7 16:17 /dev/tty51
          crw--w---- 1 root tty       4, 52 May  7 16:17 /dev/tty52
          crw--w---- 1 root tty       4, 53 May  7 16:17 /dev/tty53
          crw--w---- 1 root tty       4, 54 May  7 16:17 /dev/tty54
          crw--w---- 1 root tty       4, 55 May  7 16:17 /dev/tty55
          crw--w---- 1 root tty       4, 56 May  7 16:17 /dev/tty56
          crw--w---- 1 root tty       4, 57 May  7 16:17 /dev/tty57
          crw--w---- 1 root tty       4, 58 May  7 16:17 /dev/tty58
          crw--w---- 1 root tty       4, 59 May  7 16:17 /dev/tty59
          crw--w---- 1 root tty       4,  6 May  7 16:17 /dev/tty6
          crw--w---- 1 root tty       4, 60 May  7 16:17 /dev/tty60
          crw--w---- 1 root tty       4, 61 May  7 16:17 /dev/tty61
          crw--w---- 1 root tty       4, 62 May  7 16:17 /dev/tty62
          crw--w---- 1 root tty       4, 63 May  7 16:17 /dev/tty63
          crw--w---- 1 root tty       4,  7 May  7 16:17 /dev/tty7
          crw--w---- 1 root tty       4,  8 May  7 16:17 /dev/tty8
          crw--w---- 1 root tty       4,  9 May  7 16:17 /dev/tty9
          crw-rw---- 1 root dialout 166,  0 May  7 21:43 /dev/ttyACM0
          crw-rw---- 1 root dialout 166,  1 May  7 16:17 /dev/ttyACM1
          crw------- 1 root root      5,  3 May  7 16:17 /dev/ttyprintk
          crw-rw---- 1 root dialout   4, 64 May  7 16:17 /dev/ttyS0
            Homoran Global Moderator Administrators @legro last edited by Homoran
            @legro und die Antwort meine Frage????
            @homoran sagte in ZigBee Störung:
            hast du jetzt auf /dev/serial/by-id/ umgestellt?
            ...oder immer noch auf /ttyACM...
            Wenn immer noch, dann welchen?
              Wo soll ich das wie machen?
                du sollst seit Stunden die Schnittstelle in der Konfiguration des Zigbee Adapters auf die Schreibweise mit /dev/serial/ by-id/ ändern!
                  Danach frage ich doch gerade. Wie?
                    Thomas Braun Most Active @legro last edited by Thomas Braun
                    Da wo man den COM-Port definiert. Trag da
                    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00
                    ein, falls da was anderes drin steht.
                      legro @Thomas Braun last edited by
                      Ich fürchte, ich habe noch immer nicht verstanden, was ich genau machen soll. So sieht das bei mir aus ..
                        und wie endet dort die Zeile mit /dev/serial.....
                          Seit Jahr und Tag hat das if00 stets funktioniert.
                          • MartinP
                            MartinP @legro last edited by
                            @legro Ist dieses "Network = DDDDDDDDDDDDDDDDDDDDDDDA" auch schon immer so gewesen?
                            Langsam gehen mir die Ideen aus ...
                            Ob das Betriebssystem gemeint hat, den Braille-TTY Prozess zu starten könntest Du noch prüfen.
                            Siehe: https://github.com/arduino/help-center-content/issues/155
                            per1234 created this issue in arduino/help-center-content
                            open Article suggestion: missing port on Linux caused by interference from BRLTTY #155
                              können wir uns jetzt mal dem Problem widmen.. anstatt Sinlos irgendwelche Konfigurationen durchzugehen (sry aber anders kann ich es nicht audrücken)
                              @legro poste bitte die nvbackup.json aus dem Ordner /opt/iobroker/iobroker-data/zigbee_0
                              sollte diese ok sein. wird mit dem Board was nicht ok sein und ich würde es neu flashen..
                              wie @Asgothian schon geschrieben hat .. es stimmt mit dem Netzwerk was nicht ..NICHT mit den Adapter Einstellungen
                                legro @arteck last edited by legro
                                @arteck
                                Erst einmal vielen Dank an alle, die mir - dem schon lange die Ideen ausgegangen sind - helfen.
                                Hier die gewünschten Daten ..
                                  "metadata": {
                                    "format": "zigpy/open-coordinator-backup",
                                    "version": 1,
                                    "source": "zigbee-herdsman@0.41.2",
                                    "internal": {
                                      "date": "2024-05-07T04:10:45.563Z",
                                      "znpVersion": 1
                                  "stack_specific": {
                                    "zstack": {
                                      "tclk_seed": "960898014577f65027ed5828c80758f4"
                                  "coordinator_ieee": "00124b001caa6cf6",
                                  "pan_id": "1a62",
                                  "extended_pan_id": "ddddddddddddddda",
                                  "nwk_update_id": 0,
                                  "security_level": 5,
                                  "channel": 11,
                                  "channel_mask": [
                                    11
                                  "network_key": {
                                    "key": "01030507090b0d0f00020406080a0c0a",
                                    "sequence_number": 0,
                                    "frame_counter": 10115573
                                  "devices": [
                                      "nwk_address": "cc89",
                                      "ieee_address": "00124b0008a50109",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "51f53300984a5777ff5182e55863da07",
                                        "rx_counter": 0,
                                        "tx_counter": 748
                                      "nwk_address": "8d4d",
                                      "ieee_address": "00124b000621ad0e",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "96ac6471f61b35ed5685e90158bf8408",
                                        "rx_counter": 0,
                                        "tx_counter": 754
                                      "nwk_address": "1991",
                                      "ieee_address": "00124b00074e8fdf",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "d8d7ba9108d31345a8791e20ed133ac8",
                                        "rx_counter": 0,
                                        "tx_counter": 934
                                      "nwk_address": "0de6",
                                      "ieee_address": "00124b00077b7fe8",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "ad088d5727a64a28207823f396438a01",
                                        "rx_counter": 0,
                                        "tx_counter": 717
                                      "nwk_address": "7d27",
                                      "ieee_address": "00124b0008a68663",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "3b723000984a577795d681e55863da07",
                                        "rx_counter": 0,
                                        "tx_counter": 399
                                      "nwk_address": "b472",
                                      "ieee_address": "00124b0008e7395c",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "74f1e050f4dd1a985d7c90fe506cff58",
                                        "rx_counter": 0,
                                        "tx_counter": 747
                                      "nwk_address": "e437",
                                      "ieee_address": "00124b00090da34c",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "baf32ae45863da0714579b01984a5777",
                                        "rx_counter": 0,
                                        "tx_counter": 751
                                      "nwk_address": "642a",
                                      "ieee_address": "00124b0008e73540",
                                      "is_child": true,
                                      "link_key": {
                                        "key": "18c17100984a5777b665c0e55863da07",
                                        "rx_counter": 0,
                                        "tx_counter": 752
                                      "nwk_address": "84b8",
                                      "ieee_address": "8418260000074b81",
                                      "is_child": false,
                                      "link_key": {
                                        "key": "f6bd5727ed7e304c8613f39608be19c1",
                                        "rx_counter": 0,
                                        "tx_counter": 748
                                      "nwk_address": "e20c",
                                      "ieee_address": "841826000007fd2c",
                                      "is_child": false,
                                      "link_key": {
                                        "key": "b4fc4277f6763f6974d5cf0758d28e8c",
                                        "rx_counter": 0,
                                        "tx_counter": 748
                                      "nwk_address": "d001",
                                      "ieee_address": "841826000007feec",
                                      "is_child": false,
                                      "link_key": {
                                        "key": "a989f15027cb40ac24f95ff4962e8085",
                                        "rx_counter": 0,
                                        "tx_counter": 748
                                      "nwk_address": "ab83",
                                      "ieee_address": "8418260000ca4b3f",
                                      "is_child": false,
                                      "link_key": {
                                        "key": "38133e9608be19c148bd9a27ed7e304c",
                                        "rx_counter": 0,
                                        "tx_counter": 748
                                      "nwk_address": "ff8b",
                                      "ieee_address": "001788010278c53e",
                                      "is_child": false,
                                      "link_key": {
                                        "key": "f6c220f697808f017bb28e5226654f28",
                                        "rx_counter": 0,
                                        "tx_counter": 220
                                      "nwk_address": "008f",
                                      "ieee_address": "001788010db82a55",
                                      "is_child": false,
                                      "link_key": {
                                        "key": "72c7e025c98f4ff4c322200c44ffe150",
                                        "rx_counter": 0,
                                        "tx_counter": 165
                                An der Konfiguration habe ich seit deren Einrichtung nie mehr etwas geändert. Die Anlage lief seit 2020 problemlos. Erst nach den Stromausfällen - es haute uns drei Tage in Folge immer wieder mal den FI raus - traten diese Fehler auf.
                                Da der Raspberry Pi hinter einer USV liegt, sollte keine Überspannung etwas beschädigt haben können.
                                  arteck Developer Most Active @legro last edited by arteck
                                  @legro ok die einstellungen passen.. hätte mich auch gewundert wenn nicht .. da sonst der adapter beim start gemeckert hätte
                                  läuft der adapter jetzt nach den ?? ist der grün ?
                                  kannst du die
                                  9290024406A - Philips Hue P45 light bulb (Router)
                                  neu anlernen
                                    @arteck sagte in ZigBee Störung:
                                    kannst du die
                                    neu anlernen
                                    Eigentlich komme ich mit eurem Adapter richtig gut klar. Du und Asgothian habt mir vor vier Jahren geholfen, meine BITRON-Geräte im eurem ZigBee-Adapter ans Laufen zu bekommen. Da konnte ich viel von euch lernen.👍 Aber das ist eben schon vier Jahre her, vieles habe ich wieder vergessen.
                                    Nun aber zum Anlernen der HUE P45 Lampe ..
                                    Hierzu muss ich doch die Lampe erst einmal zurücksetzen. Dies habe ich bisher stets mittels der HUE-App gemacht, indem ich die Lampen als verwaiste Geräte über ihre Seriennummer ansprach, wobei sie ja zurückgesetzt werden. Anschließend habe ich sie aus der HUE-App wieder gelöscht, wodurch sie ja ebenfalls zurückgesetzt werden.
                                    Gibt es einen einfacheren Weg?
                                      neu anlernen
                                      Da ich den Umweg über die HUE-App scheute, habe ich folgendes probiert ..
                                      • Ich habe versucht, die P45 über den ZigBee-Adapter zu löschen
                                      • Dies schlug aufgrund der Störungen natürlich fehl, aber an der Kachel der P45 im ZigBee-Adapter erschien das Symbol zum Pairen für diese Lampe.
                                      • Ich klickte auf dieses Pairing-Symbol, dabei erhielt ich die nachfolgende dargestellte Ausgabe ..
                                      Error: Failed to open the network: Error: Data request failed with error: 'MAC channel access failure' (225)
                                          at GreenPower.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/greenPower.ts:229:13)
                                          at Controller.permitJoinInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:251:13)
                                          at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:238:9)
                                          at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:525:17). undefined
                                      Pairing started 0x001788010db82a55
                                        @legro der Button ist nicht dafür da...
                                        hast du einen Dimmer ?? von Hue..damit gehts auch
                                        ansonsten muss der coordinator an die Lampe dran .. dann gehts auch mit dem Touchlink
                                        da wo der quadrat ist..
                                          Ich hab's geahnt.😖
                                          Einen Dimmer habe ich nicht. Schließlich will ich die HUE-Bridge künftig komplett ersetzen. Ich habe sie daher nur noch in Betrieb, um nach und nach alles auf den den ZigBee-Coordinator CC26X2R1 umzustellen.
                                          Das Einfachste wird daher sein, ich versuche die Lampe in die Nähe (wenige cm ??) des Coordinators zu bringen und per Touchlink Reset und Neuanlernen zu initiieren.
                                            @arteck
                                            Ich habe die Lampe wie hier (über die HUE-App) beschrieben zurückgesetzt. Anschließend versuchte ich sie über den CC26X2R1 zu koppeln. Leider funktionierte die Kopplung nicht. Die Lampe wurde nicht erkannt.
                                            Und hier die Daten im Log ..
                                            zigbee.0
                                            2024-05-08 12:04:28.185	info	Zigbee: stop joining
                                            zigbee.0
                                            2024-05-08 12:03:26.934	info	Zigbee: allowing new devices to join.
                                            zigbee.0
                                            2024-05-08 12:02:28.450	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100QXL","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L1100QXL-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyS0"}]
                                            1998
