    4. Bayrol Webportal
    Bayrol Webportal
    • Q
      qwertz @sued72 last edited by
      @sued72 Cool ! Kannst du einmal das komplette funktionierende Skript reinstellen bitte ?
        sued72 @qwertz last edited by sued72
        @qwertz habe noch das Salzgehalt mit reingenommen. Habe die Automatic Salt. Das müsstest du halt anpassen.
        Achtung: Code kopieren und 127 sowie 113..116 nacharbeiten!!! Siehe weiter unten das beschriebene Problem im Verlauf des Chats
        // jshint esversion: 8
        const fetch = require('node-fetch');
        //config start
        let user="username";
        let password="password";
        let dpPH = "0_userdata.0.BayrolSaltRlxPro.pH";
        let dpMV = "0_userdata.0.BayrolSaltRlxPro.Redox";
        let dpCC = "0_userdata.0.BayrolSaltRlxPro.Temperature";
        let dpSL =  "0_userdata.0.BayrolSaltRlxPro.Salinity";
        let requesttime=10*1000; //erneuterdatenabruf in Millisekunden
        const useragent = "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36 Edg/123.0.0.0";
        //config end
        async function main() {
            let sessionid = await getSession();
            let cid= await login(user,password,sessionid);
            if (cid) await getData(sessionid,cid);
        async function  getSession() {
            const response = await fetch("https://www.bayrol-poolaccess.de/webview/index.php", {
                "headers": {
                  "accept": "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7",
                  "accept-language": "de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7",
                  "cache-control": "no-cache",
                  "pragma": "no-cache",
                  "sec-ch-ua": "\"Not_A Brand\";v=\"8\", \"Chromium\";v=\"120\", \"Google Chrome\";v=\"120\"",
                  "sec-ch-ua-mobile": "?0",
                  "sec-ch-ua-platform": "\"Windows\"",
                  "sec-fetch-dest": "document",
                  "sec-fetch-mode": "navigate",
                  "sec-fetch-site": "none",
                  "sec-fetch-user": "?1",
                  "upgrade-insecure-requests": "1",
                  "User-Agent":useragent
                "ReferrerPolicy": "strict-origin-when-cross-origin",
                "body": null,
                "method": "GET"
              let headers = await response.headers;
            //log (headers);
              return getSessionId(headers.get("set-cookie"));
        async function login(user,password,sessionid) {
          let body=`username=${encodeURIComponent(user)}&password=${encodeURIComponent(password)}&login=Anmelden`;
          const response = await fetch("https://www.bayrol-poolaccess.de/webview/p/login.php?r=reg", {
            "headers": {
              "content-type": "application/x-www-form-urlencoded",
              "sec-fetch-site": "same-origin",
              "cookie": `PHPSESSID=${sessionid}`,
              "Referer": "https://www.bayrol-poolaccess.de/webview/p/login.php",
              "Referrer-Policy": "strict-origin-when-cross-origin",
            "body": body,
            "method": "POST"
          let text=await response.text();
          //log(text);
          return getCID(text);
        async function getData(sessionid,cid) {
          const response = await fetch(`https://www.bayrol-poolaccess.de/webview/getdata.php?cid=${cid}`, {
               "headers": {
              "accept": "*/*",
              "sec-fetch-dest": "empty",
              "sec-fetch-mode": "cors",
              "x-requested-with": "XMLHttpRequest",
              "Referer": "https://www.bayrol-poolaccess.de/webview/p/plants.php",
            "body": null,
            "method": "GET"
          log(text)
          writeData(extractValues(text));
          setTimeout(getData.bind(this),requesttime,sessionid,cid);
        function writeData(obj) {
        try {
            setState(dpCC,parseFloat(obj.CC));
            setState(dpMV,parseFloat(obj.MV));
            setState(dpPH,parseFloat(obj.PH));
            setState(dpSL,parseFloat(obj.SL));
        } catch (error) {
            log(error);
        function extractValues(text){
          const regexPH = /[pH]\<\/span><h1>([\d\.]+)<\/h1>/gm;
          const regexMV = /[mV]\<\/span><h1>([\d\.]+)<\/h1>/gm;
          const regexCC = /[°C]\<\/span><h1>([\d\.]+)<\/h1>/gm;
          const regexSL = /[g\\l]<\/span><h1>([\d\.]+)<\/h1>/gm;
          return {
            PH:regexPH.exec(text)[1],
            MV:regexMV.exec(text)[1],
            CC:regexCC.exec(text)[1],
            SL:regexSL.exec(text)[1],
        async function getCID(text){
            const regex = /var clients = [(\d+)];/gm;
                let result = regex.exec(text);
            //log(text);
            //log(result);
            if (result.length==2) return result[1];
            return undefined;
        function getSessionId(setcookie){
            let cookieHeader = setcookie;
            if (cookieHeader.length>0) {
                let cookieArray = cookieHeader.split(";")
                const cookieObject = {};
                cookieArray.forEach(cookie => {
                  const [name, value] = cookie.split('=');
                  cookieObject[(name||"empty").trim()] = (value||"").trim();
                return cookieObject["PHPSESSID"]||"";
        main();
        Q 1 Reply Last reply Reply Quote 1
        • Q
          qwertz @sued72 last edited by qwertz
          @sued72 Danke.
          Leider weiter der gleiche Fehler
          00:22:10.707	silly	javascript.0 (1749383) Objects user redis pmessage */cfg.o.script.js.Bayrol:{"common":{"name":"Bayrol","expert":true,"engineType":"Javascript/js","engine":"system.adapter.javascript.0","source":"// jshint esversion: 8\nconst fetch = require('node-fetch'); \n \n//config start\nlet user=\"xxx\";\nlet password=\"xxx\";\nlet dpPH = \"0_userdata.0.BayrolSaltRlxPro.pH\";\nlet dpMV = \"0_userdata.0.BayrolSaltRlxPro.Redox\";\nlet dpCC = \"0_userdata.0.BayrolSaltRlxPro.Temperature\";\nlet requesttime=10*1000; //erneuterdatenabruf in Millisekunden\n \nconst useragent = \"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36 Edg/123.0.0.0\";\n//config end\n \nasync function main() {\n let sessionid = await getSession ();\n let cid= await login(user,password,sessionid); \n if (cid) await getData(sessionid,cid);\n}\nasync function getSession() {\n const response = await fetch(\"https://www.bayrol-poolaccess.de/webview/index.php\", {\n \"headers\": {\n \"accept\": \"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7\",\n \"accept-language\": \"de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7\",\n \"cache-control\": \"no-cache\",\n \"pragma\": \"no-cache\",\n \"sec-ch-ua\": \"\\\"Not_A Brand\\\";v=\\\"8\\\", \\\"Chromium\\\";v=\\\"120\\\", \\\"Google Chrome\\\";v=\\\"120\\\"\",\n \"sec-ch-ua-mobile\": \"?0\",\n \"sec-ch-ua-platform\": \"\\\"Windows\\\"\",\n \"sec-fetch-dest\": \"document\",\n \"sec-fetch-mode\": \"navigate\",\n \"sec-fetch-site\": \"none\",\n \"sec-fetch-user\": \"?1\",\n \"upgrade-insecure-requests\": \"1\",\n \"User-Agent\":useragent\n },\n \"ReferrerPolicy\": \"strict-origin-when-cross-origin\",\n \"body\": null,\n \"method\": \"GET\"\n });\n let headers = await response.headers;\n //log (headers);\n return getSessionId(headers.get(\"set-cookie\"));\n}\nasync function login(user,password,sessionid) {\n let body=`username=${encodeURIComponent(user)}&password=${encodeURIComponent(password)}&login=Anmelden`;\n const response = await fetch(\"https://www.bayrol-poolaccess.de/webview/p/login.php?r=reg\", {\n \"headers\": {\n \"accept\": \"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7\",\n \"accept-language\": \"de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7\",\n \"cache-control\": \"no-cache\",\n \"content-type\": \"application/x-www-form-urlencoded\",\n \"pragma\": \"no-cache\",\n \"sec-ch-ua\": \"\\\"Not_A Brand\\\";v=\\\"8\\\", \\\"Chromium\\\";v=\\\"120\\\", \\\"Google Chrome\\\";v=\\\"120\\\"\",\n \"sec-ch-ua-mobile\": \"?0\",\n \"sec-ch-ua-platform\": \"\\\"Windows\\\"\",\n \"sec-fetch-dest\": \"document\",\n \"sec-fetch-mode\": \"navigate\",\n \"sec-fetch-site\": \"same-origin\",\n \"sec-fetch-user\": \"?1\",\n \"upgrade-insecure-requests\": \"1\",\n \"cookie\": `PHPSESSID=${sessionid}`,\n \"Referer\": \"https://www.bayrol-poolaccess.de/webview/p/login.php\",\n \"Referrer-Policy\": \"strict-origin-when-cross-origin\",\n \"User-Agent\":useragent\n },\n \"body\": body,\n \"method\": \"POST\"\n }); \n let text=await response.text();\n //log(text);\n return getCID(text);\n}\nasync function getData(sessionid,cid) {\n const response = await fetch(`https://www.bayrol-poolaccess.de/webview/getdata.php?cid=${cid}`, {\n \"headers\": {\n \"accept\": \"*/*\",\n \"accept-language\": \"de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7\",\n \"cache-control\": \"no-cache\",\n \"pragma\": \"no-cache\",\n \"sec-ch-ua\": \"\\\"Not_A Brand\\\";v=\\\"8\\\", \\\"Chromium\\\";v=\\\"120\\\", \\\"Google Chrome\\\";v=\\\"120\\\"\",\n \"sec-ch-ua-mobile\": \"?0\",\n \"sec-ch-ua-platform\": \"\\\"Windows\\\"\",\n \"sec-fetch-dest\": \"empty\",\n \"sec-fetch-mode\": \"cors\",\n \"sec-fetch-site\": \"same-origin\",\n \"x-requested-with\": \"XMLHttpRequest\",\n \"cookie\": `PHPSESSID=${sessionid}`,\n \"Referer\": \"https://www.bayrol-poolaccess.de/webview/p/plants.php\",\n \"Referrer-Policy\": \"strict-origin-when-cross-origin\",\n \"User-Agent\":useragent\n },\n \"body\": null,\n \"method\": \"GET\"\n });\n let text=await response.text();\n log(text)\n writeData(extractValues(text));\n setTimeout(getData.bind(this),requesttime,sessionid,cid);\n}\nfunction writeData(obj) {\ntry {\n setState(dpCC,parseFloat(obj.CC));\n setState(dpMV,parseFloat(obj.MV));\n setState(dpPH,parseFloat(obj.PH));\n} catch (error) {\n log(error);\n} \n}\nfunction extractValues(text){\n const regexPH = /[pH]\\<\\/span><h1>([\\d\\.]+)<\\/h1>/gm;\n const regexMV = /[mV]\\<\\/span><h1>([\\d\\.]+)<\\/h1>/gm;\n const regexCC = /[°C]\\<\\/span><h1>([\\d\\.]+)<\\/h1>/gm;\n \n return {\n PH:regexPH.exec(text)[1],\n MV:regexMV.exec(text)[1],\n CC:regexCC.exec(text)[1],\n\n };\n \n}\nasync function getCID(text){\n const regex = /var clients = [(\\d+)];/gm;\n let result = regex.exec(text);\n //log(text);\n //log(result);\n if (result.length==2) return result[1];\n return undefined;\n}\nfunction getSessionId(setcookie){\n let cookieHeader = setcookie;\n if (cookieHeader.length>0) {\n let cookieArray = cookieHeader.split(\";\")\n const cookieObject = {};\n cookieArray.forEach(cookie => {\n const [name, value] = cookie.split('=');\n cookieObject[(name||\"empty\").trim()] = (value||\"\").trim();\n });\n return cookieObject[\"PHPSESSID\"]||\"\";\n }\n}\nmain();\n","debug":true,"verbose":true,"enabled":true},"type":"script","from":"system.adapter.admin.0","user":"system.user.admin","ts":1712352130706,"_id":"script.js.Bayrol","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          00:22:10.712	info	javascript.0 (1749383) Stop script script.js.Bayrol
          00:22:10.772	info	javascript.0 (1749383) Start javascript script.js.Bayrol
          00:22:10.782	info	javascript.0 (1749383) script.js.Bayrol: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          00:22:11.315	error	javascript.0 (1749383) script.js.Bayrol: TypeError: Cannot read properties of null (reading 'length')
          00:22:11.315	error	javascript.0 (1749383) at getCID (script.js.Bayrol:128:16)
          00:22:11.316	error	javascript.0 (1749383) at login (script.js.Bayrol:72:10)
          00:22:11.316	error	javascript.0 (1749383) at main (script.js.Bayrol:17:14)
          //config start
          let user="xxx";
          let password="xxx";
          //config end
                  "headers": {
                  "body": null,
                  "method": "GET"
              //log (headers);
              "headers": {
              "body": body,
              "method": "POST"
            //log(text);
                 "headers": {
                "accept": "*/*",
              "body": null,
              "method": "GET"
            log(text)
          try {
          } catch (error) {
              log(error);
            return {
              //log(text);
              //log(result);
              return undefined;
          main();
            Oh, das ist ja fies!!!
            Sieht so aus, als ob der Interpreter hier im Forum beim reinkopieren den syntax verändert!
            Die Zeile 127 von meinem Code oben sieht bei mir im JS Editor des ioBroker folgendermassen aus:
            Der Code, nachdem er hier im Forum reinkopiert wurde sieht dann so aus.
            Wenn du ihn dann wieder bei dir übernimmst, et voila, läuft es nicht.
            Also dein Zeile 124 mit
            ersetzen.
            Und die Zeilen 112..114 mit
            ersetzen.
            Wichtig sind die \ vor [ und ] sowie vor 3b4b9379-467f-4801-91ca-606c74d52aef-image.png
            also 34563d1b-424a-4413-808d-4e517b859368-image.png[ oderfd8d1a63-f824-413d-97f6-91eb905d8c3b-image.png] oder 1aa7c84c-e9c2-4a9b-8e65-6010f1853210-image.png\ im Skript schreiben... letzteres ist nur beim Salzgehalt relevant, da gibt es g\l im Text.
            War gerade ne ziemliche Fummelei den Backslash und die Codezeilen musst ich per png reinkopieren, sonst werden sie rausgelöscht beim Submit. Backslash sind hier nicht willkommen...
            Hoffe, ich konnte helfen.
            Q S OliverIO 3 Replies Last reply Reply Quote 0
            • Q
              @sued72 Tausen Dank ! Endlich läuft es
              Das ist ja echt saugemein. Wenn Copy/Paste nicht richtig funktioniert, sind ScriptKiddys wie ich aufgeschmissen.
              Zur Doku anbei euer Script ohne Salz als TXT, in der Hoffnung, dass in der TXT dabei alles erhalten bleibt.
              [2024 iobroker bayrol ohne Salz.txt]
              Nachtrag 25.6.2024 Script findet sich hier:
              https://github.com/oweitman/diverse-iobroker-scripts/tree/main/bayrol
                syber @sued72 last edited by
                @sued72
                Moin,
                auch von mir vielen Dank 👍 👍 👍
                • OliverIO
                  OliverIO @sued72 last edited by OliverIO
                  @sued72
                  Nach dem das hier mit dem ergänzen des backslash’s geschrieben wurde hab ich mir sowas gedacht, konnte es aber bisher noch nicht prüfen.
                  Dann war es genau das was den Unterschied immer gemacht hat.
                  Also merke, keine regexstrings direkt als Ausdruck definieren, sondern erst in einem String und damit dann das regex daraus erzeugen.
                  Nachtrag
                  ja so ist es dann auch gewesen
                  • OliverIO
                    OliverIO @OliverIO last edited by OliverIO
                    forums test für Problem mit Backslash:
                    1. ohne Codeblock
                      Programmzeile
                      EinfachBackslash
                      Doppelbackslash
                      Dreifach
                    2. mit Codeblock
                      problem mach hier die erste Codezeile. vgl mit Screenshot
                    EinfachBackslash
                    Doppelbackslash
                    Dreifach
                    Screenshot des Edit-Bereichs
                    Fehlermeldung hier
                    https://forum.iobroker.net/topic/73975/problem-mit-backslash-im-codeblock
                      mameier1234 @OliverIO last edited by mameier1234
                      Genial !!, ich habe heute meine neue Bayrol Cl+pH installiert und sofort eine funktionierende Lösung . Super Klasse
                      Jetzt kommen bei mir beim Abrufen aber immer noch Warnings im Log.. Die Werte kommen aber einwandfrei... ?
                      14:52:35.554	warn	javascript.1 (4100763) at writeData (script.js.Pool.Bayrol:103:5)
                      14:52:35.554	warn	javascript.1 (4100763) at getData (script.js.Pool.Bayrol:98:3)
                      14:52:35.554	warn	javascript.1 (4100763) at main (script.js.Pool.Bayrol:18:14)
                      14:52:35.555	warn	javascript.1 (4100763) at writeData (script.js.Pool.Bayrol:104:5)
                      14:52:35.555	warn	javascript.1 (4100763) at getData (script.js.Pool.Bayrol:98:3)
                      14:52:35.555	warn	javascript.1 (4100763) at main (script.js.Pool.Bayrol:18:14)
                      14:52:35.556	warn	javascript.1 (4100763) at writeData (script.js.Pool.Bayrol:105:5)
                      14:52:35.556	warn	javascript.1 (4100763) at getData (script.js.Pool.Bayrol:98:3)
                      14:52:35.556	warn	javascript.1 (4100763) at main (script.js.Pool.Bayrol:18:14)
                      Was könnte das wohl noch sein ?
                      Edit: Ok, gefunden .. man sollte sich zuerst die weiteren Logs ansehen 🙂
                      You are assigning a number to the state "0_userdata.0.BayrolSaltRlxPro.pH" which expects a string.
                      Ich hatte die States als String angelegt..
                      • OliverIO
                        OliverIO @mameier1234 last edited by
                        @mameier1234
                        danke für den hinweis.
                        ich habe mal den folgenden post entsprechend aktualisiert und auf das richtige skript verwiesen
                        https://forum.iobroker.net/topic/66973/bayrol-webportal/17?_=1715102271325
                          @oliverio In dem Post steht aber immernoch: Die DP müssen vom Typ String sein, (was ja falsch ist..) Die müssen "Number" sein!
                          • OliverIO
                            @mameier1234
                            ha, zu schnell gelesen. korrigiert
                              @oliverio Ich habe noch ein bisschen umgebaut...
                              das hier auskommentieren
                              //setTimeout(getData.bind(this),requesttime,sessionid,cid);
                              dafür am Schluss dann die Werte nur innerhalb 9-18 Uhr in die Datenpunkte schreiben.
                              function checkAndExecuteFunction() {
                                  const now = new Date();
                                  const startHour = 9;
                                  const endHour = 18;
                                  // Erstelle eine Kopie des aktuellen Datums und setze die Stunde auf die Start- und Endzeit
                                  const startTime = new Date(now.getFullYear(), now.getMonth(), now.getDate(), startHour, 0, 0);
                                  const endTime = new Date(now.getFullYear(), now.getMonth(), now.getDate(), endHour, 0, 0);
                                  // Prüfe, ob die aktuelle Zeit innerhalb des Zeitfensters liegt
                                  if (now >= startTime && now < endTime) {
                                      //console.log("Abfrage wird ausgeführt");
                                      main();
                                  } else {
                                      //console.log("Es ist nicht die Zeit für die Funktion, sie wird nicht ausgeführt.");
                              // Interval aufsetzen, um die Funktion alle 60 Sekunden zu prüfen
                              setInterval(checkAndExecuteFunction, 60000);
                              Damit bekomme ich die unschärfen ausserhalb meiner Filterzeiten weg. Sonst steht ja das Wasser in der Messzelle und kühlt auf die Umgebung ab... und die riesen Redox-Sprünge im stehenden Wasser habe ich so auch nicht in meinen Graphen..
                              Vieleicht hilft es ja jemandem.
                              • Q
                                Hat jemand von euch mit dem Skript auch das Problem, dass manchmal keine neuen Werte kommen ?
                                Das Skript läuft ohne Fehlermeldung aber es kommen dann irgendwann keine neuen Werte mehr.
                                Erst ein Neustart des Skriptes hilft. Eine Fehlermeldung im Log erscheint nicht.
                                  mameier1234 @qwertz last edited by
                                  @qwertz Ja.. hatte ich auch schon... Seit meiner Änderung allerdings nun schon seit einer Woche kein Problem mehr.
                                  • Q
                                    OK. Möglicherweise gibt es ein TimeOut vom Server, wenn man 24h am Stück immer wieder die Daten pullt ? Ich werde das Skript mal stoppen solange die Filterpumpe nicht läuft.
                                      @qwertz deswegen habe ich ja die Änderungen im Script.. einstellbar, wann es nicht pollen soll.. und vor allem nicht falsche Werte in die DB schreibt...
                                      • NWH
                                        NWH last edited by
                                        @OliverIO
                                        Ich versuche gerade das Script zum laufen zu bringen, allerdings habe ich die gleichen Fehler wie oben beschrieben.
                                        Meiner Meinung nach habe ich alles so wie oben von dir beschrieben gemacht.
                                        Was könnte das Problem sein?
                                        javascript.0	22:32:11.471	error	script.js.common.Pool.Byrol: TypeError: Cannot read properties of null (reading 'length')
                                        javascript.0	22:32:11.471	error	at getCID (script.js.common.Pool.Byrol:129:16)
                                        javascript.0	22:32:11.471	error	at login (script.js.common.Pool.Byrol:74:10)
                                        javascript.0	22:32:11.471	error	at main (script.js.common.Pool.Byrol:19:14)
                                        • OliverIO
                                          OliverIO @NWH last edited by
                                          @nwh
                                          hast du das skript, das als textdatei dem folgenden post anhängt, verwendet?
                                          https://forum.iobroker.net/post/1147632
                                          im skript ist ein regex enthalten, das das forum nicht richtig anzeigen mag.
                                          keine ahnung ob man das hier auch mal fixen mag.
                                          • NWH
                                            NWH last edited by
                                            @oliverio ja das habe ich genommen.
                                            1.0k
                                            100
                                            14544
